See <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/1135/changes>
Changes:
[tbarsballe] [GEOS-7826] Add check for no layers when instantiating Style Editor
[...truncated 79448 lines...]
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 4.378 s]
[INFO] Core Platform Module ............................... SUCCESS [ 14.348 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 8.497 s]
[INFO] Main Module ........................................ SUCCESS [01:36 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 2.703 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 16.727 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 17.290 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.283 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 15.322 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 17.726 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 37.359 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 59.802 s]
[INFO] Web Map Service Module ............................. FAILURE [02:29 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] REST Support Module ................................ SKIPPED
[INFO] REST Configuration Service Module .................. SKIPPED
[INFO] GeoServer Web Modules .............................. SKIPPED
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Community Space .................................... SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 07:37 min
[INFO] Finished at: 2016-11-15T02:01:30+01:00
[INFO] Final Memory: 130M/956M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wms/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/csw/web-csw/pom.xml> to org.geoserver.csw/gs-web-csw/2.11-SNAPSHOT/gs-web-csw-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/netcdf-out/pom.xml> to org.geoserver.extension/gs-netcdf-out/2.11-SNAPSHOT/gs-netcdf-out-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/arcsde/pom.xml> to org.geoserver.extension/gs-arcsde/2.11-SNAPSHOT/gs-arcsde-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/app-schema/app-schema-test/pom.xml> to org.geoserver.extension/gs-app-schema-test/2.11-SNAPSHOT/gs-app-schema-test-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/teradata/pom.xml> to org.geoserver.extension/gs-teradata/2.11-SNAPSHOT/gs-teradata-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/wfs/pom.xml> to org.geoserver.web/gs-web-wfs/2.11-SNAPSHOT/gs-web-wfs-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/ogr/ogr-wps/pom.xml> to org.geoserver.extension/gs-ogr-wps/2.11-SNAPSHOT/gs-ogr-wps-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/gdal/pom.xml> to org.geoserver.extension/gs-gdal/2.11-SNAPSHOT/gs-gdal-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/dxf/core/pom.xml> to org.geoserver.extension/gs-dxf-core/2.11-SNAPSHOT/gs-dxf-core-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/security/pom.xml> to org.geoserver.extension/gs-security/2.11-SNAPSHOT/gs-security-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/ogr/pom.xml> to org.geoserver.extension/gs-ogr/2.11-SNAPSHOT/gs-ogr-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/security/web/pom.xml> to org.geoserver.extension/gs-web-sec/2.11-SNAPSHOT/gs-web-sec-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs/pom.xml> to org.geoserver/gs-wcs/2.11-SNAPSHOT/gs-wcs-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs/target/gs-wcs-2.11-SNAPSHOT.jar> to org.geoserver/gs-wcs/2.11-SNAPSHOT/gs-wcs-2.11-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs/target/gs-wcs-2.11-SNAPSHOT-tests.jar> to org.geoserver/gs-wcs/2.11-SNAPSHOT/gs-wcs-2.11-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs/target/gs-wcs-2.11-SNAPSHOT-sources.jar> to org.geoserver/gs-wcs/2.11-SNAPSHOT/gs-wcs-2.11-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/db2/pom.xml> to org.geoserver.extension/gs-db2/2.11-SNAPSHOT/gs-db2-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_1/pom.xml> to org.geoserver/gs-wcs1_1/2.11-SNAPSHOT/gs-wcs1_1-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_1/target/gs-wcs1_1-2.11-SNAPSHOT.jar> to org.geoserver/gs-wcs1_1/2.11-SNAPSHOT/gs-wcs1_1-2.11-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_1/target/gs-wcs1_1-2.11-SNAPSHOT-tests.jar> to org.geoserver/gs-wcs1_1/2.11-SNAPSHOT/gs-wcs1_1-2.11-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_1/target/gs-wcs1_1-2.11-SNAPSHOT-sources.jar> to org.geoserver/gs-wcs1_1/2.11-SNAPSHOT/gs-wcs1_1-2.11-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_1/target/gs-wcs1_1-2.11-SNAPSHOT-test-sources.jar> to org.geoserver/gs-wcs1_1/2.11-SNAPSHOT/gs-wcs1_1-2.11-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/charts/pom.xml> to org.geoserver.extension/gs-charts/2.11-SNAPSHOT/gs-charts-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_0/pom.xml> to org.geoserver/gs-wcs1_0/2.11-SNAPSHOT/gs-wcs1_0-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_0/target/gs-wcs1_0-2.11-SNAPSHOT.jar> to org.geoserver/gs-wcs1_0/2.11-SNAPSHOT/gs-wcs1_0-2.11-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_0/target/gs-wcs1_0-2.11-SNAPSHOT-tests.jar> to org.geoserver/gs-wcs1_0/2.11-SNAPSHOT/gs-wcs1_0-2.11-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_0/target/gs-wcs1_0-2.11-SNAPSHOT-sources.jar> to org.geoserver/gs-wcs1_0/2.11-SNAPSHOT/gs-wcs1_0-2.11-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_0/target/gs-wcs1_0-2.11-SNAPSHOT-test-sources.jar> to org.geoserver/gs-wcs1_0/2.11-SNAPSHOT/gs-wcs1_0-2.11-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/core/pom.xml> to org.geoserver.web/gs-web-core/2.11-SNAPSHOT/gs-web-core-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs2_0/pom.xml> to org.geoserver/gs-wcs2_0/2.11-SNAPSHOT/gs-wcs2_0-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs2_0/target/gs-wcs2_0-2.11-SNAPSHOT.jar> to org.geoserver/gs-wcs2_0/2.11-SNAPSHOT/gs-wcs2_0-2.11-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs2_0/target/gs-wcs2_0-2.11-SNAPSHOT-tests.jar> to org.geoserver/gs-wcs2_0/2.11-SNAPSHOT/gs-wcs2_0-2.11-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs2_0/target/gs-wcs2_0-2.11-SNAPSHOT-sources.jar> to org.geoserver/gs-wcs2_0/2.11-SNAPSHOT/gs-wcs2_0-2.11-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs2_0/target/gs-wcs2_0-2.11-SNAPSHOT-test-sources.jar> to org.geoserver/gs-wcs2_0/2.11-SNAPSHOT/gs-wcs2_0-2.11-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/monitor/hibernate/pom.xml> to org.geoserver.extension/gs-monitor-hibernate/2.11-SNAPSHOT/gs-monitor-hibernate-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/jdbc/pom.xml> to org.geoserver.security/gs-sec-jdbc/2.11-SNAPSHOT/gs-sec-jdbc-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/jdbc/target/gs-sec-jdbc-2.11-SNAPSHOT.jar> to org.geoserver.security/gs-sec-jdbc/2.11-SNAPSHOT/gs-sec-jdbc-2.11-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/jdbc/target/gs-sec-jdbc-2.11-SNAPSHOT-tests.jar> to org.geoserver.security/gs-sec-jdbc/2.11-SNAPSHOT/gs-sec-jdbc-2.11-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/jdbc/target/gs-sec-jdbc-2.11-SNAPSHOT-sources.jar> to org.geoserver.security/gs-sec-jdbc/2.11-SNAPSHOT/gs-sec-jdbc-2.11-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/jdbc/target/gs-sec-jdbc-2.11-SNAPSHOT-test-sources.jar> to org.geoserver.security/gs-sec-jdbc/2.11-SNAPSHOT/gs-sec-jdbc-2.11-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/wcs2_0-eo/core/pom.xml> to org.geoserver.extension/gs-wcs2_0-eo-core/2.11-SNAPSHOT/gs-wcs2_0-eo-core-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/pom.xml> to org.geoserver/web/2.11-SNAPSHOT/web-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/libjpeg-turbo/pom.xml> to org.geoserver.extension/gs-libjpeg-turbo/2.11-SNAPSHOT/gs-libjpeg-turbo-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/pom.xml> to org.geoserver/extension/2.11-SNAPSHOT/extension-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/ldap/pom.xml> to org.geoserver.web/gs-web-sec-ldap/2.11-SNAPSHOT/gs-web-sec-ldap-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/wps/pom.xml> to org.geoserver.extension/gs-wps/2.11-SNAPSHOT/gs-wps-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/dxf/pom.xml> to org.geoserver.extension/gs-dxf/2.11-SNAPSHOT/gs-dxf-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/csw/simple-store/pom.xml> to org.geoserver.csw/gs-csw-simple-store/2.11-SNAPSHOT/gs-csw-simple-store-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/app-schema/sample-data-access-test/pom.xml> to org.geoserver.extension/gs-sample-data-access-test/2.11-SNAPSHOT/gs-sample-data-access-test-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/feature-pregeneralized/pom.xml> to org.geoserver.extension/gs-feature-pregeneralized/2.11-SNAPSHOT/gs-feature-pregeneralized-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/csw/core/pom.xml> to org.geoserver.csw/gs-csw-core/2.11-SNAPSHOT/gs-csw-core-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/ows/pom.xml> to org.geoserver/gs-ows/2.11-SNAPSHOT/gs-ows-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/ows/target/gs-ows-2.11-SNAPSHOT.jar> to org.geoserver/gs-ows/2.11-SNAPSHOT/gs-ows-2.11-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/ows/target/gs-ows-2.11-SNAPSHOT-tests.jar> to org.geoserver/gs-ows/2.11-SNAPSHOT/gs-ows-2.11-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/ows/target/gs-ows-2.11-SNAPSHOT-sources.jar> to org.geoserver/gs-ows/2.11-SNAPSHOT/gs-ows-2.11-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/ows/target/gs-ows-2.11-SNAPSHOT-test-sources.jar> to org.geoserver/gs-ows/2.11-SNAPSHOT/gs-ows-2.11-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/community/pom.xml> to org.geoserver/community/2.11-SNAPSHOT/community-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wfs/pom.xml> to org.geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wfs/target/gs-wfs-2.11-SNAPSHOT.jar> to org.geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wfs/target/gs-wfs-2.11-SNAPSHOT-tests.jar> to org.geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wfs/target/gs-wfs-2.11-SNAPSHOT-sources.jar> to org.geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wfs/target/gs-wfs-2.11-SNAPSHOT-test-sources.jar> to org.geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/ldap/pom.xml> to org.geoserver.security/gs-sec-ldap/2.11-SNAPSHOT/gs-sec-ldap-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/ldap/target/gs-sec-ldap-2.11-SNAPSHOT.jar> to org.geoserver.security/gs-sec-ldap/2.11-SNAPSHOT/gs-sec-ldap-2.11-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/ldap/target/gs-sec-ldap-2.11-SNAPSHOT-tests.jar> to org.geoserver.security/gs-sec-ldap/2.11-SNAPSHOT/gs-sec-ldap-2.11-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/ldap/target/gs-sec-ldap-2.11-SNAPSHOT-sources.jar> to org.geoserver.security/gs-sec-ldap/2.11-SNAPSHOT/gs-sec-ldap-2.11-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/ldap/target/gs-sec-ldap-2.11-SNAPSHOT-test-sources.jar> to org.geoserver.security/gs-sec-ldap/2.11-SNAPSHOT/gs-sec-ldap-2.11-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml> to org.geoserver.extension/gs-wps-cluster-hazelcast/2.11-SNAPSHOT/gs-wps-cluster-hazelcast-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/excel/pom.xml> to org.geoserver.extension/gs-excel/2.11-SNAPSHOT/gs-excel-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/wms/pom.xml> to org.geoserver.web/gs-web-wms/2.11-SNAPSHOT/gs-web-wms-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/inspire/pom.xml> to org.geoserver.extension/gs-inspire/2.11-SNAPSHOT/gs-inspire-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/wps/wps-core/pom.xml> to org.geoserver.extension/gs-wps-core/2.11-SNAPSHOT/gs-wps-core-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/css/pom.xml> to org.geoserver.extension/gs-css/2.11-SNAPSHOT/gs-css-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/main/pom.xml> to org.geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/main/target/gs-main-2.11-SNAPSHOT.jar> to org.geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/main/target/gs-main-2.11-SNAPSHOT-tests.jar> to org.geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/main/target/gs-main-2.11-SNAPSHOT-sources.jar> to org.geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/main/target/gs-main-2.11-SNAPSHOT-test-sources.jar> to org.geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/netcdf/pom.xml> to org.geoserver.extension/gs-netcdf/2.11-SNAPSHOT/gs-netcdf-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/rest/pom.xml> to org.geoserver/gs-rest/2.11-SNAPSHOT/gs-rest-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/security/cas/pom.xml> to org.geoserver.security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/wcs2_0-eo/pom.xml> to org.geoserver.extension/gs-wcs2_0-eo/2.11-SNAPSHOT/gs-wcs2_0-eo-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/pom.xml> to org.geoserver/geoserver/2.11-SNAPSHOT/geoserver-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/target/geoserver-2.11-SNAPSHOT-tests.jar> to org.geoserver/geoserver/2.11-SNAPSHOT/geoserver-2.11-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/rest/pom.xml> to org.geoserver.web/gs-web-rest/2.11-SNAPSHOT/gs-web-rest-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/monitor/pom.xml> to org.geoserver.extension/gs-monitor/2.11-SNAPSHOT/gs-monitor-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/restconfig/pom.xml> to org.geoserver/gs-restconfig/2.11-SNAPSHOT/gs-restconfig-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/platform/pom.xml> to org.geoserver/gs-platform/2.11-SNAPSHOT/gs-platform-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/platform/target/gs-platform-2.11-SNAPSHOT.jar> to org.geoserver/gs-platform/2.11-SNAPSHOT/gs-platform-2.11-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/platform/target/gs-platform-2.11-SNAPSHOT-tests.jar> to org.geoserver/gs-platform/2.11-SNAPSHOT/gs-platform-2.11-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/platform/target/gs-platform-2.11-SNAPSHOT-sources.jar> to org.geoserver/gs-platform/2.11-SNAPSHOT/gs-platform-2.11-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/platform/target/gs-platform-2.11-SNAPSHOT-test-sources.jar> to org.geoserver/gs-platform/2.11-SNAPSHOT/gs-platform-2.11-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/pom.xml> to org.geoserver.web/gs-web-sec/2.11-SNAPSHOT/gs-web-sec-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/vectortiles/pom.xml> to org.geoserver.extension/gs-vectortiles/2.11-SNAPSHOT/gs-vectortiles-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wms/pom.xml> to org.geoserver/gs-wms/2.11-SNAPSHOT/gs-wms-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/imagemap/pom.xml> to org.geoserver.extension/gs-imagemap/2.11-SNAPSHOT/gs-imagemap-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/xslt/pom.xml> to org.geoserver/gs-xslt/2.11-SNAPSHOT/gs-xslt-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/mysql/pom.xml> to org.geoserver.extension/gs-mysql/2.11-SNAPSHOT/gs-mysql-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/grib/pom.xml> to org.geoserver.extension/gs-grib/2.11-SNAPSHOT/gs-grib-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/csw/pom.xml> to org.geoserver/gs-csw/2.11-SNAPSHOT/gs-csw-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/oracle/pom.xml> to org.geoserver.extension/gs-oracle/2.11-SNAPSHOT/gs-oracle-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/sqlserver/pom.xml> to org.geoserver.extension/gs-sqlserver/2.11-SNAPSHOT/gs-sqlserver-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/importer/bdb/pom.xml> to org.geoserver.importer/gs-importer-bdb/2.11-SNAPSHOT/gs-importer-bdb-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/demo/pom.xml> to org.geoserver.web/gs-web-demo/2.11-SNAPSHOT/gs-web-demo-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/monitor/core/pom.xml> to org.geoserver.extension/gs-monitor-core/2.11-SNAPSHOT/gs-monitor-core-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/ogr/ogr-core/pom.xml> to org.geoserver.extension/gs-ogr-core/2.11-SNAPSHOT/gs-ogr-core-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/importer/core/pom.xml> to org.geoserver.importer/gs-importer-core/2.11-SNAPSHOT/gs-importer-core-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/gwc/pom.xml> to org.geoserver/gs-gwc/2.11-SNAPSHOT/gs-gwc-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/ogr/ogr-wfs/pom.xml> to org.geoserver.extension/gs-ogr-wfs/2.11-SNAPSHOT/gs-ogr-wfs-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/pom.xml> to org.geoserver/gs-security/2.11-SNAPSHOT/gs-security-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/target/gs-security-2.11-SNAPSHOT-tests.jar> to org.geoserver/gs-security/2.11-SNAPSHOT/gs-security-2.11-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/h2/pom.xml> to org.geoserver.extension/gs-h2/2.11-SNAPSHOT/gs-h2-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/wcs/pom.xml> to org.geoserver.web/gs-web-wcs/2.11-SNAPSHOT/gs-web-wcs-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/jp2k/pom.xml> to org.geoserver.extension/gs-jp2k/2.11-SNAPSHOT/gs-jp2k-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/importer/pom.xml> to org.geoserver/gs-importer/2.11-SNAPSHOT/gs-importer-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/app/pom.xml> to org.geoserver.web/gs-web-app/2.11-SNAPSHOT/gs-web-app-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/control-flow/pom.xml> to org.geoserver.extension/gs-control-flow/2.11-SNAPSHOT/gs-control-flow-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/imagemosaic-jdbc/pom.xml> to org.geoserver.extension/gs-imagemosaic-jdbc/2.11-SNAPSHOT/gs-imagemosaic-jdbc-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/kml/pom.xml> to org.geoserver/gs-kml/2.11-SNAPSHOT/gs-kml-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/wcs2_0-eo/web/pom.xml> to org.geoserver.extension/gs-web-wcs2_0-eo/2.11-SNAPSHOT/gs-web-wcs2_0-eo-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/gwc/pom.xml> to org.geoserver.web/gs-web-gwc/2.11-SNAPSHOT/gs-web-gwc-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/core/pom.xml> to org.geoserver.web/gs-web-sec-core/2.11-SNAPSHOT/gs-web-sec-core-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/security/web/web-cas/pom.xml> to org.geoserver.security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/jdbc/pom.xml> to org.geoserver.web/gs-web-sec-jdbc/2.11-SNAPSHOT/gs-web-sec-jdbc-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/printing/pom.xml> to org.geoserver.extension/gs-printing/2.11-SNAPSHOT/gs-printing-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/importer/web/pom.xml> to org.geoserver.importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/importer/rest/pom.xml> to org.geoserver.importer/gs-importer-rest/2.11-SNAPSHOT/gs-importer-rest-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/dxf/wps/pom.xml> to org.geoserver.extension/gs-dxf-wps/2.11-SNAPSHOT/gs-dxf-wps-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/querylayer/pom.xml> to org.geoserver.extension/gs-querylayer/2.11-SNAPSHOT/gs-querylayer-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/csw/api/pom.xml> to org.geoserver.csw/gs-csw-api/2.11-SNAPSHOT/gs-csw-api-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/wps/web-wps/pom.xml> to org.geoserver.extension/gs-web-wps/2.11-SNAPSHOT/gs-web-wps-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/app-schema/pom.xml> to org.geoserver.extension/gs-app-schema/2.11-SNAPSHOT/gs-app-schema-2.11-SNAPSHOT.pom
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/1136/changes>
Changes:
[Daniele Romagnoli] [GEOS-7837]: Add sample for WPS Download output as a reference + some
[...truncated 41606 lines...]
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:351)
... 71 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:359)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:108)
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:648)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:140)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1143)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:1046)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:510)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:482)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:306)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:302)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:296)
... 83 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:553)
... 97 more
Caused by: java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
at org.geotools.util.SoftValueHashMap.entrySet(SoftValueHashMap.java:370)
at org.geoserver.catalog.ResourcePool$CatalogResourceCache.clear(ResourcePool.java:2028)
at org.geoserver.catalog.ResourcePool.dispose(ResourcePool.java:1982)
at org.geoserver.catalog.impl.CatalogImpl.sync(CatalogImpl.java:1745)
at org.geoserver.config.GeoServerLoader.readCatalog(GeoServerLoader.java:240)
at org.geoserver.config.DefaultGeoServerLoader.loadCatalog(DefaultGeoServerLoader.java:36)
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:109)
at org.geoserver.config.GeoServerLoaderProxy.postProcessBeforeInitialization(GeoServerLoaderProxy.java:59)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:408)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1570)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:545)
... 103 more
Running org.geoserver.kml.icons.IconPropertyInjectorTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 1, Time elapsed: 0 sec
Running org.geoserver.kml.icons.IconRendererTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.37 sec
Running org.geoserver.kml.icons.IconServiceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.135 sec
Results :
Tests in error:
testGeometryRegionator(org.geoserver.kml.GeoSearchKMLTest): Error creating bean with name 'wmsServiceTarget' defined in URL [jar:<http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wms/target/gs-wms-2.11-SNAPSHOT.jar!/applicationContext.xml\]>: Cannot resolve reference to bean 'wms' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'wms' defined in URL [jar:<http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wms/target/gs-wms-2.11-SNAPSHOT.jar!/applicationContext.xml\]>: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testBogusRegionator(org.geoserver.kml.GeoSearchKMLTest): Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testSelfLinks(org.geoserver.kml.GeoSearchKMLTest): Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testDuplicateAttribute(org.geoserver.kml.GeoSearchKMLTest): Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testRandomRegionator(org.geoserver.kml.GeoSearchKMLTest): Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testDataRegionator(org.geoserver.kml.GeoSearchKMLTest): Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testBigGeometries(org.geoserver.kml.GeoSearchKMLTest): Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testStrategyChangesStuff(org.geoserver.kml.GeoSearchKMLTest): Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
org.geoserver.kml.GeoSearchKMLTest: Error creating bean with name 'wfsXsd-1.1' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'gml3SchemaBuilder' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'gml3SchemaBuilder' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testKmlTitleFormatOption(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'wmsServiceTarget' defined in URL [jar:<http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wms/target/gs-wms-2.11-SNAPSHOT.jar!/applicationContext.xml\]>: Cannot resolve reference to bean 'wms' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'wms' defined in URL [jar:<http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wms/target/gs-wms-2.11-SNAPSHOT.jar!/applicationContext.xml\]>: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testHeightTemplatePoint(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testCoordinateShift(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testKmlRefreshFormatOption(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testDynamicSymbolizer(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testProxyBaseURL(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testWMSTimeRequest(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testHeightTemplate(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testLabelFromTextSymbolizer(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testFilteredData(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testForceRasterKml(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testForceRasterKmz(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testRasterTransformerSLD(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testKmzEmbededPointImageSize(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testKmlVisibleFormatOption(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testNoBBOXInHREF(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testExternalGraphicBackround(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testWmsRepeatedLayerWithNonStandardStyleAndCqlFiler(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testExternalImageSize(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testSuperOverlayReflection(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testExternalGraphicSubdir(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testExtendedData(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testBBOXInHREF(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testKmlFormatOptionsAsKVP(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testLegend(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testDownloadMultiLayer(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testRasterPlacemarkTrue(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testWMSElevationRequest(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testLookatOptions(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testHeightTemplateNoExtrude(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testRasterPlacemarkFalse(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testStyleConverter(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testRelativeDynamicSymbolizer(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testLookatOptionsWithRefreshMode(org.geoserver.kml.KMLReflectorTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
org.geoserver.kml.KMLReflectorTest: Error creating bean with name 'wfsXsd-1.1' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'gml3SchemaBuilder' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'gml3SchemaBuilder' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testKmlTitleFormatOption(org.geoserver.kml.KMLSuperOverlayTest): org/geotools/resources/NIOUtilities
testWorldBoundsSuperOverlay(org.geoserver.kml.KMLSuperOverlayTest)
testGWCIntegrationFailing(org.geoserver.kml.KMLSuperOverlayTest)
testSuperOverlayLinkContents(org.geoserver.kml.KMLSuperOverlayTest)
testGWCIntegration(org.geoserver.kml.KMLSuperOverlayTest)
testCrossingSuperoverlay(org.geoserver.kml.KMLSuperOverlayTest)
testSubtileSuperOverlay(org.geoserver.kml.KMLSuperOverlayTest)
testReprojectedVector(org.geoserver.kml.KMLTest): org/geotools/resources/ClassChanger
testProjectedGroundOverlayWithPlacemarks(org.geoserver.kml.KMLTest)
testKmltitleFormatOption(org.geoserver.kml.KMLTest)
testNoAttributes(org.geoserver.kml.KMLTest)
testBasicVector(org.geoserver.kml.KMLTest)
testEncodeTime(org.geoserver.kml.KMLTest)
testHeightTemplate(org.geoserver.kml.KMLTest)
testContentDisposition(org.geoserver.kml.KMLTest)
testRelativeLinks(org.geoserver.kml.KMLTest)
testTimeTemplate(org.geoserver.kml.KMLTest)
testRasterLayer(org.geoserver.kml.KMLTest)
testKMZMixed(org.geoserver.kml.KMLTest)
testOutputModeVector(org.geoserver.kml.KMLTest)
testVectorScaleRange(org.geoserver.kml.KMLTest)
testVectorWithFeatureId(org.geoserver.kml.KMLTest)
testMissingGraphic(org.geoserver.kml.KMLTest)
testForceGroundOverlay(org.geoserver.kml.KMLTest)
testKmltitleFormatOptionWithMultipleLayers(org.geoserver.kml.KMLTest)
testVector(org.geoserver.kml.KMLTest)
testTimeInvervalTemplate(org.geoserver.kml.KMLTest)
testGetFeature(org.geoserver.kml.KMLWFSTest): Error creating bean with name 'wmsServiceTarget' defined in URL [jar:<http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wms/target/gs-wms-2.11-SNAPSHOT.jar!/applicationContext.xml\]>: Cannot resolve reference to bean 'wms' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'wms' defined in URL [jar:<http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wms/target/gs-wms-2.11-SNAPSHOT.jar!/applicationContext.xml\]>: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testForceWGS84(org.geoserver.kml.KMLWFSTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testGetCapabilities(org.geoserver.kml.KMLWFSTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testCloseIterators(org.geoserver.kml.KMLWFSTest): Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testGetFeatureKMLAlias(org.geoserver.kml.KMLWFSTest): Error creating bean with name 'wfsCiteComplianceHack' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
org.geoserver.kml.KMLWFSTest: Error creating bean with name 'wfsXsd-1.1' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'gml3SchemaBuilder' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'gml3SchemaBuilder' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testWorkspacedStyleEncodesNoProperties(org.geoserver.kml.icons.IconPropertiesTest): Error creating bean with name 'proxyfier' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testLocalFileRotate(org.geoserver.kml.icons.IconPropertiesTest): org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'proxyfier' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testFilters(org.geoserver.kml.icons.IconPropertiesTest): Error creating bean with name 'proxyfier' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testSimpleStyleEncodesNoProperties(org.geoserver.kml.icons.IconPropertiesTest): Error creating bean with name 'proxyfier' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testDynamicURL(org.geoserver.kml.icons.IconPropertiesTest): Error creating bean with name 'proxyfier' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testDynamicMark(org.geoserver.kml.icons.IconPropertiesTest): Error creating bean with name 'proxyfier' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testDynamicSize(org.geoserver.kml.icons.IconPropertiesTest): Error creating bean with name 'proxyfier' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testElseFilter(org.geoserver.kml.icons.IconPropertiesTest): Error creating bean with name 'proxyfier' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testTwoLocalFilesRotate(org.geoserver.kml.icons.IconPropertiesTest): Error creating bean with name 'proxyfier' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testLocalFile(org.geoserver.kml.icons.IconPropertiesTest): org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'proxyfier' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testMultipleSymbolizers(org.geoserver.kml.icons.IconPropertiesTest): Error creating bean with name 'proxyfier' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testMultipleFeatureTypeStyle(org.geoserver.kml.icons.IconPropertiesTest): Error creating bean with name 'proxyfier' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testMarkRotate(org.geoserver.kml.icons.IconPropertiesTest): Error creating bean with name 'proxyfier' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testDynamicRotation(org.geoserver.kml.icons.IconPropertiesTest): Error creating bean with name 'proxyfier' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testTwoLocalFilesOneRotate(org.geoserver.kml.icons.IconPropertiesTest): Error creating bean with name 'proxyfier' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
testDynamicOpacity(org.geoserver.kml.icons.IconPropertiesTest): Error creating bean with name 'proxyfier' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'geoServer' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'localWorkspaceCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'advertisedCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/tomcat/.m2/repository/org/geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Entries
Tests run: 116, Failures: 0, Errors: 93, Skipped: 1
[JENKINS] Recording test results
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] Reactor Summary:
[INFO]
[INFO] Web Map Service Module ............................. SUCCESS [01:55 min]
[INFO] KML support for GeoServer .......................... FAILURE [ 28.262 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] REST Configuration Service Module .................. SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 02:31 min
[INFO] Finished at: 2016-11-15T15:18:37+01:00
[INFO] Final Memory: 125M/593M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-kml: There are test failures.
[ERROR]
[ERROR] Please refer to <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/kml/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-kml
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/netcdf-out/pom.xml> to org.geoserver.extension/gs-netcdf-out/2.11-SNAPSHOT/gs-netcdf-out-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/app-schema/app-schema-test/pom.xml> to org.geoserver.extension/gs-app-schema-test/2.11-SNAPSHOT/gs-app-schema-test-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/security/pom.xml> to org.geoserver.extension/gs-security/2.11-SNAPSHOT/gs-security-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/security/web/pom.xml> to org.geoserver.extension/gs-web-sec/2.11-SNAPSHOT/gs-web-sec-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/monitor/hibernate/pom.xml> to org.geoserver.extension/gs-monitor-hibernate/2.11-SNAPSHOT/gs-monitor-hibernate-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/libjpeg-turbo/pom.xml> to org.geoserver.extension/gs-libjpeg-turbo/2.11-SNAPSHOT/gs-libjpeg-turbo-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/ldap/pom.xml> to org.geoserver.web/gs-web-sec-ldap/2.11-SNAPSHOT/gs-web-sec-ldap-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/wms/pom.xml> to org.geoserver.web/gs-web-wms/2.11-SNAPSHOT/gs-web-wms-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/inspire/pom.xml> to org.geoserver.extension/gs-inspire/2.11-SNAPSHOT/gs-inspire-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/netcdf/pom.xml> to org.geoserver.extension/gs-netcdf/2.11-SNAPSHOT/gs-netcdf-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/security/cas/pom.xml> to org.geoserver.security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/rest/pom.xml> to org.geoserver.web/gs-web-rest/2.11-SNAPSHOT/gs-web-rest-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/restconfig/pom.xml> to org.geoserver/gs-restconfig/2.11-SNAPSHOT/gs-restconfig-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/vectortiles/pom.xml> to org.geoserver.extension/gs-vectortiles/2.11-SNAPSHOT/gs-vectortiles-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wms/pom.xml> to org.geoserver/gs-wms/2.11-SNAPSHOT/gs-wms-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wms/target/gs-wms-2.11-SNAPSHOT.jar> to org.geoserver/gs-wms/2.11-SNAPSHOT/gs-wms-2.11-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wms/target/gs-wms-2.11-SNAPSHOT-tests.jar> to org.geoserver/gs-wms/2.11-SNAPSHOT/gs-wms-2.11-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wms/target/gs-wms-2.11-SNAPSHOT-sources.jar> to org.geoserver/gs-wms/2.11-SNAPSHOT/gs-wms-2.11-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wms/target/gs-wms-2.11-SNAPSHOT-test-sources.jar> to org.geoserver/gs-wms/2.11-SNAPSHOT/gs-wms-2.11-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/imagemap/pom.xml> to org.geoserver.extension/gs-imagemap/2.11-SNAPSHOT/gs-imagemap-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/xslt/pom.xml> to org.geoserver/gs-xslt/2.11-SNAPSHOT/gs-xslt-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/importer/bdb/pom.xml> to org.geoserver.importer/gs-importer-bdb/2.11-SNAPSHOT/gs-importer-bdb-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/demo/pom.xml> to org.geoserver.web/gs-web-demo/2.11-SNAPSHOT/gs-web-demo-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/monitor/core/pom.xml> to org.geoserver.extension/gs-monitor-core/2.11-SNAPSHOT/gs-monitor-core-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/importer/core/pom.xml> to org.geoserver.importer/gs-importer-core/2.11-SNAPSHOT/gs-importer-core-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/gwc/pom.xml> to org.geoserver/gs-gwc/2.11-SNAPSHOT/gs-gwc-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/wcs/pom.xml> to org.geoserver.web/gs-web-wcs/2.11-SNAPSHOT/gs-web-wcs-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/importer/pom.xml> to org.geoserver/gs-importer/2.11-SNAPSHOT/gs-importer-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/app/pom.xml> to org.geoserver.web/gs-web-app/2.11-SNAPSHOT/gs-web-app-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/control-flow/pom.xml> to org.geoserver.extension/gs-control-flow/2.11-SNAPSHOT/gs-control-flow-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/kml/pom.xml> to org.geoserver/gs-kml/2.11-SNAPSHOT/gs-kml-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/gwc/pom.xml> to org.geoserver.web/gs-web-gwc/2.11-SNAPSHOT/gs-web-gwc-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/core/pom.xml> to org.geoserver.web/gs-web-sec-core/2.11-SNAPSHOT/gs-web-sec-core-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/security/web/web-cas/pom.xml> to org.geoserver.security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/jdbc/pom.xml> to org.geoserver.web/gs-web-sec-jdbc/2.11-SNAPSHOT/gs-web-sec-jdbc-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/importer/web/pom.xml> to org.geoserver.importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/importer/rest/pom.xml> to org.geoserver.importer/gs-importer-rest/2.11-SNAPSHOT/gs-importer-rest-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/wps/web-wps/pom.xml> to org.geoserver.extension/gs-web-wps/2.11-SNAPSHOT/gs-web-wps-2.11-SNAPSHOT.pom
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/1137/>
[...truncated 79929 lines...]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 4.501 s]
[INFO] Core Platform Module ............................... SUCCESS [ 14.422 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 9.855 s]
[INFO] Main Module ........................................ SUCCESS [01:42 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 1.907 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 16.863 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 18.866 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.522 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 15.442 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 17.881 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 37.865 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:03 min]
[INFO] Web Map Service Module ............................. FAILURE [02:16 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] REST Support Module ................................ SKIPPED
[INFO] GeoServer Web Modules .............................. SKIPPED
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Community Space .................................... SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] Total time: 07:38 min
[INFO] Finished at: 2016-11-15T16:19:23+01:00
[INFO] Final Memory: 146M/834M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wms/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
Waiting for Jenkins to finish collecting data
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/csw/web-csw/pom.xml> to org.geoserver.csw/gs-web-csw/2.11-SNAPSHOT/gs-web-csw-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/arcsde/pom.xml> to org.geoserver.extension/gs-arcsde/2.11-SNAPSHOT/gs-arcsde-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/teradata/pom.xml> to org.geoserver.extension/gs-teradata/2.11-SNAPSHOT/gs-teradata-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/wfs/pom.xml> to org.geoserver.web/gs-web-wfs/2.11-SNAPSHOT/gs-web-wfs-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/ogr/ogr-wps/pom.xml> to org.geoserver.extension/gs-ogr-wps/2.11-SNAPSHOT/gs-ogr-wps-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/gdal/pom.xml> to org.geoserver.extension/gs-gdal/2.11-SNAPSHOT/gs-gdal-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/dxf/core/pom.xml> to org.geoserver.extension/gs-dxf-core/2.11-SNAPSHOT/gs-dxf-core-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/ogr/pom.xml> to org.geoserver.extension/gs-ogr/2.11-SNAPSHOT/gs-ogr-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs/pom.xml> to org.geoserver/gs-wcs/2.11-SNAPSHOT/gs-wcs-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs/target/gs-wcs-2.11-SNAPSHOT.jar> to org.geoserver/gs-wcs/2.11-SNAPSHOT/gs-wcs-2.11-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs/target/gs-wcs-2.11-SNAPSHOT-tests.jar> to org.geoserver/gs-wcs/2.11-SNAPSHOT/gs-wcs-2.11-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs/target/gs-wcs-2.11-SNAPSHOT-sources.jar> to org.geoserver/gs-wcs/2.11-SNAPSHOT/gs-wcs-2.11-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/db2/pom.xml> to org.geoserver.extension/gs-db2/2.11-SNAPSHOT/gs-db2-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_1/pom.xml> to org.geoserver/gs-wcs1_1/2.11-SNAPSHOT/gs-wcs1_1-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_1/target/gs-wcs1_1-2.11-SNAPSHOT.jar> to org.geoserver/gs-wcs1_1/2.11-SNAPSHOT/gs-wcs1_1-2.11-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_1/target/gs-wcs1_1-2.11-SNAPSHOT-tests.jar> to org.geoserver/gs-wcs1_1/2.11-SNAPSHOT/gs-wcs1_1-2.11-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_1/target/gs-wcs1_1-2.11-SNAPSHOT-sources.jar> to org.geoserver/gs-wcs1_1/2.11-SNAPSHOT/gs-wcs1_1-2.11-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_1/target/gs-wcs1_1-2.11-SNAPSHOT-test-sources.jar> to org.geoserver/gs-wcs1_1/2.11-SNAPSHOT/gs-wcs1_1-2.11-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/charts/pom.xml> to org.geoserver.extension/gs-charts/2.11-SNAPSHOT/gs-charts-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_0/pom.xml> to org.geoserver/gs-wcs1_0/2.11-SNAPSHOT/gs-wcs1_0-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_0/target/gs-wcs1_0-2.11-SNAPSHOT.jar> to org.geoserver/gs-wcs1_0/2.11-SNAPSHOT/gs-wcs1_0-2.11-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_0/target/gs-wcs1_0-2.11-SNAPSHOT-tests.jar> to org.geoserver/gs-wcs1_0/2.11-SNAPSHOT/gs-wcs1_0-2.11-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_0/target/gs-wcs1_0-2.11-SNAPSHOT-sources.jar> to org.geoserver/gs-wcs1_0/2.11-SNAPSHOT/gs-wcs1_0-2.11-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_0/target/gs-wcs1_0-2.11-SNAPSHOT-test-sources.jar> to org.geoserver/gs-wcs1_0/2.11-SNAPSHOT/gs-wcs1_0-2.11-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/core/pom.xml> to org.geoserver.web/gs-web-core/2.11-SNAPSHOT/gs-web-core-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs2_0/pom.xml> to org.geoserver/gs-wcs2_0/2.11-SNAPSHOT/gs-wcs2_0-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs2_0/target/gs-wcs2_0-2.11-SNAPSHOT.jar> to org.geoserver/gs-wcs2_0/2.11-SNAPSHOT/gs-wcs2_0-2.11-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs2_0/target/gs-wcs2_0-2.11-SNAPSHOT-tests.jar> to org.geoserver/gs-wcs2_0/2.11-SNAPSHOT/gs-wcs2_0-2.11-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs2_0/target/gs-wcs2_0-2.11-SNAPSHOT-sources.jar> to org.geoserver/gs-wcs2_0/2.11-SNAPSHOT/gs-wcs2_0-2.11-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs2_0/target/gs-wcs2_0-2.11-SNAPSHOT-test-sources.jar> to org.geoserver/gs-wcs2_0/2.11-SNAPSHOT/gs-wcs2_0-2.11-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/jdbc/pom.xml> to org.geoserver.security/gs-sec-jdbc/2.11-SNAPSHOT/gs-sec-jdbc-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/jdbc/target/gs-sec-jdbc-2.11-SNAPSHOT.jar> to org.geoserver.security/gs-sec-jdbc/2.11-SNAPSHOT/gs-sec-jdbc-2.11-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/jdbc/target/gs-sec-jdbc-2.11-SNAPSHOT-tests.jar> to org.geoserver.security/gs-sec-jdbc/2.11-SNAPSHOT/gs-sec-jdbc-2.11-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/jdbc/target/gs-sec-jdbc-2.11-SNAPSHOT-sources.jar> to org.geoserver.security/gs-sec-jdbc/2.11-SNAPSHOT/gs-sec-jdbc-2.11-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/jdbc/target/gs-sec-jdbc-2.11-SNAPSHOT-test-sources.jar> to org.geoserver.security/gs-sec-jdbc/2.11-SNAPSHOT/gs-sec-jdbc-2.11-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/wcs2_0-eo/core/pom.xml> to org.geoserver.extension/gs-wcs2_0-eo-core/2.11-SNAPSHOT/gs-wcs2_0-eo-core-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/pom.xml> to org.geoserver/web/2.11-SNAPSHOT/web-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/pom.xml> to org.geoserver/extension/2.11-SNAPSHOT/extension-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/wps/pom.xml> to org.geoserver.extension/gs-wps/2.11-SNAPSHOT/gs-wps-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/dxf/pom.xml> to org.geoserver.extension/gs-dxf/2.11-SNAPSHOT/gs-dxf-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/csw/simple-store/pom.xml> to org.geoserver.csw/gs-csw-simple-store/2.11-SNAPSHOT/gs-csw-simple-store-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/app-schema/sample-data-access-test/pom.xml> to org.geoserver.extension/gs-sample-data-access-test/2.11-SNAPSHOT/gs-sample-data-access-test-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/feature-pregeneralized/pom.xml> to org.geoserver.extension/gs-feature-pregeneralized/2.11-SNAPSHOT/gs-feature-pregeneralized-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/csw/core/pom.xml> to org.geoserver.csw/gs-csw-core/2.11-SNAPSHOT/gs-csw-core-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/ows/pom.xml> to org.geoserver/gs-ows/2.11-SNAPSHOT/gs-ows-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/ows/target/gs-ows-2.11-SNAPSHOT.jar> to org.geoserver/gs-ows/2.11-SNAPSHOT/gs-ows-2.11-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/ows/target/gs-ows-2.11-SNAPSHOT-tests.jar> to org.geoserver/gs-ows/2.11-SNAPSHOT/gs-ows-2.11-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/ows/target/gs-ows-2.11-SNAPSHOT-sources.jar> to org.geoserver/gs-ows/2.11-SNAPSHOT/gs-ows-2.11-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/ows/target/gs-ows-2.11-SNAPSHOT-test-sources.jar> to org.geoserver/gs-ows/2.11-SNAPSHOT/gs-ows-2.11-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/community/pom.xml> to org.geoserver/community/2.11-SNAPSHOT/community-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wfs/pom.xml> to org.geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wfs/target/gs-wfs-2.11-SNAPSHOT.jar> to org.geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wfs/target/gs-wfs-2.11-SNAPSHOT-tests.jar> to org.geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wfs/target/gs-wfs-2.11-SNAPSHOT-sources.jar> to org.geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wfs/target/gs-wfs-2.11-SNAPSHOT-test-sources.jar> to org.geoserver/gs-wfs/2.11-SNAPSHOT/gs-wfs-2.11-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/ldap/pom.xml> to org.geoserver.security/gs-sec-ldap/2.11-SNAPSHOT/gs-sec-ldap-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/ldap/target/gs-sec-ldap-2.11-SNAPSHOT.jar> to org.geoserver.security/gs-sec-ldap/2.11-SNAPSHOT/gs-sec-ldap-2.11-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/ldap/target/gs-sec-ldap-2.11-SNAPSHOT-tests.jar> to org.geoserver.security/gs-sec-ldap/2.11-SNAPSHOT/gs-sec-ldap-2.11-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/ldap/target/gs-sec-ldap-2.11-SNAPSHOT-sources.jar> to org.geoserver.security/gs-sec-ldap/2.11-SNAPSHOT/gs-sec-ldap-2.11-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/ldap/target/gs-sec-ldap-2.11-SNAPSHOT-test-sources.jar> to org.geoserver.security/gs-sec-ldap/2.11-SNAPSHOT/gs-sec-ldap-2.11-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml> to org.geoserver.extension/gs-wps-cluster-hazelcast/2.11-SNAPSHOT/gs-wps-cluster-hazelcast-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/excel/pom.xml> to org.geoserver.extension/gs-excel/2.11-SNAPSHOT/gs-excel-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/wps/wps-core/pom.xml> to org.geoserver.extension/gs-wps-core/2.11-SNAPSHOT/gs-wps-core-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/css/pom.xml> to org.geoserver.extension/gs-css/2.11-SNAPSHOT/gs-css-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/main/pom.xml> to org.geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/main/target/gs-main-2.11-SNAPSHOT.jar> to org.geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/main/target/gs-main-2.11-SNAPSHOT-tests.jar> to org.geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/main/target/gs-main-2.11-SNAPSHOT-sources.jar> to org.geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/main/target/gs-main-2.11-SNAPSHOT-test-sources.jar> to org.geoserver/gs-main/2.11-SNAPSHOT/gs-main-2.11-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/rest/pom.xml> to org.geoserver/gs-rest/2.11-SNAPSHOT/gs-rest-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/wcs2_0-eo/pom.xml> to org.geoserver.extension/gs-wcs2_0-eo/2.11-SNAPSHOT/gs-wcs2_0-eo-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/pom.xml> to org.geoserver/geoserver/2.11-SNAPSHOT/geoserver-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/target/geoserver-2.11-SNAPSHOT-tests.jar> to org.geoserver/geoserver/2.11-SNAPSHOT/geoserver-2.11-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/monitor/pom.xml> to org.geoserver.extension/gs-monitor/2.11-SNAPSHOT/gs-monitor-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/platform/pom.xml> to org.geoserver/gs-platform/2.11-SNAPSHOT/gs-platform-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/platform/target/gs-platform-2.11-SNAPSHOT.jar> to org.geoserver/gs-platform/2.11-SNAPSHOT/gs-platform-2.11-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/platform/target/gs-platform-2.11-SNAPSHOT-tests.jar> to org.geoserver/gs-platform/2.11-SNAPSHOT/gs-platform-2.11-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/platform/target/gs-platform-2.11-SNAPSHOT-sources.jar> to org.geoserver/gs-platform/2.11-SNAPSHOT/gs-platform-2.11-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/platform/target/gs-platform-2.11-SNAPSHOT-test-sources.jar> to org.geoserver/gs-platform/2.11-SNAPSHOT/gs-platform-2.11-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/pom.xml> to org.geoserver.web/gs-web-sec/2.11-SNAPSHOT/gs-web-sec-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/mysql/pom.xml> to org.geoserver.extension/gs-mysql/2.11-SNAPSHOT/gs-mysql-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/grib/pom.xml> to org.geoserver.extension/gs-grib/2.11-SNAPSHOT/gs-grib-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/csw/pom.xml> to org.geoserver/gs-csw/2.11-SNAPSHOT/gs-csw-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/oracle/pom.xml> to org.geoserver.extension/gs-oracle/2.11-SNAPSHOT/gs-oracle-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/sqlserver/pom.xml> to org.geoserver.extension/gs-sqlserver/2.11-SNAPSHOT/gs-sqlserver-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/ogr/ogr-core/pom.xml> to org.geoserver.extension/gs-ogr-core/2.11-SNAPSHOT/gs-ogr-core-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/ogr/ogr-wfs/pom.xml> to org.geoserver.extension/gs-ogr-wfs/2.11-SNAPSHOT/gs-ogr-wfs-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/pom.xml> to org.geoserver/gs-security/2.11-SNAPSHOT/gs-security-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/target/gs-security-2.11-SNAPSHOT-tests.jar> to org.geoserver/gs-security/2.11-SNAPSHOT/gs-security-2.11-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/h2/pom.xml> to org.geoserver.extension/gs-h2/2.11-SNAPSHOT/gs-h2-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/jp2k/pom.xml> to org.geoserver.extension/gs-jp2k/2.11-SNAPSHOT/gs-jp2k-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/imagemosaic-jdbc/pom.xml> to org.geoserver.extension/gs-imagemosaic-jdbc/2.11-SNAPSHOT/gs-imagemosaic-jdbc-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/wcs2_0-eo/web/pom.xml> to org.geoserver.extension/gs-web-wcs2_0-eo/2.11-SNAPSHOT/gs-web-wcs2_0-eo-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/printing/pom.xml> to org.geoserver.extension/gs-printing/2.11-SNAPSHOT/gs-printing-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/dxf/wps/pom.xml> to org.geoserver.extension/gs-dxf-wps/2.11-SNAPSHOT/gs-dxf-wps-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/querylayer/pom.xml> to org.geoserver.extension/gs-querylayer/2.11-SNAPSHOT/gs-querylayer-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/csw/api/pom.xml> to org.geoserver.csw/gs-csw-api/2.11-SNAPSHOT/gs-csw-api-2.11-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/app-schema/pom.xml> to org.geoserver.extension/gs-app-schema/2.11-SNAPSHOT/gs-app-schema-2.11-SNAPSHOT.pom
channel stopped
