[Geoserver-devel] Build failed in Jenkins: geoserver-master-nightly #2615
See <https://build.geoserver.org/job/geoserver-master-nightly/2615/display/redirect?page=changes&gt;
Changes:
[tbarsballe] split packages: Move ArcSDE factories to org.geotools.arcsde.data
[tbarsballe] split packages: Move ComplexFeatureConstants to
[tbarsballe] Java 11 runtime considerations
[Alessio Fabiani] [JIRA GEOS-9031][Backup & Restore] Add the possibility of filtering
[Alessio Fabiani] - As per @mbarto review: added br index so that web page can read it
[Alessio Fabiani] - minor optimization: filter fileds as Filter type
[Alessio Fabiani] - Dump filters on BR index.xml; BR Data Page recovering filters from
[...truncated 1.28 MB...]
[INFO] Copying 90 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-csw-api ---
[INFO] Compiling 29 source files to <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/csw/api/target/classes&gt;
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/iso/MDQueryableFilterVisitor.java&gt;:\[8,39\] error: package org.geotools.data.complex.filter does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/iso/MetaDataDescriptor.java&gt;:\[20,39\] error: package org.geotools.data.complex.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/iso/MetaDataDescriptor.java&gt;:\[21,39\] error: package org.geotools.data.complex.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/CSWRecordDescriptor.java&gt;:\[21,39\] error: package org.geotools.data.complex.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/CSWRecordDescriptor.java&gt;:\[22,39\] error: package org.geotools.data.complex.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/iso/MDQueryableFilterVisitor.java&gt;:\[37,17\] error: package XPathUtil does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/iso/MDQueryableFilterVisitor.java&gt;:\[38,16\] error: cannot find symbol
[ERROR] class MDQueryableFilterVisitor
<https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/iso/MetaDataDescriptor.java&gt;:\[76,8\] error: cannot find symbol
[ERROR] class MetaDataDescriptor
<https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/iso/MetaDataDescriptor.java&gt;:\[76,41\] error: cannot find symbol
<https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/iso/MetaDataDescriptor.java&gt;:\[89,8\] error: cannot find symbol
<https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/iso/MetaDataDescriptor.java&gt;:\[90,20\] error: cannot find symbol
<https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/CSWRecordDescriptor.java&gt;:\[142,8\] error: cannot find symbol
[ERROR] class CSWRecordDescriptor
<https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/CSWRecordDescriptor.java&gt;:\[142,41\] error: cannot find symbol
<https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/CSWRecordDescriptor.java&gt;:\[152,8\] error: cannot find symbol
<https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/CSWRecordDescriptor.java&gt;:\[153,20\] error: cannot find symbol
[INFO] 15 errors
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.152 s]
[INFO] Core Platform Module ............................... SUCCESS [ 6.126 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 7.715 s]
[INFO] Main Module ........................................ SUCCESS [ 25.798 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.054 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [ 4.858 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 3.756 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 3.730 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.122 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 4.698 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 5.011 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 6.395 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 10.552 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 13.291 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 5.763 s]
[INFO] gs-rest ............................................ SUCCESS [ 3.611 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 9.830 s]
[INFO] gs-restconfig ...................................... SUCCESS [ 7.452 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 2.985 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 2.876 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 2.895 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.017 s]
[INFO] Core UI Module ..................................... SUCCESS [ 10.984 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 5.547 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 6.213 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 3.277 s]
[INFO] Demos Module ....................................... SUCCESS [ 4.963 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 3.487 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.031 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 6.712 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 3.194 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 3.302 s]
[INFO] REST UI Module ..................................... SUCCESS [ 2.683 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 5.533 s]
[INFO] Community Space .................................... SUCCESS [ 0.190 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 5.264 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 3.818 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 2.903 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 5.170 s]
[INFO] WMS-EO ............................................. SUCCESS [ 4.283 s]
[INFO] ColorMap ........................................... SUCCESS [ 3.690 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.017 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.018 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 9.311 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 3.716 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 4.126 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 1.766 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 3.575 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 3.131 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 3.076 s]
[INFO] DownloadProcess .................................... SUCCESS [ 4.932 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.895 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 2.564 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 1.407 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 6.091 s]
[INFO] Solr Module ........................................ SUCCESS [ 3.653 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 3.969 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.036 s]
[INFO] Importer Core Module ............................... SUCCESS [ 7.183 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 4.438 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 3.059 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 3.808 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 1.594 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 3.330 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.011 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.461 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.022 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 2.919 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 2.818 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 3.980 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 3.394 s]
[INFO] GeoGig GeoServer integration ....................... SUCCESS [ 21.337 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.116 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 5.435 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 3.437 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 1.796 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 2.815 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 4.224 s]
[INFO] GeoServer Security Community Modules ............... SUCCESS [ 0.015 s]
[INFO] GeoServer OAuth2 Connect Security Module - Core .... SUCCESS [ 3.356 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 3.148 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 2.869 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 3.145 s]
[INFO] GeoServer OAuth2 Connect Security Module - OpenId Connect SUCCESS [ 3.143 s]
[INFO] GeoServer Keycloak Security Plugin ................. SUCCESS [ 3.506 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 3.380 s]
[INFO] gs-notification-common ............................. SUCCESS [ 1.020 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 1.951 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 3.065 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 1.392 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.014 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 5.280 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 3.173 s]
[INFO] OpenSearch for EO REST configuration API ........... SUCCESS [ 4.894 s]
[INFO] GeoServer Mapbox Styling ........................... SUCCESS [ 3.192 s]
[INFO] GeoServer Status Monitoring Module ................. SUCCESS [ 3.246 s]
[INFO] NSG Profiles ....................................... SUCCESS [ 0.013 s]
[INFO] NSG WMTS 1.0 Profile ............................... SUCCESS [ 1.304 s]
[INFO] NSG WFS 2.0 Profile ................................ SUCCESS [ 4.171 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 3.338 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 3.309 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 4.902 s]
[INFO] NetCDF GHRSST encoder .............................. SUCCESS [ 3.522 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 4.296 s]
[INFO] WFS 3 prototype .................................... SUCCESS [ 5.339 s]
[INFO] S3 Geotiff Support ................................. SUCCESS [ 1.407 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 3.588 s]
[INFO] GeoServer Task Manager ............................. SUCCESS [ 0.034 s]
[INFO] GeoServer Task Manager Core ........................ SUCCESS [ 8.346 s]
[INFO] GeoServer Task Manager S3 .......................... SUCCESS [ 4.078 s]
[INFO] GeoServer Quality of Service GetCapabilities module SUCCESS [ 5.057 s]
[INFO] GeoServer Community Release Module ................. SUCCESS [ 1.382 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 3.413 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.011 s]
[INFO] Application Schema Integration Test ................ SUCCESS [ 4.973 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 1.778 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 3.205 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 2.817 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.015 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.014 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.179 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.179 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 3.473 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.926 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.181 s]
[INFO] OGR WFS ............................................ SUCCESS [ 2.958 s]
[INFO] OGR WPS ............................................ SUCCESS [ 2.869 s]
[INFO] Excel Output Format ................................ SUCCESS [ 2.925 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.180 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 1.379 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.019 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 3.496 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 3.188 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 4.869 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 2.638 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.397 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.021 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 5.245 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.022 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 3.571 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.030 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 1.846 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 3.395 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 3.936 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 3.340 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.026 s]
[INFO] Catalog Services for the Web interfaces ............ FAILURE [ 2.098 s]
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SKIPPED
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 08:46 min
[INFO] Finished at: 2018-11-27T19:24:24+00:00
[INFO] Final Memory: 233M/1668M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-csw-api: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/iso/MetaDataDescriptor.java&gt;:\[76,8\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/iso/MetaDataDescriptor.java&gt;:\[76,41\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/iso/MetaDataDescriptor.java&gt;:\[89,8\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/iso/MetaDataDescriptor.java&gt;:\[90,20\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/CSWRecordDescriptor.java&gt;:\[142,8\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/CSWRecordDescriptor.java&gt;:\[142,41\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/CSWRecordDescriptor.java&gt;:\[152,8\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/csw/api/src/main/java/org/geoserver/csw/records/CSWRecordDescriptor.java&gt;:\[153,20\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-csw-api
See <https://build.geoserver.org/job/geoserver-master-nightly/2616/display/redirect?page=changes&gt;
