[Geoserver-devel] Build failed in Jenkins: geoserver-master-nightly #507
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/507/changes&gt;
Changes:
[niels] Geopackag: write spatial index in process & wfs
[andrea.aime] [GEOS-2420] Add support to limit WPS resource consuption
[andrea.aime] [GEOS-2420], headers and javadoc fixes following Jody's review
[lago.88] Various fixes for GeoServer GUI + JDBCConfig
[groldan] Preventing full scan of workspace/namespace with custom namespace support class.
[groldan] Moved data store flush on feature type delete to event listener
[cdwinslow] Use proper namespace for BoundingBox elements constructed in WPS request builder
[cdwinslow] Add unit test for bounding box encoding
[jody.garnett] minor change to logging level and file header
[...truncated 6740 lines...]
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-feature-aggregate ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/feature-aggregate/target/gs-feature-aggregate-2.7-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-feature-aggregate >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-feature-aggregate ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #849 from NielsCharlier/geopkg
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 16.01.2015 @ 00:20:38 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 16-Jan-2015 08:00
[INFO] [GitCommitIdMojo] build.build.time = 16.01.2015 @ 08:07:54 UTC
[INFO] [GitCommitIdMojo] build.branch = f98497abd48b61a29661596e40239c98622e3e51
[INFO] [GitCommitIdMojo] build.commit.user.email = ksmith@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Kevin Smith
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = f98497a
[INFO] [GitCommitIdMojo] build.commit.id = f98497abd48b61a29661596e40239c98622e3e51
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #849 from NielsCharlier/geopkg
Geopackage: write spatial index in process & wfs
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-feature-aggregate <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-feature-aggregate ---
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ gs-feature-aggregate ---
[INFO] Copying gt-api-13-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/feature-aggregate/target/dependency/gt-api-13-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.7-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/feature-aggregate/target/dependency/gwc-core-1.7-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-feature-aggregate ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/feature-aggregate/target/gs-feature-aggregate-2.7-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-feature-aggregate/2.7-SNAPSHOT/gs-feature-aggregate-2.7-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/feature-aggregate/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-feature-aggregate/2.7-SNAPSHOT/gs-feature-aggregate-2.7-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/feature-aggregate/target/gs-feature-aggregate-2.7-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-feature-aggregate/2.7-SNAPSHOT/gs-feature-aggregate-2.7-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/feature-aggregate/target/gs-feature-aggregate-2.7-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-feature-aggregate/2.7-SNAPSHOT/gs-feature-aggregate-2.7-SNAPSHOT-sources.jar
[INFO]
[INFO] Building WMS-EO 2.7-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-wms-eo ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wms-eo/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-wms-eo ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wms-eo ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-wms-eo ---
[INFO] Copying 12 resources
[INFO] Copying 19 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-wms-eo ---
[INFO] Compiling 26 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wms-eo/target/classes&gt;
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wms-eo/src/main/java/org/geoserver/wms/eo/EoCatalogBuilder.java&gt;:\[348,35\] error: cannot find symbol
[ERROR] interface LayerInfo
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wms-eo/src/main/java/org/geoserver/wms/eo/EoCatalogBuilder.java&gt;:\[472,35\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wms-eo/src/main/java/org/geoserver/wms/eo/web/EoCoverageSelectorPage.java&gt;:\[255,35\] error: cannot find symbol
[INFO] 3 errors
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [4.054s]
[INFO] Core Platform Module .............................. SUCCESS [6.288s]
[INFO] Open Web Service Module ........................... SUCCESS [8.499s]
[INFO] Main Module ....................................... SUCCESS [33.102s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.320s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [7.396s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [5.493s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.284s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [8.189s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [11.344s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [12.646s]
[INFO] Web Feature Service Module ........................ SUCCESS [19.447s]
[INFO] Web Map Service Module ............................ SUCCESS [18.904s]
[INFO] KML support for GeoServer ......................... SUCCESS [10.686s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [12.649s]
[INFO] REST Support Module ............................... SUCCESS [6.362s]
[INFO] REST Configuration Service Module ................. SUCCESS [12.439s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.138s]
[INFO] Core UI Module .................................... SUCCESS [18.480s]
[INFO] WMS UI Module ..................................... SUCCESS [8.177s]
[INFO] GWC UI Module ..................................... SUCCESS [11.354s]
[INFO] WFS UI Module ..................................... SUCCESS [5.083s]
[INFO] Demoes Module ..................................... SUCCESS [8.025s]
[INFO] WCS UI Module ..................................... SUCCESS [6.886s]
[INFO] Security UI Modules ............................... SUCCESS [0.215s]
[INFO] Security UI Core Module ........................... SUCCESS [13.362s]
[INFO] Security UI JDBC Module ........................... SUCCESS [6.431s]
[INFO] Security UI LDAP Module ........................... SUCCESS [6.724s]
[INFO] REST UI Module .................................... SUCCESS [4.826s]
[INFO] GeoServer Web Application ......................... SUCCESS [7.984s]
[INFO] Community Space ................................... SUCCESS [0.176s]
[INFO] Authentication by unique url key .................. SUCCESS [27.941s]
[INFO] WorldWind Format Module ........................... SUCCESS [6.909s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.177s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.184s]
[INFO] Web Processing Service Module ..................... SUCCESS [16.023s]
[INFO] GPX PPIO for WPS .................................. SUCCESS [5.916s]
[INFO] NetCDF Coverage format ............................ SUCCESS [4.555s]
[INFO] DownloadProcess ................................... SUCCESS [9.311s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [6.949s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [2.854s]
[INFO] GeoServer Scripting Extensions .................... SUCCESS [0.500s]
[INFO] Core Scripting Extension .......................... SUCCESS [7.938s]
[INFO] H2 DataStore Extension ............................ SUCCESS [5.043s]
[INFO] Python Scripting Extension ........................ SUCCESS [10.898s]
[INFO] JavaScript Scripting Extension .................... SUCCESS [6.989s]
[INFO] Groovy Scripting Extension ........................ SUCCESS [16.176s]
[INFO] GeoServer JDBC KV Catalog ......................... SUCCESS [9.981s]
[INFO] Simple Feature Service ............................ SUCCESS [5.459s]
[INFO] Aggregating Data Store ............................ SUCCESS [3.507s]
[INFO] WMS-EO ............................................ FAILURE [4.777s]
[INFO] ColorMap .......................................... SKIPPED
[INFO] GeoServer mbtiles Extension ....................... SKIPPED
[INFO] GeoServer GeoPackage Extension .................... SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] Dynamic WMS dimension value defaults .............. SKIPPED
[INFO] REST plugin community module ...................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] KML PPIO for WPS .................................. SKIPPED
[INFO] GeoServer JMS based clustering modules ............ SKIPPED
[INFO] GeoServer JMS clustering Commons module ........... SKIPPED
[INFO] GeoServer JMS clustering module ................... SKIPPED
[INFO] GeoFence security integration ..................... SKIPPED
[INFO] REST SLD service .................................. SKIPPED
[INFO] Solr Module ....................................... SKIPPED
[INFO] GeoServer Community Release Module ................ SKIPPED
[INFO] SpatiaLite Extension .............................. SKIPPED
[INFO] Web UI Scripting Extension ........................ SKIPPED
[INFO] BeanShell Scripting Extension ..................... SKIPPED
[INFO] Ruby Scripting Extension .......................... SKIPPED
[INFO] ActiveMQ .......................................... SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 7:18.397s
[INFO] Finished at: Fri Jan 16 08:07:59 UTC 2015
[INFO] Final Memory: 90M/265M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-wms-eo: Compilation failure: Compilation failure:
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wms-eo/src/main/java/org/geoserver/wms/eo/EoCatalogBuilder.java&gt;:\[472,35\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wms-eo/src/main/java/org/geoserver/wms/eo/web/EoCoverageSelectorPage.java&gt;:\[255,35\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms-eo
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/508/changes&gt;
