[Geoserver-devel] Build failed in Jenkins: geoserver-master-nightly #420
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/420/&gt;
Started by timer
Building in workspace <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/&gt;
Checkout:geoserver-master / <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/&gt; - hudson.remoting.LocalChannel@anonymised.com
Using strategy: Default
Last Built Revision: Revision 793476e348e906a2ee9db8fa8f73a4fb464f3288 (origin/master)
Fetching changes from 1 remote Git repository
Fetching upstream changes from origin
ERROR: Problem fetching from origin / origin - could be unavailable. Continuing anyway
hudson.plugins.git.GitException: Command "git fetch -t origin +refs/heads/*:refs/remotes/origin/*" returned status code 1:
stdout:
stderr: error: Ref refs/remotes/origin/master is at 7d7d56c77b91ff7f6c56c04c4723775899d561f1 but expected 20ff24085fbc48cc0d14aed07ca794af1fc8a225
From git://github.com/geoserver/geoserver
! 20ff240...7d7d56c master -> origin/master (unable to update local ref)
  at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:790)
  at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:756)
  at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.fetch(CliGitAPIImpl.java:144)
  at hudson.plugins.git.GitAPI.fetch(GitAPI.java:221)
  at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:791)
  at hudson.plugins.git.GitSCM.access$000(GitSCM.java:58)
  at hudson.plugins.git.GitSCM$2.invoke(GitSCM.java:983)
  at hudson.plugins.git.GitSCM$2.invoke(GitSCM.java:948)
  at hudson.FilePath.act(FilePath.java:914)
  at hudson.FilePath.act(FilePath.java:887)
  at hudson.plugins.git.GitSCM.determineRevisionToBuild(GitSCM.java:948)
  at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1114)
  at hudson.model.AbstractProject.checkout(AbstractProject.java:1320)
  at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:609)
  at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:88)
  at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:518)
  at hudson.model.Run.execute(Run.java:1689)
  at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
  at hudson.model.ResourceController.execute(ResourceController.java:88)
  at hudson.model.Executor.run(Executor.java:231)
ERROR: Could not fetch from any repository
java.io.IOException: Could not fetch from any repository
  at hudson.plugins.git.GitSCM$2.invoke(GitSCM.java:992)
Justin, please help Jenkins, which is a little confused by the rest on master. Other Jenkins instances and jobs seem OK.
Started by timer
stdout:
Comprehensive Server Monitoring with Site24x7.
Monitor 10 servers for $9/Month.
Get alerted through email, SMS, voice calls or mobile push notifications.
Take corrective actions from your mobile device.
http://p.sf.net/sfu/Zoho
Geoserver-devel mailing list
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Mineral Resources Flagship
Australian Resources Research Centre
Ok, cleaned up the local git checkout. I guess it got confused by the forced push? Anyways, think it is happy again.
On Tue, Oct 21, 2014 at 3:13 AM, Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com> wrote:
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/420/>
Started by timer
Building in workspace <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/>
Checkout:geoserver-master / <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/> - hudson.remoting.LocalChannel@45f143f1
hudson.plugins.git.GitException: Command “git fetch -t origin +refs/heads/:refs/remotes/origin/” returned status code 1:
stdout:
! 20ff240…7d7d56c master → origin/master (unable to update local ref)
Geoserver-devel@anonymised.comsourceforge.net
Ben Caradoc-Davies Ben.Caradoc-Davies@anonymised.com
Software Engineer
Justin Deoliveira
VP Engineering | Boundless
jdeolive@anonymised.com
@boundlessgeo
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/421/changes&gt;
Thanks, Justin. I am sure it was the forced push. Other builds were happy to accept the rewriting of history, but this one did not.
Software Engineer
