Hudson
1
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/551/changes>
Changes:
[lago.88] [GEOS-6886] REST resumable upload community module
[andrea.aime] Reference and tutorial for the importer REST api
[andrea.aime] Use the removeSchema datastore api insetad of hand-written sql (which is incomplete for some dbms, and won't work on other stores)
[maurobartolomeoli] GEOS-6908: fixed geofence allowed area reprojection
[...truncated 11879 lines...]
1209/1328 KB
1211/1328 KB
1215/1328 KB
1215/1328 KB
1216/1328 KB
1220/1328 KB
1221/1328 KB
1222/1328 KB
1226/1328 KB
1226/1328 KB
1229/1328 KB
1232/1328 KB
1235/1328 KB
1238/1328 KB
1241/1328 KB
1243/1328 KB
1246/1328 KB
1249/1328 KB
1252/1328 KB
1255/1328 KB
1257/1328 KB
1260/1328 KB
1263/1328 KB
1266/1328 KB
1269/1328 KB
1272/1328 KB
1274/1328 KB
1277/1328 KB
1280/1328 KB
1283/1328 KB
1286/1328 KB
1289/1328 KB
1291/1328 KB
1294/1328 KB
1297/1328 KB
1300/1328 KB
1303/1328 KB
1306/1328 KB
1308/1328 KB
1311/1328 KB
1314/1328 KB
1317/1328 KB
1320/1328 KB
1324/1328 KB
1324/1328 KB
1325/1328 KB
1327/1328 KB
1328/1328 KB
Downloaded: http://repo.boundlessgeo.com/main/org/geoserver/web/gs-web-core/2.7-SNAPSHOT/gs-web-core-2.7-20150224.191236-338.jar (1328 KB at 3293.7 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-rest-upload ---
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-rest-upload ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-rest-upload ---
Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/community/2.7-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.boundlessgeo.com/main/org/geoserver/community/2.7-SNAPSHOT/maven-metadata.xml
801/801 B
Downloaded: http://repo.boundlessgeo.com/main/org/geoserver/community/2.7-SNAPSHOT/maven-metadata.xml (801 B at 20.1 KB/sec)
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #944 from mbarto/geos6908_geofence_area_reproject
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 24.02.2015 @ 17:32:01 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 25-Feb-2015 08:01
[INFO] [GitCommitIdMojo] build.build.time = 25.02.2015 @ 08:12:08 UTC
[INFO] [GitCommitIdMojo] build.branch = 7ce2fe9cf307a6dfc01cc3994f7ba730c5ee74cf
[INFO] [GitCommitIdMojo] build.commit.user.email = simone.giannecchini@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Simone Giannecchini
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 7ce2fe9
[INFO] [GitCommitIdMojo] build.commit.id = 7ce2fe9cf307a6dfc01cc3994f7ba730c5ee74cf
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #944 from mbarto/geos6908_geofence_area_reproject
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-rest-upload ---
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/rest-upload/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-rest-upload ---
[INFO] Compiling 5 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/rest-upload/target/classes>
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/rest-upload/src/main/java/org/geoserver/restupload/ResumableUploadResourceManager.java>:\[82,38\] error: cannot find symbol
[INFO] 1 error
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.504s]
[INFO] Core Platform Module .............................. SUCCESS [6.004s]
[INFO] Open Web Service Module ........................... SUCCESS [11.844s]
[INFO] Main Module ....................................... SUCCESS [35.928s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.709s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [7.542s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [5.366s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.904s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [10.089s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [10.526s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [11.991s]
[INFO] Web Feature Service Module ........................ SUCCESS [18.081s]
[INFO] Web Map Service Module ............................ SUCCESS [20.926s]
[INFO] KML support for GeoServer ......................... SUCCESS [10.684s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [14.771s]
[INFO] REST Support Module ............................... SUCCESS [6.029s]
[INFO] REST Configuration Service Module ................. SUCCESS [11.894s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.146s]
[INFO] Core UI Module .................................... SUCCESS [19.945s]
[INFO] WMS UI Module ..................................... SUCCESS [8.510s]
[INFO] GWC UI Module ..................................... SUCCESS [9.856s]
[INFO] WFS UI Module ..................................... SUCCESS [6.010s]
[INFO] Demoes Module ..................................... SUCCESS [8.494s]
[INFO] WCS UI Module ..................................... SUCCESS [7.029s]
[INFO] Security UI Modules ............................... SUCCESS [0.204s]
[INFO] Security UI Core Module ........................... SUCCESS [11.773s]
[INFO] Security UI JDBC Module ........................... SUCCESS [6.308s]
[INFO] Security UI LDAP Module ........................... SUCCESS [5.437s]
[INFO] REST UI Module .................................... SUCCESS [5.145s]
[INFO] GeoServer Web Application ......................... SUCCESS [23.432s]
[INFO] Community Space ................................... SUCCESS [9.407s]
[INFO] Authentication by unique url key .................. SUCCESS [9.670s]
[INFO] WorldWind Format Module ........................... SUCCESS [6.541s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.147s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.216s]
[INFO] Web Processing Service Module ..................... SUCCESS [16.157s]
[INFO] GPX PPIO for WPS .................................. SUCCESS [6.284s]
[INFO] NetCDF Coverage format ............................ SUCCESS [7.959s]
[INFO] DownloadProcess ................................... SUCCESS [6.766s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [6.968s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [3.159s]
[INFO] GeoServer Scripting Extensions .................... SUCCESS [0.299s]
[INFO] Core Scripting Extension .......................... SUCCESS [7.697s]
[INFO] H2 DataStore Extension ............................ SUCCESS [4.749s]
[INFO] Python Scripting Extension ........................ SUCCESS [7.926s]
[INFO] JavaScript Scripting Extension .................... SUCCESS [6.356s]
[INFO] Groovy Scripting Extension ........................ SUCCESS [18.730s]
[INFO] GeoServer JDBC KV Catalog ......................... SUCCESS [8.985s]
[INFO] Simple Feature Service ............................ SUCCESS [5.310s]
[INFO] Aggregating Data Store ............................ SUCCESS [4.317s]
[INFO] WMS-EO ............................................ SUCCESS [8.977s]
[INFO] ColorMap .......................................... SUCCESS [5.267s]
[INFO] GeoServer mbtiles Extension ....................... SUCCESS [7.366s]
[INFO] GeoServer GeoPackage Extension .................... SUCCESS [6.419s]
[INFO] GRIB Coverage Format .............................. SUCCESS [6.919s]
[INFO] Dynamic WMS dimension value defaults .............. SUCCESS [6.904s]
[INFO] REST plugin community module ...................... SUCCESS [5.715s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [3.177s]
[INFO] KML PPIO for WPS .................................. SUCCESS [5.488s]
[INFO] GeoServer JMS based clustering modules ............ SUCCESS [2.644s]
[INFO] GeoServer JMS clustering Commons module ........... SUCCESS [2.847s]
[INFO] GeoServer JMS clustering module ................... SUCCESS [19.910s]
[INFO] GeoFence security integration ..................... SUCCESS [9.524s]
[INFO] REST SLD service .................................. SUCCESS [6.969s]
[INFO] Solr Module ....................................... SUCCESS [6.877s]
[INFO] GeoServer Community Release Module ................ SUCCESS [3.496s]
[INFO] SpatiaLite Extension .............................. SUCCESS [20.682s]
[INFO] Web UI Scripting Extension ........................ SUCCESS [6.320s]
[INFO] BeanShell Scripting Extension ..................... SUCCESS [5.225s]
[INFO] Ruby Scripting Extension .......................... SUCCESS [5.567s]
[INFO] ActiveMQ .......................................... SUCCESS [6.060s]
[INFO] Resumable REST Upload module ...................... FAILURE [37.627s]
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 10:38.911s
[INFO] Finished at: Wed Feb 25 08:12:12 UTC 2015
[INFO] Final Memory: 112M/357M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-rest-upload: Compilation failure
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-rest-upload
Hudson
2
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/552/changes>
Changes:
[andrea.aime] [GEOS-6900] Allow PPIO to be created at runtime and specify their direction
[maurobartolomeoli] GEOS-6909: let authkey parameter name be case insensitive
[lago.88] Fixed rest-upload community module dependency and assembly pom
[andrea.aime] [GEOS-6901] OGR based WPS output formats
[...truncated 16997 lines...]
[INFO] Copying iso-19139-2007-1.0.0-1.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/iso-19139-2007-1.0.0-1.jar>
[INFO] Copying ows-1.0-1.0.0-2.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/ows-1.0-1.0.0-2.jar>
[INFO] Copying xlink-1.0-1.0.0-3.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/xlink-1.0-1.0.0-3.jar>
[INFO] Copying gt-xsd-core-14-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/gt-xsd-core-14-SNAPSHOT.jar>
[INFO] Copying gt-xsd-csw-14-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/gt-xsd-csw-14-SNAPSHOT.jar>
[INFO] Copying gt-xsd-fes-14-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/gt-xsd-fes-14-SNAPSHOT.jar>
[INFO] Copying gt-xsd-filter-14-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/gt-xsd-filter-14-SNAPSHOT.jar>
[INFO] Copying gt-xsd-gml2-14-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/gt-xsd-gml2-14-SNAPSHOT.jar>
[INFO] Copying gt-xsd-gml3-14-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/gt-xsd-gml3-14-SNAPSHOT.jar>
[INFO] Copying gt-xsd-kml-14-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/gt-xsd-kml-14-SNAPSHOT.jar>
[INFO] Copying gt-xsd-ows-14-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/gt-xsd-ows-14-SNAPSHOT.jar>
[INFO] Copying gt-xsd-sld-14-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/gt-xsd-sld-14-SNAPSHOT.jar>
[INFO] Copying gt-xsd-wcs-14-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/gt-xsd-wcs-14-SNAPSHOT.jar>
[INFO] Copying gt-xsd-wfs-14-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/gt-xsd-wfs-14-SNAPSHOT.jar>
[INFO] Copying gt-xsd-wps-14-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/gt-xsd-wps-14-SNAPSHOT.jar>
[INFO] Copying hamcrest-core-1.3.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/hamcrest-core-1.3.jar>
[INFO] Copying ejb3-persistence-1.0.2.GA.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/ejb3-persistence-1.0.2.GA.jar>
[INFO] Copying hibernate-annotations-3.4.0.GA.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/hibernate-annotations-3.4.0.GA.jar>
[INFO] Copying hibernate-commons-annotations-3.1.0.GA.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/hibernate-commons-annotations-3.1.0.GA.jar>
[INFO] Copying hibernate-core-3.3.0.SP1.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/hibernate-core-3.3.0.SP1.jar>
[INFO] Copying hibernate-entitymanager-3.4.0.GA.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/hibernate-entitymanager-3.4.0.GA.jar>
[INFO] Copying hsqldb-2.2.8.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/hsqldb-2.2.8.jar>
[INFO] Copying jt-attributeop-1.3.1.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/jt-attributeop-1.3.1.jar>
[INFO] Copying jt-contour-1.3.1.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/jt-contour-1.3.1.jar>
[INFO] Copying jt-rangelookup-1.3.1.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/jt-rangelookup-1.3.1.jar>
[INFO] Copying jt-utils-1.3.1.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/jt-utils-1.3.1.jar>
[INFO] Copying jt-vectorbinarize-1.3.1.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/jt-vectorbinarize-1.3.1.jar>
[INFO] Copying jt-vectorize-1.3.1.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/jt-vectorize-1.3.1.jar>
[INFO] Copying jt-zonalstats-1.3.1.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/jt-zonalstats-1.3.1.jar>
[INFO] Copying cas-client-core-3.1.12.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/cas-client-core-3.1.12.jar>
[INFO] Copying jasypt-1.8.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/jasypt-1.8.jar>
[INFO] Copying jdom-1.1.3.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/jdom-1.1.3.jar>
[INFO] Copying json-20080701.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/json-20080701.jar>
[INFO] Copying jyaml-1.3.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/jyaml-1.3.jar>
[INFO] Copying turbojpeg-wrapper-1.2.1.1.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/turbojpeg-wrapper-1.2.1.1.jar>
[INFO] Copying mapfish-geo-lib-1.2.0.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/mapfish-geo-lib-1.2.0.jar>
[INFO] Copying print-lib-2.1.0.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/print-lib-2.1.0.jar>
[INFO] Copying mockito-core-1.8.5.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/mockito-core-1.8.5.jar>
[INFO] Copying jetty-6.1.8.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/jetty-6.1.8.jar>
[INFO] Copying jetty-util-6.1.8.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/jetty-util-6.1.8.jar>
[INFO] Copying servlet-api-2.5-6.1.8.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/servlet-api-2.5-6.1.8.jar>
[INFO] Copying objenesis-1.0.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/objenesis-1.0.jar>
[INFO] Copying prettytime-1.0.8.Final.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/prettytime-1.0.8.Final.jar>
[INFO] Copying geodb-0.7-RC2.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/geodb-0.7-RC2.jar>
[INFO] Copying asm-4.1.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/asm-4.1.jar>
[INFO] Copying asm-analysis-4.1.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/asm-analysis-4.1.jar>
[INFO] Copying asm-tree-4.1.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/asm-tree-4.1.jar>
[INFO] Copying asm-util-4.1.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/asm-util-4.1.jar>
[INFO] Copying encoder-1.1.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/encoder-1.1.jar>
[INFO] Copying parboiled-core-1.1.6.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/parboiled-core-1.1.6.jar>
[INFO] Copying parboiled-java-1.1.6.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/parboiled-java-1.1.6.jar>
[INFO] Copying org.restlet-1.0.8.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/org.restlet-1.0.8.jar>
[INFO] Copying org.restlet.ext.fileupload-1.0.8.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/org.restlet.ext.fileupload-1.0.8.jar>
[INFO] Copying org.restlet.ext.freemarker-1.0.8.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/org.restlet.ext.freemarker-1.0.8.jar>
[INFO] Copying org.restlet.ext.spring-1.0.8.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/org.restlet.ext.spring-1.0.8.jar>
[INFO] Copying slf4j-api-1.5.8.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/slf4j-api-1.5.8.jar>
[INFO] Copying slf4j-log4j12-1.4.2.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/slf4j-log4j12-1.4.2.jar>
[INFO] Copying spring-aop-3.1.4.RELEASE.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/spring-aop-3.1.4.RELEASE.jar>
[INFO] Copying spring-asm-3.1.4.RELEASE.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/spring-asm-3.1.4.RELEASE.jar>
[INFO] Copying spring-beans-3.1.4.RELEASE.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/spring-beans-3.1.4.RELEASE.jar>
[INFO] Copying spring-context-3.1.4.RELEASE.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/spring-context-3.1.4.RELEASE.jar>
[INFO] Copying spring-context-support-3.1.4.RELEASE.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/spring-context-support-3.1.4.RELEASE.jar>
[INFO] Copying spring-core-3.1.4.RELEASE.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/spring-core-3.1.4.RELEASE.jar>
[INFO] Copying spring-expression-3.1.4.RELEASE.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/spring-expression-3.1.4.RELEASE.jar>
[INFO] Copying spring-jdbc-3.1.4.RELEASE.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/spring-jdbc-3.1.4.RELEASE.jar>
[INFO] Copying spring-orm-3.1.4.RELEASE.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/spring-orm-3.1.4.RELEASE.jar>
[INFO] Copying spring-tx-3.1.4.RELEASE.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/spring-tx-3.1.4.RELEASE.jar>
[INFO] Copying spring-web-3.1.4.RELEASE.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/spring-web-3.1.4.RELEASE.jar>
[INFO] Copying spring-webmvc-3.1.4.RELEASE.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/spring-webmvc-3.1.4.RELEASE.jar>
[INFO] Copying spring-security-cas-3.1.0.RELEASE.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/spring-security-cas-3.1.0.RELEASE.jar>
[INFO] Copying spring-security-config-3.1.0.RELEASE.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/spring-security-config-3.1.0.RELEASE.jar>
[INFO] Copying spring-security-core-3.1.0.RELEASE.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/spring-security-core-3.1.0.RELEASE.jar>
[INFO] Copying spring-security-crypto-3.1.0.RELEASE.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/spring-security-crypto-3.1.0.RELEASE.jar>
[INFO] Copying spring-security-web-3.1.0.RELEASE.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/spring-security-web-3.1.0.RELEASE.jar>
[INFO] Copying htmlvalidator-1.2.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/htmlvalidator-1.2.jar>
[INFO] Copying picocontainer-1.2.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/picocontainer-1.2.jar>
[INFO] Copying postgresql-8.4-701.jdbc3.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/postgresql-8.4-701.jdbc3.jar>
[INFO] Copying stax-api-1.0.1.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/stax-api-1.0.1.jar>
[INFO] Copying jasper-compiler-5.5.15.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/jasper-compiler-5.5.15.jar>
[INFO] Copying jasper-compiler-jdt-5.5.15.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/jasper-compiler-jdt-5.5.15.jar>
[INFO] Copying jasper-runtime-5.5.15.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/jasper-runtime-5.5.15.jar>
[INFO] Copying serializer-2.7.1.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/serializer-2.7.1.jar>
[INFO] Copying xalan-2.7.0.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/xalan-2.7.0.jar>
[INFO] Copying xercesImpl-2.7.1.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/xercesImpl-2.7.1.jar>
[INFO] Copying xml-apis-1.0.b2.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/xml-apis-1.0.b2.jar>
[INFO] Copying xml-apis-ext-1.3.04.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/xml-apis-ext-1.3.04.jar>
[INFO] Copying xml-apis-xerces-2.7.1.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/xml-apis-xerces-2.7.1.jar>
[INFO] Copying xmlpull-1.1.3.1.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/xmlpull-1.1.3.1.jar>
[INFO] Copying xmlunit-1.3.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/xmlunit-1.3.jar>
[INFO] Copying xpp3-1.1.3.4.O.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/xpp3-1.1.3.4.O.jar>
[INFO] Copying xpp3_min-1.1.4c.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/xpp3_min-1.1.4c.jar>
[INFO] gt-api-14-SNAPSHOT.jar already exists in destination.
[INFO] gwc-core-1.8-SNAPSHOT.jar already exists in destination.
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (default) @ gs-release ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
[INFO] Executed tasks
[INFO]
[INFO] Building GeoServer 2.8-SNAPSHOT
[INFO]
[INFO] --- maven-assembly-plugin:2.1:attached (default-cli) @ geoserver ---
[INFO]
[INFO] GeoServer ......................................... FAILURE [11.435s]
[INFO] Core Platform Module .............................. SUCCESS [6.549s]
[INFO] Open Web Service Module ........................... SUCCESS [8.164s]
[INFO] Main Module ....................................... SUCCESS [29.542s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.437s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [9.711s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [8.663s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.687s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [10.239s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [9.044s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [10.950s]
[INFO] Web Feature Service Module ........................ SUCCESS [16.188s]
[INFO] Web Map Service Module ............................ SUCCESS [19.398s]
[INFO] KML support for GeoServer ......................... SUCCESS [10.903s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [10.876s]
[INFO] REST Support Module ............................... SUCCESS [6.442s]
[INFO] REST Configuration Service Module ................. SUCCESS [12.061s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.119s]
[INFO] Core UI Module .................................... SUCCESS [16.011s]
[INFO] WMS UI Module ..................................... SUCCESS [7.598s]
[INFO] GWC UI Module ..................................... SUCCESS [9.587s]
[INFO] WFS UI Module ..................................... SUCCESS [5.814s]
[INFO] Demoes Module ..................................... SUCCESS [7.495s]
[INFO] WCS UI Module ..................................... SUCCESS [6.490s]
[INFO] Security UI Modules ............................... SUCCESS [0.158s]
[INFO] Security UI Core Module ........................... SUCCESS [11.930s]
[INFO] Security UI JDBC Module ........................... SUCCESS [5.493s]
[INFO] Security UI LDAP Module ........................... SUCCESS [5.821s]
[INFO] REST UI Module .................................... SUCCESS [5.735s]
[INFO] GeoServer Web Application ......................... SUCCESS [7.943s]
[INFO] Community Space ................................... SUCCESS [0.252s]
[INFO] Authentication by unique url key .................. SUCCESS [9.831s]
[INFO] WorldWind Format Module ........................... SUCCESS [14.043s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.315s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.196s]
[INFO] Web Processing Service Module ..................... SUCCESS [15.161s]
[INFO] GPX PPIO for WPS .................................. SUCCESS [5.812s]
[INFO] NetCDF Coverage format ............................ SUCCESS [3.219s]
[INFO] DownloadProcess ................................... SUCCESS [6.817s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [7.202s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [3.152s]
[INFO] GeoServer Scripting Extensions .................... SUCCESS [0.210s]
[INFO] Core Scripting Extension .......................... SUCCESS [8.590s]
[INFO] H2 DataStore Extension ............................ SUCCESS [4.457s]
[INFO] Python Scripting Extension ........................ SUCCESS [9.515s]
[INFO] JavaScript Scripting Extension .................... SUCCESS [7.399s]
[INFO] Groovy Scripting Extension ........................ SUCCESS [16.147s]
[INFO] GeoServer JDBC KV Catalog ......................... SUCCESS [8.955s]
[INFO] Simple Feature Service ............................ SUCCESS [5.074s]
[INFO] Aggregating Data Store ............................ SUCCESS [3.079s]
[INFO] WMS-EO ............................................ SUCCESS [8.108s]
[INFO] ColorMap .......................................... SUCCESS [5.619s]
[INFO] GeoServer mbtiles Extension ....................... SUCCESS [6.625s]
[INFO] GeoServer GeoPackage Extension .................... SUCCESS [6.974s]
[INFO] GRIB Coverage Format .............................. SUCCESS [5.817s]
[INFO] Dynamic WMS dimension value defaults .............. SUCCESS [6.704s]
[INFO] REST plugin community module ...................... SUCCESS [6.050s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [2.568s]
[INFO] KML PPIO for WPS .................................. SUCCESS [5.332s]
[INFO] GeoServer JMS based clustering modules ............ SUCCESS [0.126s]
[INFO] GeoServer JMS clustering Commons module ........... SUCCESS [2.492s]
[INFO] GeoServer JMS clustering module ................... SUCCESS [8.394s]
[INFO] GeoFence security integration ..................... SUCCESS [7.997s]
[INFO] REST SLD service .................................. SUCCESS [7.175s]
[INFO] Solr Module ....................................... SUCCESS [5.777s]
[INFO] GeoServer Community Release Module ................ SUCCESS [1.765s]
[INFO] SpatiaLite Extension .............................. SUCCESS [14.092s]
[INFO] Web UI Scripting Extension ........................ SUCCESS [6.802s]
[INFO] BeanShell Scripting Extension ..................... SUCCESS [4.864s]
[INFO] Ruby Scripting Extension .......................... SUCCESS [5.035s]
[INFO] ActiveMQ .......................................... SUCCESS [5.243s]
[INFO] Resumable REST Upload module ...................... SUCCESS [5.832s]
[INFO] Application Schema Support ........................ SUCCESS [0.103s]
[INFO] Application Schema Integration Test ............... SUCCESS [8.251s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [2.673s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [5.217s]
[INFO] GeoSearch Index Module ............................ SUCCESS [5.243s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [0.116s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.172s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.111s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.117s]
[INFO] ImageMap Output Format ............................ SUCCESS [5.641s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.133s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.199s]
[INFO] OGR parent ........................................ SUCCESS [0.104s]
[INFO] OGR WFS ........................................... SUCCESS [5.465s]
[INFO] OGR WPS ........................................... SUCCESS [6.199s]
[INFO] Excel Output Format ............................... SUCCESS [5.017s]
[INFO] Chart external graphics support ................... SUCCESS [0.111s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.171s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.135s]
[INFO] OWS request flow controller ....................... SUCCESS [5.498s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [5.896s]
[INFO] Web Processing Service GUI ........................ SUCCESS [7.542s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [4.621s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.421s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.166s]
[INFO] Core Monitor Extension ............................ SUCCESS [9.724s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [5.800s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.156s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [6.406s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.154s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.261s]
[INFO] XLST based WFS output format ...................... SUCCESS [5.814s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [5.803s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [6.565s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.680s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [6.420s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [5.413s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [8.579s]
[INFO] CSW UI Module ..................................... SUCCESS [4.953s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.097s]
[INFO] DXF WFS output format ............................. SUCCESS [5.352s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [4.862s]
[INFO] Printing Module ................................... SUCCESS [5.009s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.159s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [6.450s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [4.784s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [5.647s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.199s]
[INFO] Importer Core Module .............................. SUCCESS [8.936s]
[INFO] Importer REST Api Module .......................... SUCCESS [7.158s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [5.580s]
[INFO] Importer Web UI Module ............................ SUCCESS [5.426s]
[INFO] GeoServer Release Module .......................... SUCCESS [1.786s]
[INFO] Total time: 12:31.036s
[INFO] Finished at: Wed Feb 25 20:56:01 UTC 2015
[INFO] Final Memory: 145M/354M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-assembly-plugin:2.1:attached (default-cli) on project geoserver: Unable to find descriptor: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/ext-ogr-wps.xml> (No such file or directory) -> [Help 1]
[ERROR]
[ERROR]
Hudson
3
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/553/>
[...truncated 18221 lines...]
[INFO]
main:
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... FAILURE [12.342s]
[INFO] Core Platform Module .............................. SUCCESS [6.412s]
[INFO] Open Web Service Module ........................... SUCCESS [11.697s]
[INFO] Main Module ....................................... SUCCESS [40.896s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.632s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [7.420s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [5.743s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.737s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [8.809s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [10.998s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [12.417s]
[INFO] Web Feature Service Module ........................ SUCCESS [17.246s]
[INFO] Web Map Service Module ............................ SUCCESS [20.643s]
[INFO] KML support for GeoServer ......................... SUCCESS [10.457s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [15.214s]
[INFO] REST Support Module ............................... SUCCESS [6.582s]
[INFO] REST Configuration Service Module ................. SUCCESS [12.892s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.142s]
[INFO] Core UI Module .................................... SUCCESS [18.016s]
[INFO] WMS UI Module ..................................... SUCCESS [7.683s]
[INFO] GWC UI Module ..................................... SUCCESS [9.627s]
[INFO] WFS UI Module ..................................... SUCCESS [5.304s]
[INFO] Demoes Module ..................................... SUCCESS [8.893s]
[INFO] WCS UI Module ..................................... SUCCESS [7.046s]
[INFO] Security UI Modules ............................... SUCCESS [0.200s]
[INFO] Security UI Core Module ........................... SUCCESS [12.989s]
[INFO] Security UI JDBC Module ........................... SUCCESS [6.717s]
[INFO] Security UI LDAP Module ........................... SUCCESS [6.490s]
[INFO] REST UI Module .................................... SUCCESS [6.128s]
[INFO] GeoServer Web Application ......................... SUCCESS [9.039s]
[INFO] Community Space ................................... SUCCESS [0.205s]
[INFO] Authentication by unique url key .................. SUCCESS [10.615s]
[INFO] WorldWind Format Module ........................... SUCCESS [23.396s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.169s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.151s]
[INFO] Web Processing Service Module ..................... SUCCESS [15.422s]
[INFO] GPX PPIO for WPS .................................. SUCCESS [5.799s]
[INFO] NetCDF Coverage format ............................ SUCCESS [5.246s]
[INFO] DownloadProcess ................................... SUCCESS [6.295s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [7.477s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [3.093s]
[INFO] GeoServer Scripting Extensions .................... SUCCESS [0.243s]
[INFO] Core Scripting Extension .......................... SUCCESS [7.587s]
[INFO] H2 DataStore Extension ............................ SUCCESS [5.510s]
[INFO] Python Scripting Extension ........................ SUCCESS [8.563s]
[INFO] JavaScript Scripting Extension .................... SUCCESS [7.007s]
[INFO] Groovy Scripting Extension ........................ SUCCESS [15.121s]
[INFO] GeoServer JDBC KV Catalog ......................... SUCCESS [9.096s]
[INFO] Simple Feature Service ............................ SUCCESS [6.092s]
[INFO] Aggregating Data Store ............................ SUCCESS [3.562s]
[INFO] WMS-EO ............................................ SUCCESS [7.804s]
[INFO] ColorMap .......................................... SUCCESS [6.018s]
[INFO] GeoServer mbtiles Extension ....................... SUCCESS [6.680s]
[INFO] GeoServer GeoPackage Extension .................... SUCCESS [6.487s]
[INFO] GRIB Coverage Format .............................. SUCCESS [5.914s]
[INFO] Dynamic WMS dimension value defaults .............. SUCCESS [6.710s]
[INFO] REST plugin community module ...................... SUCCESS [5.496s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [3.396s]
[INFO] KML PPIO for WPS .................................. SUCCESS [5.397s]
[INFO] GeoServer JMS based clustering modules ............ SUCCESS [2.610s]
[INFO] GeoServer JMS clustering Commons module ........... SUCCESS [2.661s]
[INFO] GeoServer JMS clustering module ................... SUCCESS [19.854s]
[INFO] GeoFence security integration ..................... SUCCESS [7.778s]
[INFO] REST SLD service .................................. SUCCESS [7.195s]
[INFO] Solr Module ....................................... SUCCESS [6.361s]
[INFO] GeoServer Community Release Module ................ SUCCESS [13.278s]
[INFO] SpatiaLite Extension .............................. SUCCESS [7:52.697s]
[INFO] Web UI Scripting Extension ........................ SUCCESS [6.119s]
[INFO] BeanShell Scripting Extension ..................... SUCCESS [6.012s]
[INFO] Ruby Scripting Extension .......................... SUCCESS [4.915s]
[INFO] ActiveMQ .......................................... SUCCESS [9.680s]
[INFO] Resumable REST Upload module ...................... SUCCESS [7.658s]
[INFO] Application Schema Support ........................ SUCCESS [0.898s]
[INFO] Application Schema Integration Test ............... SUCCESS [9.415s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [2.789s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [6.354s]
[INFO] GeoSearch Index Module ............................ SUCCESS [5.614s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.310s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.217s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.166s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.361s]
[INFO] ImageMap Output Format ............................ SUCCESS [5.847s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.304s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.380s]
[INFO] OGR parent ........................................ SUCCESS [0.120s]
[INFO] OGR WFS ........................................... SUCCESS [5.360s]
[INFO] OGR WPS ........................................... SUCCESS [5.418s]
[INFO] Excel Output Format ............................... SUCCESS [5.475s]
[INFO] Chart external graphics support ................... SUCCESS [1.830s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.566s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.276s]
[INFO] OWS request flow controller ....................... SUCCESS [5.746s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [6.118s]
[INFO] Web Processing Service GUI ........................ SUCCESS [9.170s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [4.827s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.014s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.171s]
[INFO] Core Monitor Extension ............................ SUCCESS [9.631s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [7.710s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.188s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [6.660s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.213s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [2.905s]
[INFO] XLST based WFS output format ...................... SUCCESS [6.412s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [5.704s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [7.286s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.137s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [6.992s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [5.723s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [8.451s]
[INFO] CSW UI Module ..................................... SUCCESS [6.004s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.151s]
[INFO] DXF WFS output format ............................. SUCCESS [4.941s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [5.127s]
[INFO] Printing Module ................................... SUCCESS [5.156s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.126s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [5.972s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [4.748s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [5.182s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.173s]
[INFO] Importer Core Module .............................. SUCCESS [9.920s]
[INFO] Importer REST Api Module .......................... SUCCESS [7.664s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [5.194s]
[INFO] Importer Web UI Module ............................ SUCCESS [5.636s]
[INFO] GeoServer Release Module .......................... SUCCESS [3.418s]
[INFO] Total time: 21:41.191s
[INFO] Finished at: Thu Feb 26 08:23:03 UTC 2015
[INFO] Final Memory: 142M/409M
[ERROR]
[ERROR]
Hudson
4
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/554/>
[...truncated 16980 lines...]
[INFO]
main:
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... FAILURE [7.863s]
[INFO] Core Platform Module .............................. SUCCESS [6.616s]
[INFO] Open Web Service Module ........................... SUCCESS [8.636s]
[INFO] Main Module ....................................... SUCCESS [29.831s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.298s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [8.145s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [5.759s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.248s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [8.524s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [9.429s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [12.738s]
[INFO] Web Feature Service Module ........................ SUCCESS [16.739s]
[INFO] Web Map Service Module ............................ SUCCESS [18.515s]
[INFO] KML support for GeoServer ......................... SUCCESS [10.128s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [11.055s]
[INFO] REST Support Module ............................... SUCCESS [7.462s]
[INFO] REST Configuration Service Module ................. SUCCESS [11.629s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.121s]
[INFO] Core UI Module .................................... SUCCESS [18.475s]
[INFO] WMS UI Module ..................................... SUCCESS [8.461s]
[INFO] GWC UI Module ..................................... SUCCESS [10.744s]
[INFO] WFS UI Module ..................................... SUCCESS [5.453s]
[INFO] Demoes Module ..................................... SUCCESS [7.684s]
[INFO] WCS UI Module ..................................... SUCCESS [7.079s]
[INFO] Security UI Modules ............................... SUCCESS [0.157s]
[INFO] Security UI Core Module ........................... SUCCESS [12.291s]
[INFO] Security UI JDBC Module ........................... SUCCESS [6.261s]
[INFO] Security UI LDAP Module ........................... SUCCESS [5.996s]
[INFO] REST UI Module .................................... SUCCESS [5.168s]
[INFO] GeoServer Web Application ......................... SUCCESS [6.938s]
[INFO] Community Space ................................... SUCCESS [0.302s]
[INFO] Authentication by unique url key .................. SUCCESS [7.288s]
[INFO] WorldWind Format Module ........................... SUCCESS [10.574s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.121s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.177s]
[INFO] Web Processing Service Module ..................... SUCCESS [15.786s]
[INFO] GPX PPIO for WPS .................................. SUCCESS [6.330s]
[INFO] NetCDF Coverage format ............................ SUCCESS [2.764s]
[INFO] DownloadProcess ................................... SUCCESS [6.572s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [6.371s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [3.023s]
[INFO] GeoServer Scripting Extensions .................... SUCCESS [0.177s]
[INFO] Core Scripting Extension .......................... SUCCESS [7.368s]
[INFO] H2 DataStore Extension ............................ SUCCESS [4.607s]
[INFO] Python Scripting Extension ........................ SUCCESS [7.786s]
[INFO] JavaScript Scripting Extension .................... SUCCESS [6.402s]
[INFO] Groovy Scripting Extension ........................ SUCCESS [17.125s]
[INFO] GeoServer JDBC KV Catalog ......................... SUCCESS [9.595s]
[INFO] Simple Feature Service ............................ SUCCESS [5.944s]
[INFO] Aggregating Data Store ............................ SUCCESS [3.612s]
[INFO] WMS-EO ............................................ SUCCESS [7.910s]
[INFO] ColorMap .......................................... SUCCESS [5.572s]
[INFO] GeoServer mbtiles Extension ....................... SUCCESS [5.947s]
[INFO] GeoServer GeoPackage Extension .................... SUCCESS [7.228s]
[INFO] GRIB Coverage Format .............................. SUCCESS [5.672s]
[INFO] Dynamic WMS dimension value defaults .............. SUCCESS [6.980s]
[INFO] REST plugin community module ...................... SUCCESS [5.950s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [2.914s]
[INFO] KML PPIO for WPS .................................. SUCCESS [5.652s]
[INFO] GeoServer JMS based clustering modules ............ SUCCESS [0.204s]
[INFO] GeoServer JMS clustering Commons module ........... SUCCESS [2.577s]
[INFO] GeoServer JMS clustering module ................... SUCCESS [7.753s]
[INFO] GeoFence security integration ..................... SUCCESS [7.554s]
[INFO] REST SLD service .................................. SUCCESS [6.802s]
[INFO] Solr Module ....................................... SUCCESS [5.027s]
[INFO] GeoServer Community Release Module ................ SUCCESS [1.278s]
[INFO] SpatiaLite Extension .............................. SUCCESS [5.183s]
[INFO] Web UI Scripting Extension ........................ SUCCESS [6.236s]
[INFO] BeanShell Scripting Extension ..................... SUCCESS [7.635s]
[INFO] Ruby Scripting Extension .......................... SUCCESS [5.302s]
[INFO] ActiveMQ .......................................... SUCCESS [5.155s]
[INFO] Resumable REST Upload module ...................... SUCCESS [5.560s]
[INFO] Application Schema Support ........................ SUCCESS [0.149s]
[INFO] Application Schema Integration Test ............... SUCCESS [7.036s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [2.883s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [5.770s]
[INFO] GeoSearch Index Module ............................ SUCCESS [6.017s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [0.120s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.114s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.194s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.116s]
[INFO] ImageMap Output Format ............................ SUCCESS [6.955s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.206s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.195s]
[INFO] OGR parent ........................................ SUCCESS [0.094s]
[INFO] OGR WFS ........................................... SUCCESS [5.419s]
[INFO] OGR WPS ........................................... SUCCESS [5.243s]
[INFO] Excel Output Format ............................... SUCCESS [5.127s]
[INFO] Chart external graphics support ................... SUCCESS [0.120s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.130s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.120s]
[INFO] OWS request flow controller ....................... SUCCESS [5.877s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [6.487s]
[INFO] Web Processing Service GUI ........................ SUCCESS [8.023s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [5.074s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.049s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.181s]
[INFO] Core Monitor Extension ............................ SUCCESS [10.154s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [6.901s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.146s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [6.431s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.147s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [2.824s]
[INFO] XLST based WFS output format ...................... SUCCESS [6.516s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [6.002s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [7.008s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.232s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [6.960s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [5.230s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [9.095s]
[INFO] CSW UI Module ..................................... SUCCESS [5.281s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.091s]
[INFO] DXF WFS output format ............................. SUCCESS [5.700s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [5.473s]
[INFO] Printing Module ................................... SUCCESS [5.046s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.089s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [6.264s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [5.609s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [5.925s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.234s]
[INFO] Importer Core Module .............................. SUCCESS [9.454s]
[INFO] Importer REST Api Module .......................... SUCCESS [6.816s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [6.214s]
[INFO] Importer Web UI Module ............................ SUCCESS [5.330s]
[INFO] GeoServer Release Module .......................... SUCCESS [1.161s]
[INFO] Total time: 12:16.689s
[INFO] Finished at: Thu Feb 26 11:21:02 UTC 2015
[INFO] Final Memory: 145M/353M
[ERROR]
[ERROR]
Hudson
5
