See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/795/>
[...truncated 539 lines...]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/ows/target/gs-ows-2.9-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ gs-ows ---
[INFO] Copying gt-api-15-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/ows/target/dependency/gt-api-15-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.9-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/ows/target/dependency/gwc-core-1.9-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-ows ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/ows/target/gs-ows-2.9-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-ows/2.9-SNAPSHOT/gs-ows-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/ows/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-ows/2.9-SNAPSHOT/gs-ows-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/ows/target/gs-ows-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-ows/2.9-SNAPSHOT/gs-ows-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/ows/target/gs-ows-2.9-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-ows/2.9-SNAPSHOT/gs-ows-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/ows/target/gs-ows-2.9-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-ows/2.9-SNAPSHOT/gs-ows-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Main Module 2.9-SNAPSHOT
Downloading: http://repo.boundlessgeo.com/main/org/geotools/jdbc/gt-jdbc/15-SNAPSHOT/gt-jdbc-15-20151021.082736-23.pom
3/4 KB
4/4 KB
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/jdbc/gt-jdbc/15-SNAPSHOT/gt-jdbc-15-20151021.082736-23.pom (4 KB at 0.1 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-main ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-main ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-main ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1273 from dromagnoli/GEOS-7254
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 20.10.2015 @ 09:08:18 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 21-Oct-2015 08:36
[INFO] [GitCommitIdMojo] build.build.time = 21.10.2015 @ 08:38:16 UTC
[INFO] [GitCommitIdMojo] build.branch = 21cd49295aab64e8a2aff8d703040ed3fc39c231
[INFO] [GitCommitIdMojo] build.commit.user.email = daniele.romagnoli@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Daniele Romagnoli
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 21cd492
[INFO] [GitCommitIdMojo] build.commit.id = 21cd49295aab64e8a2aff8d703040ed3fc39c231
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1273 from dromagnoli/GEOS-7254
GEOS-7254: Fixing GSIP doc
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-main ---
[INFO] Copying 34 resources
[INFO] Copying 168 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-main ---
[INFO] Compiling 610 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/target/classes>
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredGridCoverage2DReader.java>:\[41,7\] error: SecuredGridCoverage2DReader is not abstract and does not override abstract method getInfo(String) in GridCoverage2DReader
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/catalog/SingleGridCoverage2DReader.java>:\[32,7\] error: SingleGridCoverage2DReader is not abstract and does not override abstract method getInfo(String) in GridCoverage2DReader
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/catalog/StructuredSingleGridCoverage2DReader.java>:\[24,7\] error: StructuredSingleGridCoverage2DReader is not abstract and does not override abstract method getInfo(String) in GridCoverage2DReader
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/catalog/CoverageViewReader.java>:\[62,7\] error: CoverageViewReader is not abstract and does not override abstract method getInfo(String) in GridCoverage2DReader
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/catalog/CoverageDimensionCustomizerReader.java>:\[65,7\] error: CoverageDimensionCustomizerReader is not abstract and does not override abstract method getInfo(String) in GridCoverage2DReader
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/catalog/CoverageDimensionCustomizerReader.java>:\[212,24\] error: getInfo() in CoverageDimensionCustomizerReader cannot implement getInfo() in GridCoverage2DReader
[ERROR] return type CoverageInfo is not compatible with ServiceInfo
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/catalog/CoverageDimensionCustomizerReader.java>:\[77,11\] error: CoverageDimensionCustomizerStructuredReader is not abstract and does not override abstract method getInfo(String) in GridCoverage2DReader
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/catalog/CoverageViewReader.java>:\[173,11\] error: getInfo() in CoverageDimensionCustomizerReader cannot implement getInfo() in GridCoverage2DReader
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/catalog/CoverageViewReader.java>:\[213,11\] error: getInfo() in CoverageDimensionCustomizerReader cannot implement getInfo() in GridCoverage2DReader
<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/catalog/StructuredCoverageViewReader.java>:\[44,7\] error: StructuredCoverageViewReader is not abstract and does not override abstract method getInfo(String) in GridCoverage2DReader
[INFO] 10 errors
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [4.488s]
[INFO] Core Platform Module .............................. SUCCESS [7.104s]
[INFO] Open Web Service Module ........................... SUCCESS [10.515s]
[INFO] Main Module ....................................... FAILURE [1:14.753s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Authentication by unique url key .................. SKIPPED
[INFO] WorldWind Format Module ........................... SKIPPED
[INFO] GeoServer Embedded FTP server ..................... SKIPPED
[INFO] SpatiaLite Extension .............................. SKIPPED
[INFO] GeoServer JDBC KV Catalog ......................... SKIPPED
[INFO] Simple Feature Service ............................ SKIPPED
[INFO] Aggregating Data Store ............................ SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Scripting Extensions .................... SKIPPED
[INFO] Core Scripting Extension .......................... SKIPPED
[INFO] Web UI Scripting Extension ........................ SKIPPED
[INFO] BeanShell Scripting Extension ..................... SKIPPED
[INFO] Groovy Scripting Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] Python Scripting Extension ........................ SKIPPED
[INFO] JavaScript Scripting Extension .................... SKIPPED
[INFO] Ruby Scripting Extension .......................... SKIPPED
[INFO] WMS-EO ............................................ SKIPPED
[INFO] ColorMap .......................................... SKIPPED
[INFO] GeoServer mbtiles Extension ....................... SKIPPED
[INFO] GeoServer GeoPackage Extension .................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults .............. SKIPPED
[INFO] REST plugin community module ...................... SKIPPED
[INFO] GPX PPIO for WPS .................................. SKIPPED
[INFO] KML PPIO for WPS .................................. SKIPPED
[INFO] DownloadProcess ................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............ SKIPPED
[INFO] ActiveMQ .......................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ........... SKIPPED
[INFO] GeoServer JMS clustering module ................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module ............. SKIPPED
[INFO] Solr Module ....................................... SKIPPED
[INFO] Resumable REST Upload module ...................... SKIPPED
[INFO] GeoFence security integration ..................... SKIPPED
[INFO] GeoFence Server ................................... SKIPPED
[INFO] REST SLD service .................................. SKIPPED
[INFO] GWC Distributed Caching Plugin .................... SKIPPED
[INFO] GeoWebCache S3 .................................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] GDAL translate parent ............................. SKIPPED
[INFO] GDAL translate WCS ................................ SKIPPED
[INFO] GDAL translate WPS ................................ SKIPPED
[INFO] GeoServer Community Release Module ................ SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 1:44.758s
[INFO] Finished at: Wed Oct 21 08:38:29 UTC 2015
[INFO] Final Memory: 51M/258M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-main: Compilation failure: Compilation failure:
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/catalog/CoverageDimensionCustomizerReader.java>:\[77,11\] error: CoverageDimensionCustomizerStructuredReader is not abstract and does not override abstract method getInfo(String) in GridCoverage2DReader
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/catalog/CoverageViewReader.java>:\[213,11\] error: getInfo() in CoverageDimensionCustomizerReader cannot implement getInfo() in GridCoverage2DReader
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/catalog/StructuredCoverageViewReader.java>:\[44,7\] error: StructuredCoverageViewReader is not abstract and does not override abstract method getInfo(String) in GridCoverage2DReader
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
