[Geoserver-devel] Build failed in Jenkins: geoserver-master-nightly #924
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/924/changes&gt;
Changes:
[andrea.aime] wps-remote GeoServer contribution
[andrea.aime] Use ExtensionPriority instead of custom sorting
[andrea.aime] Simplify names management
[afabiani] - add support for applicazion/zip mime types
[afabiani] - Remote WPS RST Documentation first draft
[afabiani] - minor improvements to the Java Docs
[andrea.aime] Some fixes to the docs
[afabiani] - Updating the Remote WPS Community module documentation
[afabiani] - logging reference documentation
[daniele.romagnoli] [GEOS-7431]: Updating the GRIB Zip's included dependencies
[jody.garnett] Revert "[GEOS-7396]: ClassCastException fix"
[andrea.aime] Clean up repo since we have broken jars into it
[daniele.romagnoli] [GEOS-7396]: ClassCastException fix
[afabiani] - fix Python Remote WPS Git repo URL
[...truncated 545 lines...]
2/2 KB
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-filter/15-SNAPSHOT/maven-metadata.xml (2 KB at 5.7 KB/sec)
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-coverage/15-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-coverage/15-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-coverage/15-SNAPSHOT/maven-metadata.xml
958/958 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-coverage/15-SNAPSHOT/maven-metadata.xml (958 B at 5.3 KB/sec)
[WARNING] The POM for org.geotools:gt-coverage:jar:15-SNAPSHOT is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-core/15-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-core/15-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/xsd/gt-xsd-core/15-SNAPSHOT/maven-metadata.xml
962/962 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-core/15-SNAPSHOT/maven-metadata.xml (962 B at 4.2 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-graph/15-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-graph/15-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-graph/15-SNAPSHOT/maven-metadata.xml
955/955 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-graph/15-SNAPSHOT/maven-metadata.xml (955 B at 5.0 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-gml2/15-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/xsd/gt-xsd-gml2/15-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-gml2/15-SNAPSHOT/maven-metadata.xml
962/962 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-gml2/15-SNAPSHOT/maven-metadata.xml (962 B at 4.1 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-gml3/15-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-gml3/15-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/xsd/gt-xsd-gml3/15-SNAPSHOT/maven-metadata.xml
962/962 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-gml3/15-SNAPSHOT/maven-metadata.xml (962 B at 5.7 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-ows ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/ows/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-ows ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-ows ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = - fix Python Remote WPS Git repo URL
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 18.02.2016 @ 11:29:34 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 19-Feb-2016 08:01
[INFO] [GitCommitIdMojo] build.build.time = 19.02.2016 @ 08:01:51 UTC
[INFO] [GitCommitIdMojo] build.branch = b2269ceeedea11805bf8dc55350b6e99075fccaa
[INFO] [GitCommitIdMojo] build.commit.user.email = alessio.fabiani@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = afabiani
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = b2269ce
[INFO] [GitCommitIdMojo] build.commit.id = b2269ceeedea11805bf8dc55350b6e99075fccaa
[INFO] [GitCommitIdMojo] build.commit.message.full = - fix Python Remote WPS Git repo URL
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-ows ---
[INFO] Copying 9 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/ows/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-ows ---
[INFO] Compiling 92 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/ows/target/classes&gt;
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] error: error reading /var/lib/jenkins/.m2/repository/org/geotools/gt-coverage/15-SNAPSHOT/gt-coverage-15-SNAPSHOT.jar; error in opening zip file
[INFO] 1 error
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [11.853s]
[INFO] Core Platform Module .............................. SUCCESS [10.521s]
[INFO] Open Web Service Module ........................... FAILURE [6.577s]
[INFO] Main Module ....................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Demos Module ...................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Authentication by unique url key .................. SKIPPED
[INFO] WorldWind Format Module ........................... SKIPPED
[INFO] SpatiaLite Extension .............................. SKIPPED
[INFO] GeoServer JDBC KV Catalog ......................... SKIPPED
[INFO] Aggregating Data Store ............................ SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Scripting Extensions .................... SKIPPED
[INFO] Core Scripting Extension .......................... SKIPPED
[INFO] Web UI Scripting Extension ........................ SKIPPED
[INFO] BeanShell Scripting Extension ..................... SKIPPED
[INFO] Groovy Scripting Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] Python Scripting Extension ........................ SKIPPED
[INFO] JavaScript Scripting Extension .................... SKIPPED
[INFO] Ruby Scripting Extension .......................... SKIPPED
[INFO] WMS-EO ............................................ SKIPPED
[INFO] ColorMap .......................................... SKIPPED
[INFO] GeoServer mbtiles Extension ....................... SKIPPED
[INFO] GeoServer GeoPackage Extension .................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults .............. SKIPPED
[INFO] REST plugin community module ...................... SKIPPED
[INFO] GPX PPIO for WPS .................................. SKIPPED
[INFO] KML PPIO for WPS .................................. SKIPPED
[INFO] DownloadProcess ................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............ SKIPPED
[INFO] ActiveMQ .......................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ........... SKIPPED
[INFO] GeoServer JMS clustering module ................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module ............. SKIPPED
[INFO] Solr Module ....................................... SKIPPED
[INFO] Resumable REST Upload module ...................... SKIPPED
[INFO] GeoFence security integration ..................... SKIPPED
[INFO] GeoFence Server ................................... SKIPPED
[INFO] REST SLD service .................................. SKIPPED
[INFO] Parameters Extractor .............................. SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Web Processing Service - Remote processes invocation SKIPPED
[INFO] GWC Distributed Caching Plugin .................... SKIPPED
[INFO] GeoWebCache S3 .................................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] GDAL translate parent ............................. SKIPPED
[INFO] GDAL translate WCS ................................ SKIPPED
[INFO] GDAL translate WPS ................................ SKIPPED
[INFO] GeoServer Community Release Module ................ SKIPPED
[INFO] GeoServer JDBC Configuration Resource Store ....... SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 31.806s
[INFO] Finished at: Fri Feb 19 08:01:52 UTC 2016
[INFO] Final Memory: 47M/307M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-ows: Compilation failure
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-ows
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/925/&gt;
