[Geoserver-devel] Build failed in Jenkins: geoserver-master-nightly #399
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/399/changes&gt;
Changes:
[bradh] Fix broken CCLA link
[andrea.aime] [GEOS-6705] JMS based clustering module
[andrea.aime] Some initial docs for the clustering extension
[andrea.aime] Adding LICENSE.txt to the root, just like our headers say
Started by timer
Building in workspace <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/&gt;
Checkout:geoserver-master / <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/&gt; - hudson.remoting.LocalChannel@anonymised.com
Using strategy: Default
Last Built Revision: Revision b512da6b814b45effef4881c97a1ad15c1033971 (origin/master)
Fetching changes from 1 remote Git repository
Fetching upstream changes from origin
Commencing build of Revision e333489b49979d4bb9f393aef0652f645e4d35fa (origin/master)
Checking out Revision e333489b49979d4bb9f393aef0652f645e4d35fa (origin/master)
[geoserver-master] $ /opt/apache-maven-3.0.4/bin/mvn -f src/pom.xml -Dhudson.buildId=399 -DskipTests -Prelease -PcommunityRelease clean install assembly:attached
[INFO] Scanning for projects...
[ERROR] The build could not read 1 project -> [Help 1]
[ERROR]
[ERROR] The project org.geoserver:community:2.7-SNAPSHOT (<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/pom.xml)> has 1 error
[ERROR] Child module <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/jms-cluster/pom.xml&gt; of <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/pom.xml&gt; does not exist
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/ProjectBuildingException
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/400/&gt;
Started by timer
Last Built Revision: Revision e333489b49979d4bb9f393aef0652f645e4d35fa (origin/master)
[geoserver-master] $ /opt/apache-maven-3.0.4/bin/mvn -f src/pom.xml -Dhudson.buildId=400 -DskipTests -Prelease -PcommunityRelease clean install assembly:attached
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/401/changes&gt;
Changes:
[juha.hyvarinen] Add support for XML3D output format in W3DS module.
[juha.hyvarinen] Add support for octet-stream output to XML3D request. This output format is used to optimize network traffic and only elevation information is returned.
[juha.hyvarinen] Add support for predefined LODset to XML3D output. Scale is from 1 to 10 and 10 is with maximum details.
[parker] Renamed aus_dem.tif to aus_dem.tiff. Top level pom file lists *.tiff
[parker] Fixed (most) of the failing tests in the BIL module. Changed test to
[juha.hyvarinen] c) 2014 Open Source Geospatial Foundation (GSIP-118)
[jdeolive] Creating zip entry for directories.
[andrea.aime] GEOS-6692 do not assume that the subset envelope is using WGS84 lat lon
[andrea.aime] Adding missing pom file
[parker] Changed expected content length for application/bil test to match
[Ben.Caradoc-Davies] Fixed jms-cluster artifactId and removed inconsistent property activation
[...truncated 8226 lines...]
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-jms-commons ---
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/jms-cluster/jms-commons/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/jms-cluster/jms-commons/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-jms-commons ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-jms-commons ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-jms-commons ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/jms-cluster/jms-commons/target/gs-jms-commons-2.7-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-jms-commons ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/jms-cluster/jms-commons/target/gs-jms-commons-2.7-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-jms-commons >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-jms-commons ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Fixed jms-cluster artifactId and removed inconsistent property activation
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 06.10.2014 @ 04:54:46 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 06-Oct-2014 08:00
[INFO] [GitCommitIdMojo] build.build.time = 06.10.2014 @ 08:08:32 UTC
[INFO] [GitCommitIdMojo] build.branch = 12c6c1637f74f0d83120d4b27864ad50688e2ce4
[INFO] [GitCommitIdMojo] build.commit.user.email = Ben.Caradoc-Davies@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Ben Caradoc-Davies
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 12c6c16
[INFO] [GitCommitIdMojo] build.commit.id = 12c6c1637f74f0d83120d4b27864ad50688e2ce4
[INFO] [GitCommitIdMojo] build.commit.message.full = Fixed jms-cluster artifactId and removed inconsistent property activation
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-jms-commons <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-jms-commons ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/jms-cluster/jms-commons/target/gs-jms-commons-2.7-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-jms-commons >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-jms-commons <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-jms-commons ---
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ gs-jms-commons ---
[INFO] Copying gt-api-13-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/jms-cluster/jms-commons/target/dependency/gt-api-13-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.7-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/jms-cluster/jms-commons/target/dependency/gwc-core-1.7-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-jms-commons ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/jms-cluster/jms-commons/target/gs-jms-commons-2.7-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-jms-commons/2.7-SNAPSHOT/gs-jms-commons-2.7-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/jms-cluster/jms-commons/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-jms-commons/2.7-SNAPSHOT/gs-jms-commons-2.7-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/jms-cluster/jms-commons/target/gs-jms-commons-2.7-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-jms-commons/2.7-SNAPSHOT/gs-jms-commons-2.7-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/jms-cluster/jms-commons/target/gs-jms-commons-2.7-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-jms-commons/2.7-SNAPSHOT/gs-jms-commons-2.7-SNAPSHOT-sources.jar
[INFO]
[INFO] Building GeoServer Community Release Module 2.7-SNAPSHOT
Downloading: http://repo.boundlessgeo.com/main/org/geoserver/gs-jms-cluster/2.7-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/gs-jms-cluster/2.7-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.boundlessgeo.com/main/org/geoserver/gs-jms-cluster/2.7-SNAPSHOT/gs-jms-cluster-2.7-SNAPSHOT.pom
Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/gs-jms-cluster/2.7-SNAPSHOT/gs-jms-cluster-2.7-SNAPSHOT.pom
[WARNING] The POM for org.geoserver:gs-jms-cluster:jar:2.7-SNAPSHOT is missing, no dependency information available
Downloading: http://repo.boundlessgeo.com/main/org/geoserver/gs-jms-cluster/2.7-SNAPSHOT/gs-jms-cluster-2.7-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/gs-jms-cluster/2.7-SNAPSHOT/gs-jms-cluster-2.7-SNAPSHOT.jar
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [3.913s]
[INFO] Core Platform Module .............................. SUCCESS [6.235s]
[INFO] Open Web Service Module ........................... SUCCESS [8.947s]
[INFO] Main Module ....................................... SUCCESS [31.447s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.334s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [7.215s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [5.428s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.372s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [7.912s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [9.819s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [11.484s]
[INFO] Web Feature Service Module ........................ SUCCESS [17.657s]
[INFO] Web Map Service Module ............................ SUCCESS [18.297s]
[INFO] KML support for GeoServer ......................... SUCCESS [10.597s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [11.300s]
[INFO] REST Support Module ............................... SUCCESS [5.535s]
[INFO] REST Configuration Service Module ................. SUCCESS [12.973s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.111s]
[INFO] Core UI Module .................................... SUCCESS [15.747s]
[INFO] WMS UI Module ..................................... SUCCESS [8.061s]
[INFO] GWC UI Module ..................................... SUCCESS [10.378s]
[INFO] WFS UI Module ..................................... SUCCESS [5.049s]
[INFO] Demoes Module ..................................... SUCCESS [7.444s]
[INFO] WCS UI Module ..................................... SUCCESS [6.497s]
[INFO] Security UI Modules ............................... SUCCESS [0.149s]
[INFO] Security UI Core Module ........................... SUCCESS [14.502s]
[INFO] Security UI JDBC Module ........................... SUCCESS [6.619s]
[INFO] Security UI LDAP Module ........................... SUCCESS [5.768s]
[INFO] REST UI Module .................................... SUCCESS [5.388s]
[INFO] GeoServer Web Application ......................... SUCCESS [15.335s]
[INFO] Community Space ................................... SUCCESS [0.097s]
[INFO] Authentication by unique url key .................. SUCCESS [21.290s]
[INFO] WorldWind Format Module ........................... SUCCESS [6.725s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.085s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.121s]
[INFO] Web Processing Service Module ..................... SUCCESS [12.818s]
[INFO] GPX PPIO for WPS .................................. SUCCESS [5.088s]
[INFO] NetCDF Coverage format ............................ SUCCESS [2.709s]
[INFO] DownloadProcess ................................... SUCCESS [6.261s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [6.776s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [3.785s]
[INFO] GeoServer Scripting Extensions .................... SUCCESS [0.185s]
[INFO] Core Scripting Extension .......................... SUCCESS [8.013s]
[INFO] H2 DataStore Extension ............................ SUCCESS [5.402s]
[INFO] Python Scripting Extension ........................ SUCCESS [7.420s]
[INFO] JavaScript Scripting Extension .................... SUCCESS [7.585s]
[INFO] Groovy Scripting Extension ........................ SUCCESS [19.066s]
[INFO] GeoServer JDBC KV Catalog ......................... SUCCESS [8.341s]
[INFO] Simple Feature Service ............................ SUCCESS [5.585s]
[INFO] Aggregating Data Store ............................ SUCCESS [3.004s]
[INFO] WMS-EO ............................................ SUCCESS [8.663s]
[INFO] ColorMap .......................................... SUCCESS [6.463s]
[INFO] GeoServer mbtiles Extension ....................... SUCCESS [5.939s]
[INFO] GeoServer GeoPackage Extension .................... SUCCESS [6.528s]
[INFO] GRIB Coverage Format .............................. SUCCESS [5.319s]
[INFO] Dynamic WMS dimension value defaults .............. SUCCESS [6.418s]
[INFO] REST plugin community module ...................... SUCCESS [5.558s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [3.308s]
[INFO] KML PPIO for WPS .................................. SUCCESS [5.788s]
[INFO] GeoServer JMS based clustering modules ............ SUCCESS [0.889s]
[INFO] GeoServer JMS clustering Commons module ........... SUCCESS [9.295s]
[INFO] GeoServer Community Release Module ................ FAILURE [1.128s]
[INFO] SpatiaLite Extension .............................. SKIPPED
[INFO] Web UI Scripting Extension ........................ SKIPPED
[INFO] BeanShell Scripting Extension ..................... SKIPPED
[INFO] Ruby Scripting Extension .......................... SKIPPED
[INFO] ActiveMQ .......................................... SKIPPED
[INFO] GeoServer JMS clustering module ................... SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 7:56.559s
[INFO] Finished at: Mon Oct 06 08:08:33 UTC 2014
[INFO] Final Memory: 98M/280M
[ERROR] Failed to execute goal on project gs-release: Could not resolve dependencies for project org.geoserver.community:gs-release:jar:2.7-SNAPSHOT: Could not find artifact org.geoserver:gs-jms-cluster:jar:2.7-SNAPSHOT in boundless (http://repo.boundlessgeo.com/main) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-release
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/402/changes&gt;
Changes:
[alex3305] [GEOS-6654] Refer to right Xlink XSD in WFS
[dwinslow] Enable geojson geometry output in WPS
[jdeolive] Allow StyleGenerator to create style inside of a workspace.
[jdeolive] Added DataStoreFactoryInitializer for GeoPkg. Fixes GEOS-6708.
[Ben.Caradoc-Davies] [GEOS-6707] SortBy property name validation breaks app-schema
[...truncated 8098 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-6707] SortBy property name validation breaks app-schema
[INFO] [GitCommitIdMojo] build.commit.time = 07.10.2014 @ 02:08:12 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 07-Oct-2014 08:00
[INFO] [GitCommitIdMojo] build.build.time = 07.10.2014 @ 08:09:06 UTC
[INFO] [GitCommitIdMojo] build.branch = 7372cf62bd59c057b155f2935077c5b8d67fe4c2
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 7372cf6
[INFO] [GitCommitIdMojo] build.commit.id = 7372cf62bd59c057b155f2935077c5b8d67fe4c2
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-6707] SortBy property name validation breaks app-schema
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.408s]
[INFO] Core Platform Module .............................. SUCCESS [7.652s]
[INFO] Open Web Service Module ........................... SUCCESS [8.773s]
[INFO] Main Module ....................................... SUCCESS [34.225s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.279s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [6.888s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [5.941s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.570s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [9.042s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [9.985s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [12.507s]
[INFO] Web Feature Service Module ........................ SUCCESS [17.747s]
[INFO] Web Map Service Module ............................ SUCCESS [19.817s]
[INFO] KML support for GeoServer ......................... SUCCESS [11.228s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [12.271s]
[INFO] REST Support Module ............................... SUCCESS [6.236s]
[INFO] REST Configuration Service Module ................. SUCCESS [14.009s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.165s]
[INFO] Core UI Module .................................... SUCCESS [17.587s]
[INFO] WMS UI Module ..................................... SUCCESS [8.700s]
[INFO] GWC UI Module ..................................... SUCCESS [10.612s]
[INFO] WFS UI Module ..................................... SUCCESS [5.380s]
[INFO] Demoes Module ..................................... SUCCESS [7.818s]
[INFO] WCS UI Module ..................................... SUCCESS [6.650s]
[INFO] Security UI Modules ............................... SUCCESS [0.192s]
[INFO] Security UI Core Module ........................... SUCCESS [12.709s]
[INFO] Security UI JDBC Module ........................... SUCCESS [6.589s]
[INFO] Security UI LDAP Module ........................... SUCCESS [5.511s]
[INFO] REST UI Module .................................... SUCCESS [5.043s]
[INFO] GeoServer Web Application ......................... SUCCESS [16.127s]
[INFO] Community Space ................................... SUCCESS [12.769s]
[INFO] Authentication by unique url key .................. SUCCESS [8.878s]
[INFO] WorldWind Format Module ........................... SUCCESS [5.732s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.139s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.127s]
[INFO] Web Processing Service Module ..................... SUCCESS [13.035s]
[INFO] GPX PPIO for WPS .................................. SUCCESS [6.208s]
[INFO] NetCDF Coverage format ............................ SUCCESS [9.534s]
[INFO] DownloadProcess ................................... SUCCESS [6.206s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [7.000s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [3.167s]
[INFO] GeoServer Scripting Extensions .................... SUCCESS [0.210s]
[INFO] Core Scripting Extension .......................... SUCCESS [7.405s]
[INFO] H2 DataStore Extension ............................ SUCCESS [4.962s]
[INFO] Python Scripting Extension ........................ SUCCESS [9.242s]
[INFO] JavaScript Scripting Extension .................... SUCCESS [7.296s]
[INFO] Groovy Scripting Extension ........................ SUCCESS [18.538s]
[INFO] GeoServer JDBC KV Catalog ......................... SUCCESS [9.492s]
[INFO] Simple Feature Service ............................ SUCCESS [5.304s]
[INFO] Aggregating Data Store ............................ SUCCESS [3.393s]
[INFO] WMS-EO ............................................ SUCCESS [8.407s]
[INFO] ColorMap .......................................... SUCCESS [5.269s]
[INFO] GeoServer mbtiles Extension ....................... SUCCESS [6.505s]
[INFO] GeoServer GeoPackage Extension .................... SUCCESS [6.724s]
[INFO] GRIB Coverage Format .............................. SUCCESS [6.522s]
[INFO] Dynamic WMS dimension value defaults .............. SUCCESS [6.951s]
[INFO] REST plugin community module ...................... SUCCESS [5.542s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [2.835s]
[INFO] KML PPIO for WPS .................................. SUCCESS [5.274s]
[INFO] GeoServer JMS based clustering modules ............ SUCCESS [2.739s]
[INFO] GeoServer JMS clustering Commons module ........... SUCCESS [2.389s]
[INFO] GeoServer Community Release Module ................ FAILURE [0.971s]
[INFO] Total time: 8:18.422s
[INFO] Finished at: Tue Oct 07 08:09:07 UTC 2014
[INFO] Final Memory: 98M/268M
[ERROR]
[ERROR]
[ERROR]
Aha! I missed a spot. Will push a fix and kick the nightly.
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Mineral Resources Flagship
Australian Resources Research Centre
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/403/changes&gt;
