[Geoserver-devel] Build failed in Jenkins: geoserver-master-nightly #962
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/962/changes&gt;
Changes:
[afabiani] - Promote logging 'TEST' messages into 'Finer' debug ones
[afabiani] - Added Resource Monitor Thread and Get Load Average XMPP Message handlers
[daniele.romagnoli] [GEOS-7325]: Adding missing jars to NetCDF Output format plugin
[srstclair] Add web app excel profile
[srstclair] Add Excel output Wicket labels
[srstclair] Upgrade Apache POI to 3.14
[andrea.aime] [GEOS-7444] Handle unmarshalling of GridGeometry2D objects when the JSON/XML definition follows an arbitrary order
[ben] Upgrade git-commit-id-plugin to 2.2.0
[...truncated 143 lines...]
[INFO] Core Monitor Extension
[INFO] Monitor Hibernate Extension
[INFO] GeoServer Security Extension Modules
[INFO] GeoServer CAS Security Module
[INFO] GeoServer Security Extension Web Modules
[INFO] GeoServer CAS Security Web Module
[INFO] XLST based WFS output format
[INFO] GeoServer INSPIRE Extensions
[INFO] GeoServer CSS Styling
[INFO] Catalog Services for the Web parent
[INFO] Catalog Services for the Web interfaces
[INFO] Catalog Services for the Web - Simple CatalogStore implementation
[INFO] Catalog Services for the Web core module
[INFO] CSW UI Module
[INFO] DXF WFS output format and WPS PPIO
[INFO] DXF WPS PPIO
[INFO] Printing Module
[INFO] GeoServer WCS 2.0 Earth Observation Extensions
[INFO] Web Coverage Service 2.0 Earth Observation extensions
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension
[INFO] GeoServer libjpeg-turbo Module
[INFO] Importer REST Api Module
[INFO] Importer Berkley DB Persistence Module
[INFO] Importer Web UI Module
[INFO] GRIB Coverage Format
[INFO] NetCDF Coverage format
[INFO] WCS NetCDF output Module
[INFO] GeoServer Release Module
[INFO]
[INFO] Building GeoServer 2.9-SNAPSHOT
Downloading: http://repo.maven.apache.org/maven2/pl/project13/maven/git-commit-id-plugin/2.2.0/git-commit-id-plugin-2.2.0.pom
3/12 KB
7/12 KB
11/12 KB
12/12 KB
Downloaded: http://repo.maven.apache.org/maven2/pl/project13/maven/git-commit-id-plugin/2.2.0/git-commit-id-plugin-2.2.0.pom (12 KB at 18.2 KB/sec)
Downloading: http://repo.maven.apache.org/maven2/pl/project13/maven/git-commit-id-plugin/2.2.0/git-commit-id-plugin-2.2.0.jar
1/117 KB
5/117 KB
9/117 KB
13/117 KB
17/117 KB
18/117 KB
21/117 KB
24/117 KB
27/117 KB
30/117 KB
34/117 KB
35/117 KB
38/117 KB
41/117 KB
45/117 KB
47/117 KB
49/117 KB
51/117 KB
52/117 KB
55/117 KB
58/117 KB
61/117 KB
65/117 KB
66/117 KB
70/117 KB
72/117 KB
76/117 KB
76/117 KB
78/117 KB
82/117 KB
83/117 KB
87/117 KB
88/117 KB
90/117 KB
93/117 KB
96/117 KB
99/117 KB
102/117 KB
104/117 KB
107/117 KB
110/117 KB
113/117 KB
117/117 KB
Downloaded: http://repo.maven.apache.org/maven2/pl/project13/maven/git-commit-id-plugin/2.2.0/git-commit-id-plugin-2.2.0.jar (117 KB at 487.7 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ geoserver ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ geoserver ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... FAILURE [1.592s]
[INFO] Core Platform Module .............................. SKIPPED
[INFO] Open Web Service Module ........................... SKIPPED
[INFO] Main Module ....................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Demos Module ...................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Authentication by unique url key .................. SKIPPED
[INFO] WorldWind Format Module ........................... SKIPPED
[INFO] SpatiaLite Extension .............................. SKIPPED
[INFO] GeoServer JDBC KV Catalog ......................... SKIPPED
[INFO] Aggregating Data Store ............................ SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Scripting Extensions .................... SKIPPED
[INFO] Core Scripting Extension .......................... SKIPPED
[INFO] Web UI Scripting Extension ........................ SKIPPED
[INFO] BeanShell Scripting Extension ..................... SKIPPED
[INFO] Groovy Scripting Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] Python Scripting Extension ........................ SKIPPED
[INFO] JavaScript Scripting Extension .................... SKIPPED
[INFO] Ruby Scripting Extension .......................... SKIPPED
[INFO] WMS-EO ............................................ SKIPPED
[INFO] ColorMap .......................................... SKIPPED
[INFO] GeoServer mbtiles Extension ....................... SKIPPED
[INFO] GeoServer GeoPackage Extension .................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults .............. SKIPPED
[INFO] REST plugin community module ...................... SKIPPED
[INFO] GPX PPIO for WPS .................................. SKIPPED
[INFO] KML PPIO for WPS .................................. SKIPPED
[INFO] DownloadProcess ................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............ SKIPPED
[INFO] ActiveMQ .......................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ........... SKIPPED
[INFO] GeoServer JMS clustering module ................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module ............. SKIPPED
[INFO] Solr Module ....................................... SKIPPED
[INFO] Resumable REST Upload module ...................... SKIPPED
[INFO] GeoFence security integration ..................... SKIPPED
[INFO] GeoFence Server ................................... SKIPPED
[INFO] REST SLD service .................................. SKIPPED
[INFO] Parameters Extractor .............................. SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Web Processing Service - Remote processes invocation SKIPPED
[INFO] WPS cluster on jdbc datastores .................... SKIPPED
[INFO] GWC Distributed Caching Plugin .................... SKIPPED
[INFO] GeoWebCache S3 .................................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] GDAL translate parent ............................. SKIPPED
[INFO] GDAL translate WCS ................................ SKIPPED
[INFO] GDAL translate WPS ................................ SKIPPED
[INFO] GeoServer Community Release Module ................ SKIPPED
[INFO] GeoServer JDBC Configuration Resource Store ....... SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 5.570s
[INFO] Finished at: Sat Mar 19 23:11:56 UTC 2016
[INFO] Final Memory: 45M/314M
[ERROR] Failed to execute goal pl.project13.maven:git-commit-id-plugin:2.2.0:revision (default) on project geoserver: The plugin pl.project13.maven:git-commit-id-plugin:2.2.0 requires Maven version [3.1.1,) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/PluginIncompatibleException
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/963/&gt;
Started by user Hudson
Started by timer
Building in workspace <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/&gt;
Checkout:geoserver-master / <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/&gt; - hudson.remoting.LocalChannel@anonymised.com
Using strategy: Default
Last Built Revision: Revision 3a43c1dff917289d1b2dfbc0d4e9a89cd22aa240 (origin/master)
Fetching changes from 1 remote Git repository
Fetching upstream changes from origin
ERROR: Problem fetching from origin / origin - could be unavailable. Continuing anyway
hudson.plugins.git.GitException: Command "git fetch -t origin +refs/heads/*:refs/remotes/origin/*" returned status code 1:
stdout:
stderr: error: Ref refs/remotes/origin/2.7.x is at 9290710a127b97ac4d8c12c01b7efacbb0e4bb7a but expected 264ab0b1ee14e809363ed818e76e19e6fd5dee4c
From git://github.com/geoserver/geoserver
! 264ab0b..9290710 2.7.x -> origin/2.7.x (unable to update local ref)
error: Ref refs/remotes/origin/2.8.x is at 1c8c9ba0f74a465c397d46cf19d3b34b95b2fb6e but expected f716f66c558d25661d5df860563b730b888afe56
! f716f66..1c8c9ba 2.8.x -> origin/2.8.x (unable to update local ref)
error: Ref refs/remotes/origin/master is at 5764d58de3af4d71287f8a0ef9b5817980f1a7cd but expected cf57d96947a06f5f5757762e3190e167f95d1cd2
! cf57d96..5764d58 master -> origin/master (unable to update local ref)
  at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:790)
  at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:756)
  at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.fetch(CliGitAPIImpl.java:144)
  at hudson.plugins.git.GitAPI.fetch(GitAPI.java:221)
  at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:791)
  at hudson.plugins.git.GitSCM.access$000(GitSCM.java:58)
  at hudson.plugins.git.GitSCM$2.invoke(GitSCM.java:983)
  at hudson.plugins.git.GitSCM$2.invoke(GitSCM.java:948)
  at hudson.FilePath.act(FilePath.java:914)
  at hudson.FilePath.act(FilePath.java:887)
  at hudson.plugins.git.GitSCM.determineRevisionToBuild(GitSCM.java:948)
  at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1114)
  at hudson.model.AbstractProject.checkout(AbstractProject.java:1320)
  at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:609)
  at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:88)
  at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:518)
  at hudson.model.Run.execute(Run.java:1689)
  at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
  at hudson.model.ResourceController.execute(ResourceController.java:88)
  at hudson.model.Executor.run(Executor.java:231)
ERROR: Could not fetch from any repository
java.io.IOException: Could not fetch from any repository
  at hudson.plugins.git.GitSCM$2.invoke(GitSCM.java:992)
This is the second time I have seen this sort of error. Last time:
http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/179/console
Last time the fix was:
https://sourceforge.net/p/geoserver/mailman/message/34941839/
"I temporarily enabled "wipe out workspace" to force a fresh checkout and kicked the build. I then restored this setting (unchecked)."
I have not yet applied this fix. Any idea of the cause? I saw no force push. Is there some concurrency issue on ares?
Kind regards,
BEn.
Started by timer
stdout:
Transform Data into Opportunity.
Accelerate data analysis in your applications with
Intel Data Analytics Acceleration Library.
Click to learn more.
http://pubads.g.doubleclick.net/gampad/clk?id=278785231&iu=/4140
Geoserver-devel mailing list
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
Hi Ben,
I’m unsure… doesn’t ares build only a single build at a time?
On Sun, Mar 20, 2016 at 11:27 AM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
“I temporarily enabled “wipe out workspace” to force a fresh checkout
and kicked the build. I then restored this setting (unchecked).”
Kind regards,
BEn.
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/963/>
Started by timer
Building in workspace <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/>
Checkout:geoserver-master / <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/> - hudson.remoting.LocalChannel@anonymised.com
hudson.plugins.git.GitException: Command “git fetch -t origin +refs/heads/:refs/remotes/origin/” returned status code 1:
stdout:
! 264ab0b…9290710 2.7.x → origin/2.7.x (unable to update local ref)
! f716f66…1c8c9ba 2.8.x → origin/2.8.x (unable to update local ref)
! cf57d96…5764d58 master → origin/master (unable to update local ref)
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
I am pretty sure that only one build job runs at a time. The Throttle Concurrent Builds Plugin is configured but I do not understand the settings.
One oddity is that all nightlies have:
Advanced Project Options
Use custom workspace > workspace/geoserver-master
Yes, *all* nightlies build in workspace/geoserver-master. I do not know why this option is set for any nightly. They all run clean install. Is this a space saver?
Kind regards,
Ben.
On 20/03/16 23:43, Andrea Aime wrote:
I'm unsure... doesn't ares build only a single build at a time?
Director
New Zealand
Hi Ben,
I remember that in order to save space the normal and nightly builds
were using the same workspace, e.g, 2.x.y and 2.x.y-nightly
would share the same workpace.
All nightlies in the same workspace looks like a copy/paste error to me,
but I might be wrong
On Sun, Mar 20, 2016 at 12:15 PM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Yes, all nightlies build in workspace/geoserver-master. I do not know why this option is set for any nightly. They all run clean install. Is this a space saver?
Kind regards,
Ben.
Director
New Zealand
Ing. Andrea Aime
@geowolf
Technical Lead
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/964/changes&gt;
