See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/471/>
[...truncated 2416 lines...]
Downloading: http://download.osgeo.org/webdav/geotools/org/geowebcache/gwc-kml/1.7-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-kml/1.7-SNAPSHOT/maven-metadata.xml (2 KB at 9.3 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-rest/1.7-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geowebcache/gwc-rest/1.7-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-rest/1.7-SNAPSHOT/maven-metadata.xml (2 KB at 7.8 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/geowebcache/gwc-tms/1.7-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-tms/1.7-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-tms/1.7-SNAPSHOT/maven-metadata.xml (2 KB at 4.3 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-ve/1.7-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geowebcache/gwc-ve/1.7-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-ve/1.7-SNAPSHOT/maven-metadata.xml (2 KB at 9.4 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-wms/1.7-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geowebcache/gwc-wms/1.7-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-wms/1.7-SNAPSHOT/maven-metadata.xml (2 KB at 10.2 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-wmts/1.7-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geowebcache/gwc-wmts/1.7-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-wmts/1.7-SNAPSHOT/maven-metadata.xml (2 KB at 7.8 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/geowebcache/gwc-diskquota-jdbc/1.7-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-diskquota-jdbc/1.7-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-diskquota-jdbc/1.7-SNAPSHOT/maven-metadata.xml (2 KB at 5.3 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-diskquota/1.7-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geowebcache/gwc-diskquota/1.7-SNAPSHOT/maven-metadata.xml
803/803 B
Downloaded: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-diskquota/1.7-SNAPSHOT/maven-metadata.xml (803 B at 7.5 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/geowebcache/gwc-diskquota-core/1.7-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-diskquota-core/1.7-SNAPSHOT/maven-metadata.xml
Downloading: http://repository.codehaus.org/org/geowebcache/gwc-diskquota-core/1.7-SNAPSHOT/maven-metadata.xml
Downloading: http://download.oracle.com/maven/org/geowebcache/gwc-diskquota-core/1.7-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-diskquota-core/1.7-SNAPSHOT/maven-metadata.xml (2 KB at 6.5 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-gwc ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/gwc/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-gwc ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-gwc ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #846 from Geodan/GEOS-6688-2
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 08.12.2014 @ 20:20:05 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 10-Dec-2014 08:01
[INFO] [GitCommitIdMojo] build.build.time = 10.12.2014 @ 08:05:02 UTC
[INFO] [GitCommitIdMojo] build.branch = c42f9cd33044dec6968e3ccced3ea96c9ca04f81
[INFO] [GitCommitIdMojo] build.commit.user.email = jody.garnett@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Jody Garnett
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = c42f9cd
[INFO] [GitCommitIdMojo] build.commit.id = c42f9cd33044dec6968e3ccced3ea96c9ca04f81
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #846 from Geodan/GEOS-6688-2
[GEOS-6688] Addition to support more interpolation types.
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-gwc ---
[INFO] Copying 0 resource
[INFO] Copying 13 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-gwc ---
[INFO] Compiling 40 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/gwc/target/classes>
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/layer/GeoServerTileLayer.java>:\[83,7\] error: GeoServerTileLayer is not abstract and does not override abstract method setTransientLayer(boolean) in TileLayer
[INFO] 1 error
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [10.805s]
[INFO] Core Platform Module .............................. SUCCESS [10.631s]
[INFO] Open Web Service Module ........................... SUCCESS [14.118s]
[INFO] Main Module ....................................... SUCCESS [41.258s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.891s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [7.493s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [7.313s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.730s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [9.738s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [11.071s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [12.367s]
[INFO] Web Feature Service Module ........................ SUCCESS [18.003s]
[INFO] Web Map Service Module ............................ SUCCESS [24.231s]
[INFO] KML support for GeoServer ......................... SUCCESS [12.569s]
[INFO] GeoWebCache (GWC) Module .......................... FAILURE [10.314s]
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Authentication by unique url key .................. SKIPPED
[INFO] WorldWind Format Module ........................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GPX PPIO for WPS .................................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] DownloadProcess ................................... SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Embedded FTP server ..................... SKIPPED
[INFO] GeoServer Scripting Extensions .................... SKIPPED
[INFO] Core Scripting Extension .......................... SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] Python Scripting Extension ........................ SKIPPED
[INFO] JavaScript Scripting Extension .................... SKIPPED
[INFO] Groovy Scripting Extension ........................ SKIPPED
[INFO] GeoServer JDBC KV Catalog ......................... SKIPPED
[INFO] Simple Feature Service ............................ SKIPPED
[INFO] Aggregating Data Store ............................ SKIPPED
[INFO] WMS-EO ............................................ SKIPPED
[INFO] ColorMap .......................................... SKIPPED
[INFO] GeoServer mbtiles Extension ....................... SKIPPED
[INFO] GeoServer GeoPackage Extension .................... SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] Dynamic WMS dimension value defaults .............. SKIPPED
[INFO] REST plugin community module ...................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] KML PPIO for WPS .................................. SKIPPED
[INFO] GeoServer JMS based clustering modules ............ SKIPPED
[INFO] GeoServer JMS clustering Commons module ........... SKIPPED
[INFO] GeoServer JMS clustering module ................... SKIPPED
[INFO] GeoFence security integration ..................... SKIPPED
[INFO] Solr Module ....................................... SKIPPED
[INFO] GeoServer Community Release Module ................ SKIPPED
[INFO] SpatiaLite Extension .............................. SKIPPED
[INFO] Web UI Scripting Extension ........................ SKIPPED
[INFO] BeanShell Scripting Extension ..................... SKIPPED
[INFO] Ruby Scripting Extension .......................... SKIPPED
[INFO] ActiveMQ .......................................... SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 3:24.382s
[INFO] Finished at: Wed Dec 10 08:05:08 UTC 2014
[INFO] Final Memory: 53M/188M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-gwc: Compilation failure
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
