[Geoserver-devel] Build failed in Jenkins: geoserver-master-nightly #409
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/409/changes&gt;
Changes:
[andrea.aime] [GEOS-6713] GeoFence integration community module
[andrea.aime] Fix GUI problem on re-edit SOLR attributes before save layer
[andrea.aime] [GEOS-6714] Geoserver Logs page inaccessible
[...truncated 9002 lines...]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-solr ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/solr/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-solr ---
[INFO] Compiling 1 source file to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/solr/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-solr ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-solr ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/solr/target/gs-web-solr-2.7-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-solr ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/solr/target/gs-web-solr-2.7-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-solr >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-solr ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-6714] Geoserver Logs page inaccessible
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 12.10.2014 @ 09:06:14 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 13-Oct-2014 08:00
[INFO] [GitCommitIdMojo] build.build.time = 13.10.2014 @ 08:09:30 UTC
[INFO] [GitCommitIdMojo] build.branch = b1da38fbdc2e56585b82aad84ea859ac3498df27
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = b1da38f
[INFO] [GitCommitIdMojo] build.commit.id = b1da38fbdc2e56585b82aad84ea859ac3498df27
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-6714] Geoserver Logs page inaccessible
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-solr <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-solr ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/solr/target/gs-web-solr-2.7-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-solr >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-solr <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-solr ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/solr/target/gs-web-solr-2.7-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ gs-web-solr ---
[INFO] Copying gt-api-13-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/solr/target/dependency/gt-api-13-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.7-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/solr/target/dependency/gwc-core-1.7-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-solr ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/solr/target/gs-web-solr-2.7-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-solr/2.7-SNAPSHOT/gs-web-solr-2.7-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/solr/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-solr/2.7-SNAPSHOT/gs-web-solr-2.7-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/solr/target/gs-web-solr-2.7-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-solr/2.7-SNAPSHOT/gs-web-solr-2.7-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/solr/target/gs-web-solr-2.7-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-solr/2.7-SNAPSHOT/gs-web-solr-2.7-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/solr/target/gs-web-solr-2.7-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-solr/2.7-SNAPSHOT/gs-web-solr-2.7-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Community Release Module 2.7-SNAPSHOT
Downloading: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-geofence/2.7-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/community/gs-geofence/2.7-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-geofence/2.7-SNAPSHOT/gs-geofence-2.7-SNAPSHOT.pom
Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/community/gs-geofence/2.7-SNAPSHOT/gs-geofence-2.7-SNAPSHOT.pom
[WARNING] The POM for org.geoserver.community:gs-geofence:jar:2.7-SNAPSHOT is missing, no dependency information available
Downloading: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-geofence/2.7-SNAPSHOT/gs-geofence-2.7-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/community/gs-geofence/2.7-SNAPSHOT/gs-geofence-2.7-SNAPSHOT.jar
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.804s]
[INFO] Core Platform Module .............................. SUCCESS [7.231s]
[INFO] Open Web Service Module ........................... SUCCESS [12.103s]
[INFO] Main Module ....................................... SUCCESS [38.921s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.689s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [7.212s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [6.424s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.379s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [8.496s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [9.459s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [11.762s]
[INFO] Web Feature Service Module ........................ SUCCESS [18.640s]
[INFO] Web Map Service Module ............................ SUCCESS [20.668s]
[INFO] KML support for GeoServer ......................... SUCCESS [10.723s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [14.233s]
[INFO] REST Support Module ............................... SUCCESS [6.386s]
[INFO] REST Configuration Service Module ................. SUCCESS [11.554s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.089s]
[INFO] Core UI Module .................................... SUCCESS [19.836s]
[INFO] WMS UI Module ..................................... SUCCESS [8.231s]
[INFO] GWC UI Module ..................................... SUCCESS [9.794s]
[INFO] WFS UI Module ..................................... SUCCESS [5.232s]
[INFO] Demoes Module ..................................... SUCCESS [8.020s]
[INFO] WCS UI Module ..................................... SUCCESS [6.805s]
[INFO] Security UI Modules ............................... SUCCESS [0.142s]
[INFO] Security UI Core Module ........................... SUCCESS [12.807s]
[INFO] Security UI JDBC Module ........................... SUCCESS [6.274s]
[INFO] Security UI LDAP Module ........................... SUCCESS [5.668s]
[INFO] REST UI Module .................................... SUCCESS [4.966s]
[INFO] GeoServer Web Application ......................... SUCCESS [7.929s]
[INFO] Community Space ................................... SUCCESS [0.136s]
[INFO] Authentication by unique url key .................. SUCCESS [26.601s]
[INFO] WorldWind Format Module ........................... SUCCESS [11.394s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.111s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.114s]
[INFO] Web Processing Service Module ..................... SUCCESS [13.335s]
[INFO] GPX PPIO for WPS .................................. SUCCESS [5.890s]
[INFO] NetCDF Coverage format ............................ SUCCESS [8.220s]
[INFO] DownloadProcess ................................... SUCCESS [6.545s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [7.609s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [3.360s]
[INFO] GeoServer Scripting Extensions .................... SUCCESS [0.169s]
[INFO] Core Scripting Extension .......................... SUCCESS [7.487s]
[INFO] H2 DataStore Extension ............................ SUCCESS [5.208s]
[INFO] Python Scripting Extension ........................ SUCCESS [11.141s]
[INFO] JavaScript Scripting Extension .................... SUCCESS [8.237s]
[INFO] Groovy Scripting Extension ........................ SUCCESS [17.983s]
[INFO] GeoServer JDBC KV Catalog ......................... SUCCESS [9.071s]
[INFO] Simple Feature Service ............................ SUCCESS [5.519s]
[INFO] Aggregating Data Store ............................ SUCCESS [3.523s]
[INFO] WMS-EO ............................................ SUCCESS [8.275s]
[INFO] ColorMap .......................................... SUCCESS [5.477s]
[INFO] GeoServer mbtiles Extension ....................... SUCCESS [6.571s]
[INFO] GeoServer GeoPackage Extension .................... SUCCESS [6.377s]
[INFO] Dynamic WMS dimension value defaults .............. SUCCESS [6.423s]
[INFO] REST plugin community module ...................... SUCCESS [5.467s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [2.959s]
[INFO] KML PPIO for WPS .................................. SUCCESS [5.311s]
[INFO] GeoServer JMS based clustering modules ............ SUCCESS [2.383s]
[INFO] GeoServer JMS clustering Commons module ........... SUCCESS [2.624s]
[INFO] GeoServer JMS clustering module ................... SUCCESS [18.514s]
[INFO] Solr Module ....................................... SUCCESS [6.481s]
[INFO] GeoServer Community Release Module ................ FAILURE [1.062s]
[INFO] SpatiaLite Extension .............................. SKIPPED
[INFO] Web UI Scripting Extension ........................ SKIPPED
[INFO] BeanShell Scripting Extension ..................... SKIPPED
[INFO] Ruby Scripting Extension .......................... SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] ActiveMQ .......................................... SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 8:48.468s
[INFO] Finished at: Mon Oct 13 08:09:31 UTC 2014
[INFO] Final Memory: 103M/266M
[ERROR] Failed to execute goal on project gs-release: Could not resolve dependencies for project org.geoserver.community:gs-release:jar:2.7-SNAPSHOT: Could not find artifact org.geoserver.community:gs-geofence:jar:2.7-SNAPSHOT in boundless (http://repo.boundlessgeo.com/main) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-release
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/410/&gt;
[...truncated 8241 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.timestamp = 14-Oct-2014 08:59
[INFO] [GitCommitIdMojo] build.build.time = 14.10.2014 @ 09:07:23 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.344s]
[INFO] Core Platform Module .............................. SUCCESS [6.336s]
[INFO] Open Web Service Module ........................... SUCCESS [8.804s]
[INFO] Main Module ....................................... SUCCESS [30.302s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.220s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [7.739s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [6.162s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.019s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [8.216s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [9.803s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [11.287s]
[INFO] Web Feature Service Module ........................ SUCCESS [18.010s]
[INFO] Web Map Service Module ............................ SUCCESS [19.717s]
[INFO] KML support for GeoServer ......................... SUCCESS [11.578s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [13.599s]
[INFO] REST Support Module ............................... SUCCESS [6.079s]
[INFO] REST Configuration Service Module ................. SUCCESS [11.469s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.097s]
[INFO] Core UI Module .................................... SUCCESS [17.240s]
[INFO] WMS UI Module ..................................... SUCCESS [8.625s]
[INFO] GWC UI Module ..................................... SUCCESS [9.698s]
[INFO] WFS UI Module ..................................... SUCCESS [5.143s]
[INFO] Demoes Module ..................................... SUCCESS [7.842s]
[INFO] WCS UI Module ..................................... SUCCESS [6.778s]
[INFO] Security UI Modules ............................... SUCCESS [0.181s]
[INFO] Security UI Core Module ........................... SUCCESS [12.979s]
[INFO] Security UI JDBC Module ........................... SUCCESS [5.903s]
[INFO] Security UI LDAP Module ........................... SUCCESS [5.883s]
[INFO] REST UI Module .................................... SUCCESS [4.834s]
[INFO] GeoServer Web Application ......................... SUCCESS [17.484s]
[INFO] Community Space ................................... SUCCESS [8.300s]
[INFO] Authentication by unique url key .................. SUCCESS [12.223s]
[INFO] WorldWind Format Module ........................... SUCCESS [6.046s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.155s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.118s]
[INFO] Web Processing Service Module ..................... SUCCESS [13.977s]
[INFO] GPX PPIO for WPS .................................. SUCCESS [5.158s]
[INFO] NetCDF Coverage format ............................ SUCCESS [3.069s]
[INFO] DownloadProcess ................................... SUCCESS [7.762s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [6.736s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [2.772s]
[INFO] GeoServer Scripting Extensions .................... SUCCESS [0.143s]
[INFO] Core Scripting Extension .......................... SUCCESS [7.397s]
[INFO] H2 DataStore Extension ............................ SUCCESS [4.766s]
[INFO] Python Scripting Extension ........................ SUCCESS [6.904s]
[INFO] JavaScript Scripting Extension .................... SUCCESS [7.288s]
[INFO] Groovy Scripting Extension ........................ SUCCESS [16.457s]
[INFO] GeoServer JDBC KV Catalog ......................... SUCCESS [9.592s]
[INFO] Simple Feature Service ............................ SUCCESS [5.411s]
[INFO] Aggregating Data Store ............................ SUCCESS [2.999s]
[INFO] WMS-EO ............................................ SUCCESS [7.444s]
[INFO] ColorMap .......................................... SUCCESS [5.555s]
[INFO] GeoServer mbtiles Extension ....................... SUCCESS [7.500s]
[INFO] GeoServer GeoPackage Extension .................... SUCCESS [6.484s]
[INFO] Dynamic WMS dimension value defaults .............. SUCCESS [6.313s]
[INFO] REST plugin community module ...................... SUCCESS [5.201s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [2.695s]
[INFO] KML PPIO for WPS .................................. SUCCESS [5.186s]
[INFO] GeoServer JMS based clustering modules ............ SUCCESS [1.120s]
[INFO] GeoServer JMS clustering Commons module ........... SUCCESS [3.035s]
[INFO] GeoServer JMS clustering module ................... SUCCESS [7.567s]
[INFO] Solr Module ....................................... SUCCESS [5.724s]
[INFO] GeoServer Community Release Module ................ FAILURE [1.121s]
[INFO] Total time: 7:59.976s
[INFO] Finished at: Tue Oct 14 09:07:24 UTC 2014
[INFO] Final Memory: 103M/259M
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/411/changes&gt;
Changes:
[dwinslow] Avoid declaring XML namespace in WFS 1.1 capabilities
[...truncated 9218 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #781 from dwins/wfs-xml-declaration
[INFO] [GitCommitIdMojo] build.commit.time = 14.10.2014 @ 13:40:12 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 15-Oct-2014 08:00
[INFO] [GitCommitIdMojo] build.build.time = 15.10.2014 @ 08:09:36 UTC
[INFO] [GitCommitIdMojo] build.branch = f25c665fe57619aebc35eadfca4a3ebd854557ac
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = f25c665
[INFO] [GitCommitIdMojo] build.commit.id = f25c665fe57619aebc35eadfca4a3ebd854557ac
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #781 from dwins/wfs-xml-declaration
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.863s]
[INFO] Core Platform Module .............................. SUCCESS [7.955s]
[INFO] Open Web Service Module ........................... SUCCESS [14.279s]
[INFO] Main Module ....................................... SUCCESS [37.028s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.727s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [7.423s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [6.193s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.980s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [8.401s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [10.184s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [11.131s]
[INFO] Web Feature Service Module ........................ SUCCESS [18.368s]
[INFO] Web Map Service Module ............................ SUCCESS [21.164s]
[INFO] KML support for GeoServer ......................... SUCCESS [11.071s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [14.449s]
[INFO] REST Support Module ............................... SUCCESS [6.185s]
[INFO] REST Configuration Service Module ................. SUCCESS [11.985s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.147s]
[INFO] Core UI Module .................................... SUCCESS [20.889s]
[INFO] WMS UI Module ..................................... SUCCESS [7.517s]
[INFO] GWC UI Module ..................................... SUCCESS [9.772s]
[INFO] WFS UI Module ..................................... SUCCESS [5.728s]
[INFO] Demoes Module ..................................... SUCCESS [7.750s]
[INFO] WCS UI Module ..................................... SUCCESS [6.986s]
[INFO] Security UI Modules ............................... SUCCESS [0.267s]
[INFO] Security UI Core Module ........................... SUCCESS [12.087s]
[INFO] Security UI JDBC Module ........................... SUCCESS [6.093s]
[INFO] Security UI LDAP Module ........................... SUCCESS [5.655s]
[INFO] REST UI Module .................................... SUCCESS [5.452s]
[INFO] GeoServer Web Application ......................... SUCCESS [9.681s]
[INFO] Community Space ................................... SUCCESS [0.226s]
[INFO] Authentication by unique url key .................. SUCCESS [14.137s]
[INFO] WorldWind Format Module ........................... SUCCESS [17.045s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.167s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.155s]
[INFO] Web Processing Service Module ..................... SUCCESS [14.571s]
[INFO] GPX PPIO for WPS .................................. SUCCESS [5.949s]
[INFO] NetCDF Coverage format ............................ SUCCESS [6.904s]
[INFO] DownloadProcess ................................... SUCCESS [6.037s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [7.168s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [2.824s]
[INFO] GeoServer Scripting Extensions .................... SUCCESS [0.198s]
[INFO] Core Scripting Extension .......................... SUCCESS [7.092s]
[INFO] H2 DataStore Extension ............................ SUCCESS [5.709s]
[INFO] Python Scripting Extension ........................ SUCCESS [10.192s]
[INFO] JavaScript Scripting Extension .................... SUCCESS [7.260s]
[INFO] Groovy Scripting Extension ........................ SUCCESS [18.764s]
[INFO] GeoServer JDBC KV Catalog ......................... SUCCESS [9.295s]
[INFO] Simple Feature Service ............................ SUCCESS [5.599s]
[INFO] Aggregating Data Store ............................ SUCCESS [3.886s]
[INFO] WMS-EO ............................................ SUCCESS [7.993s]
[INFO] ColorMap .......................................... SUCCESS [5.280s]
[INFO] GeoServer mbtiles Extension ....................... SUCCESS [7.022s]
[INFO] GeoServer GeoPackage Extension .................... SUCCESS [6.754s]
[INFO] Dynamic WMS dimension value defaults .............. SUCCESS [6.868s]
[INFO] REST plugin community module ...................... SUCCESS [5.934s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [2.744s]
[INFO] KML PPIO for WPS .................................. SUCCESS [5.446s]
[INFO] GeoServer JMS based clustering modules ............ SUCCESS [2.611s]
[INFO] GeoServer JMS clustering Commons module ........... SUCCESS [2.584s]
[INFO] GeoServer JMS clustering module ................... SUCCESS [17.057s]
[INFO] Solr Module ....................................... SUCCESS [6.398s]
[INFO] GeoServer Community Release Module ................ FAILURE [0.997s]
[INFO] Total time: 8:46.321s
[INFO] Finished at: Wed Oct 15 08:09:37 UTC 2014
[INFO] Final Memory: 100M/250M
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/412/changes&gt;
Changes:
[etj] GeoFence: fix cache setup
[...truncated 9005 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.commit.message.short = GeoFence: fix cache setup
[INFO] [GitCommitIdMojo] build.commit.time = 15.10.2014 @ 14:56:07 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 16-Oct-2014 08:00
[INFO] [GitCommitIdMojo] build.build.time = 16.10.2014 @ 08:10:12 UTC
[INFO] [GitCommitIdMojo] build.branch = 2bc2ba768219c30ceb4d418e36d5e886b76e7de1
[INFO] [GitCommitIdMojo] build.commit.user.email = etj@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = etj
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 2bc2ba7
[INFO] [GitCommitIdMojo] build.commit.id = 2bc2ba768219c30ceb4d418e36d5e886b76e7de1
[INFO] [GitCommitIdMojo] build.commit.message.full = GeoFence: fix cache setup
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [10.251s]
[INFO] Core Platform Module .............................. SUCCESS [8.450s]
[INFO] Open Web Service Module ........................... SUCCESS [17.741s]
[INFO] Main Module ....................................... SUCCESS [40.155s]
[INFO] GeoServer Security Modules ........................ SUCCESS [2.000s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [7.583s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [7.707s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.074s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [10.079s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [10.020s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [11.917s]
[INFO] Web Feature Service Module ........................ SUCCESS [17.379s]
[INFO] Web Map Service Module ............................ SUCCESS [23.456s]
[INFO] KML support for GeoServer ......................... SUCCESS [11.622s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [14.878s]
[INFO] REST Support Module ............................... SUCCESS [6.592s]
[INFO] REST Configuration Service Module ................. SUCCESS [13.017s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.139s]
[INFO] Core UI Module .................................... SUCCESS [18.728s]
[INFO] WMS UI Module ..................................... SUCCESS [8.053s]
[INFO] GWC UI Module ..................................... SUCCESS [9.329s]
[INFO] WFS UI Module ..................................... SUCCESS [5.312s]
[INFO] Demoes Module ..................................... SUCCESS [8.081s]
[INFO] WCS UI Module ..................................... SUCCESS [7.302s]
[INFO] Security UI Modules ............................... SUCCESS [0.239s]
[INFO] Security UI Core Module ........................... SUCCESS [12.575s]
[INFO] Security UI JDBC Module ........................... SUCCESS [6.110s]
[INFO] Security UI LDAP Module ........................... SUCCESS [5.840s]
[INFO] REST UI Module .................................... SUCCESS [4.911s]
[INFO] GeoServer Web Application ......................... SUCCESS [10.985s]
[INFO] Community Space ................................... SUCCESS [0.221s]
[INFO] Authentication by unique url key .................. SUCCESS [34.038s]
[INFO] WorldWind Format Module ........................... SUCCESS [6.033s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.169s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.134s]
[INFO] GPX PPIO for WPS .................................. SUCCESS [5.649s]
[INFO] NetCDF Coverage format ............................ SUCCESS [10.234s]
[INFO] DownloadProcess ................................... SUCCESS [7.595s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [6.945s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [3.199s]
[INFO] GeoServer Scripting Extensions .................... SUCCESS [0.294s]
[INFO] Core Scripting Extension .......................... SUCCESS [8.358s]
[INFO] H2 DataStore Extension ............................ SUCCESS [5.459s]
[INFO] Python Scripting Extension ........................ SUCCESS [9.740s]
[INFO] JavaScript Scripting Extension .................... SUCCESS [7.330s]
[INFO] Groovy Scripting Extension ........................ SUCCESS [17.720s]
[INFO] GeoServer JDBC KV Catalog ......................... SUCCESS [9.294s]
[INFO] Simple Feature Service ............................ SUCCESS [5.601s]
[INFO] Aggregating Data Store ............................ SUCCESS [3.979s]
[INFO] WMS-EO ............................................ SUCCESS [8.431s]
[INFO] ColorMap .......................................... SUCCESS [5.968s]
[INFO] GeoServer mbtiles Extension ....................... SUCCESS [6.401s]
[INFO] GeoServer GeoPackage Extension .................... SUCCESS [6.799s]
[INFO] Dynamic WMS dimension value defaults .............. SUCCESS [6.826s]
[INFO] REST plugin community module ...................... SUCCESS [5.933s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [2.906s]
[INFO] KML PPIO for WPS .................................. SUCCESS [5.471s]
[INFO] GeoServer JMS based clustering modules ............ SUCCESS [2.172s]
[INFO] GeoServer JMS clustering Commons module ........... SUCCESS [2.264s]
[INFO] GeoServer JMS clustering module ................... SUCCESS [17.195s]
[INFO] Solr Module ....................................... SUCCESS [6.097s]
[INFO] GeoServer Community Release Module ................ FAILURE [0.964s]
[INFO] Total time: 9:16.859s
[INFO] Finished at: Thu Oct 16 08:10:13 UTC 2014
[INFO] Final Memory: 100M/248M
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/413/changes&gt;
Changes:
[andrea.aime] [GEOS-6725] JSON totalFeatures does not account for viewparams
[...truncated 8032 lines...]
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-solr ---
[INFO] Copying 3 resources
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-solr ---
[INFO] Compiling 6 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/solr/target/classes&gt;
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-6725] JSON totalFeatures does not account for viewparams
[INFO] [GitCommitIdMojo] build.commit.time = 16.10.2014 @ 09:50:44 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 16-Oct-2014 13:03
[INFO] [GitCommitIdMojo] build.build.time = 16.10.2014 @ 13:10:54 UTC
[INFO] [GitCommitIdMojo] build.branch = 7569b6279d29a5a098a83d9b6425145992e6da59
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 7569b62
[INFO] [GitCommitIdMojo] build.commit.id = 7569b6279d29a5a098a83d9b6425145992e6da59
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-6725] JSON totalFeatures does not account for viewparams
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [3.186s]
[INFO] Core Platform Module .............................. SUCCESS [6.343s]
[INFO] Open Web Service Module ........................... SUCCESS [9.157s]
[INFO] Main Module ....................................... SUCCESS [29.322s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.205s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [7.839s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [5.294s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.386s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [8.118s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [9.633s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [10.929s]
[INFO] Web Feature Service Module ........................ SUCCESS [18.017s]
[INFO] Web Map Service Module ............................ SUCCESS [18.219s]
[INFO] KML support for GeoServer ......................... SUCCESS [10.432s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [11.812s]
[INFO] REST Support Module ............................... SUCCESS [5.581s]
[INFO] REST Configuration Service Module ................. SUCCESS [12.199s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.844s]
[INFO] Core UI Module .................................... SUCCESS [17.549s]
[INFO] WMS UI Module ..................................... SUCCESS [8.179s]
[INFO] GWC UI Module ..................................... SUCCESS [9.402s]
[INFO] WFS UI Module ..................................... SUCCESS [5.248s]
[INFO] Demoes Module ..................................... SUCCESS [7.917s]
[INFO] WCS UI Module ..................................... SUCCESS [6.411s]
[INFO] Security UI Modules ............................... SUCCESS [0.164s]
[INFO] Security UI Core Module ........................... SUCCESS [12.787s]
[INFO] Security UI JDBC Module ........................... SUCCESS [6.608s]
[INFO] Security UI LDAP Module ........................... SUCCESS [6.626s]
[INFO] REST UI Module .................................... SUCCESS [5.515s]
[INFO] GeoServer Web Application ......................... SUCCESS [7.048s]
[INFO] Community Space ................................... SUCCESS [2.294s]
[INFO] Authentication by unique url key .................. SUCCESS [6.985s]
[INFO] WorldWind Format Module ........................... SUCCESS [10.277s]
[INFO] GeoServer Extensions .............................. SUCCESS [4.679s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.083s]
[INFO] Web Processing Service Module ..................... SUCCESS [12.970s]
[INFO] NetCDF Coverage format ............................ SUCCESS [2.923s]
[INFO] DownloadProcess ................................... SUCCESS [6.449s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [6.750s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [2.515s]
[INFO] GeoServer Scripting Extensions .................... SUCCESS [0.152s]
[INFO] Core Scripting Extension .......................... SUCCESS [6.992s]
[INFO] H2 DataStore Extension ............................ SUCCESS [5.215s]
[INFO] Python Scripting Extension ........................ SUCCESS [7.352s]
[INFO] JavaScript Scripting Extension .................... SUCCESS [6.815s]
[INFO] Groovy Scripting Extension ........................ SUCCESS [18.384s]
[INFO] GeoServer JDBC KV Catalog ......................... SUCCESS [8.674s]
[INFO] Simple Feature Service ............................ SUCCESS [5.294s]
[INFO] Aggregating Data Store ............................ SUCCESS [3.058s]
[INFO] WMS-EO ............................................ SUCCESS [7.864s]
[INFO] ColorMap .......................................... SUCCESS [5.324s]
[INFO] GeoServer mbtiles Extension ....................... SUCCESS [5.764s]
[INFO] GeoServer GeoPackage Extension .................... SUCCESS [6.272s]
[INFO] Dynamic WMS dimension value defaults .............. SUCCESS [6.528s]
[INFO] REST plugin community module ...................... SUCCESS [5.805s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [3.097s]
[INFO] KML PPIO for WPS .................................. SUCCESS [5.864s]
[INFO] GeoServer JMS based clustering modules ............ SUCCESS [0.125s]
[INFO] GeoServer JMS clustering Commons module ........... SUCCESS [1.847s]
[INFO] GeoServer JMS clustering module ................... SUCCESS [7.976s]
[INFO] Solr Module ....................................... SUCCESS [6.029s]
[INFO] GeoServer Community Release Module ................ FAILURE [0.612s]
[INFO] Total time: 7:36.903s
[INFO] Finished at: Thu Oct 16 13:10:55 UTC 2014
[INFO] Final Memory: 99M/276M
[ERROR] Failed to execute goal on project gs-release: Could not resolve dependencies for project org.geoserver.community:gs-release:jar:2.7-SNAPSHOT: Failure to find org.geoserver.community:gs-geofence:jar:2.7-SNAPSHOT in http://repo.boundlessgeo.com/main was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/414/changes&gt;
