[Geoserver-devel] Build failed in Jenkins: geoserver-master-nightly #249
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/249/changes&gt;
Changes:
[ksmith] Change compile target to 1.7
[...truncated 57 lines...]
[INFO] GeoServer Scripting Extensions
[INFO] Core Scripting Extension
[INFO] H2 DataStore Extension
[INFO] Python Scripting Extension
[INFO] JavaScript Scripting Extension
[INFO] Groovy Scripting Extension
[INFO] GeoServer JDBC KV Catalog
[INFO] Simple Feature Service
[INFO] Aggregating Data Store
[INFO] WMS-EO
[INFO] ColorMap
[INFO] GeoServer mbtiles Extension
[INFO] GeoServer GeoPackage Extension
[INFO] GRIB Coverage Format
[INFO] Dynamic WMS dimension value defaults
[INFO] GeoServer Community Release Module
[INFO] SpatiaLite Extension
[INFO] BeanShell Scripting Extension
[INFO] Ruby Scripting Extension
[INFO] Application Schema Support
[INFO] Application Schema Integration Test
[INFO] Sample DataAccess Integration Test
[INFO] ArcSDE DataStore Extension
[INFO] GeoSearch Index Module
[INFO] SQL Server DataStore Extension
[INFO] Oracle DataStore Extension
[INFO] MySQL DataStore Extension
[INFO] DB2 DataStore Extension
[INFO] ImageMap Output Format
[INFO] ImageI/O-Ext GDAL Coverage Extension
[INFO] JP2K Coverage Extension
[INFO] ogr2ogr Output Format
[INFO] Excel Output Format
[INFO] Validation Module
[INFO] Chart external graphics support
[INFO] Feature Generalization Extension
[INFO] Image Mosaic JDBC Extension
[INFO] OWS request flow controller
[INFO] Web Processing Service GUI
[INFO] GeoServer Layer Querying filter functions
[INFO] Teradata DataStore Extension
[INFO] GeoServer Monitor Extensions
[INFO] Core Monitor Extension
[INFO] Monitor Hibernate Extension
[INFO] GeoServer Security Extension Modules
[INFO] GeoServer CAS Security Module
[INFO] GeoServer Security Extension Web Modules
[INFO] GeoServer CAS Security Web Module
[INFO] XLST based WFS output format
[INFO] GeoServer INSPIRE Extensions
[INFO] GeoServer CSS Styling
[INFO] Catalog Services for the Web parent
[INFO] Catalog Services for the Web interfaces
[INFO] Catalog Services for the Web - Simple CatalogStore implementation
[INFO] Catalog Services for the Web core module
[INFO] CSW UI Module
[INFO] DXF output format
[INFO] DXF WPS PPIO
[INFO] Printing Module
[INFO] GeoServer WCS 2.0 Earth Observation Extensions
[INFO] Web Coverage Service 2.0 Earth Observation extensions
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension
[INFO] GeoServer libjpeg-turbo Module
[INFO] GeoServer Data Importer
[INFO] Importer Core Module
[INFO] Importer REST Api Module
[INFO] Importer Berkley DB Persistence Module
[INFO] Importer Web UI Module
[INFO] GeoServer Release Module
[INFO] Building GeoServer
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target&gt;
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Change compile target to 1.7
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 13.05.2014 @ 00:02:48 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 13-May-2014 08:17
[INFO] [GitCommitIdMojo] build.build.time = 13.05.2014 @ 08:18:01 UTC
[INFO] [GitCommitIdMojo] build.branch = 9d5b648f04ad7b153f60562f9c5cbc330c275c75
[INFO] [GitCommitIdMojo] build.commit.user.email = jody.garnett@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Jody Garnett
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 9d5b648
[INFO] [GitCommitIdMojo] build.commit.id = 9d5b648f04ad7b153f60562f9c5cbc330c275c75
[INFO] [GitCommitIdMojo] build.commit.message.full = Change compile target to 1.7
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] snapshot org.geotools:gt-api:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:library:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:modules:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:geotools:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-referencing:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-referencing:12-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-referencing:12-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-metadata:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-metadata:12-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-metadata:12-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-opengis:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-opengis:12-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-opengis:12-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-main:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-core:1.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:geowebcache:1.6-SNAPSHOT: checking for updates from osgeo
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/geoserver-2.6-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [GitCommitIdMojo] build.build.time = 13.05.2014 @ 08:18:08 UTC
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-12-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/dependency/gt-api-12-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.6-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/dependency/gwc-core-1.6-SNAPSHOT.jar&gt;
[WARNING] DEPRECATED [tasks]: Use target instead
[INFO] [antrun:run {execution: read-manifest}]
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
     [copy] Copying 1 file to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target&gt;
[INFO] Executed tasks
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/geoserver/2.6-SNAPSHOT/geoserver-2.6-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/geoserver-2.6-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/geoserver/2.6-SNAPSHOT/geoserver-2.6-SNAPSHOT-tests.jar
[INFO] Building Core Platform Module
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/platform/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 13.05.2014 @ 08:18:13 UTC
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/platform/src/main/resources&gt;
[INFO] Compiling 39 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/platform/target/classes&gt;
[ERROR] COMPILATION ERROR :
[ERROR] Failure executing javac, but could not parse the error:
javac: invalid target release: 1.7
Usage: javac <options> <source files>
use -help for a list of possible options
[INFO] 1 error
[ERROR] BUILD FAILURE
[INFO] Compilation failure
[INFO] Total time: 44 seconds
[INFO] Finished at: Tue May 13 08:18:14 UTC 2014
[INFO] Final Memory: 77M/383M
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/master/geoserver-master-2014-05-13-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
Build step 'Execute shell' marked build as failure
Oops, geoserver-master-nightly was still building with Oracle JDK 6; I changed it to Oracle JDK 7 (same as geoserver-master) and kicked it.
Thanks for the fix, Kevin, without which this oversight would not have been detected!
Kind regards,
Ben.
Changes:
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
In fact Jody was the author (Jenkins reports the committer not the author).
been detected!
Kind regards,
Ben.
Changes:
Software Engineer
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/250/&gt;
