Hudson
1
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/450/changes>
Changes:
[andrea.aime] [GEOS-6755] GSIP 119 - WPS clustering of asynchronous requests - architecture refactor to allow pluggable status sharing
[andrea.aime] [GEOS-6755] GSIP 119 - Hazelcast based status store
[andrea.aime] [GEOS-6755] GSIP 119 - Adding heartbeat so that long procesess not reporting progress won't have their resources expired by mistake
[jdeolive] Exposing style generator from importer
[...truncated 5451 lines...]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-netcdf <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-netcdf ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/netcdf/target/gs-netcdf-2.7-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-netcdf >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-netcdf ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Exposing style generator from importer
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 18.11.2014 @ 17:08:57 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 19-Nov-2014 08:00
[INFO] [GitCommitIdMojo] build.build.time = 19.11.2014 @ 08:08:27 UTC
[INFO] [GitCommitIdMojo] build.branch = db287497cfdfbe7cff827c3c400be40113462461
[INFO] [GitCommitIdMojo] build.commit.user.email = jdeolive@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = jdeolive
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = db28749
[INFO] [GitCommitIdMojo] build.commit.id = db287497cfdfbe7cff827c3c400be40113462461
[INFO] [GitCommitIdMojo] build.commit.message.full = Exposing style generator from importer
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-netcdf <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-netcdf ---
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ gs-netcdf ---
[INFO] Copying gt-api-13-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/netcdf/target/dependency/gt-api-13-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.7-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/netcdf/target/dependency/gwc-core-1.7-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-netcdf ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/netcdf/target/gs-netcdf-2.7-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-netcdf/2.7-SNAPSHOT/gs-netcdf-2.7-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/netcdf/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-netcdf/2.7-SNAPSHOT/gs-netcdf-2.7-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/netcdf/target/gs-netcdf-2.7-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-netcdf/2.7-SNAPSHOT/gs-netcdf-2.7-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/netcdf/target/gs-netcdf-2.7-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-netcdf/2.7-SNAPSHOT/gs-netcdf-2.7-SNAPSHOT-sources.jar
[INFO]
[INFO] Building DownloadProcess 2.7-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-wps-download ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wps-download/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-wps-download ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wps-download ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-wps-download ---
[INFO] Copying 0 resource
[INFO] Copying 2 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-wps-download ---
[INFO] Compiling 15 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wps-download/target/classes>
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wps-download/src/main/java/org/geoserver/wps/gs/download/VectorDownload.java>:\[255,43\] error: cannot find symbol
[ERROR] variable resourceManager of type WPSResourceManager
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wps-download/src/main/java/org/geoserver/wps/gs/download/DownloadProcess.java>:\[232,47\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wps-download/src/main/java/org/geoserver/wps/gs/download/RasterDownload.java>:\[302,43\] error: cannot find symbol
[INFO] 3 errors
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.090s]
[INFO] Core Platform Module .............................. SUCCESS [6.847s]
[INFO] Open Web Service Module ........................... SUCCESS [11.970s]
[INFO] Main Module ....................................... SUCCESS [38.159s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.784s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [7.357s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [47.785s]
[INFO] Web Coverage Service Module ....................... SUCCESS [7.382s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [15.372s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [9.623s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [12.342s]
[INFO] Web Feature Service Module ........................ SUCCESS [19.206s]
[INFO] Web Map Service Module ............................ SUCCESS [21.832s]
[INFO] KML support for GeoServer ......................... SUCCESS [11.441s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [14.663s]
[INFO] REST Support Module ............................... SUCCESS [6.224s]
[INFO] REST Configuration Service Module ................. SUCCESS [11.633s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.175s]
[INFO] Core UI Module .................................... SUCCESS [29.042s]
[INFO] WMS UI Module ..................................... SUCCESS [14.015s]
[INFO] GWC UI Module ..................................... SUCCESS [21.346s]
[INFO] WFS UI Module ..................................... SUCCESS [5.456s]
[INFO] Demoes Module ..................................... SUCCESS [15.840s]
[INFO] WCS UI Module ..................................... SUCCESS [6.394s]
[INFO] Security UI Modules ............................... SUCCESS [0.183s]
[INFO] Security UI Core Module ........................... SUCCESS [18.041s]
[INFO] Security UI JDBC Module ........................... SUCCESS [6.651s]
[INFO] Security UI LDAP Module ........................... SUCCESS [6.286s]
[INFO] REST UI Module .................................... SUCCESS [5.794s]
[INFO] GeoServer Web Application ......................... SUCCESS [16.649s]
[INFO] Community Space ................................... SUCCESS [0.112s]
[INFO] Authentication by unique url key .................. SUCCESS [12.093s]
[INFO] WorldWind Format Module ........................... SUCCESS [13.700s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.118s]
[INFO] Web Processing Service parent ..................... SUCCESS [1.041s]
[INFO] Web Processing Service Module ..................... SUCCESS [14.009s]
[INFO] GPX PPIO for WPS .................................. SUCCESS [4.982s]
[INFO] NetCDF Coverage format ............................ SUCCESS [5.170s]
[INFO] DownloadProcess ................................... FAILURE [3.777s]
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Embedded FTP server ..................... SKIPPED
[INFO] GeoServer Scripting Extensions .................... SKIPPED
[INFO] Core Scripting Extension .......................... SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] Python Scripting Extension ........................ SKIPPED
[INFO] JavaScript Scripting Extension .................... SKIPPED
[INFO] Groovy Scripting Extension ........................ SKIPPED
[INFO] GeoServer JDBC KV Catalog ......................... SKIPPED
[INFO] Simple Feature Service ............................ SKIPPED
[INFO] Aggregating Data Store ............................ SKIPPED
[INFO] WMS-EO ............................................ SKIPPED
[INFO] ColorMap .......................................... SKIPPED
[INFO] GeoServer mbtiles Extension ....................... SKIPPED
[INFO] GeoServer GeoPackage Extension .................... SKIPPED
[INFO] Dynamic WMS dimension value defaults .............. SKIPPED
[INFO] REST plugin community module ...................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] KML PPIO for WPS .................................. SKIPPED
[INFO] GeoServer JMS based clustering modules ............ SKIPPED
[INFO] GeoServer JMS clustering Commons module ........... SKIPPED
[INFO] GeoServer JMS clustering module ................... SKIPPED
[INFO] GeoFence security integration ..................... SKIPPED
[INFO] Solr Module ....................................... SKIPPED
[INFO] GeoServer Community Release Module ................ SKIPPED
[INFO] SpatiaLite Extension .............................. SKIPPED
[INFO] Web UI Scripting Extension ........................ SKIPPED
[INFO] BeanShell Scripting Extension ..................... SKIPPED
[INFO] Ruby Scripting Extension .......................... SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] ActiveMQ .......................................... SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 7:38.488s
[INFO] Finished at: Wed Nov 19 08:08:31 UTC 2014
[INFO] Final Memory: 71M/260M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-wps-download: Compilation failure: Compilation failure:
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wps-download/src/main/java/org/geoserver/wps/gs/download/DownloadProcess.java>:\[232,47\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wps-download/src/main/java/org/geoserver/wps/gs/download/RasterDownload.java>:\[302,43\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-download
Hudson
2
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/451/changes>
Changes:
[andrea.aime] Fixing nightly build compile/build failures in wps-download
[andrea.aime] [GEOS-6770] Allow flow controllers access to the current Operation
[...truncated 7494 lines...]
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-colormap ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/colormap/target/gs-colormap-2.7-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-colormap >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-colormap ---
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-6770] Allow flow controllers access to the current Operation
[INFO] [GitCommitIdMojo] build.commit.time = 19.11.2014 @ 15:07:16 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 20-Nov-2014 08:00
[INFO] [GitCommitIdMojo] build.build.time = 20.11.2014 @ 08:09:11 UTC
[INFO] [GitCommitIdMojo] build.branch = 1da367bd5c56954e86ffc80633fbefcd908a3aff
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 1da367b
[INFO] [GitCommitIdMojo] build.commit.id = 1da367bd5c56954e86ffc80633fbefcd908a3aff
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-6770] Allow flow controllers access to the current Operation
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-colormap <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-colormap ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/colormap/target/gs-colormap-2.7-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ gs-colormap ---
[INFO] Copying gt-api-13-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/colormap/target/dependency/gt-api-13-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.7-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/colormap/target/dependency/gwc-core-1.7-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-colormap ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/colormap/target/gs-colormap-2.7-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-colormap/2.7-SNAPSHOT/gs-colormap-2.7-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/colormap/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-colormap/2.7-SNAPSHOT/gs-colormap-2.7-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/colormap/target/gs-colormap-2.7-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-colormap/2.7-SNAPSHOT/gs-colormap-2.7-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/colormap/target/gs-colormap-2.7-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-colormap/2.7-SNAPSHOT/gs-colormap-2.7-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/colormap/target/gs-colormap-2.7-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-colormap/2.7-SNAPSHOT/gs-colormap-2.7-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer mbtiles Extension 2.7-SNAPSHOT
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-mbtiles/13-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-mbtiles/13-SNAPSHOT/maven-metadata.xml
967/967 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-mbtiles/13-SNAPSHOT/maven-metadata.xml (967 B at 28.6 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-mbtiles ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-mbtiles ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-mbtiles ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-mbtiles ---
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-mbtiles ---
[INFO] Compiling 3 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/target/classes>
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/src/main/java/org/geoserver/mbtiles/gs/wps/MBTilesProcess.java>:\[134,49\] error: cannot find symbol
[ERROR] variable storage of type WPSStorageCleaner
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/src/main/java/org/geoserver/mbtiles/gs/wps/MBTilesProcess.java>:\[291,26\] error: cannot find symbol
[INFO] 2 errors
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [12.364s]
[INFO] Core Platform Module .............................. SUCCESS [8.734s]
[INFO] Open Web Service Module ........................... SUCCESS [15.845s]
[INFO] Main Module ....................................... SUCCESS [43.456s]
[INFO] GeoServer Security Modules ........................ SUCCESS [2.259s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [8.486s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [7.095s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.349s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [9.057s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [12.003s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [12.062s]
[INFO] Web Feature Service Module ........................ SUCCESS [17.654s]
[INFO] Web Map Service Module ............................ SUCCESS [20.536s]
[INFO] KML support for GeoServer ......................... SUCCESS [11.238s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [16.555s]
[INFO] REST Support Module ............................... SUCCESS [7.631s]
[INFO] REST Configuration Service Module ................. SUCCESS [13.348s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.152s]
[INFO] Core UI Module .................................... SUCCESS [16.416s]
[INFO] WMS UI Module ..................................... SUCCESS [8.832s]
[INFO] GWC UI Module ..................................... SUCCESS [9.664s]
[INFO] WFS UI Module ..................................... SUCCESS [5.475s]
[INFO] Demoes Module ..................................... SUCCESS [7.758s]
[INFO] WCS UI Module ..................................... SUCCESS [7.498s]
[INFO] Security UI Modules ............................... SUCCESS [0.139s]
[INFO] Security UI Core Module ........................... SUCCESS [12.318s]
[INFO] Security UI JDBC Module ........................... SUCCESS [6.773s]
[INFO] Security UI LDAP Module ........................... SUCCESS [5.801s]
[INFO] REST UI Module .................................... SUCCESS [5.461s]
[INFO] GeoServer Web Application ......................... SUCCESS [9.384s]
[INFO] Community Space ................................... SUCCESS [0.231s]
[INFO] Authentication by unique url key .................. SUCCESS [28.318s]
[INFO] WorldWind Format Module ........................... SUCCESS [6.567s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.131s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.128s]
[INFO] Web Processing Service Module ..................... SUCCESS [14.575s]
[INFO] GPX PPIO for WPS .................................. SUCCESS [5.378s]
[INFO] NetCDF Coverage format ............................ SUCCESS [8.229s]
[INFO] DownloadProcess ................................... SUCCESS [6.946s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [6.859s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [2.804s]
[INFO] GeoServer Scripting Extensions .................... SUCCESS [0.512s]
[INFO] Core Scripting Extension .......................... SUCCESS [7.221s]
[INFO] H2 DataStore Extension ............................ SUCCESS [4.569s]
[INFO] Python Scripting Extension ........................ SUCCESS [11.689s]
[INFO] JavaScript Scripting Extension .................... SUCCESS [6.842s]
[INFO] Groovy Scripting Extension ........................ SUCCESS [19.549s]
[INFO] GeoServer JDBC KV Catalog ......................... SUCCESS [8.875s]
[INFO] Simple Feature Service ............................ SUCCESS [6.060s]
[INFO] Aggregating Data Store ............................ SUCCESS [4.112s]
[INFO] WMS-EO ............................................ SUCCESS [7.615s]
[INFO] ColorMap .......................................... SUCCESS [5.850s]
[INFO] GeoServer mbtiles Extension ....................... FAILURE [3.363s]
[INFO] Total time: 8:15.171s
[INFO] Finished at: Thu Nov 20 08:09:14 UTC 2014
[INFO] Final Memory: 92M/248M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-mbtiles: Compilation failure: Compilation failure:
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/src/main/java/org/geoserver/mbtiles/gs/wps/MBTilesProcess.java>:\[291,26\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-mbtiles
Hudson
3
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/452/changes>
Changes:
[andrea.aime] Have the artifact store work with a NIO lock directory inside GEOSERVER_DATA_DIR/tmp
[...truncated 7492 lines...]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.commit.message.short = Have the artifact store work with a NIO lock directory inside GEOSERVER_DATA_DIR/tmp
[INFO] [GitCommitIdMojo] build.commit.time = 20.11.2014 @ 13:57:15 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 21-Nov-2014 08:00
[INFO] [GitCommitIdMojo] build.build.time = 21.11.2014 @ 08:08:50 UTC
[INFO] [GitCommitIdMojo] build.branch = 23539377421cf4ee1bcfd092ff661b2e2fccbcc7
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 2353937
[INFO] [GitCommitIdMojo] build.commit.id = 23539377421cf4ee1bcfd092ff661b2e2fccbcc7
[INFO] [GitCommitIdMojo] build.commit.message.full = Have the artifact store work with a NIO lock directory inside GEOSERVER_DATA_DIR/tmp
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
967/967 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-mbtiles/13-SNAPSHOT/maven-metadata.xml (967 B at 27.8 KB/sec)
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 21.11.2014 @ 08:08:51 UTC
[INFO]
[INFO]
[INFO] 2 errors
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [11.066s]
[INFO] Core Platform Module .............................. SUCCESS [7.611s]
[INFO] Open Web Service Module ........................... SUCCESS [16.676s]
[INFO] Main Module ....................................... SUCCESS [40.075s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.963s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [6.656s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [7.286s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.327s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [8.616s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [9.377s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [11.511s]
[INFO] Web Feature Service Module ........................ SUCCESS [18.414s]
[INFO] Web Map Service Module ............................ SUCCESS [21.916s]
[INFO] KML support for GeoServer ......................... SUCCESS [11.527s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [15.975s]
[INFO] REST Support Module ............................... SUCCESS [6.850s]
[INFO] REST Configuration Service Module ................. SUCCESS [12.864s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.228s]
[INFO] Core UI Module .................................... SUCCESS [19.147s]
[INFO] WMS UI Module ..................................... SUCCESS [8.364s]
[INFO] GWC UI Module ..................................... SUCCESS [10.290s]
[INFO] WFS UI Module ..................................... SUCCESS [5.458s]
[INFO] Demoes Module ..................................... SUCCESS [8.256s]
[INFO] WCS UI Module ..................................... SUCCESS [6.316s]
[INFO] Security UI Modules ............................... SUCCESS [0.194s]
[INFO] Security UI Core Module ........................... SUCCESS [12.781s]
[INFO] Security UI JDBC Module ........................... SUCCESS [6.705s]
[INFO] Security UI LDAP Module ........................... SUCCESS [5.916s]
[INFO] REST UI Module .................................... SUCCESS [5.520s]
[INFO] GeoServer Web Application ......................... SUCCESS [23.882s]
[INFO] Community Space ................................... SUCCESS [0.247s]
[INFO] Authentication by unique url key .................. SUCCESS [14.904s]
[INFO] WorldWind Format Module ........................... SUCCESS [6.829s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.228s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.166s]
[INFO] Web Processing Service Module ..................... SUCCESS [15.626s]
[INFO] GPX PPIO for WPS .................................. SUCCESS [5.515s]
[INFO] NetCDF Coverage format ............................ SUCCESS [6.289s]
[INFO] DownloadProcess ................................... SUCCESS [6.042s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [7.253s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [3.109s]
[INFO] GeoServer Scripting Extensions .................... SUCCESS [0.239s]
[INFO] Core Scripting Extension .......................... SUCCESS [7.668s]
[INFO] H2 DataStore Extension ............................ SUCCESS [5.105s]
[INFO] Python Scripting Extension ........................ SUCCESS [9.146s]
[INFO] JavaScript Scripting Extension .................... SUCCESS [7.585s]
[INFO] Groovy Scripting Extension ........................ SUCCESS [20.902s]
[INFO] GeoServer JDBC KV Catalog ......................... SUCCESS [8.449s]
[INFO] Simple Feature Service ............................ SUCCESS [5.310s]
[INFO] Aggregating Data Store ............................ SUCCESS [3.885s]
[INFO] WMS-EO ............................................ SUCCESS [7.624s]
[INFO] ColorMap .......................................... SUCCESS [5.714s]
[INFO] GeoServer mbtiles Extension ....................... FAILURE [3.568s]
[INFO] Total time: 8:04.993s
[INFO] Finished at: Fri Nov 21 08:08:54 UTC 2014
[INFO] Final Memory: 92M/241M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Hudson
4
