See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/280/>
[...truncated 2742 lines...]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/netcdf-out/target/gs-netcdf-out-2.6-SNAPSHOT-test-sources.jar>
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-12-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/netcdf-out/target/dependency/gt-api-12-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.6-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/netcdf-out/target/dependency/gwc-core-1.6-SNAPSHOT.jar>
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/netcdf-out/target/gs-netcdf-out-2.6-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-netcdf-out/2.6-SNAPSHOT/gs-netcdf-out-2.6-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/netcdf-out/target/gs-netcdf-out-2.6-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-netcdf-out/2.6-SNAPSHOT/gs-netcdf-out-2.6-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/netcdf-out/target/gs-netcdf-out-2.6-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-netcdf-out/2.6-SNAPSHOT/gs-netcdf-out-2.6-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/netcdf-out/target/gs-netcdf-out-2.6-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-netcdf-out/2.6-SNAPSHOT/gs-netcdf-out-2.6-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer Embedded FTP server
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/ftp/target>
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #609 from n-lagomarsini/GEOS-6527
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 10.06.2014 @ 13:32:08 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 12-Jun-2014 08:01
[INFO] [GitCommitIdMojo] build.build.time = 12.06.2014 @ 08:07:41 UTC
[INFO] [GitCommitIdMojo] build.branch = d7cb6bd5d3724ce8497aed7658fa13d3a1f57390
[INFO] [GitCommitIdMojo] build.commit.user.email = daniele.romagnoli@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Daniele Romagnoli
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = d7cb6bd
[INFO] [GitCommitIdMojo] build.commit.id = d7cb6bd5d3724ce8497aed7658fa13d3a1f57390
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #609 from n-lagomarsini/GEOS-6527
[GEOS-6527] REST Upload fails when doing a POST request on an externally configured mosaic
[INFO] Copying 0 resource
[INFO] Copying 1 resource
[INFO] Compiling 10 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/ftp/target/classes>
[WARNING] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/ftp/src/main/java/org/geoserver/ftp/FtpLetCallBackAdapter.java>:\[23,47\] ACONST_NULL is internal proprietary API and may be removed in a future release
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/ftp/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/ftp/src/test/resources>
[INFO] No sources to compile
[INFO] Tests are skipped.
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/ftp/target/gs-ftp-2.6-SNAPSHOT.jar>
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/ftp/target/gs-ftp-2.6-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/ftp/target/gs-ftp-2.6-SNAPSHOT-sources.jar>
[INFO] Copying gt-api-12-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/ftp/target/dependency/gt-api-12-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.6-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/ftp/target/dependency/gwc-core-1.6-SNAPSHOT.jar>
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/ftp/target/gs-ftp-2.6-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-ftp/2.6-SNAPSHOT/gs-ftp-2.6-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/ftp/target/gs-ftp-2.6-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-ftp/2.6-SNAPSHOT/gs-ftp-2.6-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/ftp/target/gs-ftp-2.6-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-ftp/2.6-SNAPSHOT/gs-ftp-2.6-SNAPSHOT-sources.jar
[INFO] Building GeoServer Extensions
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/target>
[INFO] [GitCommitIdMojo] build.build.time = 12.06.2014 @ 08:07:45 UTC
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/target/extension-2.6-SNAPSHOT-tests.jar>
[INFO] Copying gt-api-12-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/target/dependency/gt-api-12-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.6-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/target/dependency/gwc-core-1.6-SNAPSHOT.jar>
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/2.6-SNAPSHOT/extension-2.6-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/target/extension-2.6-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/2.6-SNAPSHOT/extension-2.6-SNAPSHOT-tests.jar
[INFO] Building Web Processing Service parent
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/wps/target>
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/wps/target/gs-wps-2.6-SNAPSHOT-tests.jar>
[INFO] Copying gt-api-12-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/wps/target/dependency/gt-api-12-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.6-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/wps/target/dependency/gwc-core-1.6-SNAPSHOT.jar>
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/wps/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps/2.6-SNAPSHOT/gs-wps-2.6-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/wps/target/gs-wps-2.6-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps/2.6-SNAPSHOT/gs-wps-2.6-SNAPSHOT-tests.jar
[INFO] Building Web Processing Service Module
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/wps/wps-core/target>
[INFO] Copying 9 resources
[INFO] Copying 14 resources
[INFO] snapshot org.geotools.ogc:net.opengis.wps:12-SNAPSHOT: checking for updates from jaitools-snapshots
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '780ba3cf6b6eb0f7c9f6d41d8d25a86a2f46b0c4'; remote = '<html>
<head><title>301' - RETRYING
<head><title>301' - IGNORING
[INFO] snapshot org.geotools.ogc:net.opengis.wps:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wps:12-SNAPSHOT: checking for updates from osgeo
[ERROR] BUILD ERROR
[INFO] Error building POM (may not be this project's POM).
Project ID: org.geotools.ogc:net.opengis.wps
Reason: Error getting POM for 'org.geotools.ogc:net.opengis.wps' from the repository: Unable to read local copy of metadata: Cannot read metadata from '/var/lib/jenkins/.m2/repository/org/geotools/ogc/net.opengis.wps/12-SNAPSHOT/maven-metadata-jaitools-snapshots.xml': end tag name </body> must match start tag name <hr> from line 5 (position: TEXT seen ...</center>\r\n</body>... @6:8)
org.geotools.ogc:net.opengis.wps:pom:12-SNAPSHOT
for project org.geotools.ogc:net.opengis.wps
[INFO] Total time: 6 minutes 11 seconds
[INFO] Finished at: Thu Jun 12 08:07:46 UTC 2014
[INFO] Final Memory: 101M/439M
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/master/geoserver-master-2014-06-12-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
Build step 'Execute shell' marked build as failure
