[Geoserver-devel] Build failed in Jenkins: geoserver-master-nightly #587
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/587/changes&gt;
Changes:
[andrea.aime] Fixing security related build failure on windows
[andrea.aime] Adding a bit more info in the failing tests
[...truncated 900 lines...]
976/976 B
Downloaded: http://maven.geo-solutions.it/org/geotools/gt-shapefile/14-SNAPSHOT/maven-metadata.xml (976 B at 4.8 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-transform/14-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/gt-transform/14-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-transform/14-SNAPSHOT/maven-metadata.xml
969/969 B
Downloading: http://maven.geo-solutions.it/org/geotools/gt-transform/14-SNAPSHOT/maven-metadata.xml
969/969 B 976/976 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-transform/14-SNAPSHOT/maven-metadata.xml (969 B at 3.7 KB/sec)
Downloaded: http://maven.geo-solutions.it/org/geotools/gt-transform/14-SNAPSHOT/maven-metadata.xml (976 B at 2.3 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/jdbc/gt-jdbc-postgis/14-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.boundlessgeo.com/main/org/geotools/jdbc/gt-jdbc-postgis/14-SNAPSHOT/maven-metadata.xml
977/977 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/jdbc/gt-jdbc-postgis/14-SNAPSHOT/maven-metadata.xml (977 B at 47.7 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/jdbc/gt-jdbc/14-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.boundlessgeo.com/main/org/geotools/jdbc/gt-jdbc/14-SNAPSHOT/maven-metadata.xml
586/586 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/jdbc/gt-jdbc/14-SNAPSHOT/maven-metadata.xml (586 B at 57.2 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-main ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-main ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-main ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Adding a bit more info in the failing tests
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 29.03.2015 @ 17:22:40 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 30-Mar-2015 08:01
[INFO] [GitCommitIdMojo] build.build.time = 30.03.2015 @ 08:01:53 UTC
[INFO] [GitCommitIdMojo] build.branch = 7b396ce5f0fbe6d9bf8f737d2de2d748aac06478
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 7b396ce
[INFO] [GitCommitIdMojo] build.commit.id = 7b396ce5f0fbe6d9bf8f737d2de2d748aac06478
[INFO] [GitCommitIdMojo] build.commit.message.full = Adding a bit more info in the failing tests
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-main ---
[INFO] Copying 33 resources
[INFO] Copying 163 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-main ---
[INFO] Compiling 602 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/target/classes&gt;
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/catalog/CoverageDimensionCustomizerReader.java&gt;:\[493,28\] error: cannot find symbol
[ERROR] variable sampleDim of type GridSampleDimension
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/catalog/CoverageDimensionCustomizerReader.java&gt;:\[491,8\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/catalog/CoverageDimensionCustomizerReader.java&gt;:\[541,28\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/catalog/CoverageDimensionCustomizerReader.java&gt;:\[539,8\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/catalog/CoverageDimensionCustomizerReader.java&gt;:\[545,28\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/catalog/CoverageDimensionCustomizerReader.java&gt;:\[543,8\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/catalog/CoverageDimensionCustomizerReader.java&gt;:\[573,28\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/catalog/CoverageDimensionCustomizerReader.java&gt;:\[571,8\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/catalog/CoverageDimensionCustomizerReader.java&gt;:\[699,48\] error: cannot find symbol
[INFO] 9 errors
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.945s]
[INFO] Core Platform Module .............................. SUCCESS [6.480s]
[INFO] Open Web Service Module ........................... SUCCESS [12.898s]
[INFO] Main Module ....................................... FAILURE [21.236s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Authentication by unique url key .................. SKIPPED
[INFO] WorldWind Format Module ........................... SKIPPED
[INFO] GeoServer Embedded FTP server ..................... SKIPPED
[INFO] SpatiaLite Extension .............................. SKIPPED
[INFO] GeoServer JDBC KV Catalog ......................... SKIPPED
[INFO] Simple Feature Service ............................ SKIPPED
[INFO] Aggregating Data Store ............................ SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Scripting Extensions .................... SKIPPED
[INFO] Core Scripting Extension .......................... SKIPPED
[INFO] Web UI Scripting Extension ........................ SKIPPED
[INFO] BeanShell Scripting Extension ..................... SKIPPED
[INFO] Groovy Scripting Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] Python Scripting Extension ........................ SKIPPED
[INFO] JavaScript Scripting Extension .................... SKIPPED
[INFO] Ruby Scripting Extension .......................... SKIPPED
[INFO] WMS-EO ............................................ SKIPPED
[INFO] ColorMap .......................................... SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer mbtiles Extension ....................... SKIPPED
[INFO] GeoServer GeoPackage Extension .................... SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults .............. SKIPPED
[INFO] REST plugin community module ...................... SKIPPED
[INFO] GPX PPIO for WPS .................................. SKIPPED
[INFO] KML PPIO for WPS .................................. SKIPPED
[INFO] DownloadProcess ................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............ SKIPPED
[INFO] ActiveMQ .......................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ........... SKIPPED
[INFO] GeoServer JMS clustering module ................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module ............. SKIPPED
[INFO] Solr Module ....................................... SKIPPED
[INFO] Resumable REST Upload module ...................... SKIPPED
[INFO] GeoFence security integration ..................... SKIPPED
[INFO] REST SLD service .................................. SKIPPED
[INFO] GeoServer Community Release Module ................ SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 53.057s
[INFO] Finished at: Mon Mar 30 08:02:09 UTC 2015
[INFO] Final Memory: 47M/281M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-main: Compilation failure: Compilation failure:
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/catalog/CoverageDimensionCustomizerReader.java&gt;:\[491,8\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/catalog/CoverageDimensionCustomizerReader.java&gt;:\[539,8\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/catalog/CoverageDimensionCustomizerReader.java&gt;:\[543,8\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/catalog/CoverageDimensionCustomizerReader.java&gt;:\[571,8\] error: method does not override or implement a method from a supertype
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/588/&gt;
[...truncated 502 lines...]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-ows <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-ows ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/ows/target/gs-ows-2.8-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ gs-ows ---
[INFO] Copying gt-api-14-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/ows/target/dependency/gt-api-14-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.8-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/ows/target/dependency/gwc-core-1.8-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-ows ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/ows/target/gs-ows-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-ows/2.8-SNAPSHOT/gs-ows-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/ows/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-ows/2.8-SNAPSHOT/gs-ows-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/ows/target/gs-ows-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-ows/2.8-SNAPSHOT/gs-ows-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/ows/target/gs-ows-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-ows/2.8-SNAPSHOT/gs-ows-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/ows/target/gs-ows-2.8-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-ows/2.8-SNAPSHOT/gs-ows-2.8-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Main Module 2.8-SNAPSHOT
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.timestamp = 30-Mar-2015 09:36
[INFO] [GitCommitIdMojo] build.build.time = 30.03.2015 @ 09:37:05 UTC
[INFO]
[INFO]
[INFO] 9 errors
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [3.879s]
[INFO] Core Platform Module .............................. SUCCESS [6.007s]
[INFO] Open Web Service Module ........................... SUCCESS [8.706s]
[INFO] Main Module ....................................... FAILURE [15.871s]
[INFO] Total time: 40.219s
[INFO] Finished at: Mon Mar 30 09:37:21 UTC 2015
[INFO] Final Memory: 46M/252M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/589/changes&gt;
