See <https://build.geoserver.org/job/geoserver-master-nightly/3033/display/redirect?page=changes>
Changes:
[daniele.romagnoli] cleanup OWS ExceptionHandler test
[Andrea Aime] Follow up on scale/offset imageio-ext and gt support
[...truncated 767.06 KB...]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-ogr-core ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-ogr-core ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/ogr/ogr-core/src/test/java’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 9 files (0 reformatted).
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-ogr-core ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/ogr/ogr-core/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-ogr-core ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 9 source files to <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/ogr/ogr-core/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-ogr-core ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/ogr/ogr-core/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/ogr/ogr-core/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-ogr-core ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-ogr-core ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-ogr-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/ogr/ogr-core/target/gs-ogr-core-2.16-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-ogr-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/ogr/ogr-core/target/gs-ogr-core-2.16-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-ogr-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/ogr/ogr-core/target/gs-ogr-core-2.16-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-ogr-core ---
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-ogr-core ---
[INFO] Copying gt-main-22-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/ogr/ogr-core/target/dependency/gt-main-22-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.16-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/ogr/ogr-core/target/dependency/gwc-core-1.16-SNAPSHOT.jar>
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 4.719 s]
[INFO] Core Platform Module ............................... SUCCESS [ 3.574 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 3.660 s]
[INFO] Main Module ........................................ SUCCESS [ 14.687 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.042 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [ 1.068 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 0.662 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 0.820 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.411 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 1.184 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 1.482 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 1.548 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 3.448 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 5.132 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 0.914 s]
[INFO] gs-rest ............................................ SUCCESS [ 0.598 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 3.699 s]
[INFO] gs-restconfig ...................................... SUCCESS [ 1.929 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 0.648 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 0.427 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 0.540 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.022 s]
[INFO] Core UI Module ..................................... SUCCESS [ 3.613 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 1.134 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 1.201 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 0.498 s]
[INFO] Demos Module ....................................... SUCCESS [ 1.094 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 0.780 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.035 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 1.495 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 0.500 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 1.534 s]
[INFO] REST UI Module ..................................... SUCCESS [ 0.427 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 4.298 s]
[INFO] Community Space .................................... SUCCESS [ 0.027 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 0.817 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 1.053 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 0.958 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.022 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.017 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 2.949 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.041 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 0.711 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 0.653 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 0.573 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 0.480 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 5.309 s]
[INFO] WMS-EO ............................................. SUCCESS [ 0.761 s]
[INFO] ColorMap ........................................... SUCCESS [ 0.534 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 0.692 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 0.733 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 0.424 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 0.578 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 0.494 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 0.655 s]
[INFO] DownloadProcess .................................... SUCCESS [ 2.648 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.268 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 12.060 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 4.455 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 6.963 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 5.434 s]
[INFO] Solr Module ........................................ SUCCESS [ 0.917 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 0.611 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.041 s]
[INFO] Importer Core Module ............................... SUCCESS [ 3.191 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 19.517 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 0.690 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 0.769 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 0.582 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 4.594 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.100 s]
[INFO] OGR CORE ........................................... FAILURE [ 0.230 s]
[INFO] GDAL translate parent .............................. SKIPPED
[INFO] GDAL translate WCS ................................. SKIPPED
[INFO] GDAL translate WPS ................................. SKIPPED
[INFO] GeoServer JDBC Configuration Resource Store ........ SKIPPED
[INFO] GeoWebCache SQLite ................................. SKIPPED
[INFO] GeoServer Config Backup And Restore ................ SKIPPED
[INFO] GeoServer Config Backup And Restore Core Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore REST Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore Extensions ..... SKIPPED
[INFO] GeoServer Config Backup And Restore Web UI Module .. SKIPPED
[INFO] WMTS Multi Dimensional ............................. SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] GeoServer Mapbox Styling ........................... SKIPPED
[INFO] WMTS Style editing extension ....................... SKIPPED
[INFO] GeoServer Security Community Modules ............... SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - Core .... SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - OpenId Connect SKIPPED
[INFO] GeoServer Keycloak Security Plugin ................. SKIPPED
[INFO] GeoServer OneLogin Module .......................... SKIPPED
[INFO] gs-notification-common ............................. SKIPPED
[INFO] GeoServer notification event system extension for GeoNode SKIPPED
[INFO] OWS Dispatcher Simulate Plugin ..................... SKIPPED
[INFO] JDBC Metrics Plugin ................................ SKIPPED
[INFO] OpenSearch EO parent ............................... SKIPPED
[INFO] OpenSearch for EO .................................. SKIPPED
[INFO] OpenSearch for EO web UI ........................... SKIPPED
[INFO] OpenSearch for EO REST configuration API ........... SKIPPED
[INFO] GeoServer Status Monitoring Module ................. SKIPPED
[INFO] NSG Profiles ....................................... SKIPPED
[INFO] NSG WMTS 1.0 Profile ............................... SKIPPED
[INFO] NSG WFS 2.0 Profile ................................ SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF GHRSST encoder .............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] WFS 3 prototype .................................... SKIPPED
[INFO] MapML Support ...................................... SKIPPED
[INFO] S3 Geotiff Support ................................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SKIPPED
[INFO] GeoServer Task Manager ............................. SKIPPED
[INFO] GeoServer Task Manager Core ........................ SKIPPED
[INFO] GeoServer Task Manager S3 .......................... SKIPPED
[INFO] GeoServer Quality of Service GetCapabilities module SKIPPED
[INFO] OGR datastore panel ................................ SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer notification event system ................ SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SKIPPED
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 02:31 min
[INFO] Finished at: 2019-06-08T08:02:46Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) on project gs-ogr-core: Error copying artifact from /home/ubuntu/.m2/repository/org/geowebcache/gwc-core/1.16-SNAPSHOT/gwc-core-1.16-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/extension/ogr/ogr-core/target/dependency/gwc-core-1.16-SNAPSHOT.jar>: No space left on device -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-ogr-core
$ ssh-agent -k
unset SSH_AUTH_SOCK;
unset SSH_AGENT_PID;
echo Agent pid 32678 killed;
[ssh-agent] Stopped.
Skipped archiving because build is not successful
