[Geoserver-devel] Build failed in Jenkins: geoserver-master-nightly #3780
See <https://build.geoserver.org/job/geoserver-master-nightly/3780/display/redirect&gt;
[...truncated 284.25 KB...]
[INFO] Copying 87 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-core ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 143 source files to <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/security/core/target/classes&gt;
[INFO] <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/security/core/src/main/java/org/geoserver/security/web/SecurityNamedServicePanel.java&gt;: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/security/core/src/main/java/org/geoserver/security/web/SecurityNamedServicePanel.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-sec-core ---
[INFO] Copying 4 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/security/core/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-core ---
[INFO] Compiling 44 source files to <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/security/core/target/test-classes&gt;
[INFO] <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/security/core/src/test/java/org/geoserver/security/web/AbstractSecurityWicketTestSupport.java&gt;: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/security/core/src/test/java/org/geoserver/security/web/AbstractSecurityWicketTestSupport.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-sec-core ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-sec-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/security/core/target/gs-web-sec-core-2.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/security/core/target/gs-web-sec-core-2.17-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/security/core/target/gs-web-sec-core-2.17-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/security/core/target/gs-web-sec-core-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-web-sec-core ---
[INFO] Copying gt-main-23-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/security/core/target/dependency/gt-main-23-SNAPSHOT.jar&gt;
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary for GeoServer 2.17-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 4.920 s]
[INFO] Core Platform Module ............................... SUCCESS [ 3.044 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 3.369 s]
[INFO] Main Module ........................................ SUCCESS [ 14.485 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.061 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [ 1.222 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 0.698 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 0.900 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.665 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 1.518 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 1.272 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 1.566 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 3.409 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 6.218 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 1.260 s]
[INFO] gs-rest ............................................ SUCCESS [ 0.740 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 3.669 s]
[INFO] gs-restconfig ...................................... SUCCESS [ 2.005 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 0.840 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 0.719 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 0.569 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.022 s]
[INFO] Core UI Module ..................................... SUCCESS [ 5.615 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 1.305 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 1.524 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 0.637 s]
[INFO] Demos Module ....................................... SUCCESS [ 1.496 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 0.798 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.040 s]
[INFO] Security UI Core Module ............................ FAILURE [ 2.098 s]
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Community Space .................................... SKIPPED
[INFO] WorldWind Format Module ............................ SKIPPED
[INFO] GeoServer JDBC KV Catalog .......................... SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] GeoServer Scripting Extensions ..................... SKIPPED
[INFO] Core Scripting Extension ........................... SKIPPED
[INFO] Web UI Scripting Extension ......................... SKIPPED
[INFO] BeanShell Scripting Extension ...................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] Python Scripting Extension ......................... SKIPPED
[INFO] WMS-EO ............................................. SKIPPED
[INFO] ColorMap ........................................... SKIPPED
[INFO] GeoServer mbtiles Extension ........................ SKIPPED
[INFO] GeoServer GeoPackage Extension ..................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults ............... SKIPPED
[INFO] GPX PPIO for WPS ................................... SKIPPED
[INFO] KML PPIO for WPS ................................... SKIPPED
[INFO] DownloadProcess .................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............. SKIPPED
[INFO] ActiveMQ ........................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ............ SKIPPED
[INFO] GeoServer JMS clustering module .................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module .............. SKIPPED
[INFO] Solr Module ........................................ SKIPPED
[INFO] Parameters Extractor ............................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Web Processing Service - Remote processes invocation SKIPPED
[INFO] WPS cluster on jdbc datastores ..................... SKIPPED
[INFO] ncWMS compatibility extension ...................... SKIPPED
[INFO] GWC Distributed Caching Plugin ..................... SKIPPED
[INFO] GeoWebCache S3 ..................................... SKIPPED
[INFO] GeoWebCache Azure blob ............................. SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] GDAL translate parent .............................. SKIPPED
[INFO] GDAL translate WCS ................................. SKIPPED
[INFO] GDAL translate WPS ................................. SKIPPED
[INFO] GeoServer JDBC Configuration Resource Store ........ SKIPPED
[INFO] GeoWebCache SQLite ................................. SKIPPED
[INFO] GeoServer Config Backup And Restore ................ SKIPPED
[INFO] GeoServer Config Backup And Restore Core Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore REST Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore Extensions ..... SKIPPED
[INFO] GeoServer Config Backup And Restore Web UI Module .. SKIPPED
[INFO] WMTS Multi Dimensional ............................. SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] GeoServer Mapbox Styling ........................... SKIPPED
[INFO] WMTS Style editing extension ....................... SKIPPED
[INFO] GeoServer Security Community Modules ............... SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - Core .... SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - OpenId Connect SKIPPED
[INFO] GeoServer Keycloak Security Plugin ................. SKIPPED
[INFO] GeoServer SAMLv2 SSO Module ........................ SKIPPED
[INFO] gs-notification-common ............................. SKIPPED
[INFO] GeoServer notification event system extension for GeoNode SKIPPED
[INFO] OWS Dispatcher Simulate Plugin ..................... SKIPPED
[INFO] JDBC Metrics Plugin ................................ SKIPPED
[INFO] OpenSearch EO parent ............................... SKIPPED
[INFO] OpenSearch for EO .................................. SKIPPED
[INFO] OpenSearch for EO web UI ........................... SKIPPED
[INFO] OpenSearch for EO REST configuration API ........... SKIPPED
[INFO] NSG Profiles ....................................... SKIPPED
[INFO] NSG WMTS 1.0 Profile ............................... SKIPPED
[INFO] NSG WFS 2.0 Profile ................................ SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF GHRSST encoder .............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] WFS 3 prototype .................................... SKIPPED
[INFO] MapML Support for GeoServer ........................ SKIPPED
[INFO] S3 Geotiff Support ................................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SKIPPED
[INFO] GeoServer Task Manager ............................. SKIPPED
[INFO] GeoServer Task Manager Core ........................ SKIPPED
[INFO] GeoServer Task Manager S3 .......................... SKIPPED
[INFO] GeoServer Quality of Service GetCapabilities module SKIPPED
[INFO] OGR datastore panel ................................ SKIPPED
[INFO] gs-ogcapi .......................................... SKIPPED
[INFO] gs-ogcapi-core ..................................... SKIPPED
[INFO] gs-ogcapi-features ................................. SKIPPED
[INFO] gs-ogcapi-tiles .................................... SKIPPED
[INFO] gs-ogcapi-styles ................................... SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] Catalog Services for the Web ISO metadata profile module SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoStyler community module ......................... SKIPPED
[INFO] GeoServer notification event system ................ SKIPPED
[INFO] GeoServer Metadata Customizer ...................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SKIPPED
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] Authentication by unique url key ................... SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 01:08 min
[INFO] Finished at: 2019-09-18T08:55:56Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) on project gs-web-sec-core: Error copying artifact from /home/ubuntu/.m2/repository/org/geotools/gt-main/23-SNAPSHOT/gt-main-23-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/security/core/target/dependency/gt-main-23-SNAPSHOT.jar&gt;: File /home/ubuntu/.m2/repository/org/geotools/gt-main/23-SNAPSHOT/gt-main-23-SNAPSHOT.jar does not exist -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-sec-core
$ ssh-agent -k
unset SSH_AUTH_SOCK;
unset SSH_AGENT_PID;
echo Agent pid 27622 killed;
[ssh-agent] Stopped.
Skipped archiving because build is not successful
See <https://build.geoserver.org/job/geoserver-master-nightly/3781/display/redirect&gt;
