See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/431/changes>
Changes:
[dwinslow] Enforce that store and layer names are xml-safe at the catalog level
[...truncated 4992 lines...]
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wps >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wps ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Enforce that store and layer names are xml-safe at the catalog level
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 30.10.2014 @ 13:30:58 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 31-Oct-2014 08:00
[INFO] [GitCommitIdMojo] build.build.time = 31.10.2014 @ 08:06:48 UTC
[INFO] [GitCommitIdMojo] build.branch = b00ed3c5e86006a009ba44dd4c4f4f3767b68999
[INFO] [GitCommitIdMojo] build.commit.user.email = dwinslow@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = David Winslow
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = b00ed3c
[INFO] [GitCommitIdMojo] build.commit.id = b00ed3c5e86006a009ba44dd4c4f4f3767b68999
[INFO] [GitCommitIdMojo] build.commit.message.full = Enforce that store and layer names are xml-safe at the catalog level
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wps <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wps ---
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ gs-wps ---
[INFO] Copying gt-api-13-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/wps/target/dependency/gt-api-13-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.7-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/wps/target/dependency/gwc-core-1.7-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-wps ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/wps/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps/2.7-SNAPSHOT/gs-wps-2.7-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/wps/target/gs-wps-2.7-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps/2.7-SNAPSHOT/gs-wps-2.7-SNAPSHOT-tests.jar
[INFO]
[INFO] Building Web Processing Service Module 2.7-SNAPSHOT
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/ogc/net.opengis.wps/13-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.wps/13-SNAPSHOT/maven-metadata.xml
976/976 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.wps/13-SNAPSHOT/maven-metadata.xml (976 B at 19.5 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wps/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-wps/13-SNAPSHOT/maven-metadata.xml
971/971 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wps/13-SNAPSHOT/maven-metadata.xml (971 B at 35.1 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-process-geometry/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-process-geometry/13-SNAPSHOT/maven-metadata.xml
976/976 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-process-geometry/13-SNAPSHOT/maven-metadata.xml (976 B at 28.0 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-wps-core ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/wps/wps-core/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-wps-core ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wps-core ---
[INFO] [GitCommitIdMojo] build.build.time = 31.10.2014 @ 08:06:49 UTC
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-wps-core ---
[INFO] Copying 9 resources
[INFO] Copying 14 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-wps-core ---
[INFO] Compiling 131 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/wps/wps-core/target/classes>
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/gs/ImportProcess.java>:\[443,62\] error: cannot find symbol
[INFO] 1 error
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [9.988s]
[INFO] Core Platform Module .............................. SUCCESS [8.624s]
[INFO] Open Web Service Module ........................... SUCCESS [14.239s]
[INFO] Main Module ....................................... SUCCESS [38.315s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.725s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [7.698s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [6.215s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.744s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [9.374s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [10.272s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [11.504s]
[INFO] Web Feature Service Module ........................ SUCCESS [18.651s]
[INFO] Web Map Service Module ............................ SUCCESS [22.131s]
[INFO] KML support for GeoServer ......................... SUCCESS [10.646s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [15.088s]
[INFO] REST Support Module ............................... SUCCESS [6.620s]
[INFO] REST Configuration Service Module ................. SUCCESS [12.022s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.163s]
[INFO] Core UI Module .................................... SUCCESS [18.925s]
[INFO] WMS UI Module ..................................... SUCCESS [7.823s]
[INFO] GWC UI Module ..................................... SUCCESS [9.733s]
[INFO] WFS UI Module ..................................... SUCCESS [5.529s]
[INFO] Demoes Module ..................................... SUCCESS [8.122s]
[INFO] WCS UI Module ..................................... SUCCESS [6.181s]
[INFO] Security UI Modules ............................... SUCCESS [0.218s]
[INFO] Security UI Core Module ........................... SUCCESS [12.199s]
[INFO] Security UI JDBC Module ........................... SUCCESS [5.972s]
[INFO] Security UI LDAP Module ........................... SUCCESS [5.532s]
[INFO] REST UI Module .................................... SUCCESS [5.411s]
[INFO] GeoServer Web Application ......................... SUCCESS [24.751s]
[INFO] Community Space ................................... SUCCESS [11.149s]
[INFO] Authentication by unique url key .................. SUCCESS [10.386s]
[INFO] WorldWind Format Module ........................... SUCCESS [5.814s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.206s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.194s]
[INFO] Web Processing Service Module ..................... FAILURE [7.839s]
[INFO] GPX PPIO for WPS .................................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] DownloadProcess ................................... SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Embedded FTP server ..................... SKIPPED
[INFO] GeoServer Scripting Extensions .................... SKIPPED
[INFO] Core Scripting Extension .......................... SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] Python Scripting Extension ........................ SKIPPED
[INFO] JavaScript Scripting Extension .................... SKIPPED
[INFO] Groovy Scripting Extension ........................ SKIPPED
[INFO] GeoServer JDBC KV Catalog ......................... SKIPPED
[INFO] Simple Feature Service ............................ SKIPPED
[INFO] Aggregating Data Store ............................ SKIPPED
[INFO] WMS-EO ............................................ SKIPPED
[INFO] ColorMap .......................................... SKIPPED
[INFO] GeoServer mbtiles Extension ....................... SKIPPED
[INFO] GeoServer GeoPackage Extension .................... SKIPPED
[INFO] Dynamic WMS dimension value defaults .............. SKIPPED
[INFO] REST plugin community module ...................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] KML PPIO for WPS .................................. SKIPPED
[INFO] GeoServer JMS based clustering modules ............ SKIPPED
[INFO] GeoServer JMS clustering Commons module ........... SKIPPED
[INFO] GeoServer JMS clustering module ................... SKIPPED
[INFO] GeoFence security integration ..................... SKIPPED
[INFO] Solr Module ....................................... SKIPPED
[INFO] GeoServer Community Release Module ................ SKIPPED
[INFO] SpatiaLite Extension .............................. SKIPPED
[INFO] Web UI Scripting Extension ........................ SKIPPED
[INFO] BeanShell Scripting Extension ..................... SKIPPED
[INFO] Ruby Scripting Extension .......................... SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] ActiveMQ .......................................... SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 6:00.155s
[INFO] Finished at: Fri Oct 31 08:06:56 UTC 2014
[INFO] Final Memory: 68M/205M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-wps-core: Compilation failure
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
