See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/1419/>
[...truncated 882 lines...]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/wms/target/gs-wms-2.12-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wms/2.12-SNAPSHOT/gs-wms-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building KML support for GeoServer 2.12-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-kml ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/kml/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-kml ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-kml ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-kml ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-kml ---
[INFO] Compiling 58 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/kml/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-kml ---
[INFO] Copying 27 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-kml ---
[INFO] Compiling 11 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/kml/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-kml ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-kml ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/kml/target/gs-kml-2.12-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-kml ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/kml/target/gs-kml-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-kml ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/kml/target/gs-kml-2.12-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-kml ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/kml/target/gs-kml-2.12-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-kml ---
[INFO] Copying gt-api-18-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/kml/target/dependency/gt-api-18-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.12-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/kml/target/dependency/gwc-core-1.12-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-kml ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/kml/target/gs-kml-2.12-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-kml/2.12-SNAPSHOT/gs-kml-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/kml/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-kml/2.12-SNAPSHOT/gs-kml-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/kml/target/gs-kml-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-kml/2.12-SNAPSHOT/gs-kml-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/kml/target/gs-kml-2.12-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-kml/2.12-SNAPSHOT/gs-kml-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/kml/target/gs-kml-2.12-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-kml/2.12-SNAPSHOT/gs-kml-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoWebCache (GWC) Module 2.12-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-gwc ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/gwc/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-gwc ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-gwc ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-gwc ---
[INFO] Copying 0 resource
[INFO] Copying 15 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-gwc ---
[INFO] Compiling 47 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/gwc/target/classes>
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java>:\[27,7\] error: DummyQuotaStore is not abstract and does not override abstract method deleteParameters(String,String) in QuotaStore
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java>:\[25,7\] error: ConfigurableQuotaStore is not abstract and does not override abstract method deleteParameters(String,String) in QuotaStore
[INFO] 2 errors
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.605 s]
[INFO] Core Platform Module ............................... SUCCESS [ 6.419 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 6.009 s]
[INFO] Main Module ........................................ SUCCESS [ 24.275 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.093 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 5.482 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 4.616 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.717 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 5.863 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 6.610 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 7.711 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 12.605 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 14.623 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 6.931 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [ 4.671 s]
[INFO] gs-rest ............................................ SKIPPED
[INFO] gs-restconfig ...................................... SKIPPED
[INFO] GeoServer Web Modules .............................. SKIPPED
[INFO] Core UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Community Space .................................... SKIPPED
[INFO] Authentication by unique url key ................... SKIPPED
[INFO] WorldWind Format Module ............................ SKIPPED
[INFO] SpatiaLite Extension ............................... SKIPPED
[INFO] GeoServer JDBC KV Catalog .......................... SKIPPED
[INFO] Aggregating Data Store ............................. SKIPPED
[INFO] WMS-EO ............................................. SKIPPED
[INFO] ColorMap ........................................... SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] GeoServer mbtiles Extension ........................ SKIPPED
[INFO] GeoServer GeoPackage Extension ..................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults ............... SKIPPED
[INFO] GPX PPIO for WPS ................................... SKIPPED
[INFO] KML PPIO for WPS ................................... SKIPPED
[INFO] DownloadProcess .................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............. SKIPPED
[INFO] ActiveMQ ........................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ............ SKIPPED
[INFO] GeoServer JMS clustering module .................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module .............. SKIPPED
[INFO] Solr Module ........................................ SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] Parameters Extractor ............................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Web Processing Service - Remote processes invocation SKIPPED
[INFO] WPS cluster on jdbc datastores ..................... SKIPPED
[INFO] ncWMS compatibility extension ...................... SKIPPED
[INFO] GWC Distributed Caching Plugin ..................... SKIPPED
[INFO] GeoWebCache S3 ..................................... SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] GDAL translate parent .............................. SKIPPED
[INFO] GDAL translate WCS ................................. SKIPPED
[INFO] GDAL translate WPS ................................. SKIPPED
[INFO] GeoServer JDBC Configuration Resource Store ........ SKIPPED
[INFO] GeoWebCache SQLite ................................. SKIPPED
[INFO] WMTS Multi Dimensional ............................. SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module ........... SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SKIPPED
[INFO] GeoServer OneLogin Module .......................... SKIPPED
[INFO] gs-notification-common ............................. SKIPPED
[INFO] GeoServer notification event system extension for GeoNode SKIPPED
[INFO] OWS Dispatcher Simulate Plugin ..................... SKIPPED
[INFO] JDBC Metrics Plugin ................................ SKIPPED
[INFO] OpenSearch EO parent ............................... SKIPPED
[INFO] OpenSearch for EO .................................. SKIPPED
[INFO] OpenSearch for EO web UI ........................... SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SKIPPED
[INFO] GeoServer notification event system ................ SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 01:59 min
[INFO] Finished at: 2017-05-11T08:03:24+00:00
[INFO] Final Memory: 142M/642M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-gwc: Compilation failure: Compilation failure:
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
