Hudson
1
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/792/changes>
Changes:
[ksmith] GEOS-7172, Fix checkbox/radio inputs in UI so they can be toggled by their labels.
[...truncated 551 lines...]
2/2 KB
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-filter/15-SNAPSHOT/maven-metadata.xml (2 KB at 3.9 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-coverage/15-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-coverage/15-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-coverage/15-SNAPSHOT/maven-metadata.xml
967/967 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-coverage/15-SNAPSHOT/maven-metadata.xml (967 B at 3.2 KB/sec)
[WARNING] The POM for org.geotools:gt-coverage:jar:15-SNAPSHOT is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
Downloading: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-core/15-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-core/15-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/xsd/gt-xsd-core/15-SNAPSHOT/maven-metadata.xml
971/971 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-core/15-SNAPSHOT/maven-metadata.xml (971 B at 3.1 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-graph/15-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-graph/15-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-graph/15-SNAPSHOT/maven-metadata.xml
964/964 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-graph/15-SNAPSHOT/maven-metadata.xml (964 B at 3.2 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-gml2/15-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/xsd/gt-xsd-gml2/15-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-gml2/15-SNAPSHOT/maven-metadata.xml
971/971 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-gml2/15-SNAPSHOT/maven-metadata.xml (971 B at 3.2 KB/sec)
Downloading: http://www.hibernatespatial.org/repository/org/geotools/xsd/gt-xsd-gml3/15-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-gml3/15-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-gml3/15-SNAPSHOT/maven-metadata.xml
971/971 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-gml3/15-SNAPSHOT/maven-metadata.xml (971 B at 3.1 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-ows ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/ows/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-ows ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-ows ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1259 from smithkm/choicelist
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 18.10.2015 @ 21:39:32 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 19-Oct-2015 08:00
[INFO] [GitCommitIdMojo] build.build.time = 19.10.2015 @ 08:01:14 UTC
[INFO] [GitCommitIdMojo] build.branch = a3b79b18f0bdc0a5a8010b7db2902e45cdc320de
[INFO] [GitCommitIdMojo] build.commit.user.email = jody.garnett@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Jody Garnett
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = a3b79b1
[INFO] [GitCommitIdMojo] build.commit.id = a3b79b18f0bdc0a5a8010b7db2902e45cdc320de
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1259 from smithkm/choicelist
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-ows ---
[INFO] Copying 9 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/ows/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-ows ---
[INFO] Compiling 90 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/ows/target/classes>
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] error: error reading /var/lib/jenkins/.m2/repository/org/geotools/gt-coverage/15-SNAPSHOT/gt-coverage-15-SNAPSHOT.jar; error in opening zip file
[INFO] 1 error
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [9.692s]
[INFO] Core Platform Module .............................. SUCCESS [7.894s]
[INFO] Open Web Service Module ........................... FAILURE [5.610s]
[INFO] Main Module ....................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Authentication by unique url key .................. SKIPPED
[INFO] WorldWind Format Module ........................... SKIPPED
[INFO] GeoServer Embedded FTP server ..................... SKIPPED
[INFO] SpatiaLite Extension .............................. SKIPPED
[INFO] GeoServer JDBC KV Catalog ......................... SKIPPED
[INFO] Simple Feature Service ............................ SKIPPED
[INFO] Aggregating Data Store ............................ SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Scripting Extensions .................... SKIPPED
[INFO] Core Scripting Extension .......................... SKIPPED
[INFO] Web UI Scripting Extension ........................ SKIPPED
[INFO] BeanShell Scripting Extension ..................... SKIPPED
[INFO] Groovy Scripting Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] Python Scripting Extension ........................ SKIPPED
[INFO] JavaScript Scripting Extension .................... SKIPPED
[INFO] Ruby Scripting Extension .......................... SKIPPED
[INFO] WMS-EO ............................................ SKIPPED
[INFO] ColorMap .......................................... SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer mbtiles Extension ....................... SKIPPED
[INFO] GeoServer GeoPackage Extension .................... SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults .............. SKIPPED
[INFO] REST plugin community module ...................... SKIPPED
[INFO] GPX PPIO for WPS .................................. SKIPPED
[INFO] KML PPIO for WPS .................................. SKIPPED
[INFO] DownloadProcess ................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............ SKIPPED
[INFO] ActiveMQ .......................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ........... SKIPPED
[INFO] GeoServer JMS clustering module ................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module ............. SKIPPED
[INFO] Solr Module ....................................... SKIPPED
[INFO] Resumable REST Upload module ...................... SKIPPED
[INFO] GeoFence security integration ..................... SKIPPED
[INFO] GeoFence Server ................................... SKIPPED
[INFO] REST SLD service .................................. SKIPPED
[INFO] GWC Distributed Caching Plugin .................... SKIPPED
[INFO] GeoWebCache S3 .................................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] GDAL translate parent ............................. SKIPPED
[INFO] GDAL translate WCS ................................ SKIPPED
[INFO] GDAL translate WPS ................................ SKIPPED
[INFO] GeoServer Community Release Module ................ SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 30.214s
[INFO] Finished at: Mon Oct 19 08:01:15 UTC 2015
[INFO] Final Memory: 47M/279M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-ows: Compilation failure
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-ows
Hudson
2
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/793/changes>
Changes:
[daniele.romagnoli] GSIP-134: promoting multidim modules to extension
[...truncated 19843 lines...]
[INFO] Copying spring-orm-3.1.4.RELEASE.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/spring-orm-3.1.4.RELEASE.jar>
[INFO] Copying spring-tx-3.1.4.RELEASE.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/spring-tx-3.1.4.RELEASE.jar>
[INFO] Copying spring-web-3.1.4.RELEASE.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/spring-web-3.1.4.RELEASE.jar>
[INFO] Copying spring-webmvc-3.1.4.RELEASE.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/spring-webmvc-3.1.4.RELEASE.jar>
[INFO] Copying spring-security-cas-3.1.0.RELEASE.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/spring-security-cas-3.1.0.RELEASE.jar>
[INFO] Copying spring-security-config-3.1.0.RELEASE.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/spring-security-config-3.1.0.RELEASE.jar>
[INFO] Copying spring-security-core-3.1.0.RELEASE.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/spring-security-core-3.1.0.RELEASE.jar>
[INFO] Copying spring-security-crypto-3.1.0.RELEASE.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/spring-security-crypto-3.1.0.RELEASE.jar>
[INFO] Copying spring-security-web-3.1.0.RELEASE.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/spring-security-web-3.1.0.RELEASE.jar>
[INFO] Copying htmlvalidator-1.2.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/htmlvalidator-1.2.jar>
[INFO] Copying picocontainer-1.2.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/picocontainer-1.2.jar>
[INFO] Copying regexp-1.3.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/regexp-1.3.jar>
[INFO] Copying stax-api-1.0.1.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/stax-api-1.0.1.jar>
[INFO] Copying jasper-compiler-5.5.15.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/jasper-compiler-5.5.15.jar>
[INFO] Copying jasper-compiler-jdt-5.5.15.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/jasper-compiler-jdt-5.5.15.jar>
[INFO] Copying jasper-runtime-5.5.15.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/jasper-runtime-5.5.15.jar>
[INFO] Copying serializer-2.7.1.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/serializer-2.7.1.jar>
[INFO] Copying xalan-2.7.0.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/xalan-2.7.0.jar>
[INFO] Copying xercesImpl-2.11.0.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/xercesImpl-2.11.0.jar>
[INFO] Copying xml-apis-1.0.b2.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/xml-apis-1.0.b2.jar>
[INFO] Copying xml-apis-ext-1.3.04.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/xml-apis-ext-1.3.04.jar>
[INFO] Copying xml-apis-xerces-2.7.1.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/xml-apis-xerces-2.7.1.jar>
[INFO] Copying xmlpull-1.1.3.1.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/xmlpull-1.1.3.1.jar>
[INFO] Copying xmlunit-1.3.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/xmlunit-1.3.jar>
[INFO] Copying xpp3-1.1.3.4.O.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/xpp3-1.1.3.4.O.jar>
[INFO] Copying xpp3_min-1.1.4c.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/release/target/dependency/xpp3_min-1.1.4c.jar>
[INFO] gt-api-15-SNAPSHOT.jar already exists in destination.
[INFO] gwc-core-1.9-SNAPSHOT.jar already exists in destination.
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (default) @ gs-release ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
[INFO] Executed tasks
[INFO]
[INFO] Building GeoServer 2.9-SNAPSHOT
[INFO]
[INFO] --- maven-assembly-plugin:2.1:attached (default-cli) @ geoserver ---
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-war.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-javadoc.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-bin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-db2-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-feature-pregeneralized-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-imagemosaic-jdbc-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-jp2k-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-mysql-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-oracle-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-arcsde-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-pyramid-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-gdal-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-h2-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-sqlserver-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-imagemap-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-ogr-wfs-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-ogr-wps-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-excel-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-geosearch-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-charts-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-app-schema-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-control-flow-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-wps-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-wps-cluster-hazelcast-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-querylayer-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-teradata-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-cas-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-monitor-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-monitor-hibernate-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-xslt-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-inspire-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-css-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-csw-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-dxf-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-printing-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-wcs2_0-eo-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-libjpeg-turbo-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-importer-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-importer-bdb-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-grib-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-netcdf-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target/release/geoserver-2.9-SNAPSHOT-netcdf-out-plugin.zip>
[INFO]
[INFO] GeoServer ......................................... SUCCESS [49.056s]
[INFO] Core Platform Module .............................. SUCCESS [7.701s]
[INFO] Open Web Service Module ........................... SUCCESS [20.480s]
[INFO] Main Module ....................................... SUCCESS [46.888s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.455s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [8.341s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [7.545s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.378s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [11.285s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [10.529s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [13.615s]
[INFO] Web Feature Service Module ........................ SUCCESS [20.997s]
[INFO] Web Map Service Module ............................ SUCCESS [24.321s]
[INFO] KML support for GeoServer ......................... SUCCESS [11.239s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [21.713s]
[INFO] REST Support Module ............................... SUCCESS [7.048s]
[INFO] REST Configuration Service Module ................. SUCCESS [14.046s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.235s]
[INFO] Core UI Module .................................... SUCCESS [18.440s]
[INFO] WMS UI Module ..................................... SUCCESS [9.709s]
[INFO] GWC UI Module ..................................... SUCCESS [11.950s]
[INFO] WFS UI Module ..................................... SUCCESS [6.574s]
[INFO] Demoes Module ..................................... SUCCESS [11.077s]
[INFO] WCS UI Module ..................................... SUCCESS [7.372s]
[INFO] Security UI Modules ............................... SUCCESS [0.307s]
[INFO] Security UI Core Module ........................... SUCCESS [13.567s]
[INFO] Security UI JDBC Module ........................... SUCCESS [8.157s]
[INFO] Security UI LDAP Module ........................... SUCCESS [6.620s]
[INFO] REST UI Module .................................... SUCCESS [6.150s]
[INFO] GeoServer Web Application ......................... SUCCESS [31.934s]
[INFO] Community Space ................................... SUCCESS [0.618s]
[INFO] Authentication by unique url key .................. SUCCESS [10.777s]
[INFO] WorldWind Format Module ........................... SUCCESS [8.391s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [3.412s]
[INFO] SpatiaLite Extension .............................. SUCCESS [6.679s]
[INFO] GeoServer JDBC KV Catalog ......................... SUCCESS [9.505s]
[INFO] Simple Feature Service ............................ SUCCESS [6.857s]
[INFO] Aggregating Data Store ............................ SUCCESS [4.621s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.279s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.222s]
[INFO] Web Processing Service Module ..................... SUCCESS [18.418s]
[INFO] GeoServer Scripting Extensions .................... SUCCESS [0.928s]
[INFO] Core Scripting Extension .......................... SUCCESS [8.749s]
[INFO] Web UI Scripting Extension ........................ SUCCESS [7.869s]
[INFO] BeanShell Scripting Extension ..................... SUCCESS [6.599s]
[INFO] Groovy Scripting Extension ........................ SUCCESS [40.274s]
[INFO] H2 DataStore Extension ............................ SUCCESS [5.681s]
[INFO] Python Scripting Extension ........................ SUCCESS [16.686s]
[INFO] JavaScript Scripting Extension .................... SUCCESS [8.679s]
[INFO] Ruby Scripting Extension .......................... SUCCESS [6.394s]
[INFO] WMS-EO ............................................ SUCCESS [8.374s]
[INFO] ColorMap .......................................... SUCCESS [6.267s]
[INFO] GeoServer mbtiles Extension ....................... SUCCESS [34.581s]
[INFO] GeoServer GeoPackage Extension .................... SUCCESS [8.200s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [3.991s]
[INFO] Dynamic WMS dimension value defaults .............. SUCCESS [7.575s]
[INFO] REST plugin community module ...................... SUCCESS [6.377s]
[INFO] GPX PPIO for WPS .................................. SUCCESS [6.184s]
[INFO] KML PPIO for WPS .................................. SUCCESS [6.456s]
[INFO] DownloadProcess ................................... SUCCESS [8.363s]
[INFO] GeoServer JMS based clustering modules ............ SUCCESS [1.747s]
[INFO] ActiveMQ .......................................... SUCCESS [7.045s]
[INFO] GeoServer JMS clustering Commons module ........... SUCCESS [12.823s]
[INFO] GeoServer JMS clustering module ................... SUCCESS [17.468s]
[INFO] GeoServer Hazelcast Clustering Module ............. SUCCESS [8.077s]
[INFO] Solr Module ....................................... SUCCESS [7.156s]
[INFO] Resumable REST Upload module ...................... SUCCESS [6.613s]
[INFO] GeoFence security integration ..................... SUCCESS [11.253s]
[INFO] GeoFence Server ................................... SUCCESS [9.849s]
[INFO] REST SLD service .................................. SUCCESS [7.803s]
[INFO] GWC Distributed Caching Plugin .................... SUCCESS [3.996s]
[INFO] GeoWebCache S3 .................................... SUCCESS [8.662s]
[INFO] OGR parent ........................................ SUCCESS [0.321s]
[INFO] OGR CORE .......................................... SUCCESS [2.649s]
[INFO] GDAL translate parent ............................. SUCCESS [0.264s]
[INFO] GDAL translate WCS ................................ SUCCESS [7.118s]
[INFO] GDAL translate WPS ................................ SUCCESS [7.854s]
[INFO] GeoServer Community Release Module ................ SUCCESS [28.114s]
[INFO] Application Schema Support ........................ SUCCESS [0.306s]
[INFO] Application Schema Integration Test ............... SUCCESS [28.450s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [9.314s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [55.902s]
[INFO] GeoSearch Index Module ............................ SUCCESS [6.455s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [8.478s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.198s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.218s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [10.033s]
[INFO] ImageMap Output Format ............................ SUCCESS [7.071s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.288s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [5.653s]
[INFO] OGR WFS ........................................... SUCCESS [6.123s]
[INFO] OGR WPS ........................................... SUCCESS [6.433s]
[INFO] Excel Output Format ............................... SUCCESS [6.234s]
[INFO] Chart external graphics support ................... SUCCESS [0.264s]
[INFO] Feature Generalization Extension .................. SUCCESS [7.481s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.291s]
[INFO] OWS request flow controller ....................... SUCCESS [6.480s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [5.995s]
[INFO] Web Processing Service GUI ........................ SUCCESS [9.363s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [6.267s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.459s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.291s]
[INFO] Core Monitor Extension ............................ SUCCESS [11.564s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [7.766s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.616s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [7.256s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.300s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.586s]
[INFO] XLST based WFS output format ...................... SUCCESS [6.766s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [7.571s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [9.142s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.271s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [8.543s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [6.280s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [10.838s]
[INFO] CSW UI Module ..................................... SUCCESS [6.230s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.220s]
[INFO] DXF WFS output format ............................. SUCCESS [6.129s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [5.280s]
[INFO] Printing Module ................................... SUCCESS [6.833s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.249s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [9.337s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [5.400s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [6.836s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.619s]
[INFO] Importer Core Module .............................. SUCCESS [12.595s]
[INFO] Importer REST Api Module .......................... SUCCESS [9.351s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [6.425s]
[INFO] Importer Web UI Module ............................ SUCCESS [9.174s]
[INFO] GRIB Coverage Format .............................. SUCCESS [7.737s]
[INFO] NetCDF Coverage format ............................ SUCCESS [5.624s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [19.553s]
[INFO] GeoServer Release Module .......................... SUCCESS [17.125s]
[INFO] BUILD SUCCESS
[INFO] Total time: 21:11.825s
[INFO] Finished at: Tue Oct 20 08:22:20 UTC 2015
[INFO] Final Memory: 159M/428M
[geoserver-master] $ /opt/apache-maven-3.0.4/bin/mvn -f src/community/pom.xml assembly:attached
[INFO] Scanning for projects...
[INFO]
[INFO] Building Community Space 2.9-SNAPSHOT
[INFO]
[INFO] --- maven-assembly-plugin:2.1:attached (default-cli) @ community ---
[INFO] Total time: 2.786s
[INFO] Finished at: Tue Oct 20 08:22:26 UTC 2015
[INFO] Final Memory: 8M/110M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-assembly-plugin:2.1:attached (default-cli) on project community: Unable to find descriptor: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/release/ext-netcdf.xml> (No such file or directory) -> [Help 1]
[ERROR]
[ERROR]
Hudson
3
