[Geoserver-devel] Build failed in Jenkins: geoserver-master-nightly #632
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/632/changes&gt;
Changes:
[groldan] Remove TileObject.setId(long) calls in gwc tests.
[...truncated 10546 lines...]
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 12.05.2015 @ 01:13:01 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 12-May-2015 08:01
[INFO] [GitCommitIdMojo] build.build.time = 12.05.2015 @ 08:12:06 UTC
[INFO] [GitCommitIdMojo] build.branch = 8234ec68d8e0b2f3f763443ceeda6577495e4d08
[INFO] [GitCommitIdMojo] build.commit.user.email = groldan@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Gabriel Roldan
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 8234ec6
[INFO] [GitCommitIdMojo] build.commit.id = 8234ec68d8e0b2f3f763443ceeda6577495e4d08
[INFO] [GitCommitIdMojo] build.commit.message.full = Remove TileObject.setId(long) calls in gwc tests.
TileObject.setId(long) is an unused property and will be removed from GWC,
no need to set it in the tests, nor they're using it for anything.
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-sldservice <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-sldservice ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/sldService/target/gs-sldservice-2.8-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ gs-sldservice ---
[INFO] Copying gt-api-14-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/sldService/target/dependency/gt-api-14-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.8-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/sldService/target/dependency/gwc-core-1.8-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-sldservice ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/sldService/target/gs-sldservice-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-sldservice/2.8-SNAPSHOT/gs-sldservice-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/sldService/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-sldservice/2.8-SNAPSHOT/gs-sldservice-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/sldService/target/gs-sldservice-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-sldservice/2.8-SNAPSHOT/gs-sldservice-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/sldService/target/gs-sldservice-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-sldservice/2.8-SNAPSHOT/gs-sldservice-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/sldService/target/gs-sldservice-2.8-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-sldservice/2.8-SNAPSHOT/gs-sldservice-2.8-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GWC Distributed Caching Plugin 2.8-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-gwc-distributed ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/gwc-distributed/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-gwc-distributed ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-gwc-distributed ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Remove TileObject.setId(long) calls in gwc tests.
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-gwc-distributed ---
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/gwc-distributed/src/main/java&gt;
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-gwc-distributed ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-gwc-distributed ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/gwc-distributed/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-gwc-distributed ---
[INFO] Compiling 1 source file to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/gwc-distributed/target/test-classes&gt;
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/gwc-distributed/src/test/java/org/geoserver/gwc/HazelcastTest.java&gt;:\[146,10\] error: cannot find symbol
[ERROR] variable to of type TileObject
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/gwc-distributed/src/test/java/org/geoserver/gwc/HazelcastTest.java&gt;:\[152,11\] error: cannot find symbol
[INFO] 2 errors
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [4.972s]
[INFO] Core Platform Module .............................. SUCCESS [6.971s]
[INFO] Open Web Service Module ........................... SUCCESS [10.034s]
[INFO] Main Module ....................................... SUCCESS [30.590s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.280s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [8.159s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [7.260s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.588s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [8.877s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [9.625s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [13.273s]
[INFO] Web Feature Service Module ........................ SUCCESS [19.362s]
[INFO] Web Map Service Module ............................ SUCCESS [21.199s]
[INFO] KML support for GeoServer ......................... SUCCESS [11.275s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [11.979s]
[INFO] REST Support Module ............................... SUCCESS [6.175s]
[INFO] REST Configuration Service Module ................. SUCCESS [14.320s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.231s]
[INFO] Core UI Module .................................... SUCCESS [16.745s]
[INFO] WMS UI Module ..................................... SUCCESS [8.171s]
[INFO] GWC UI Module ..................................... SUCCESS [10.728s]
[INFO] WFS UI Module ..................................... SUCCESS [5.769s]
[INFO] Demoes Module ..................................... SUCCESS [8.643s]
[INFO] WCS UI Module ..................................... SUCCESS [8.214s]
[INFO] Security UI Modules ............................... SUCCESS [0.297s]
[INFO] Security UI Core Module ........................... SUCCESS [13.812s]
[INFO] Security UI JDBC Module ........................... SUCCESS [6.931s]
[INFO] Security UI LDAP Module ........................... SUCCESS [6.472s]
[INFO] REST UI Module .................................... SUCCESS [5.604s]
[INFO] GeoServer Web Application ......................... SUCCESS [8.083s]
[INFO] Community Space ................................... SUCCESS [0.362s]
[INFO] Authentication by unique url key .................. SUCCESS [22.763s]
[INFO] WorldWind Format Module ........................... SUCCESS [15.227s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [3.082s]
[INFO] SpatiaLite Extension .............................. SUCCESS [7.230s]
[INFO] GeoServer JDBC KV Catalog ......................... SUCCESS [9.139s]
[INFO] Simple Feature Service ............................ SUCCESS [6.841s]
[INFO] Aggregating Data Store ............................ SUCCESS [6.867s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.350s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.149s]
[INFO] Web Processing Service Module ..................... SUCCESS [15.603s]
[INFO] GeoServer Scripting Extensions .................... SUCCESS [0.291s]
[INFO] Core Scripting Extension .......................... SUCCESS [8.196s]
[INFO] Web UI Scripting Extension ........................ SUCCESS [7.103s]
[INFO] BeanShell Scripting Extension ..................... SUCCESS [5.672s]
[INFO] Groovy Scripting Extension ........................ SUCCESS [20.943s]
[INFO] H2 DataStore Extension ............................ SUCCESS [5.701s]
[INFO] Python Scripting Extension ........................ SUCCESS [10.864s]
[INFO] JavaScript Scripting Extension .................... SUCCESS [8.716s]
[INFO] Ruby Scripting Extension .......................... SUCCESS [5.985s]
[INFO] WMS-EO ............................................ SUCCESS [8.432s]
[INFO] ColorMap .......................................... SUCCESS [7.219s]
[INFO] NetCDF Coverage format ............................ SUCCESS [4.717s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [7.612s]
[INFO] GeoServer mbtiles Extension ....................... SUCCESS [8.607s]
[INFO] GeoServer GeoPackage Extension .................... SUCCESS [8.241s]
[INFO] GRIB Coverage Format .............................. SUCCESS [7.659s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [3.072s]
[INFO] Dynamic WMS dimension value defaults .............. SUCCESS [7.022s]
[INFO] REST plugin community module ...................... SUCCESS [6.156s]
[INFO] GPX PPIO for WPS .................................. SUCCESS [6.179s]
[INFO] KML PPIO for WPS .................................. SUCCESS [6.093s]
[INFO] DownloadProcess ................................... SUCCESS [7.947s]
[INFO] GeoServer JMS based clustering modules ............ SUCCESS [1.901s]
[INFO] ActiveMQ .......................................... SUCCESS [5.968s]
[INFO] GeoServer JMS clustering Commons module ........... SUCCESS [11.846s]
[INFO] GeoServer JMS clustering module ................... SUCCESS [17.865s]
[INFO] GeoServer Hazelcast Clustering Module ............. SUCCESS [8.248s]
[INFO] Solr Module ....................................... SUCCESS [6.787s]
[INFO] Resumable REST Upload module ...................... SUCCESS [6.416s]
[INFO] GeoFence security integration ..................... SUCCESS [10.627s]
[INFO] REST SLD service .................................. SUCCESS [7.903s]
[INFO] GWC Distributed Caching Plugin .................... FAILURE [2.971s]
[INFO] GeoServer Community Release Module ................ SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 10:29.962s
[INFO] Finished at: Tue May 12 08:12:09 UTC 2015
[INFO] Final Memory: 115M/348M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-gwc-distributed: Compilation failure: Compilation failure:
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/gwc-distributed/src/test/java/org/geoserver/gwc/HazelcastTest.java&gt;:\[152,11\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc-distributed
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/633/changes&gt;
