[Geoserver-devel] Build failed in Jenkins: geoserver-master-nightly #913
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/913/&gt;
[...truncated 15906 lines...]
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-sec-cas ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1450 from NielsCharlier/jdbc_resource_store
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 05.02.2016 @ 23:30:34 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 07-Feb-2016 08:00
[INFO] [GitCommitIdMojo] build.build.time = 07.02.2016 @ 08:12:39 UTC
[INFO] [GitCommitIdMojo] build.branch = 33887ef6ee9e2ee08a6a1759f945efa36eecfdb4
[INFO] [GitCommitIdMojo] build.commit.user.email = ben@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Ben Caradoc-Davies
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 33887ef
[INFO] [GitCommitIdMojo] build.commit.id = 33887ef6ee9e2ee08a6a1759f945efa36eecfdb4
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1450 from NielsCharlier/jdbc_resource_store
API change for JDBC Resource Store [GSIP-136]
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-sec-cas ---
[INFO] Copying 1 resource
[INFO] Copying 14 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-sec-cas ---
[INFO] Compiling 11 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/security/cas/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-sec-cas ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/security/cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-sec-cas ---
[INFO] Compiling 4 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/security/cas/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-cas ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/security/cas/target/gs-sec-cas-2.9-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/security/cas/target/gs-sec-cas-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-sec-cas >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 07.02.2016 @ 08:12:44 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/security/cas/target/gs-sec-cas-2.9-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/security/cas/target/gs-sec-cas-2.9-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ gs-sec-cas ---
[INFO] Copying gt-api-15-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/security/cas/target/dependency/gt-api-15-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.9-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/security/cas/target/dependency/gwc-core-1.9-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/security/cas/target/gs-sec-cas-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.9-SNAPSHOT/gs-sec-cas-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/security/cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.9-SNAPSHOT/gs-sec-cas-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/security/cas/target/gs-sec-cas-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.9-SNAPSHOT/gs-sec-cas-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/security/cas/target/gs-sec-cas-2.9-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.9-SNAPSHOT/gs-sec-cas-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/security/cas/target/gs-sec-cas-2.9-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.9-SNAPSHOT/gs-sec-cas-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Security Extension Web Modules 2.9-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-sec ---
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/security/web/target/gs-web-sec-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 07.02.2016 @ 08:12:45 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ gs-web-sec ---
[INFO] Copying gt-api-15-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/security/web/target/dependency/gt-api-15-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.9-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/security/web/target/dependency/gwc-core-1.9-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/security/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.9-SNAPSHOT/gs-web-sec-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/security/web/target/gs-web-sec-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.9-SNAPSHOT/gs-web-sec-2.9-SNAPSHOT-tests.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.9-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-sec-cas ---
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas ---
[ERROR] Java heap space -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/OutOfMemoryError
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/914/changes&gt;
