See <https://build.geoserver.org/job/geoserver-master-nightly/2412/display/redirect?page=changes>
Changes:
[Alessio Fabiani] [WPS-Remote Community Module] - gracefully handle JSONNull keys
[...truncated 134.11 KB...]
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wcs2_0 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/wcs2_0/target/gs-wcs2_0-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wcs2_0 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/wcs2_0/target/gs-wcs2_0-2.15-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wcs2_0 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/wcs2_0/target/gs-wcs2_0-2.15-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-wcs2_0 ---
[INFO] Copying gt-api-21-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/wcs2_0/target/dependency/gt-api-21-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.15-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/wcs2_0/target/dependency/gwc-core-1.15-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wcs2_0 ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/wcs2_0/target/gs-wcs2_0-2.15-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/gs-wcs2_0/2.15-SNAPSHOT/gs-wcs2_0-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/wcs2_0/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/gs-wcs2_0/2.15-SNAPSHOT/gs-wcs2_0-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/wcs2_0/target/gs-wcs2_0-2.15-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/gs-wcs2_0/2.15-SNAPSHOT/gs-wcs2_0-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/wcs2_0/target/gs-wcs2_0-2.15-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/gs-wcs2_0/2.15-SNAPSHOT/gs-wcs2_0-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/wcs2_0/target/gs-wcs2_0-2.15-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/gs-wcs2_0/2.15-SNAPSHOT/gs-wcs2_0-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Web Feature Service Module 2.15-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-wfs ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/wfs/target>
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-wfs ---
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-wfs ---
[debug] Using AOSP style
[INFO] Processed 100 files (0 reformatted).
[INFO] Processed 200 files (0 reformatted).
[INFO] Processed 300 files (0 reformatted).
[INFO] Processed 364 files (0 reformatted).
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-wfs ---
[INFO] Copying 11 resources
[INFO] Copying 10 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-wfs ---
[INFO] Compiling 263 source files to <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/wfs/target/classes>
[ERROR] COMPILATION ERROR :
[ERROR] <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/wfs/src/main/java/org/geoserver/wfs/xml/GML3GeometryTranslator.java>:\[17,23\] error: incompatible types: int cannot be converted to String
[ERROR] <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/wfs/src/main/java/org/geoserver/wfs/xml/GML3GeometryTranslator.java>:\[21,8\] error: no suitable constructor found for GeometryTranslator(ContentHandler,int)
[INFO] 2 errors
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.597 s]
[INFO] Core Platform Module ............................... SUCCESS [ 6.218 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 7.860 s]
[INFO] Main Module ........................................ SUCCESS [ 26.467 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.056 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [ 5.244 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 4.169 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 3.764 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.281 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 5.175 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 5.324 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 6.470 s]
[INFO] Web Feature Service Module ......................... FAILURE [ 5.559 s]
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SKIPPED
[INFO] gs-restconfig-wcs .................................. SKIPPED
[INFO] gs-restconfig-wfs .................................. SKIPPED
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SKIPPED
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Community Space .................................... SKIPPED
[INFO] Authentication by unique url key ................... SKIPPED
[INFO] WorldWind Format Module ............................ SKIPPED
[INFO] SpatiaLite Extension ............................... SKIPPED
[INFO] GeoServer JDBC KV Catalog .......................... SKIPPED
[INFO] WMS-EO ............................................. SKIPPED
[INFO] ColorMap ........................................... SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] GeoServer mbtiles Extension ........................ SKIPPED
[INFO] GeoServer GeoPackage Extension ..................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults ............... SKIPPED
[INFO] GPX PPIO for WPS ................................... SKIPPED
[INFO] KML PPIO for WPS ................................... SKIPPED
[INFO] DownloadProcess .................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............. SKIPPED
[INFO] ActiveMQ ........................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ............ SKIPPED
[INFO] GeoServer JMS clustering module .................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module .............. SKIPPED
[INFO] Solr Module ........................................ SKIPPED
[INFO] Parameters Extractor ............................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Web Processing Service - Remote processes invocation SKIPPED
[INFO] WPS cluster on jdbc datastores ..................... SKIPPED
[INFO] ncWMS compatibility extension ...................... SKIPPED
[INFO] GWC Distributed Caching Plugin ..................... SKIPPED
[INFO] GeoWebCache S3 ..................................... SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] GDAL translate parent .............................. SKIPPED
[INFO] GDAL translate WCS ................................. SKIPPED
[INFO] GDAL translate WPS ................................. SKIPPED
[INFO] GeoServer JDBC Configuration Resource Store ........ SKIPPED
[INFO] GeoWebCache SQLite ................................. SKIPPED
[INFO] GeoGig GeoServer integration ....................... SKIPPED
[INFO] GeoServer Config Backup And Restore ................ SKIPPED
[INFO] GeoServer Config Backup And Restore Core Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore REST Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore Extensions ..... SKIPPED
[INFO] GeoServer Config Backup And Restore Web UI Module .. SKIPPED
[INFO] WMTS Multi Dimensional ............................. SKIPPED
[INFO] GeoServer Security Community Modules ............... SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - Core .... SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - OpenId Connect SKIPPED
[INFO] GeoServer Keycloak Security Plugin ................. SKIPPED
[INFO] GeoServer OneLogin Module .......................... SKIPPED
[INFO] gs-notification-common ............................. SKIPPED
[INFO] GeoServer notification event system extension for GeoNode SKIPPED
[INFO] OWS Dispatcher Simulate Plugin ..................... SKIPPED
[INFO] JDBC Metrics Plugin ................................ SKIPPED
[INFO] OpenSearch EO parent ............................... SKIPPED
[INFO] OpenSearch for EO .................................. SKIPPED
[INFO] OpenSearch for EO web UI ........................... SKIPPED
[INFO] OpenSearch for EO REST configuration API ........... SKIPPED
[INFO] GeoServer Mapbox Styling ........................... SKIPPED
[INFO] GeoServer Status Monitoring Module ................. SKIPPED
[INFO] NSG Profiles ....................................... SKIPPED
[INFO] NSG WMTS 1.0 Profile ............................... SKIPPED
[INFO] NSG WFS 2.0 Profile ................................ SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF GHRSST encoder .............................. SKIPPED
[INFO] WFS 3 prototype .................................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] S3 Geotiff Support ................................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SKIPPED
[INFO] GeoServer Task Manager ............................. SKIPPED
[INFO] GeoServer Task Manager Core ........................ SKIPPED
[INFO] GeoServer Task Manager S3 .......................... SKIPPED
[INFO] GeoServer Quality of Service GetCapabilities module SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer notification event system ................ SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SKIPPED
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 01:30 min
[INFO] Finished at: 2018-09-26T13:22:12+00:00
[INFO] Final Memory: 169M/1421M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-wfs: Compilation failure: Compilation failure:
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wfs
