[jody.garnett] c) 2014 Open Source Geospatial Foundation (GSIP-118)
[jody.garnett] Missed a few (GSIP-118)
[jody.garnett] Change instructions for OSGeo license, headers and use of GitHub for docs
[gabriel.roldan] Restore "Make GWCLifeCycleHandler behave correctly on application shutdown."
[jody.garnett] A few more references to openplans
Started by timer
Building in workspace <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/>
Checkout:geoserver-master / <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/> - hudson.remoting.LocalChannel@anonymised.com
Using strategy: Default
Last Built Revision: Revision 87ecb035dd45e5a56d051f704c1af47421b46bbf (origin/master)
Fetching changes from 1 remote Git repository
Fetching upstream changes from origin
Commencing build of Revision a087c4a523d167cbc4d82a62a0cade7f56729d04 (origin/master)
Checking out Revision a087c4a523d167cbc4d82a62a0cade7f56729d04 (origin/master)
[geoserver-master] $ /bin/sh -xe /tmp/hudson2745454466188553867.sh
+ ver=master
+ dist=/var/www/geoserver/master
+ date +%Y-%m-%d
+ datestamp=2014-09-05
+ mvn=/opt/apache-maven-2.2.1/bin/mvn
+ cd src
+ /opt/apache-maven-2.2.1/bin/mvn -DskipTests -Dbuild.hudsonId=366 -P release,communityRelease clean install
Error: Could not find or load main class org.codehaus.classworlds.Launcher
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/master/geoserver-master-2014-09-05-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
Build step 'Execute shell' marked build as failure
[damianofds] [GEOS-6645] NPE when trying to reload bands with empty range
[alessio.fabiani] - A GPX PPIO for WPS
[alessio.fabiani] - A KML PPIO for WPS
[simone.giannecchini] fixing community release
[simone.giannecchini] addin kml to community release
[strk] Update postgis website to postgis.net
Started by timer
Last Built Revision: Revision a087c4a523d167cbc4d82a62a0cade7f56729d04 (origin/master)
Commencing build of Revision d58cabd6d6cd1a2a68dd94a66a6a23d33c0790c4 (origin/master)
Checking out Revision d58cabd6d6cd1a2a68dd94a66a6a23d33c0790c4 (origin/master)
[geoserver-master] $ /bin/sh -xe /tmp/hudson2028060438987028690.sh
+ ver=master
+ date +%Y-%m-%d
+ datestamp=2014-09-06
+ cd src
+ /opt/apache-maven-2.2.1/bin/mvn -DskipTests -Dbuild.hudsonId=367 -P release,communityRelease clean install
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/master/geoserver-master-2014-09-06-bin.zip
Started by timer
Last Built Revision: Revision d58cabd6d6cd1a2a68dd94a66a6a23d33c0790c4 (origin/master)
[geoserver-master] $ /bin/sh -xe /tmp/hudson267742335648212064.sh
+ ver=master
+ date +%Y-%m-%d
+ datestamp=2014-09-07
+ cd src
+ /opt/apache-maven-2.2.1/bin/mvn -DskipTests -Dbuild.hudsonId=368 -P release,communityRelease clean install
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/master/geoserver-master-2014-09-07-bin.zip
Started by timer
[geoserver-master] $ /bin/sh -xe /tmp/hudson4643181721780590653.sh
+ ver=master
+ date +%Y-%m-%d
+ datestamp=2014-09-08
+ cd src
+ /opt/apache-maven-2.2.1/bin/mvn -DskipTests -Dbuild.hudsonId=369 -P release,communityRelease clean install
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/master/geoserver-master-2014-09-08-bin.zip
Started by timer
[geoserver-master] $ /bin/sh -xe /tmp/hudson7741783393711933599.sh
+ ver=master
+ date +%Y-%m-%d
+ datestamp=2014-09-09
+ cd src
+ /opt/apache-maven-2.2.1/bin/mvn -DskipTests -Dbuild.hudsonId=370 -P release,communityRelease clean install
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/master/geoserver-master-2014-09-09-bin.zip
Started by timer
[geoserver-master] $ /bin/sh -xe /tmp/hudson5033686982541864452.sh
+ ver=master
+ date +%Y-%m-%d
+ datestamp=2014-09-10
+ cd src
+ /opt/apache-maven-2.2.1/bin/mvn -DskipTests -Dbuild.hudsonId=371 -P release,communityRelease clean install
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/master/geoserver-master-2014-09-10-bin.zip
Started by timer
[geoserver-master] $ /bin/sh -xe /tmp/hudson66629216938650160.sh
+ ver=master
+ date +%Y-%m-%d
+ datestamp=2014-09-11
+ cd src
+ /opt/apache-maven-2.2.1/bin/mvn -DskipTests -Dbuild.hudsonId=372 -P release,communityRelease clean install
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/master/geoserver-master-2014-09-11-bin.zip
[damianofds] GEOS-6658 and a minor fix on the bound generator
[damianofds] [GEOS-6695] GeoPackageProcess should support the configuration of an external file
Started by timer
Commencing build of Revision 31bb8a1bde53066b4166ee588bd3a788d38906ed (origin/master)
Checking out Revision 31bb8a1bde53066b4166ee588bd3a788d38906ed (origin/master)
[geoserver-master] $ /bin/sh -xe /tmp/hudson5575151196177264043.sh
+ ver=master
+ date +%Y-%m-%d
+ datestamp=2014-09-12
+ cd src
+ /opt/apache-maven-2.2.1/bin/mvn -DskipTests -Dbuild.hudsonId=373 -P release,communityRelease clean install
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/master/geoserver-master-2014-09-12-bin.zip
Started by timer
Last Built Revision: Revision 31bb8a1bde53066b4166ee588bd3a788d38906ed (origin/master)
Commencing build of Revision 016c97fe5e7c5128ab5afd3f560cdfa3aaec986c (origin/master)
Checking out Revision 016c97fe5e7c5128ab5afd3f560cdfa3aaec986c (origin/master)
[geoserver-master] $ /bin/sh -xe /tmp/hudson1371665754520097518.sh
+ ver=master
+ date +%Y-%m-%d
+ datestamp=2014-09-13
+ cd src
+ /opt/apache-maven-2.2.1/bin/mvn -DskipTests -Dbuild.hudsonId=374 -P release,communityRelease clean install
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/master/geoserver-master-2014-09-13-bin.zip
