See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/464/changes>
Changes:
[andrea.aime] [GEOS-6764] Ability to cancel/dismiss asynchronous WPS processes still executing in the server
[niels] Geopackage: close connections.
[...truncated 5119 lines...]
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-netcdf >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-netcdf ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #842 from NielsCharlier/master
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 02.12.2014 @ 15:26:45 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 03-Dec-2014 08:01
[INFO] [GitCommitIdMojo] build.build.time = 03.12.2014 @ 08:07:51 UTC
[INFO] [GitCommitIdMojo] build.branch = 3896241526e61ed95c313a1f7f29cf5438d3195c
[INFO] [GitCommitIdMojo] build.commit.user.email = niels@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = NielsCharlier
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 3896241
[INFO] [GitCommitIdMojo] build.commit.id = 3896241526e61ed95c313a1f7f29cf5438d3195c
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #842 from NielsCharlier/master
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-netcdf <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-netcdf ---
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ gs-netcdf ---
[INFO] Copying gt-api-13-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/netcdf/target/dependency/gt-api-13-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.7-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/netcdf/target/dependency/gwc-core-1.7-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-netcdf ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/netcdf/target/gs-netcdf-2.7-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-netcdf/2.7-SNAPSHOT/gs-netcdf-2.7-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/netcdf/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-netcdf/2.7-SNAPSHOT/gs-netcdf-2.7-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/netcdf/target/gs-netcdf-2.7-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-netcdf/2.7-SNAPSHOT/gs-netcdf-2.7-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/netcdf/target/gs-netcdf-2.7-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-netcdf/2.7-SNAPSHOT/gs-netcdf-2.7-SNAPSHOT-sources.jar
[INFO]
[INFO] Building DownloadProcess 2.7-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-wps-download ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wps-download/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-wps-download ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wps-download ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-wps-download ---
[INFO] Copying 0 resource
[INFO] Copying 2 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-wps-download ---
[INFO] Compiling 15 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wps-download/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-wps-download ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-wps-download ---
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wps-download/target/test-classes>
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wps-download/src/test/java/org/geoserver/wps/gs/download/DownloadProcessTest.java>:\[944,52\] error: cannot find symbol
[ERROR] class ProcessState
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wps-download/src/test/java/org/geoserver/wps/gs/download/DownloadProcessTest.java>:\[954,44\] error: cannot find symbol
[INFO] 2 errors
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.692s]
[INFO] Core Platform Module .............................. SUCCESS [7.572s]
[INFO] Open Web Service Module ........................... SUCCESS [9.016s]
[INFO] Main Module ....................................... SUCCESS [32.409s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.287s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [7.681s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [6.065s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.268s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [8.901s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [9.872s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [13.846s]
[INFO] Web Feature Service Module ........................ SUCCESS [18.069s]
[INFO] Web Map Service Module ............................ SUCCESS [19.544s]
[INFO] KML support for GeoServer ......................... SUCCESS [12.177s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [17.519s]
[INFO] REST Support Module ............................... SUCCESS [7.765s]
[INFO] REST Configuration Service Module ................. SUCCESS [12.914s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.120s]
[INFO] Core UI Module .................................... SUCCESS [20.267s]
[INFO] WMS UI Module ..................................... SUCCESS [8.128s]
[INFO] GWC UI Module ..................................... SUCCESS [9.933s]
[INFO] WFS UI Module ..................................... SUCCESS [5.648s]
[INFO] Demoes Module ..................................... SUCCESS [9.589s]
[INFO] WCS UI Module ..................................... SUCCESS [7.179s]
[INFO] Security UI Modules ............................... SUCCESS [0.192s]
[INFO] Security UI Core Module ........................... SUCCESS [12.730s]
[INFO] Security UI JDBC Module ........................... SUCCESS [6.690s]
[INFO] Security UI LDAP Module ........................... SUCCESS [6.700s]
[INFO] REST UI Module .................................... SUCCESS [5.941s]
[INFO] GeoServer Web Application ......................... SUCCESS [12.342s]
[INFO] Community Space ................................... SUCCESS [3.340s]
[INFO] Authentication by unique url key .................. SUCCESS [22.061s]
[INFO] WorldWind Format Module ........................... SUCCESS [7.039s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.139s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.140s]
[INFO] Web Processing Service Module ..................... SUCCESS [16.727s]
[INFO] GPX PPIO for WPS .................................. SUCCESS [6.369s]
[INFO] NetCDF Coverage format ............................ SUCCESS [3.566s]
[INFO] DownloadProcess ................................... FAILURE [6.253s]
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Embedded FTP server ..................... SKIPPED
[INFO] GeoServer Scripting Extensions .................... SKIPPED
[INFO] Core Scripting Extension .......................... SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] Python Scripting Extension ........................ SKIPPED
[INFO] JavaScript Scripting Extension .................... SKIPPED
[INFO] Groovy Scripting Extension ........................ SKIPPED
[INFO] GeoServer JDBC KV Catalog ......................... SKIPPED
[INFO] Simple Feature Service ............................ SKIPPED
[INFO] Aggregating Data Store ............................ SKIPPED
[INFO] WMS-EO ............................................ SKIPPED
[INFO] ColorMap .......................................... SKIPPED
[INFO] GeoServer mbtiles Extension ....................... SKIPPED
[INFO] GeoServer GeoPackage Extension .................... SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] Dynamic WMS dimension value defaults .............. SKIPPED
[INFO] REST plugin community module ...................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] KML PPIO for WPS .................................. SKIPPED
[INFO] GeoServer JMS based clustering modules ............ SKIPPED
[INFO] GeoServer JMS clustering Commons module ........... SKIPPED
[INFO] GeoServer JMS clustering module ................... SKIPPED
[INFO] GeoFence security integration ..................... SKIPPED
[INFO] Solr Module ....................................... SKIPPED
[INFO] GeoServer Community Release Module ................ SKIPPED
[INFO] SpatiaLite Extension .............................. SKIPPED
[INFO] Web UI Scripting Extension ........................ SKIPPED
[INFO] BeanShell Scripting Extension ..................... SKIPPED
[INFO] Ruby Scripting Extension .......................... SKIPPED
[INFO] ActiveMQ .......................................... SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 6:12.301s
[INFO] Finished at: Wed Dec 03 08:07:58 UTC 2014
[INFO] Final Memory: 71M/245M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-wps-download: Compilation failure: Compilation failure:
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wps-download/src/test/java/org/geoserver/wps/gs/download/DownloadProcessTest.java>:\[954,44\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-download
