[Geoserver-devel] Build failed in Jenkins: geoserver-master-nightly #597
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/597/changes&gt;
Changes:
[lago.88] GEOS-6960: Updating GS code after viewsManager cleanup (GEOT-5050)
[andrea.aime] Some extra checks to better understand the random windows build failures in this area
[lago.88] GSIP-128 JAIEXT integration
[andrea.aime] Do not trust InputSource and friend to manage file streams, multiple reports on the net suggest they do not do it correctly
[daniele.romagnoli] GEOS-6893: FillValue and NoData management
[...truncated 4256 lines...]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-authkey <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-authkey ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/authkey/target/gs-authkey-2.8-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-authkey >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-authkey ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1007 from geosolutions-it/GEOS-6893
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 08.04.2015 @ 07:16:35 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 08-Apr-2015 08:40
[INFO] [GitCommitIdMojo] build.build.time = 08.04.2015 @ 08:45:40 UTC
[INFO] [GitCommitIdMojo] build.branch = 42c963107d737c53270a7c93c8aeb40b5cd27262
[INFO] [GitCommitIdMojo] build.commit.user.email = daniele.romagnoli@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Daniele Romagnoli
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 42c9631
[INFO] [GitCommitIdMojo] build.commit.id = 42c963107d737c53270a7c93c8aeb40b5cd27262
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1007 from geosolutions-it/GEOS-6893
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-authkey <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-authkey ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/authkey/target/gs-authkey-2.8-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ gs-authkey ---
[INFO] Copying gt-api-14-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/authkey/target/dependency/gt-api-14-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.8-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/authkey/target/dependency/gwc-core-1.8-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-authkey ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/authkey/target/gs-authkey-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-authkey/2.8-SNAPSHOT/gs-authkey-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/authkey/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-authkey/2.8-SNAPSHOT/gs-authkey-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/authkey/target/gs-authkey-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-authkey/2.8-SNAPSHOT/gs-authkey-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/authkey/target/gs-authkey-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-authkey/2.8-SNAPSHOT/gs-authkey-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/authkey/target/gs-authkey-2.8-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-authkey/2.8-SNAPSHOT/gs-authkey-2.8-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building WorldWind Format Module 2.8-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-dds ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/dds/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-dds ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-dds ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-dds ---
[INFO] Copying 11 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/dds/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-dds ---
[INFO] Compiling 6 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/dds/target/classes&gt;
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/dds/src/main/java/org/geoserver/wms/worldwind/BilMapResponse.java&gt;:\[204,16\] error: cannot find symbol
[INFO] 1 error
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [3.448s]
[INFO] Core Platform Module .............................. SUCCESS [6.494s]
[INFO] Open Web Service Module ........................... SUCCESS [8.730s]
[INFO] Main Module ....................................... SUCCESS [31.916s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.318s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [7.871s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [6.682s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.749s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [8.999s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [9.979s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [11.483s]
[INFO] Web Feature Service Module ........................ SUCCESS [17.236s]
[INFO] Web Map Service Module ............................ SUCCESS [19.275s]
[INFO] KML support for GeoServer ......................... SUCCESS [11.008s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [11.527s]
[INFO] REST Support Module ............................... SUCCESS [6.808s]
[INFO] REST Configuration Service Module ................. SUCCESS [12.826s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.115s]
[INFO] Core UI Module .................................... SUCCESS [16.901s]
[INFO] WMS UI Module ..................................... SUCCESS [7.839s]
[INFO] GWC UI Module ..................................... SUCCESS [10.949s]
[INFO] WFS UI Module ..................................... SUCCESS [6.884s]
[INFO] Demoes Module ..................................... SUCCESS [7.526s]
[INFO] WCS UI Module ..................................... SUCCESS [7.225s]
[INFO] Security UI Modules ............................... SUCCESS [0.192s]
[INFO] Security UI Core Module ........................... SUCCESS [13.352s]
[INFO] Security UI JDBC Module ........................... SUCCESS [7.072s]
[INFO] Security UI LDAP Module ........................... SUCCESS [6.158s]
[INFO] REST UI Module .................................... SUCCESS [5.687s]
[INFO] GeoServer Web Application ......................... SUCCESS [6.857s]
[INFO] Community Space ................................... SUCCESS [0.131s]
[INFO] Authentication by unique url key .................. SUCCESS [38.349s]
[INFO] WorldWind Format Module ........................... FAILURE [3.895s]
[INFO] GeoServer Embedded FTP server ..................... SKIPPED
[INFO] SpatiaLite Extension .............................. SKIPPED
[INFO] GeoServer JDBC KV Catalog ......................... SKIPPED
[INFO] Simple Feature Service ............................ SKIPPED
[INFO] Aggregating Data Store ............................ SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Scripting Extensions .................... SKIPPED
[INFO] Core Scripting Extension .......................... SKIPPED
[INFO] Web UI Scripting Extension ........................ SKIPPED
[INFO] BeanShell Scripting Extension ..................... SKIPPED
[INFO] Groovy Scripting Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] Python Scripting Extension ........................ SKIPPED
[INFO] JavaScript Scripting Extension .................... SKIPPED
[INFO] Ruby Scripting Extension .......................... SKIPPED
[INFO] WMS-EO ............................................ SKIPPED
[INFO] ColorMap .......................................... SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer mbtiles Extension ....................... SKIPPED
[INFO] GeoServer GeoPackage Extension .................... SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults .............. SKIPPED
[INFO] REST plugin community module ...................... SKIPPED
[INFO] GPX PPIO for WPS .................................. SKIPPED
[INFO] KML PPIO for WPS .................................. SKIPPED
[INFO] DownloadProcess ................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............ SKIPPED
[INFO] ActiveMQ .......................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ........... SKIPPED
[INFO] GeoServer JMS clustering module ................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module ............. SKIPPED
[INFO] Solr Module ....................................... SKIPPED
[INFO] Resumable REST Upload module ...................... SKIPPED
[INFO] GeoFence security integration ..................... SKIPPED
[INFO] REST SLD service .................................. SKIPPED
[INFO] GeoServer Community Release Module ................ SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 5:24.163s
[INFO] Finished at: Wed Apr 08 08:45:44 UTC 2015
[INFO] Final Memory: 70M/255M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-dds: Compilation failure
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-dds
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/598/changes&gt;
