See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/196/changes>
Changes:
[jody.garnett] Port LockProvider from GWC
[jody.garnett] Integration of LockProvider with Resource API
[jody.garnett] UI integration of Lock Provider (includes docs)
[...truncated 8113 lines...]
[INFO] Aggregating Data Store ................................ SUCCESS [3.128s]
[INFO] WMS-EO ................................................ SUCCESS [6.957s]
[INFO] ColorMap .............................................. SUCCESS [5.791s]
[INFO] GeoServer Community Release Module .................... SUCCESS [4.397s]
[INFO] SpatiaLite Extension .................................. SUCCESS [10.382s]
[INFO] BeanShell Scripting Extension ......................... SUCCESS [11.131s]
[INFO] Ruby Scripting Extension .............................. SUCCESS [4.517s]
[INFO] Application Schema Support ............................ SUCCESS [0.343s]
[INFO] Application Schema Integration Test ................... SUCCESS [9.509s]
[INFO] Sample DataAccess Integration Test .................... SUCCESS [2.861s]
[INFO] ArcSDE DataStore Extension ............................ SUCCESS [5.406s]
[INFO] GeoSearch Index Module ................................ SUCCESS [5.611s]
[INFO] SQL Server DataStore Extension ........................ SUCCESS [0.621s]
[INFO] Oracle DataStore Extension ............................ SUCCESS [0.420s]
[INFO] MySQL DataStore Extension ............................. SUCCESS [0.515s]
[INFO] DB2 DataStore Extension ............................... SUCCESS [0.651s]
[INFO] ImageMap Output Format ................................ SUCCESS [5.962s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .................. SUCCESS [0.821s]
[INFO] JP2K Coverage Extension ............................... SUCCESS [0.674s]
[INFO] ogr2ogr Output Format ................................. SUCCESS [4.953s]
[INFO] Excel Output Format ................................... SUCCESS [4.415s]
[INFO] Validation Module ..................................... SUCCESS [2.302s]
[INFO] Chart external graphics support ....................... SUCCESS [0.454s]
[INFO] Feature Generalization Extension ...................... SUCCESS [2.354s]
[INFO] Image Mosaic JDBC Extension ........................... SUCCESS [0.662s]
[INFO] OWS request flow controller ........................... SUCCESS [4.126s]
[INFO] Web Processing Service GUI ............................ SUCCESS [7.236s]
[INFO] GeoServer Layer Querying filter functions ............. SUCCESS [4.214s]
[INFO] Teradata DataStore Extension .......................... SUCCESS [2.562s]
[INFO] GeoServer Monitor Extensions .......................... SUCCESS [0.362s]
[INFO] Core Monitor Extension ................................ SUCCESS [9.038s]
[INFO] Monitor Hibernate Extension ........................... SUCCESS [5.823s]
[INFO] GeoServer Security Extension Modules .................. SUCCESS [0.441s]
[INFO] GeoServer CAS Security Module ......................... SUCCESS [6.493s]
[INFO] GeoServer Security Extension Web Modules .............. SUCCESS [0.447s]
[INFO] GeoServer CAS Security Web Module ..................... SUCCESS [2.988s]
[INFO] XLST based WFS output format .......................... SUCCESS [5.921s]
[INFO] GeoServer INSPIRE Extensions .......................... SUCCESS [5.683s]
[INFO] GeoServer CSS Styling ................................. SUCCESS [5.812s]
[INFO] Catalog Services for the Web parent ................... SUCCESS [0.377s]
[INFO] Catalog Services for the Web interfaces ............... SUCCESS [6.365s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [5.189s]
[INFO] Catalog Services for the Web core module .............. SUCCESS [7.844s]
[INFO] CSW UI Module ......................................... SUCCESS [4.442s]
[INFO] DXF output format ..................................... SUCCESS [0.564s]
[INFO] DXF output format ..................................... SUCCESS [4.452s]
[INFO] DXF WPS PPIO .......................................... SUCCESS [4.393s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ........ SUCCESS [0.302s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions . SUCCESS [6.113s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [4.496s]
[INFO] GeoServer libjpeg-turbo Module ........................ SUCCESS [5.014s]
[INFO] GeoServer Data Importer ............................... SUCCESS [0.456s]
[INFO] Importer Core Module .................................. SUCCESS [7.750s]
[INFO] Importer REST Api Module .............................. SUCCESS [7.134s]
[INFO] Importer Berkley DB Persistence Module ................ SUCCESS [4.888s]
[INFO] Importer Web UI Module ................................ SUCCESS [4.669s]
[INFO] GeoServer Release Module .............................. SUCCESS [6.240s]
[INFO] BUILD SUCCESSFUL
[INFO] Total time: 10 minutes 7 seconds
[INFO] Finished at: Fri Mar 21 08:12:14 UTC 2014
[INFO] Final Memory: 139M/350M
+ /opt/apache-maven-2.2.1/bin/mvn assembly:attached
[INFO] Scanning for projects...
[INFO] Reactor build order:
[INFO] GeoServer
[INFO] Core Platform Module
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] GeoServer Security Modules
[INFO] GeoServer JDBC Security Module
[INFO] GeoServer LDAP Security Module
[INFO] Web Coverage Service Module
[INFO] Web Coverage Service 1.0 Module
[INFO] Web Coverage Service 1.1 Module
[INFO] Web Coverage Service 2.0 Module
[INFO] Web Feature Service Module
[INFO] Web Map Service Module
[INFO] KML support for GeoServer
[INFO] GeoWebCache (GWC) Module
[INFO] REST Support Module
[INFO] REST Configuration Service Module
[INFO] GeoServer Web Modules
[INFO] Core UI Module
[INFO] WMS UI Module
[INFO] GWC UI Module
[INFO] WFS UI Module
[INFO] Demoes Module
[INFO] WCS UI Module
[INFO] Security UI Modules
[INFO] Security UI Core Module
[INFO] Security UI JDBC Module
[INFO] Security UI LDAP Module
[INFO] GeoServer Web Application
[INFO] Community Space
[INFO] GeoServer Extensions
[INFO] Building GeoServer
[INFO] task-segment: [assembly:attached] (aggregator-style)
[INFO] snapshot org.geoserver:gs-platform:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:gs-platform:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:gs-ows:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:gs-ows:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:gs-main:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:gs-main:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:gs-wcs:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:gs-wcs:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:gs-wcs1_1:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:gs-wcs1_1:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:gs-wfs:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:gs-wfs:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:gs-wms:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:gs-wms:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:gs-rest:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:gs-rest:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:gs-wcs1_0:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:gs-wcs1_0:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:gs-web-core:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.web:gs-web-core:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:gs-gwc:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:gs-gwc:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:gs-web-demo:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.web:gs-web-demo:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:gs-web-sec-core:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.security:gs-sec-jdbc:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.web:gs-web-sec-core:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.security:gs-sec-jdbc:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.security:gs-sec-ldap:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.security:gs-sec-ldap:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:gs-web-wms:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:gs-wcs2_0:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.web:gs-web-wms:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:gs-wcs2_0:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:gs-web-gwc:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:gs-kml:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.web:gs-web-gwc:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:gs-kml:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:gs-web-wfs:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:gs-restconfig:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.web:gs-web-wfs:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:gs-restconfig:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:gs-web-wcs:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.web:gs-web-wcs:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:gs-web-sec-jdbc:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.web:gs-web-sec-jdbc:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:gs-web-sec-ldap:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.web:gs-web-sec-ldap:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] [assembly:attached {execution: default-cli}]
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-src.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-war.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-javadoc.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-bin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-db2-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-feature-pregeneralized-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-imagemosaic-jdbc-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-jp2k-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-mysql-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-oracle-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-arcsde-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-pyramid-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-gdal-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-h2-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-sqlserver-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-imagemap-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-ogr-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-excel-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-geosearch-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-charts-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-app-schema-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-control-flow-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-wps-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-querylayer-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-teradata-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-cas-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-monitor-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-monitor-hibernate-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-xslt-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-inspire-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-css-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-csw-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-dxf-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-wcs2_0-eo-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-libjpeg-turbo-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-importer-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.6-SNAPSHOT-importer-bdb-plugin.zip>
[INFO] Total time: 3 minutes 25 seconds
[INFO] Finished at: Fri Mar 21 08:15:41 UTC 2014
[INFO] Final Memory: 40M/238M
+ cp target/release/geoserver-2.6-SNAPSHOT-war.zip /var/www/geoserver/master/geoserver-master-2014-03-21-war.zip
+ cp target/release/geoserver-2.6-SNAPSHOT-bin.zip /var/www/geoserver/master/geoserver-master-2014-03-21-bin.zip
+ cp target/release/geoserver-2.6-SNAPSHOT-war.zip /var/www/geoserver/master/geoserver-master-latest-war.zip
+ cp target/release/geoserver-2.6-SNAPSHOT-bin.zip /var/www/geoserver/master/geoserver-master-latest-bin.zip
+ cd community
[INFO] Building Community Space
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.6-SNAPSHOT-authkey-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.6-SNAPSHOT-ftp-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.6-SNAPSHOT-printing-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.6-SNAPSHOT-python-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.6-SNAPSHOT-groovy-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.6-SNAPSHOT-javascript-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.6-SNAPSHOT-spatialite-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.6-SNAPSHOT-jdbcconfig-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.6-SNAPSHOT-simpleFeatureService-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.6-SNAPSHOT-dds-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.6-SNAPSHOT-aggregate-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.6-SNAPSHOT-wms-eo-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.6-SNAPSHOT-netcdf-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.6-SNAPSHOT-netcdf-out-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.6-SNAPSHOT-colormap-plugin.zip>
[INFO] Total time: 16 seconds
[INFO] Finished at: Fri Mar 21 08:16:00 UTC 2014
[INFO] Final Memory: 13M/152M
+ cd ..
+ [ ! -e /var/www/geoserver/master/ext-2014-03-21 ]
+ mkdir /var/www/geoserver/master/ext-2014-03-21
+ [ ! -e /var/www/geoserver/master/community-2014-03-21 ]
+ mkdir /var/www/geoserver/master/community-2014-03-21
+ cp target/release/geoserver-2.6-SNAPSHOT-app-schema-plugin.zip target/release/geoserver-2.6-SNAPSHOT-arcsde-plugin.zip target/release/geoserver-2.6-SNAPSHOT-cas-plugin.zip target/release/geoserver-2.6-SNAPSHOT-charts-plugin.zip target/release/geoserver-2.6-SNAPSHOT-control-flow-plugin.zip target/release/geoserver-2.6-SNAPSHOT-css-plugin.zip target/release/geoserver-2.6-SNAPSHOT-csw-plugin.zip target/release/geoserver-2.6-SNAPSHOT-db2-plugin.zip target/release/geoserver-2.6-SNAPSHOT-dxf-plugin.zip target/release/geoserver-2.6-SNAPSHOT-excel-plugin.zip target/release/geoserver-2.6-SNAPSHOT-feature-pregeneralized-plugin.zip target/release/geoserver-2.6-SNAPSHOT-gdal-plugin.zip target/release/geoserver-2.6-SNAPSHOT-geosearch-plugin.zip target/release/geoserver-2.6-SNAPSHOT-h2-plugin.zip target/release/geoserver-2.6-SNAPSHOT-imagemap-plugin.zip target/release/geoserver-2.6-SNAPSHOT-imagemosaic-jdbc-plugin.zip target/release/geoserver-2.6-SNAPSHOT-importer-bdb-plugin.zip target/release/geoserver-2.6-SNAPSHOT-importer-plugin.zip target/release/geoserver-2.6-SNAPSHOT-inspire-plugin.zip target/release/geoserver-2.6-SNAPSHOT-jp2k-plugin.zip target/release/geoserver-2.6-SNAPSHOT-libjpeg-turbo-plugin.zip target/release/geoserver-2.6-SNAPSHOT-monitor-hibernate-plugin.zip target/release/geoserver-2.6-SNAPSHOT-monitor-plugin.zip target/release/geoserver-2.6-SNAPSHOT-mysql-plugin.zip target/release/geoserver-2.6-SNAPSHOT-ogr-plugin.zip target/release/geoserver-2.6-SNAPSHOT-oracle-plugin.zip target/release/geoserver-2.6-SNAPSHOT-pyramid-plugin.zip target/release/geoserver-2.6-SNAPSHOT-querylayer-plugin.zip target/release/geoserver-2.6-SNAPSHOT-sqlserver-plugin.zip target/release/geoserver-2.6-SNAPSHOT-teradata-plugin.zip target/release/geoserver-2.6-SNAPSHOT-wcs2_0-eo-plugin.zip target/release/geoserver-2.6-SNAPSHOT-wps-plugin.zip target/release/geoserver-2.6-SNAPSHOT-xslt-plugin.zip /var/www/geoserver/master/ext-2014-03-21
+ rm -rf /var/www/geoserver/master/ext-latest
+ mkdir /var/www/geoserver/master/ext-latest
+ cp target/release/geoserver-2.6-SNAPSHOT-app-schema-plugin.zip target/release/geoserver-2.6-SNAPSHOT-arcsde-plugin.zip target/release/geoserver-2.6-SNAPSHOT-cas-plugin.zip target/release/geoserver-2.6-SNAPSHOT-charts-plugin.zip target/release/geoserver-2.6-SNAPSHOT-control-flow-plugin.zip target/release/geoserver-2.6-SNAPSHOT-css-plugin.zip target/release/geoserver-2.6-SNAPSHOT-csw-plugin.zip target/release/geoserver-2.6-SNAPSHOT-db2-plugin.zip target/release/geoserver-2.6-SNAPSHOT-dxf-plugin.zip target/release/geoserver-2.6-SNAPSHOT-excel-plugin.zip target/release/geoserver-2.6-SNAPSHOT-feature-pregeneralized-plugin.zip target/release/geoserver-2.6-SNAPSHOT-gdal-plugin.zip target/release/geoserver-2.6-SNAPSHOT-geosearch-plugin.zip target/release/geoserver-2.6-SNAPSHOT-h2-plugin.zip target/release/geoserver-2.6-SNAPSHOT-imagemap-plugin.zip target/release/geoserver-2.6-SNAPSHOT-imagemosaic-jdbc-plugin.zip target/release/geoserver-2.6-SNAPSHOT-importer-bdb-plugin.zip target/release/geoserver-2.6-SNAPSHOT-importer-plugin.zip target/release/geoserver-2.6-SNAPSHOT-inspire-plugin.zip target/release/geoserver-2.6-SNAPSHOT-jp2k-plugin.zip target/release/geoserver-2.6-SNAPSHOT-libjpeg-turbo-plugin.zip target/release/geoserver-2.6-SNAPSHOT-monitor-hibernate-plugin.zip target/release/geoserver-2.6-SNAPSHOT-monitor-plugin.zip target/release/geoserver-2.6-SNAPSHOT-mysql-plugin.zip target/release/geoserver-2.6-SNAPSHOT-ogr-plugin.zip target/release/geoserver-2.6-SNAPSHOT-oracle-plugin.zip target/release/geoserver-2.6-SNAPSHOT-pyramid-plugin.zip target/release/geoserver-2.6-SNAPSHOT-querylayer-plugin.zip target/release/geoserver-2.6-SNAPSHOT-sqlserver-plugin.zip target/release/geoserver-2.6-SNAPSHOT-teradata-plugin.zip target/release/geoserver-2.6-SNAPSHOT-wcs2_0-eo-plugin.zip target/release/geoserver-2.6-SNAPSHOT-wps-plugin.zip target/release/geoserver-2.6-SNAPSHOT-xslt-plugin.zip /var/www/geoserver/master/ext-latest
+ cp community/target/release/geoserver-2.6-SNAPSHOT-aggregate-plugin.zip community/target/release/geoserver-2.6-SNAPSHOT-authkey-plugin.zip community/target/release/geoserver-2.6-SNAPSHOT-colormap-plugin.zip community/target/release/geoserver-2.6-SNAPSHOT-dds-plugin.zip community/target/release/geoserver-2.6-SNAPSHOT-ftp-plugin.zip community/target/release/geoserver-2.6-SNAPSHOT-groovy-plugin.zip community/target/release/geoserver-2.6-SNAPSHOT-javascript-plugin.zip community/target/release/geoserver-2.6-SNAPSHOT-jdbcconfig-plugin.zip community/target/release/geoserver-2.6-SNAPSHOT-netcdf-out-plugin.zip community/target/release/geoserver-2.6-SNAPSHOT-netcdf-plugin.zip community/target/release/geoserver-2.6-SNAPSHOT-printing-plugin.zip community/target/release/geoserver-2.6-SNAPSHOT-python-plugin.zip community/target/release/geoserver-2.6-SNAPSHOT-simpleFeatureService-plugin.zip community/target/release/geoserver-2.6-SNAPSHOT-spatialite-plugin.zip community/target/release/geoserver-2.6-SNAPSHOT-wms-eo-plugin.zip /var/www/geoserver/master/community-2014-03-21
cp: writing `/var/www/geoserver/master/community-2014-03-21/geoserver-2.6-SNAPSHOT-javascript-plugin.zip': Disk quota exceeded
cp: failed to extend `/var/www/geoserver/master/community-2014-03-21/geoserver-2.6-SNAPSHOT-javascript-plugin.zip': Disk quota exceeded
cp: writing `/var/www/geoserver/master/community-2014-03-21/geoserver-2.6-SNAPSHOT-jdbcconfig-plugin.zip': Disk quota exceeded
cp: failed to extend `/var/www/geoserver/master/community-2014-03-21/geoserver-2.6-SNAPSHOT-jdbcconfig-plugin.zip': Disk quota exceeded
cp: writing `/var/www/geoserver/master/community-2014-03-21/geoserver-2.6-SNAPSHOT-netcdf-out-plugin.zip': Disk quota exceeded
cp: failed to extend `/var/www/geoserver/master/community-2014-03-21/geoserver-2.6-SNAPSHOT-netcdf-out-plugin.zip': Disk quota exceeded
cp: writing `/var/www/geoserver/master/community-2014-03-21/geoserver-2.6-SNAPSHOT-netcdf-plugin.zip': Disk quota exceeded
cp: failed to extend `/var/www/geoserver/master/community-2014-03-21/geoserver-2.6-SNAPSHOT-netcdf-plugin.zip': Disk quota exceeded
cp: writing `/var/www/geoserver/master/community-2014-03-21/geoserver-2.6-SNAPSHOT-printing
