See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/273/changes>
Changes:
[mike] Updating CSS section
[andrea.aime] Fixing web build
[ksmith] Fixed failing unit test from GSIP-113 PR
[...truncated 7333 lines...]
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/kvp/AcceptVersionsKvpParser.java>:\[27,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/AbstractRecordsResponse.java>:\[45,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/AbstractRecordsResponse.java>:\[67,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/AbstractRecordsResponse.java>:\[72,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/store/internal/InternalCatalogStore.java>:\[77,96\] error: cannot find symbol
[ERROR] class InternalCatalogStore
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/store/internal/InternalCatalogStore.java>:\[77,51\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/store/internal/InternalCatalogStore.java>:\[78,96\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/store/internal/InternalCatalogStore.java>:\[78,51\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/kvp/GetRecordsKvpRequestReader.java>:\[58,8\] error: cannot find symbol
[ERROR] class GetRecordsKvpRequestReader
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/kvp/GetRecordsKvpRequestReader.java>:\[83,20\] error: cannot find symbol
[ERROR] method read(Object,Map,Map)
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/kvp/GetRecordsKvpRequestReader.java>:\[61,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/xml/v2_0_2/CSWRecordingXmlReader.java>:\[38,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/xml/v2_0_2/CSWRecordingXmlReader.java>:\[43,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/xml/v2_0_2/CSWRecordingXmlReader.java>:\[48,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/xml/v2_0_2/CSWRecordingXmlReader.java>:\[53,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/xml/v2_0_2/CSWRecordingXmlReader.java>:\[58,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/xml/v2_0_2/CSWRecordingXmlReader.java>:\[64,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/kvp/GetRepositoryItemKvpRequestReader.java>:\[32,64\] error: cannot find symbol
[ERROR] class GetRepositoryItemKvpRequestReader
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/kvp/GetRepositoryItemKvpRequestReader.java>:\[29,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/GetCapabilities.java>:\[285,25\] error: cannot find symbol
[ERROR] class GetCapabilities
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/GetCapabilities.java>:\[474,47\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/GetCapabilities.java>:\[473,37\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/GetCapabilities.java>:\[517,47\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/GetCapabilities.java>:\[516,36\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/GetCapabilities.java>:\[567,47\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/GetCapabilities.java>:\[566,32\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/GetCapabilities.java>:\[644,47\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/GetCapabilities.java>:\[643,35\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/GetCapabilities.java>:\[694,47\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/GetCapabilities.java>:\[693,31\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/GetCapabilities.java>:\[774,47\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/GetCapabilities.java>:\[773,33\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/TemplatedSchemaComponentDelegate.java>:\[65,33\] error: cannot find symbol
[ERROR] class TemplatedSchemaComponentDelegate
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/kvp/DescribeRecordKvpRequestReader.java>:\[48,20\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/kvp/DescribeRecordKvpRequestReader.java>:\[31,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/GetRepositoryItem.java>:\[40,26\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/kvp/SortByKvpParser.java>:\[27,8\] error: cannot find symbol
[ERROR] class SortByKvpParser
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/kvp/SortByKvpParser.java>:\[52,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/kvp/TypenamesKvpParser.java>:\[21,8\] error: cannot find symbol
[INFO] 100 errors
[INFO] -------------------------------------------------------------
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/AcknowledgementTransformer.java>:\[18,24\] error: cannot find symbol
package org.geoserver.ows
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/AcknowledgementTransformer.java>:\[19,24\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/AbstractCSWTransformer.java>:\[7,36\] error: package org.geoserver.ows.util does not exist
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/AcknowledgementTransformer.java>:\[84,35\] error: cannot find symbol
class AcknowledgementTransformer.AcknowledgementTranslator
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/kvp/AcceptFormatsKvpParser.java>:\[21,7\] error: cannot access KvpParser
class file for org.geoserver.ows.KvpParser not found
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/kvp/CSWKvpRequestReader.java>:\[11,28\] error: cannot find symbol
package org.geoserver.ows.kvp
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/kvp/CSWKvpRequestReader.java>:\[18,41\] error: cannot find symbol
class EMFKvpRequestReader
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/CSWGetRepositoryItemResponse.java>:\[15,24\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/CSWGetRepositoryItemResponse.java>:\[16,24\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/CSWGetRepositoryItemResponse.java>:\[25,50\] error: cannot find symbol
class Response
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/AbstractRecordsResponse.java>:\[19,24\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/AbstractRecordsResponse.java>:\[30,54\] error: cannot find symbol
class Response
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/GetRecords.java>:\[31,35\] error: package org.geoserver.ows.URLMangler does not exist
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/GetRecords.java>:\[32,29\] error: package org.geoserver.ows.util does not exist
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/store/internal/InternalCatalogStore.java>:\[17,35\] error: package org.geoserver.ows.URLMangler does not exist
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/store/internal/InternalCatalogStore.java>:\[18,29\] error: package org.geoserver.ows.util does not exist
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/xml/v2_0_2/CSWXmlReader.java>:\[15,24\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/xml/v2_0_2/CSWXmlReader.java>:\[27,34\] error: cannot find symbol
class XmlRequestReader
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/xml/v2_0_2/CSWRecordingXmlReader.java>:\[12,24\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/xml/v2_0_2/CSWRecordingXmlReader.java>:\[13,24\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/xml/v2_0_2/CSWRecordingXmlReader.java>:\[14,24\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/xml/v2_0_2/CSWRecordingXmlReader.java>:\[24,67\] error: cannot find symbol
class DispatcherCallback
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/xml/v2_0_2/CSWRecordingXmlReader.java>:\[39,24\] error: cannot find symbol
class CSWRecordingXmlReader
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/xml/v2_0_2/CSWRecordingXmlReader.java>:\[39,11\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/xml/v2_0_2/CSWRecordingXmlReader.java>:\[44,37\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/xml/v2_0_2/CSWRecordingXmlReader.java>:\[49,41\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/xml/v2_0_2/CSWRecordingXmlReader.java>:\[54,36\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/xml/v2_0_2/CSWRecordingXmlReader.java>:\[59,39\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/xml/v2_0_2/CSWRecordingXmlReader.java>:\[60,12\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/xml/v2_0_2/CSWRecordingXmlReader.java>:\[59,11\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/xml/v2_0_2/CSWRecordingXmlReader.java>:\[65,25\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/kvp/GetRepositoryItemKvpRequestReader.java>:\[11,24\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/kvp/GetRepositoryItemKvpRequestReader.java>:\[20,55\] error: cannot find symbol
class KvpRequestReader
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/GetCapabilities.java>:\[46,35\] error: package org.geoserver.ows.URLMangler does not exist
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/GetCapabilities.java>:\[47,29\] error: package org.geoserver.ows.util does not exist
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/GetCapabilities.java>:\[48,29\] error: package org.geoserver.ows.util does not exist
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/TemplatedSchemaComponentDelegate.java>:\[7,36\] error: package org.geoserver.ows.util does not exist
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/GetRepositoryItem.java>:\[10,24\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/kvp/SortByKvpParser.java>:\[9,24\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/kvp/SortByKvpParser.java>:\[22,37\] error: cannot find symbol
class FlatKvpParser
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/kvp/TypenamesKvpParser.java>:\[17,40\] error: cannot find symbol
class KvpParser
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/DescribeRecordResponse.java>:\[7,36\] error: package org.geoserver.ows.util does not exist
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/DescribeRecordResponse.java>:\[20,24\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/DescribeRecordResponse.java>:\[31,44\] error: cannot find symbol
class Response
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/CSWDomainValuesTransformer.java>:\[7,36\] error: package org.geoserver.ows.util does not exist
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/CSWDomainValuesTransformer.java>:\[7,0\] error: static import only from classes and interfaces
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/CSWGetDomainResponse.java>:\[18,24\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/CSWGetDomainResponse.java>:\[27,42\] error: cannot find symbol
class Response
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/CSWObjectEncodingResponse.java>:\[10,24\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/CSWObjectEncodingResponse.java>:\[11,33\] error: package org.geoserver.ows.xml.v1_0 does not exist
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/CSWObjectEncodingResponse.java>:\[21,47\] error: cannot find symbol
class XmlObjectEncodingResponse
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/AbstractCSWTransformer.java>:\[58,23\] error: cannot find symbol
class AbstractCSWTransformer.AbstractCSWTranslator
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/AcknowledgementTransformer.java>:\[72,12\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/AcknowledgementTransformer.java>:\[72,40\] error: package Dispatcher does not exist
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/kvp/AcceptFormatsKvpParser.java>:\[24,8\] error: cannot find symbol
class AcceptFormatsKvpParser
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/kvp/CSWKvpRequestReader.java>:\[25,30\] error: cannot find symbol
class CSWKvpRequestReader
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/CSWGetRepositoryItemResponse.java>:\[34,4\] error: method does not override or implement a method from a supertype
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/CSWGetRepositoryItemResponse.java>:\[44,4\] error: method does not override or implement a method from a supertype
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/CSWGetRepositoryItemResponse.java>:\[60,26\] error: cannot find symbol
class CSWGetRepositoryItemResponse
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/response/CSWGetRepositoryItemResponse.java>:\[50,4\] error: method does not override or implement a method from a supertype
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/csw/core/src/main/java/org/geoserver/csw/kvp/AcceptVersionsKvpParser.java>:\[24,8\] error: cannot find symbol
class AcceptVersionsKvpParser
[INFO] Total time: 12 minutes 8 seconds
[INFO] Finished at: Thu Jun 05 08:13:26 UTC 2014
[INFO] Final Memory: 134M/506M
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/master/geoserver-master-2014-06-05-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
Build step 'Execute shell' marked build as failure
