See <https://build.geoserver.org/job/geoserver-master-nightly/3092/display/redirect>
[...truncated 1.75 MB...]
[INFO] Application Schema Support ......................... SUCCESS [ 0.019 s]
[INFO] Application Schema Integration Test ................ SUCCESS [ 1.776 s]
[INFO] WFS 3 prototype .................................... SUCCESS [ 1.336 s]
[INFO] MapML Support for GeoServer ........................ SUCCESS [ 0.936 s]
[INFO] S3 Geotiff Support ................................. SUCCESS [ 0.416 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 0.822 s]
[INFO] GeoServer Task Manager ............................. SUCCESS [ 0.028 s]
[INFO] GeoServer Task Manager Core ........................ SUCCESS [ 2.681 s]
[INFO] GeoServer Task Manager S3 .......................... SUCCESS [ 0.586 s]
[INFO] GeoServer Quality of Service GetCapabilities module SUCCESS [ 1.082 s]
[INFO] OGR datastore panel ................................ SUCCESS [ 0.785 s]
[INFO] gs-ogcapi .......................................... SUCCESS [ 1.163 s]
[INFO] GeoStyler community module ......................... SUCCESS [ 0.683 s]
[INFO] GeoServer Community Release Module ................. SUCCESS [ 0.526 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 0.576 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 0.426 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 0.674 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.022 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.022 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.021 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.192 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 0.634 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 0.129 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.197 s]
[INFO] OGR WFS ............................................ SUCCESS [ 0.663 s]
[INFO] OGR WPS ............................................ SUCCESS [ 0.714 s]
[INFO] Excel Output Format ................................ SUCCESS [ 0.618 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.077 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.372 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.024 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 0.614 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 0.641 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 0.986 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 0.584 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.432 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.033 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 1.008 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.030 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 0.542 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.037 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.365 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 0.493 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 0.700 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.025 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 1.192 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 0.494 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 0.896 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 0.479 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.016 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 0.464 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 0.656 s]
[INFO] Printing Module .................................... SUCCESS [ 0.519 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.018 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 0.598 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 0.646 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 0.501 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 0.900 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 0.594 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 0.872 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 0.744 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.422 s]
[INFO] REST SLD service ................................... SUCCESS [ 1.070 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 1.089 s]
[INFO] GeoFence Server .................................... SUCCESS [ 1.052 s]
[INFO] GeoServer Release Module ........................... SUCCESS [ 0.469 s]
[INFO] BUILD SUCCESS
[INFO] Total time: 03:05 min
[INFO] Finished at: 2019-06-29T11:53:19Z
[geoserver-master] $ mvn -f src/community/pom.xml -B -U assembly:attached
[INFO] Scanning for projects...
[INFO]
[INFO] ----------------------< org.geoserver:community >-----------------------
[INFO] Building Community Space 2.16-SNAPSHOT
[INFO] --------------------------------[ pom ]---------------------------------
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geoserver/gs-platform/2.16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geoserver/gs-platform/2.16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geoserver/gs-platform/2.16-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geoserver/gs-platform/2.16-SNAPSHOT/maven-metadata.xml (1.4 kB at 4.4 kB/s)
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geoserver/geoserver/2.16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geoserver/geoserver/2.16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geoserver/geoserver/2.16-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geoserver/geoserver/2.16-SNAPSHOT/maven-metadata.xml (814 B at 25 kB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/gt-main/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-main/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geotools/gt-main/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-main/22-SNAPSHOT/maven-metadata.xml (1.2 kB at 32 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/library/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/library/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geotools/library/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/library/22-SNAPSHOT/maven-metadata.xml (594 B at 11 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/modules/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geotools/modules/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/modules/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/modules/22-SNAPSHOT/maven-metadata.xml (594 B at 19 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/geotools/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/geotools/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geotools/geotools/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/geotools/22-SNAPSHOT/maven-metadata.xml (595 B at 17 kB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/gt-referencing/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-referencing/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geotools/gt-referencing/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-referencing/22-SNAPSHOT/maven-metadata.xml (1.2 kB at 35 kB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/gt-metadata/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-metadata/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geotools/gt-metadata/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-metadata/22-SNAPSHOT/maven-metadata.xml (983 B at 38 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-opengis/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geotools/gt-opengis/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/gt-opengis/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-opengis/22-SNAPSHOT/maven-metadata.xml (982 B at 41 kB/s)
[INFO]
[INFO] --- maven-assembly-plugin:2.1:attached (default-cli) @ community ---
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-authkey-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-jdbcconfig-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-dds-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-wms-eo-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-colormap-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-mbtiles-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-geopkg-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-pgraster-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-dyndimension-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-kmlppio-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-gpx-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-wps-download-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-jms-cluster-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-hz-cluster-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-activeMQ-broker-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-solr-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-gwc-distributed-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-gwc-s3-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-gdal-wcs-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-gdal-wps-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-wps-jdbc-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-params-extractor-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-wps-remote-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-python-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-jdbcstore-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-ncwms-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-gwc-sqlite-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-sec-oauth2-google-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-sec-oauth2-github-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-sec-oauth2-geonode-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-sec-oauth2-openid-connect-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-sec-keycloak-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-backup-restore-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-wmts-multi-dimensional-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-saml-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-notification-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-ows-simulate-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-jdbc-metrics-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-opensearch-eo-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-mbstyle-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-status-monitoring-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-nsg-wmts-profile-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-nsg-wfs-profile-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-taskmanager-core-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-taskmanager-s3-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-netcdf-ghrsst-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-wfs3-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-mapml-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-qos-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-web-resource-browser-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-s3-geotiff-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-wmts-styles-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-ogr-datastore-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-ogcapi-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-geostyler-plugin.zip>
[INFO] Total time: 11.849 s
[INFO] Finished at: 2019-06-29T11:53:32Z
[geoserver-master] $ /bin/sh -xe /tmp/jenkins6758987658157563080.sh
+ ver=origin/master
+ ver=master
+ dist=../nightly/master
+ date +%Y-%m-%d
+ datestamp=2019-06-29
+ cd src
+ mkdir -p ../nightly/master
+ cp target/release/geoserver-2.16-SNAPSHOT-war.zip ../nightly/master/geoserver-master-2019-06-29-war.zip
+ cp target/release/geoserver-2.16-SNAPSHOT-bin.zip ../nightly/master/geoserver-master-2019-06-29-bin.zip
+ cp target/release/geoserver-2.16-SNAPSHOT-war.zip ../nightly/master/geoserver-master-latest-war.zip
+ cp target/release/geoserver-2.16-SNAPSHOT-bin.zip ../nightly/master/geoserver-master-latest-bin.zip
+ [ ! -e ../nightly/master/ext-2019-06-29 ]
+ [ ! -e ../nightly/master/community-2019-06-29 ]
+ cp target/release/geoserver-2.16-SNAPSHOT-app-schema-plugin.zip target/release/geoserver-2.16-SNAPSHOT-arcsde-plugin.zip target/release/geoserver-2.16-SNAPSHOT-cas-plugin.zip target/release/geoserver-2.16-SNAPSHOT-charts-plugin.zip target/release/geoserver-2.16-SNAPSHOT-control-flow-plugin.zip target/release/geoserver-2.16-SNAPSHOT-css-plugin.zip target/release/geoserver-2.16-SNAPSHOT-csw-plugin.zip target/release/geoserver-2.16-SNAPSHOT-db2-plugin.zip target/release/geoserver-2.16-SNAPSHOT-dxf-plugin.zip target/release/geoserver-2.16-SNAPSHOT-excel-plugin.zip target/release/geoserver-2.16-SNAPSHOT-feature-pregeneralized-plugin.zip target/release/geoserver-2.16-SNAPSHOT-gdal-plugin.zip target/release/geoserver-2.16-SNAPSHOT-geofence-plugin.zip target/release/geoserver-2.16-SNAPSHOT-geofence-server-plugin.zip target/release/geoserver-2.16-SNAPSHOT-grib-plugin.zip target/release/geoserver-2.16-SNAPSHOT-h2-plugin.zip target/release/geoserver-2.16-SNAPSHOT-imagemap-plugin.zip target/release/geoserver-2.16-SNAPSHOT-imagemosaic-jdbc-plugin.zip target/release/geoserver-2.16-SNAPSHOT-importer-bdb-plugin.zip target/release/geoserver-2.16-SNAPSHOT-importer-plugin.zip target/release/geoserver-2.16-SNAPSHOT-inspire-plugin.zip target/release/geoserver-2.16-SNAPSHOT-jp2k-plugin.zip target/release/geoserver-2.16-SNAPSHOT-libjpeg-turbo-plugin.zip target/release/geoserver-2.16-SNAPSHOT-mongodb-plugin.zip target/release/geoserver-2.16-SNAPSHOT-monitor-plugin.zip target/release/geoserver-2.16-SNAPSHOT-mysql-plugin.zip target/release/geoserver-2.16-SNAPSHOT-netcdf-out-plugin.zip target/release/geoserver-2.16-SNAPSHOT-netcdf-plugin.zip target/release/geoserver-2.16-SNAPSHOT-ogr-wfs-plugin.zip target/release/geoserver-2.16-SNAPSHOT-ogr-wps-plugin.zip target/release/geoserver-2.16-SNAPSHOT-oracle-plugin.zip target/release/geoserver-2.16-SNAPSHOT-printing-plugin.zip target/release/geoserver-2.16-SNAPSHOT-pyramid-plugin.zip target/release/geoserver-2.16-SNAPSHOT-querylayer-plugin.zip target/release/geoserver-2.16-SNAPSHOT-sldservice-plugin.zip target/release/geoserver-2.16-SNAPSHOT-sqlserver-plugin.zip target/release/geoserver-2.16-SNAPSHOT-teradata-plugin.zip target/release/geoserver-2.16-SNAPSHOT-vectortiles-plugin.zip target/release/geoserver-2.16-SNAPSHOT-wcs2_0-eo-plugin.zip target/release/geoserver-2.16-SNAPSHOT-wps-cluster-hazelcast-plugin.zip target/release/geoserver-2.16-SNAPSHOT-wps-plugin.zip target/release/geoserver-2.16-SNAPSHOT-xslt-plugin.zip target/release/geoserver-2.16-SNAPSHOT-ysld-plugin.zip ../nightly/master/ext-2019-06-29
+ rm -rf ../nightly/master/ext-latest
+ mkdir ../nightly/master/ext-latest
+ cp target/release/geoserver-2.16-SNAPSHOT-app-schema-plugin.zip target/release/geoserver-2.16-SNAPSHOT-arcsde-plugin.zip target/release/geoserver-2.16-SNAPSHOT-cas-plugin.zip target/release/geoserver-2.16-SNAPSHOT-charts-plugin.zip target/release/geoserver-2.16-SNAPSHOT-control-flow-plugin.zip target/release/geoserver-2.16-SNAPSHOT-css-plugin.zip target/release/geoserver-2.16-SNAPSHOT-csw-plugin.zip target/release/geoserver-2.16-SNAPSHOT-db2-plugin.zip target/release/geoserver-2.16-SNAPSHOT-dxf-plugin.zip target/release/geoserver-2.16-SNAPSHOT-excel-plugin.zip target/release/geoserver-2.16-SNAPSHOT-feature-pregeneralized-plugin.zip target/release/geoserver-2.16-SNAPSHOT-gdal-plugin.zip target/release/geoserver-2.16-SNAPSHOT-geofence-plugin.zip target/release/geoserver-2.16-SNAPSHOT-geofence-server-plugin.zip target/release/geoserver-2.16-SNAPSHOT-grib-plugin.zip target/release/geoserver-2.16-SNAPSHOT-h2-plugin.zip target/release/geoserver-2.16-SNAPSHOT-imagemap-plugin.zip target/release/geoserver-2.16-SNAPSHOT-imagemosaic-jdbc-plugin.zip target/release/geoserver-2.16-SNAPSHOT-importer-bdb-plugin.zip target/release/geoserver-2.16-SNAPSHOT-importer-plugin.zip target/release/geoserver-2.16-SNAPSHOT-inspire-plugin.zip target/release/geoserver-2.16-SNAPSHOT-jp2k-plugin.zip target/release/geoserver-2.16-SNAPSHOT-libjpeg-turbo-plugin.zip target/release/geoserver-2.16-SNAPSHOT-mongodb-plugin.zip target/release/geoserver-2.16-SNAPSHOT-monitor-plugin.zip target/release/geoserver-2.16-SNAPSHOT-mysql-plugin.zip target/release/geoserver-2.16-SNAPSHOT-netcdf-out-plugin.zip target/release/geoserver-2.16-SNAPSHOT-netcdf-plugin.zip target/release/geoserver-2.16-SNAPSHOT-ogr-wfs-plugin.zip target/release/geoserver-2.16-SNAPSHOT-ogr-wps-plugin.zip target/release/geoserver-2.16-SNAPSHOT-oracle-plugin.zip target/release/geoserver-2.16-SNAPSHOT-printing-plugin.zip target/release/geoserver-2.16-SNAPSHOT-pyramid-plugin.zip target/release/geoserver-2.16-SNAPSHOT-querylayer-plugin.zip target/release/geoserver-2.16-SNAPSHOT-sldservice-plugin.zip target/release/geoserver-2.16-SNAPSHOT-sqlserver-plugin.zip target/release/geoserver-2.16-SNAPSHOT-teradata-plugin.zip target/release/geoserver-2.16-SNAPSHOT-vectortiles-plugin.zip target/release/geoserver-2.16-SNAPSHOT-wcs2_0-eo-plugin.zip target/release/geoserver-2.16-SNAPSHOT-wps-cluster-hazelcast-plugin.zip target/release/geoserver-2.16-SNAPSHOT-wps-plugin.zip target/release/geoserver-2.16-SNAPSHOT-xslt-plugin.zip target/release/geoserver-2.16-SNAPSHOT-ysld-plugin.zip ../nightly/master/ext-latest
+ cp community/target/release/geoserver-2.16-SNAPSHOT-activeMQ-broker-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-authkey-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-backup-restore-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-colormap-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-dds-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-dyndimension-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gdal-wcs-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gdal-wps-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-geopkg-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-geostyler-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gpx-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gwc-distributed-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gwc-s3-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gwc-sqlite-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-hz-cluster-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-jdbc-metrics-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-jdbcconfig-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-jdbcstore-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-jms-cluster-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-kmlppio-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-mapml-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-mbstyle-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-mbtiles-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-ncwms-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-netcdf-ghrsst-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-notification-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-nsg-wfs-profile-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-nsg-wmts-profile-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-ogcapi-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-ogr-datastore-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-opensearch-eo-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-ows-simulate-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-params-extractor-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-pgraster-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-python-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-qos-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-s3-geotiff-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-saml-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-sec-keycloak-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-sec-oauth2-geonode-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-sec-oauth2-github-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-sec-oauth2-google-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-sec-oauth2-openid-connect-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-solr-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-status-monitoring-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-taskmanager-core-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-taskmanager-s3-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-web-resource-browser-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wfs3-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wms-eo-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wmts-multi-dimensional-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wmts-styles-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wps-download-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wps-jdbc-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wps-remote-plugin.zip ../nightly/master/community-2019-06-29
+ rm -rf ../nightly/master/community-latest
+ mkdir ../nightly/master/community-latest
+ cp community/target/release/geoserver-2.16-SNAPSHOT-activeMQ-broker-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-authkey-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-backup-restore-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-colormap-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-dds-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-dyndimension-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gdal-wcs-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gdal-wps-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-geopkg-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-geostyler-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gpx-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gwc-distributed-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gwc-s3-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gwc-sqlite-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-hz-cluster-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-jdbc-metrics-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-jdbcconfig-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-jdbcstore-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-jms-cluster-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-kmlppio-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-mapml-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-mbstyle-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-mbtiles-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-ncwms-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-netcdf-ghrsst-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-notification-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-nsg-wfs-profile-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-nsg-wmts-profile-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-ogcapi-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-ogr-datastore-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-opensearch-eo-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-ows-simulate-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-params-extractor-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-pgraster-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-python-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-qos-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-s3-geotiff-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-saml-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-sec-keycloak-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-sec-oauth2-geonode-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-sec-oauth2-github-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-sec-oauth2-google-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-sec-oauth2-openid-connect-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-solr-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-status-monitoring-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-taskmanager-core-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-taskmanager-s3-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-web-resource-browser-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wfs3-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wms-eo-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wmts-multi-dimensional-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wmts-styles-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wps-download-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wps-jdbc-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wps-remote-plugin.zip ../nightly/master/community-latest
+ echo Done
Done
$ ssh-agent -k
unset SSH_AUTH_SOCK;
unset SSH_AGENT_PID;
echo Agent pid 25889 killed;
[ssh-agent] Stopped.
Archiving artifacts
ERROR: Step ‘Archive the artifacts’ aborted due to exception:
java.io.IOException: No space left on device
at sun.nio.ch.FileDispatcherImpl.write0(Native Method)
at sun.nio.ch.FileDispatcherImpl.write(FileDispatcherImpl.java:60)
at sun.nio.ch.IOUtil.writeFromNativeBuffer(IOUtil.java:93)
at sun.nio.ch.IOUtil.write(IOUtil.java:65)
at sun.nio.ch.FileChannelImpl.write(FileChannelImpl.java:211)
at java.nio.channels.Channels.writeFullyImpl(Channels.java:78)
at java.nio.channels.Channels.writeFully(Channels.java:101)
at java.nio.channels.Channels.access$000(Channels.java:61)
at java.nio.channels.Channels$1.write(Channels.java:174)
at org.apache.commons.io.IOUtils.copyLarge(IOUtils.java:2315)
at org.apache.commons.io.IOUtils.copy(IOUtils.java:2270)
at org.apache.commons.io.IOUtils.copyLarge(IOUtils.java:2291)
at org.apache.commons.io.IOUtils.copy(IOUtils.java:2246)
at hudson.util.IOUtils.copy(IOUtils.java:43)
at hudson.FilePath.readFromTar(FilePath.java:2579)
Also: Also: hudson.remoting.Channel$CallSiteStackTrace: Remote call to i-01adc278a02b76ff7
at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1743)
at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:357)
at hudson.remoting.Channel$2.adapt(Channel.java:992)
at hudson.remoting.Channel$2.adapt(Channel.java:988)
at hudson.remoting.FutureAdapter.get(FutureAdapter.java:59)
at hudson.FilePath.copyRecursiveTo(FilePath.java:2382)
at jenkins.model.StandardArtifactManager.archive(StandardArtifactManager.java:61)
at hudson.tasks.ArtifactArchiver.perform(ArtifactArchiver.java:235)
at hudson.tasks.BuildStepCompatibilityLayer.perform(BuildStepCompatibilityLayer.java:81)
at hudson.tasks.BuildStepMonitor$1.perform(BuildStepMonitor.java:20)
at hudson.model.AbstractBuild$AbstractBuildExecution.perform(AbstractBuild.java:744)
at hudson.model.AbstractBuild$AbstractBuildExecution.performAllBuildSteps(AbstractBuild.java:690)
at hudson.model.Build$BuildExecution.post2(Build.java:186)
at hudson.model.AbstractBuild$AbstractBuildExecution.post(AbstractBuild.java:635)
at hudson.model.Run.execute(Run.java:1841)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
at hudson.model.ResourceController.execute(ResourceController.java:97)
at hudson.model.Executor.run(Executor.java:429)
java.io.IOException: This archives contains unclosed entries.
at org.apache.commons.compress.archivers.tar.TarArchiveOutputStream.finish(TarArchiveOutputStream.java:225)
at org.apache.commons.compress.archivers.tar.TarArchiveOutputStream.close(TarArchiveOutputStream.java:241)
at hudson.util.io.TarArchiver.close(TarArchiver.java:127)
at hudson.FilePath.writeToTar(FilePath.java:2549)
at hudson.FilePath.access$4000(FilePath.java:210)
at hudson.FilePath$CopyRecursiv
Uh oh, looks like the build server is in trouble, it’s disk space related again,
see the error below:
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
See <https://build.geoserver.org/job/geoserver-master-nightly/3093/display/redirect?page=changes>
Changes:
[Andrea Aime] Switching to openjdk11 for Travis
[INFO] WFS 3 prototype .................................... SUCCESS [ 1.133 s]
[INFO] MapML Support for GeoServer ........................ SUCCESS [ 0.824 s]
[INFO] S3 Geotiff Support ................................. SUCCESS [ 0.388 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 0.694 s]
[INFO] GeoServer Task Manager ............................. SUCCESS [ 0.024 s]
[INFO] GeoServer Task Manager Core ........................ SUCCESS [ 2.311 s]
[INFO] GeoServer Task Manager S3 .......................... SUCCESS [ 0.553 s]
[INFO] GeoServer Quality of Service GetCapabilities module SUCCESS [ 1.064 s]
[INFO] OGR datastore panel ................................ SUCCESS [ 0.769 s]
[INFO] gs-ogcapi .......................................... SUCCESS [ 1.080 s]
[INFO] GeoStyler community module ......................... SUCCESS [ 0.636 s]
[INFO] GeoServer Community Release Module ................. SUCCESS [ 0.464 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 0.559 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 0.405 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 0.643 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.191 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 0.624 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 0.139 s]
[INFO] OGR WFS ............................................ SUCCESS [ 0.601 s]
[INFO] OGR WPS ............................................ SUCCESS [ 0.466 s]
[INFO] Excel Output Format ................................ SUCCESS [ 0.419 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.028 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.373 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.026 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 0.558 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 0.787 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 1.029 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 0.425 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.523 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.026 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 1.013 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 0.510 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.030 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.283 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 0.522 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 0.731 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.027 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 1.213 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 0.438 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 0.839 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 0.450 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 0.430 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 0.437 s]
[INFO] Printing Module .................................... SUCCESS [ 0.521 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.019 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 0.621 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 0.630 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 0.532 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 0.867 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 0.497 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 0.828 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 0.695 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.423 s]
[INFO] REST SLD service ................................... SUCCESS [ 0.997 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 0.921 s]
[INFO] GeoFence Server .................................... SUCCESS [ 0.897 s]
[INFO] GeoServer Release Module ........................... SUCCESS [ 0.364 s]
[INFO] Finished at: 2019-06-30T01:03:22Z
[INFO]
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geoserver/gs-platform/2.16-SNAPSHOT/maven-metadata.xml (1.4 kB at 5.2 kB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-main/22-SNAPSHOT/maven-metadata.xml (1.2 kB at 35 kB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/library/22-SNAPSHOT/maven-metadata.xml (594 B at 23 kB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/modules/22-SNAPSHOT/maven-metadata.xml (594 B at 23 kB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/geotools/22-SNAPSHOT/maven-metadata.xml (595 B at 25 kB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-referencing/22-SNAPSHOT/maven-metadata.xml (1.2 kB at 31 kB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-metadata/22-SNAPSHOT/maven-metadata.xml (983 B at 39 kB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-opengis/22-SNAPSHOT/maven-metadata.xml (982 B at 32 kB/s)
[INFO]
[INFO] Total time: 11.618 s
[INFO] Finished at: 2019-06-30T01:03:35Z
[geoserver-master] $ /bin/sh -xe /tmp/jenkins8799845711507339336.sh
+ ver=origin/master
+ ver=master
+ date +%Y-%m-%d
+ datestamp=2019-06-30
+ cd src
+ cp target/release/geoserver-2.16-SNAPSHOT-war.zip ../nightly/master/geoserver-master-2019-06-30-war.zip
+ cp target/release/geoserver-2.16-SNAPSHOT-bin.zip ../nightly/master/geoserver-master-2019-06-30-bin.zip
+ [ ! -e ../nightly/master/ext-2019-06-30 ]
+ mkdir ../nightly/master/ext-2019-06-30
+ [ ! -e ../nightly/master/community-2019-06-30 ]
+ mkdir ../nightly/master/community-2019-06-30
+ cp target/release/geoserver-2.16-SNAPSHOT-app-schema-plugin.zip target/release/geoserver-2.16-SNAPSHOT-arcsde-plugin.zip target/release/geoserver-2.16-SNAPSHOT-cas-plugin.zip target/release/geoserver-2.16-SNAPSHOT-charts-plugin.zip target/release/geoserver-2.16-SNAPSHOT-control-flow-plugin.zip target/release/geoserver-2.16-SNAPSHOT-css-plugin.zip target/release/geoserver-2.16-SNAPSHOT-csw-plugin.zip target/release/geoserver-2.16-SNAPSHOT-db2-plugin.zip target/release/geoserver-2.16-SNAPSHOT-dxf-plugin.zip target/release/geoserver-2.16-SNAPSHOT-excel-plugin.zip target/release/geoserver-2.16-SNAPSHOT-feature-pregeneralized-plugin.zip target/release/geoserver-2.16-SNAPSHOT-gdal-plugin.zip target/release/geoserver-2.16-SNAPSHOT-geofence-plugin.zip target/release/geoserver-2.16-SNAPSHOT-geofence-server-plugin.zip target/release/geoserver-2.16-SNAPSHOT-grib-plugin.zip target/release/geoserver-2.16-SNAPSHOT-h2-plugin.zip target/release/geoserver-2.16-SNAPSHOT-imagemap-plugin.zip target/release/geoserver-2.16-SNAPSHOT-imagemosaic-jdbc-plugin.zip target/release/geoserver-2.16-SNAPSHOT-importer-bdb-plugin.zip target/release/geoserver-2.16-SNAPSHOT-importer-plugin.zip target/release/geoserver-2.16-SNAPSHOT-inspire-plugin.zip target/release/geoserver-2.16-SNAPSHOT-jp2k-plugin.zip target/release/geoserver-2.16-SNAPSHOT-libjpeg-turbo-plugin.zip target/release/geoserver-2.16-SNAPSHOT-mongodb-plugin.zip target/release/geoserver-2.16-SNAPSHOT-monitor-plugin.zip target/release/geoserver-2.16-SNAPSHOT-mysql-plugin.zip target/release/geoserver-2.16-SNAPSHOT-netcdf-out-plugin.zip target/release/geoserver-2.16-SNAPSHOT-netcdf-plugin.zip target/release/geoserver-2.16-SNAPSHOT-ogr-wfs-plugin.zip target/release/geoserver-2.16-SNAPSHOT-ogr-wps-plugin.zip target/release/geoserver-2.16-SNAPSHOT-oracle-plugin.zip target/release/geoserver-2.16-SNAPSHOT-printing-plugin.zip target/release/geoserver-2.16-SNAPSHOT-pyramid-plugin.zip target/release/geoserver-2.16-SNAPSHOT-querylayer-plugin.zip target/release/geoserver-2.16-SNAPSHOT-sldservice-plugin.zip target/release/geoserver-2.16-SNAPSHOT-sqlserver-plugin.zip target/release/geoserver-2.16-SNAPSHOT-teradata-plugin.zip target/release/geoserver-2.16-SNAPSHOT-vectortiles-plugin.zip target/release/geoserver-2.16-SNAPSHOT-wcs2_0-eo-plugin.zip target/release/geoserver-2.16-SNAPSHOT-wps-cluster-hazelcast-plugin.zip target/release/geoserver-2.16-SNAPSHOT-wps-plugin.zip target/release/geoserver-2.16-SNAPSHOT-xslt-plugin.zip target/release/geoserver-2.16-SNAPSHOT-ysld-plugin.zip ../nightly/master/ext-2019-06-30
+ cp community/target/release/geoserver-2.16-SNAPSHOT-activeMQ-broker-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-authkey-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-backup-restore-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-colormap-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-dds-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-dyndimension-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gdal-wcs-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gdal-wps-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-geopkg-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-geostyler-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gpx-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gwc-distributed-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gwc-s3-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gwc-sqlite-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-hz-cluster-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-jdbc-metrics-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-jdbcconfig-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-jdbcstore-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-jms-cluster-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-kmlppio-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-mapml-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-mbstyle-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-mbtiles-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-ncwms-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-netcdf-ghrsst-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-notification-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-nsg-wfs-profile-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-nsg-wmts-profile-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-ogcapi-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-ogr-datastore-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-opensearch-eo-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-ows-simulate-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-params-extractor-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-pgraster-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-python-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-qos-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-s3-geotiff-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-saml-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-sec-keycloak-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-sec-oauth2-geonode-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-sec-oauth2-github-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-sec-oauth2-google-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-sec-oauth2-openid-connect-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-solr-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-status-monitoring-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-taskmanager-core-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-taskmanager-s3-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-web-resource-browser-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wfs3-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wms-eo-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wmts-multi-dimensional-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wmts-styles-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wps-download-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wps-jdbc-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wps-remote-plugin.zip ../nightly/master/community-2019-06-30
+ echo Done
Done
$ ssh-agent -k
echo Agent pid 1006 killed;
Archiving artifacts
at hu
See <https://build.geoserver.org/job/geoserver-master-nightly/3095/display/redirect>
[INFO] GeoServer OAuth2 Connect Security Module - OpenId Connect SUCCESS [ 0.545 s]
[INFO] GeoServer Keycloak Security Plugin ................. SUCCESS [ 0.960 s]
[INFO] GeoServer SAMLv2 SSO Module ........................ SUCCESS [ 0.698 s]
[INFO] gs-notification-common ............................. SUCCESS [ 0.124 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 0.261 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 0.460 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 0.231 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.019 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 1.268 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 0.537 s]
[INFO] OpenSearch for EO REST configuration API ........... SUCCESS [ 0.903 s]
[INFO] GeoServer Status Monitoring Module ................. SUCCESS [ 0.943 s]
[INFO] NSG Profiles ....................................... SUCCESS [ 0.027 s]
[INFO] NSG WMTS 1.0 Profile ............................... SUCCESS [ 0.333 s]
[INFO] NSG WFS 2.0 Profile ................................ SUCCESS [ 0.970 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 1.079 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 1.242 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 1.240 s]
[INFO] NetCDF GHRSST encoder .............................. SUCCESS [ 0.721 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 0.786 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.030 s]
[INFO] Application Schema Integration Test ................ SUCCESS [ 1.481 s]
[INFO] WFS 3 prototype .................................... SUCCESS [ 1.421 s]
[INFO] MapML Support for GeoServer ........................ SUCCESS [ 1.349 s]
[INFO] S3 Geotiff Support ................................. SUCCESS [ 0.535 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 0.742 s]
[INFO] GeoServer Task Manager ............................. SUCCESS [ 0.034 s]
[INFO] GeoServer Task Manager Core ........................ SUCCESS [ 2.753 s]
[INFO] GeoServer Quality of Service GetCapabilities module SUCCESS [ 1.498 s]
[INFO] OGR datastore panel ................................ SUCCESS [ 0.750 s]
[INFO] gs-ogcapi .......................................... SUCCESS [ 1.162 s]
[INFO] GeoStyler community module ......................... SUCCESS [ 0.759 s]
[INFO] GeoServer Community Release Module ................. SUCCESS [ 0.658 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 0.686 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 0.524 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 0.854 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.073 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.096 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.193 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 0.904 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 0.157 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.205 s]
[INFO] OGR WFS ............................................ SUCCESS [ 0.463 s]
[INFO] OGR WPS ............................................ SUCCESS [ 0.937 s]
[INFO] Excel Output Format ................................ SUCCESS [ 0.661 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.025 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.420 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.036 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 0.890 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 0.893 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 1.287 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 0.718 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.584 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.050 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 1.173 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.028 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 0.596 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.112 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.589 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 0.941 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 0.796 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.029 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 1.676 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 0.551 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 1.111 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 0.586 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.019 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 0.592 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 0.503 s]
[INFO] Printing Module .................................... SUCCESS [ 0.567 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.023 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 0.947 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 0.507 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 0.488 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 0.772 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 0.498 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 0.840 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 0.774 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.569 s]
[INFO] REST SLD service ................................... SUCCESS [ 1.237 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 1.060 s]
[INFO] GeoServer Release Module ........................... SUCCESS [ 0.381 s]
[INFO] Total time: 03:12 min
[INFO] Finished at: 2019-07-01T02:36:07Z
[INFO]
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geoserver/gs-platform/2.16-SNAPSHOT/maven-metadata.xml (1.4 kB at 2.6 kB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geoserver/geoserver/2.16-SNAPSHOT/maven-metadata.xml (814 B at 30 kB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-main/22-SNAPSHOT/maven-metadata.xml (1.2 kB at 11 kB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/library/22-SNAPSHOT/maven-metadata.xml (594 B at 5.7 kB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/modules/22-SNAPSHOT/maven-metadata.xml (594 B at 5.4 kB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/geotools/22-SNAPSHOT/maven-metadata.xml (595 B at 5.5 kB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-referencing/22-SNAPSHOT/maven-metadata.xml (1.2 kB at 11 kB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-metadata/22-SNAPSHOT/maven-metadata.xml (983 B at 8.6 kB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-opengis/22-SNAPSHOT/maven-metadata.xml (982 B at 9.0 kB/s)
[INFO]
[INFO] Total time: 12.772 s
[INFO] Finished at: 2019-07-01T02:36:22Z
[geoserver-master] $ /bin/sh -xe /tmp/jenkins15275885348473086106.sh
+ ver=origin/master
+ ver=master
+ date +%Y-%m-%d
+ datestamp=2019-07-01
+ cd src
+ cp target/release/geoserver-2.16-SNAPSHOT-war.zip ../nightly/master/geoserver-master-2019-07-01-war.zip
+ cp target/release/geoserver-2.16-SNAPSHOT-bin.zip ../nightly/master/geoserver-master-2019-07-01-bin.zip
+ [ ! -e ../nightly/master/ext-2019-07-01 ]
+ mkdir ../nightly/master/ext-2019-07-01
+ [ ! -e ../nightly/master/community-2019-07-01 ]
+ mkdir ../nightly/master/community-2019-07-01
+ cp target/release/geoserver-2.16-SNAPSHOT-app-schema-plugin.zip target/release/geoserver-2.16-SNAPSHOT-arcsde-plugin.zip target/release/geoserver-2.16-SNAPSHOT-cas-plugin.zip target/release/geoserver-2.16-SNAPSHOT-charts-plugin.zip target/release/geoserver-2.16-SNAPSHOT-control-flow-plugin.zip target/release/geoserver-2.16-SNAPSHOT-css-plugin.zip target/release/geoserver-2.16-SNAPSHOT-csw-plugin.zip target/release/geoserver-2.16-SNAPSHOT-db2-plugin.zip target/release/geoserver-2.16-SNAPSHOT-dxf-plugin.zip target/release/geoserver-2.16-SNAPSHOT-excel-plugin.zip target/release/geoserver-2.16-SNAPSHOT-feature-pregeneralized-plugin.zip target/release/geoserver-2.16-SNAPSHOT-gdal-plugin.zip target/release/geoserver-2.16-SNAPSHOT-geofence-plugin.zip target/release/geoserver-2.16-SNAPSHOT-geofence-server-plugin.zip target/release/geoserver-2.16-SNAPSHOT-grib-plugin.zip target/release/geoserver-2.16-SNAPSHOT-h2-plugin.zip target/release/geoserver-2.16-SNAPSHOT-imagemap-plugin.zip target/release/geoserver-2.16-SNAPSHOT-imagemosaic-jdbc-plugin.zip target/release/geoserver-2.16-SNAPSHOT-importer-bdb-plugin.zip target/release/geoserver-2.16-SNAPSHOT-importer-plugin.zip target/release/geoserver-2.16-SNAPSHOT-inspire-plugin.zip target/release/geoserver-2.16-SNAPSHOT-jp2k-plugin.zip target/release/geoserver-2.16-SNAPSHOT-libjpeg-turbo-plugin.zip target/release/geoserver-2.16-SNAPSHOT-mongodb-plugin.zip target/release/geoserver-2.16-SNAPSHOT-monitor-plugin.zip target/release/geoserver-2.16-SNAPSHOT-mysql-plugin.zip target/release/geoserver-2.16-SNAPSHOT-netcdf-out-plugin.zip target/release/geoserver-2.16-SNAPSHOT-netcdf-plugin.zip target/release/geoserver-2.16-SNAPSHOT-ogr-wfs-plugin.zip target/release/geoserver-2.16-SNAPSHOT-ogr-wps-plugin.zip target/release/geoserver-2.16-SNAPSHOT-oracle-plugin.zip target/release/geoserver-2.16-SNAPSHOT-printing-plugin.zip target/release/geoserver-2.16-SNAPSHOT-pyramid-plugin.zip target/release/geoserver-2.16-SNAPSHOT-querylayer-plugin.zip target/release/geoserver-2.16-SNAPSHOT-sldservice-plugin.zip target/release/geoserver-2.16-SNAPSHOT-sqlserver-plugin.zip target/release/geoserver-2.16-SNAPSHOT-teradata-plugin.zip target/release/geoserver-2.16-SNAPSHOT-vectortiles-plugin.zip target/release/geoserver-2.16-SNAPSHOT-wcs2_0-eo-plugin.zip target/release/geoserver-2.16-SNAPSHOT-wps-cluster-hazelcast-plugin.zip target/release/geoserver-2.16-SNAPSHOT-wps-plugin.zip target/release/geoserver-2.16-SNAPSHOT-xslt-plugin.zip target/release/geoserver-2.16-SNAPSHOT-ysld-plugin.zip ../nightly/master/ext-2019-07-01
+ cp community/target/release/geoserver-2.16-SNAPSHOT-activeMQ-broker-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-authkey-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-backup-restore-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-colormap-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-dds-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-dyndimension-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gdal-wcs-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gdal-wps-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-geopkg-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-geostyler-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gpx-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gwc-distributed-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gwc-s3-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gwc-sqlite-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-hz-cluster-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-jdbc-metrics-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-jdbcconfig-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-jdbcstore-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-jms-cluster-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-kmlppio-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-mapml-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-mbstyle-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-mbtiles-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-ncwms-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-netcdf-ghrsst-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-notification-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-nsg-wfs-profile-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-nsg-wmts-profile-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-ogcapi-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-ogr-datastore-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-opensearch-eo-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-ows-simulate-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-params-extractor-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-pgraster-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-python-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-qos-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-s3-geotiff-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-saml-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-sec-keycloak-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-sec-oauth2-geonode-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-sec-oauth2-github-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-sec-oauth2-google-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-sec-oauth2-openid-connect-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-solr-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-status-monitoring-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-taskmanager-core-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-taskmanager-s3-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-web-resource-browser-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wfs3-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wms-eo-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wmts-multi-dimensional-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wmts-styles-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wps-download-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wps-jdbc-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wps-remote-plugin.zip ../nightly/master/community-2019-07-01
+ echo Done
Done
$ ssh-agent -k
echo Agent pid 26714 killed;
Archiving artifacts
See <https://build.geoserver.org/job/geoserver-master-nightly/3096/display/redirect>
[...truncated 1.75 MB...]
[INFO] OpenSearch for EO REST configuration API ........... SUCCESS [ 1.010 s]
[INFO] GeoServer Status Monitoring Module ................. SUCCESS [ 0.507 s]
[INFO] NSG Profiles ....................................... SUCCESS [ 0.016 s]
[INFO] NSG WMTS 1.0 Profile ............................... SUCCESS [ 0.287 s]
[INFO] NSG WFS 2.0 Profile ................................ SUCCESS [ 0.821 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 0.807 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 1.225 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 1.145 s]
[INFO] NetCDF GHRSST encoder .............................. SUCCESS [ 0.734 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 0.819 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.019 s]
[INFO] Application Schema Integration Test ................ SUCCESS [ 1.591 s]
[INFO] WFS 3 prototype .................................... SUCCESS [ 1.241 s]
[INFO] MapML Support for GeoServer ........................ SUCCESS [ 1.013 s]
[INFO] S3 Geotiff Support ................................. SUCCESS [ 0.427 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 0.580 s]
[INFO] GeoServer Task Manager Core ........................ SUCCESS [ 2.531 s]
[INFO] GeoServer Task Manager S3 .......................... SUCCESS [ 0.846 s]
[INFO] GeoServer Quality of Service GetCapabilities module SUCCESS [ 1.177 s]
[INFO] OGR datastore panel ................................ SUCCESS [ 0.883 s]
[INFO] gs-ogcapi .......................................... SUCCESS [ 1.148 s]
[INFO] GeoStyler community module ......................... SUCCESS [ 0.649 s]
[INFO] GeoServer Community Release Module ................. SUCCESS [ 0.542 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 0.715 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 0.387 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 0.802 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.037 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.037 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.033 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.189 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 0.609 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 0.252 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.251 s]
[INFO] OGR WFS ............................................ SUCCESS [ 0.599 s]
[INFO] OGR WPS ............................................ SUCCESS [ 0.814 s]
[INFO] Excel Output Format ................................ SUCCESS [ 0.583 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.044 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.380 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.030 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 0.552 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 0.581 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 1.094 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 0.383 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.414 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.029 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 1.115 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.027 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 0.676 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.028 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.275 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 0.567 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 0.829 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.028 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 0.979 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 0.437 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 0.793 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 0.476 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.018 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 0.450 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 0.430 s]
[INFO] Printing Module .................................... SUCCESS [ 0.679 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.017 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 0.662 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 0.503 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 0.496 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 0.891 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 0.595 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 1.147 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 0.994 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.392 s]
[INFO] REST SLD service ................................... SUCCESS [ 0.978 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 0.960 s]
[INFO] GeoFence Server .................................... SUCCESS [ 0.877 s]
[INFO] GeoServer Release Module ........................... SUCCESS [ 0.390 s]
[INFO] BUILD SUCCESS
[INFO] Total time: 03:04 min
[INFO] Finished at: 2019-07-01T09:47:09Z
[geoserver-master] $ mvn -f src/community/pom.xml -B -U assembly:attached
[INFO] Scanning for projects...
[INFO]
[INFO] ----------------------< org.geoserver:community >-----------------------
[INFO] Building Community Space 2.16-SNAPSHOT
[INFO] --------------------------------[ pom ]---------------------------------
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geoserver/gs-platform/2.16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geoserver/gs-platform/2.16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geoserver/gs-platform/2.16-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geoserver/gs-platform/2.16-SNAPSHOT/maven-metadata.xml (1.4 kB at 5.0 kB/s)
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geoserver/geoserver/2.16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geoserver/geoserver/2.16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geoserver/geoserver/2.16-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geoserver/geoserver/2.16-SNAPSHOT/maven-metadata.xml (814 B at 31 kB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/gt-main/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-main/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geotools/gt-main/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-main/22-SNAPSHOT/maven-metadata.xml (1.2 kB at 12 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/library/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/library/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geotools/library/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/library/22-SNAPSHOT/maven-metadata.xml (594 B at 6.0 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/modules/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/modules/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geotools/modules/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/modules/22-SNAPSHOT/maven-metadata.xml (594 B at 22 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/geotools/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/geotools/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geotools/geotools/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/geotools/22-SNAPSHOT/maven-metadata.xml (595 B at 5.7 kB/s)
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geotools/gt-referencing/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/gt-referencing/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-referencing/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-referencing/22-SNAPSHOT/maven-metadata.xml (1.2 kB at 12 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-metadata/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/gt-metadata/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geotools/gt-metadata/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-metadata/22-SNAPSHOT/maven-metadata.xml (983 B at 9.3 kB/s)
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geotools/gt-opengis/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-opengis/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/gt-opengis/22-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-opengis/22-SNAPSHOT/maven-metadata.xml (982 B at 8.9 kB/s)
[INFO]
[INFO] --- maven-assembly-plugin:2.1:attached (default-cli) @ community ---
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-authkey-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-jdbcconfig-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-dds-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-wms-eo-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-colormap-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-mbtiles-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-geopkg-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-pgraster-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-dyndimension-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-kmlppio-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-gpx-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-wps-download-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-jms-cluster-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-hz-cluster-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-activeMQ-broker-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-solr-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-gwc-distributed-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-gwc-s3-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-gdal-wcs-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-gdal-wps-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-wps-jdbc-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-params-extractor-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-wps-remote-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-python-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-jdbcstore-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-ncwms-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-gwc-sqlite-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-sec-oauth2-google-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-sec-oauth2-github-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-sec-oauth2-geonode-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-sec-oauth2-openid-connect-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-sec-keycloak-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-backup-restore-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-wmts-multi-dimensional-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-saml-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-notification-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-ows-simulate-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-jdbc-metrics-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-opensearch-eo-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-mbstyle-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-status-monitoring-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-nsg-wmts-profile-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-nsg-wfs-profile-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-taskmanager-core-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-taskmanager-s3-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-netcdf-ghrsst-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-wfs3-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-mapml-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-qos-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-web-resource-browser-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-s3-geotiff-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-wmts-styles-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-ogr-datastore-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-ogcapi-plugin.zip>
[INFO] Building zip: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/community/target/release/geoserver-2.16-SNAPSHOT-geostyler-plugin.zip>
[INFO] Total time: 11.684 s
[INFO] Finished at: 2019-07-01T09:47:22Z
[geoserver-master] $ /bin/sh -xe /tmp/jenkins5253971541083499848.sh
+ ver=origin/master
+ ver=master
+ dist=../nightly/master
+ date +%Y-%m-%d
+ cd src
+ mkdir -p ../nightly/master
+ cp target/release/geoserver-2.16-SNAPSHOT-war.zip ../nightly/master/geoserver-master-latest-war.zip
+ cp target/release/geoserver-2.16-SNAPSHOT-bin.zip ../nightly/master/geoserver-master-latest-bin.zip
+ rm -rf ../nightly/master/ext-latest
+ mkdir ../nightly/master/ext-latest
+ cp target/release/geoserver-2.16-SNAPSHOT-app-schema-plugin.zip target/release/geoserver-2.16-SNAPSHOT-arcsde-plugin.zip target/release/geoserver-2.16-SNAPSHOT-cas-plugin.zip target/release/geoserver-2.16-SNAPSHOT-charts-plugin.zip target/release/geoserver-2.16-SNAPSHOT-control-flow-plugin.zip target/release/geoserver-2.16-SNAPSHOT-css-plugin.zip target/release/geoserver-2.16-SNAPSHOT-csw-plugin.zip target/release/geoserver-2.16-SNAPSHOT-db2-plugin.zip target/release/geoserver-2.16-SNAPSHOT-dxf-plugin.zip target/release/geoserver-2.16-SNAPSHOT-excel-plugin.zip target/release/geoserver-2.16-SNAPSHOT-feature-pregeneralized-plugin.zip target/release/geoserver-2.16-SNAPSHOT-gdal-plugin.zip target/release/geoserver-2.16-SNAPSHOT-geofence-plugin.zip target/release/geoserver-2.16-SNAPSHOT-geofence-server-plugin.zip target/release/geoserver-2.16-SNAPSHOT-grib-plugin.zip target/release/geoserver-2.16-SNAPSHOT-h2-plugin.zip target/release/geoserver-2.16-SNAPSHOT-imagemap-plugin.zip target/release/geoserver-2.16-SNAPSHOT-imagemosaic-jdbc-plugin.zip target/release/geoserver-2.16-SNAPSHOT-importer-bdb-plugin.zip target/release/geoserver-2.16-SNAPSHOT-importer-plugin.zip target/release/geoserver-2.16-SNAPSHOT-inspire-plugin.zip target/release/geoserver-2.16-SNAPSHOT-jp2k-plugin.zip target/release/geoserver-2.16-SNAPSHOT-libjpeg-turbo-plugin.zip target/release/geoserver-2.16-SNAPSHOT-mongodb-plugin.zip target/release/geoserver-2.16-SNAPSHOT-monitor-plugin.zip target/release/geoserver-2.16-SNAPSHOT-mysql-plugin.zip target/release/geoserver-2.16-SNAPSHOT-netcdf-out-plugin.zip target/release/geoserver-2.16-SNAPSHOT-netcdf-plugin.zip target/release/geoserver-2.16-SNAPSHOT-ogr-wfs-plugin.zip target/release/geoserver-2.16-SNAPSHOT-ogr-wps-plugin.zip target/release/geoserver-2.16-SNAPSHOT-oracle-plugin.zip target/release/geoserver-2.16-SNAPSHOT-printing-plugin.zip target/release/geoserver-2.16-SNAPSHOT-pyramid-plugin.zip target/release/geoserver-2.16-SNAPSHOT-querylayer-plugin.zip target/release/geoserver-2.16-SNAPSHOT-sldservice-plugin.zip target/release/geoserver-2.16-SNAPSHOT-sqlserver-plugin.zip target/release/geoserver-2.16-SNAPSHOT-teradata-plugin.zip target/release/geoserver-2.16-SNAPSHOT-vectortiles-plugin.zip target/release/geoserver-2.16-SNAPSHOT-wcs2_0-eo-plugin.zip target/release/geoserver-2.16-SNAPSHOT-wps-cluster-hazelcast-plugin.zip target/release/geoserver-2.16-SNAPSHOT-wps-plugin.zip target/release/geoserver-2.16-SNAPSHOT-xslt-plugin.zip target/release/geoserver-2.16-SNAPSHOT-ysld-plugin.zip ../nightly/master/ext-latest
+ echo Done
Done
$ ssh-agent -k
echo Agent pid 24140 killed;
Archiving artifacts
See <https://build.geoserver.org/job/geoserver-master-nightly/3097/display/redirect?page=changes>
Changes:
[fernandomino7] [GEOS-9271] NullPointerException on WFS ComplexGeoJsonWriter Link check
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 0.644 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 0.745 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.218 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 1.256 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 0.890 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 0.452 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 0.795 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 1.674 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 0.988 s]
[INFO] GeoServer Mapbox Styling ........................... SUCCESS [ 0.747 s]
[INFO] WMTS Style editing extension ....................... SUCCESS [ 0.662 s]
[INFO] GeoServer Security Community Modules ............... SUCCESS [ 0.020 s]
[INFO] GeoServer OAuth2 Connect Security Module - Core .... SUCCESS [ 0.581 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 0.648 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 0.562 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 0.548 s]
[INFO] GeoServer OAuth2 Connect Security Module - OpenId Connect SUCCESS [ 0.587 s]
[INFO] GeoServer Keycloak Security Plugin ................. SUCCESS [ 0.584 s]
[INFO] GeoServer SAMLv2 SSO Module ........................ SUCCESS [ 0.818 s]
[INFO] gs-notification-common ............................. SUCCESS [ 0.103 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 0.228 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 0.520 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 0.215 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.024 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 1.201 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 0.755 s]
[INFO] OpenSearch for EO REST configuration API ........... SUCCESS [ 1.101 s]
[INFO] GeoServer Status Monitoring Module ................. SUCCESS [ 1.018 s]
[INFO] NSG Profiles ....................................... SUCCESS [ 0.017 s]
[INFO] NSG WMTS 1.0 Profile ............................... SUCCESS [ 0.280 s]
[INFO] NSG WFS 2.0 Profile ................................ SUCCESS [ 1.040 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 0.892 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 1.130 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 1.402 s]
[INFO] NetCDF GHRSST encoder .............................. SUCCESS [ 0.707 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 0.793 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.027 s]
[INFO] Application Schema Integration Test ................ SUCCESS [ 2.141 s]
[INFO] WFS 3 prototype .................................... SUCCESS [ 1.603 s]
[INFO] MapML Support for GeoServer ........................ SUCCESS [ 0.850 s]
[INFO] S3 Geotiff Support ................................. SUCCESS [ 0.508 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 0.988 s]
[INFO] GeoServer Task Manager ............................. SUCCESS [ 0.032 s]
[INFO] GeoServer Task Manager Core ........................ SUCCESS [ 2.909 s]
[INFO] GeoServer Task Manager S3 .......................... SUCCESS [ 0.565 s]
[INFO] GeoServer Quality of Service GetCapabilities module SUCCESS [ 1.388 s]
[INFO] OGR datastore panel ................................ SUCCESS [ 0.831 s]
[INFO] gs-ogcapi .......................................... SUCCESS [ 1.647 s]
[INFO] GeoStyler community module ......................... SUCCESS [ 1.268 s]
[INFO] GeoServer Community Release Module ................. SUCCESS [ 0.590 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 0.835 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 0.479 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 0.922 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.045 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.029 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.039 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.202 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 0.977 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 0.163 s]
[INFO] OGR WFS ............................................ SUCCESS [ 0.760 s]
[INFO] OGR WPS ............................................ SUCCESS [ 0.498 s]
[INFO] Excel Output Format ................................ SUCCESS [ 0.643 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.027 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.391 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.024 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 0.643 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 0.632 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 1.300 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 0.632 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.466 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.072 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 1.078 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.035 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 0.556 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.268 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 0.615 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.030 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 1.355 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 0.487 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 1.028 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 0.518 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 0.496 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 0.514 s]
[INFO] Printing Module .................................... SUCCESS [ 0.541 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.018 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 0.617 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 0.706 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 0.502 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 1.078 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 0.522 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 0.950 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 1.068 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.445 s]
[INFO] REST SLD service ................................... SUCCESS [ 1.176 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 1.064 s]
[INFO] GeoFence Server .................................... SUCCESS [ 1.058 s]
[INFO] GeoServer Release Module ........................... SUCCESS [ 0.426 s]
[INFO] Total time: 03:25 min
[INFO] Finished at: 2019-07-01T19:17:06Z
[INFO]
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geoserver/gs-platform/2.16-SNAPSHOT/maven-metadata.xml (1.4 kB at 4.0 kB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geoserver/geoserver/2.16-SNAPSHOT/maven-metadata.xml (814 B at 7.5 kB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-main/22-SNAPSHOT/maven-metadata.xml (1.2 kB at 34 kB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/library/22-SNAPSHOT/maven-metadata.xml (594 B at 19 kB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/modules/22-SNAPSHOT/maven-metadata.xml (594 B at 17 kB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/geotools/22-SNAPSHOT/maven-metadata.xml (595 B at 20 kB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-referencing/22-SNAPSHOT/maven-metadata.xml (1.2 kB at 37 kB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-metadata/22-SNAPSHOT/maven-metadata.xml (983 B at 34 kB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-opengis/22-SNAPSHOT/maven-metadata.xml (982 B at 35 kB/s)
[INFO]
[INFO] Total time: 12.385 s
[INFO] Finished at: 2019-07-01T19:17:20Z
[geoserver-master] $ /bin/sh -xe /tmp/jenkins2969479614360862165.sh
+ ver=origin/master
+ ver=master
+ date +%Y-%m-%d
+ cd src
+ rm -rf ../nightly/master/community-latest
+ mkdir ../nightly/master/community-latest
+ cp community/target/release/geoserver-2.16-SNAPSHOT-activeMQ-broker-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-authkey-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-backup-restore-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-colormap-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-dds-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-dyndimension-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gdal-wcs-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gdal-wps-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-geopkg-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-geostyler-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gpx-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gwc-distributed-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gwc-s3-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-gwc-sqlite-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-hz-cluster-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-jdbc-metrics-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-jdbcconfig-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-jdbcstore-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-jms-cluster-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-kmlppio-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-mapml-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-mbstyle-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-mbtiles-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-ncwms-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-netcdf-ghrsst-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-notification-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-nsg-wfs-profile-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-nsg-wmts-profile-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-ogcapi-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-ogr-datastore-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-opensearch-eo-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-ows-simulate-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-params-extractor-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-pgraster-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-python-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-qos-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-s3-geotiff-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-saml-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-sec-keycloak-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-sec-oauth2-geonode-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-sec-oauth2-github-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-sec-oauth2-google-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-sec-oauth2-openid-connect-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-solr-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-status-monitoring-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-taskmanager-core-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-taskmanager-s3-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-web-resource-browser-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wfs3-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wms-eo-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wmts-multi-dimensional-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wmts-styles-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wps-download-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wps-jdbc-plugin.zip community/target/release/geoserver-2.16-SNAPSHOT-wps-remote-plugin.zip ../nightly/master/community-latest
+ echo Done
Done
$ ssh-agent -k
unset SSH_AUTH_SOCK;
unset SSH_AGENT_PID;
echo Agent pid 29529 killed;
[ssh-agent] Stopped.
Archiving artifacts
ERROR: Step ‘Archive the artifacts’ aborted due to exception:
java.io.IOException: No space left on device
at sun.nio.ch.FileDispatcherImpl.write0(Native Method)
at sun.nio.ch.FileDispatcherImpl.write(FileDispatcherImpl.java:60)
at sun.nio.ch.IOUtil.writeFromNativeBuffer(IOUtil.java:93)
at sun.nio.ch.IOUtil.write(IOUtil.java:65)
at sun.nio.ch.FileChannelImpl.write(FileChann
That might be a problem on the master this time - I’ll look into it.
We might need to reduce/configure how long archived artifacts are stored.
Torben
On Sat, Jun 29, 2019 at 5:35 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
Uh oh, looks like the build server is in trouble, it’s disk space related again,
see the error below:
On Sat, Jun 29, 2019 at 2:03 PM Jenkins <gtbuildergh@anonymised.com> wrote:
$ ssh-agent -k
echo Agent pid 25889 killed;
Archiving artifacts
at sun.nio.ch.FileChannelImpl.write(FileChannelImpl.java:211)
at java.nio.channels.Channels.writeFullyImpl(Channels.java:78)
at java.nio.channels.Channels.writeFully(Channels.java:101)
at java.nio.channels.Channels.access$000(Channels.java:61)
at java.nio.channels.Channels$1.write(Channels.java:174)
at org.apache.commons.io.IOUtils.copyLarge(IOUtils.java:2315)
at org.apache.commons.io.IOUtils.copy(IOUtils.java:2270)
at org.apache.commons.io.IOUtils.copyLarge(IOUtils.java:2291)
at org.apache.commons.io.IOUtils.copy(IOUtils.java:2246)
at hudson.util.IOUtils.copy(IOUtils.java:43)
at hudson.FilePath.readFromTar(FilePath.java:2579)
Also: Also: hudson.remoting.Channel$CallSiteStackTrace: Remote call to i-01adc278a02b76ff7
at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1743)
at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:357)
at hudson.remoting.Channel$2.adapt(Channel.java:992)
at hudson.remoting.Channel$2.adapt(Channel.java:988)
at hudson.remoting.FutureAdapter.get(FutureAdapter.java:59)
at hudson.FilePath.copyRecursiveTo(FilePath.java:2382)
at jenkins.model.StandardArtifactManager.archive(StandardArtifactManager.java:61)
at hudson.tasks.ArtifactArchiver.perform(ArtifactArchiver.java:235)
at hudson.tasks.BuildStepCompatibilityLayer.perform(BuildStepCompatibilityLayer.java:81)
at hudson.tasks.BuildStepMonitor$1.perform(BuildStepMonitor.java:20)
at hudson.model.AbstractBuild$AbstractBuildExecution.perform(AbstractBuild.java:744)
at hudson.model.AbstractBuild$AbstractBuildExecution.performAllBuildSteps(AbstractBuild.java:690)
at hudson.model.Build$BuildExecution.post2(Build.java:186)
at hudson.model.AbstractBuild$AbstractBuildExecution.post(AbstractBuild.java:635)
at hudson.model.Run.execute(Run.java:1841)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
at hudson.model.ResourceController.execute(ResourceController.java:97)
at hudson.model.Executor.run(Executor.java:429)
java.io.IOException: This archives contains unclosed entries.
at org.apache.commons.compress.archivers.tar.TarArchiveOutputStream.finish(TarArchiveOutputStream.java:225)
at org.apache.commons.compress.archivers.tar.TarArchiveOutputStream.close(TarArchiveOutputStream.java:241)
at hudson.util.io.TarArchiver.close(TarArchiver.java:127)
at hudson.FilePath.writeToTar(FilePath.java:2549)
at hudson.FilePath.access$4000(FilePath.java:210)
at hudson.FilePath$CopyRecursiv
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
It was indeed an issue on master - there was about 200 G of archived nightly build artifacts. I’ve cleared out some old artifacts, and set more strict restrictions on how long to keep them for future builds so this shouldn’t be an issue in the future.
Torben
On Tue, Jul 2, 2019 at 9:21 AM Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
$ ssh-agent -k
Archiving artifacts
