See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/381/changes>
Changes:
[ksmith] Update JDBCConfig documentation to warn of security risks
[jdeolive] Updating css demo to handle case of style natively being stored in css.
[lago.88] [GEOS-6673] AbstractTilesGetMapOutputFormat should perform cleanup continuously
[jdeolive] Removing manual formatChoice procesing during validation. Fixes GEOS-6666.
[jared.erickson] The Scripting app resource throws null pointer exception is main script isn't found.
[damianofds] [GEOS-6672] Creation of a WPS Process for mbtiles generation
[daniele.romagnoli] [GEOS-6679]: WCS20 GetCoverage multipart does encoding 2 times
[lago.88] [GEOS-6680]Creation of a new wps process for downloading vector and raster data as zip
[daniele.romagnoli] GEOS-6648: Report proper uom, nilValue, ranges on GML GetCoverage requests
[...truncated 7863 lines...]
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = b260554
[INFO] [GitCommitIdMojo] build.commit.id = b260554a6b0edd2df4ec030a629172e1e4ad8b61
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #741 from jericks/GEOS-6676
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-mbtiles <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-mbtiles ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/target/gs-mbtiles-2.7-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-mbtiles >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-mbtiles ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #741 from jericks/GEOS-6676
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 17.09.2014 @ 16:08:42 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 18-Sep-2014 02:36
[INFO] [GitCommitIdMojo] build.build.time = 18.09.2014 @ 02:44:14 UTC
[INFO] [GitCommitIdMojo] build.branch = b260554a6b0edd2df4ec030a629172e1e4ad8b61
[INFO] [GitCommitIdMojo] build.commit.user.email = jody.garnett@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Jody Garnett
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-mbtiles <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-mbtiles ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/target/gs-mbtiles-2.7-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ gs-mbtiles ---
[INFO] Copying gt-api-13-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/target/dependency/gt-api-13-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.7-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/target/dependency/gwc-core-1.7-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-mbtiles ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/target/gs-mbtiles-2.7-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-mbtiles/2.7-SNAPSHOT/gs-mbtiles-2.7-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-mbtiles/2.7-SNAPSHOT/gs-mbtiles-2.7-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/target/gs-mbtiles-2.7-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-mbtiles/2.7-SNAPSHOT/gs-mbtiles-2.7-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/target/gs-mbtiles-2.7-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-mbtiles/2.7-SNAPSHOT/gs-mbtiles-2.7-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/target/gs-mbtiles-2.7-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-mbtiles/2.7-SNAPSHOT/gs-mbtiles-2.7-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer GeoPackage Extension 2.7-SNAPSHOT
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-geopkg/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-geopkg/13-SNAPSHOT/maven-metadata.xml
966/966 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-geopkg/13-SNAPSHOT/maven-metadata.xml (966 B at 78.6 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-geopkg ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/geopkg/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-geopkg ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-geopkg ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-geopkg ---
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/geopkg/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-geopkg ---
[INFO] Compiling 5 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/geopkg/target/classes>
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/geopkg/src/main/java/org/geoserver/geopkg/GeoPackageGetMapOutputFormat.java>:\[285,24\] error: cannot find symbol
[INFO] 1 error
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.634s]
[INFO] Core Platform Module .............................. SUCCESS [6.522s]
[INFO] Open Web Service Module ........................... SUCCESS [10.443s]
[INFO] Main Module ....................................... SUCCESS [35.363s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.614s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [7.502s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [6.042s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.204s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [7.803s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [9.661s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [12.426s]
[INFO] Web Feature Service Module ........................ SUCCESS [18.482s]
[INFO] Web Map Service Module ............................ SUCCESS [19.344s]
[INFO] KML support for GeoServer ......................... SUCCESS [10.349s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [14.258s]
[INFO] REST Support Module ............................... SUCCESS [6.602s]
[INFO] REST Configuration Service Module ................. SUCCESS [11.349s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.084s]
[INFO] Core UI Module .................................... SUCCESS [16.900s]
[INFO] WMS UI Module ..................................... SUCCESS [7.843s]
[INFO] GWC UI Module ..................................... SUCCESS [9.874s]
[INFO] WFS UI Module ..................................... SUCCESS [5.346s]
[INFO] Demoes Module ..................................... SUCCESS [7.899s]
[INFO] WCS UI Module ..................................... SUCCESS [7.433s]
[INFO] Security UI Modules ............................... SUCCESS [0.122s]
[INFO] Security UI Core Module ........................... SUCCESS [12.028s]
[INFO] Security UI JDBC Module ........................... SUCCESS [6.475s]
[INFO] Security UI LDAP Module ........................... SUCCESS [5.407s]
[INFO] REST UI Module .................................... SUCCESS [5.694s]
[INFO] GeoServer Web Application ......................... SUCCESS [7.872s]
[INFO] Community Space ................................... SUCCESS [0.111s]
[INFO] Authentication by unique url key .................. SUCCESS [30.594s]
[INFO] WorldWind Format Module ........................... SUCCESS [5.954s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.094s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.183s]
[INFO] Web Processing Service Module ..................... SUCCESS [14.208s]
[INFO] GPX PPIO for WPS .................................. SUCCESS [5.053s]
[INFO] NetCDF Coverage format ............................ SUCCESS [4.868s]
[INFO] DownloadProcess ................................... SUCCESS [6.679s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [7.483s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [2.988s]
[INFO] GeoServer Scripting Extensions .................... SUCCESS [0.257s]
[INFO] Core Scripting Extension .......................... SUCCESS [7.686s]
[INFO] H2 DataStore Extension ............................ SUCCESS [5.274s]
[INFO] Python Scripting Extension ........................ SUCCESS [8.085s]
[INFO] JavaScript Scripting Extension .................... SUCCESS [6.707s]
[INFO] Groovy Scripting Extension ........................ SUCCESS [17.595s]
[INFO] GeoServer JDBC KV Catalog ......................... SUCCESS [9.569s]
[INFO] Simple Feature Service ............................ SUCCESS [5.264s]
[INFO] Aggregating Data Store ............................ SUCCESS [3.405s]
[INFO] WMS-EO ............................................ SUCCESS [8.196s]
[INFO] ColorMap .......................................... SUCCESS [5.867s]
[INFO] GeoServer mbtiles Extension ....................... SUCCESS [7.275s]
[INFO] GeoServer GeoPackage Extension .................... FAILURE [3.313s]
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] Dynamic WMS dimension value defaults .............. SKIPPED
[INFO] REST plugin community module ...................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] KML PPIO for WPS .................................. SKIPPED
[INFO] GeoServer Community Release Module ................ SKIPPED
[INFO] SpatiaLite Extension .............................. SKIPPED
[INFO] Web UI Scripting Extension ........................ SKIPPED
[INFO] BeanShell Scripting Extension ..................... SKIPPED
[INFO] Ruby Scripting Extension .......................... SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 7:41.841s
[INFO] Finished at: Thu Sep 18 02:44:17 UTC 2014
[INFO] Final Memory: 90M/243M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-geopkg: Compilation failure
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-geopkg
