[Geoserver-devel] Build failed in Jenkins: GeoServer-Master-OpenJDK8 #675
See <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/675/changes&gt;
Changes:
[jody.garnett] Squashed commit of the following:
[...truncated 259 lines...]
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
Started calculate disk usage of build
[INFO] Reactor Build Order:
[INFO]
[INFO] Community Space
[INFO] Importer Core Module
[INFO] Importer REST Api Module
[INFO] Importer Berkley DB Persistence Module
[INFO] Importer Web UI Module
[INFO]
[INFO] Building Community Space 2.10-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ community ---
[INFO] Deleting <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/community/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ community ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ community ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ community ---
[INFO] Building jar: <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/community/target/community-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) > generate-sources @ community >>>
[INFO]
[WARNING] Failed to getClass for org.apache.maven.plugin.source.SourceJarMojo
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) < generate-sources @ community <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ community ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) > generate-sources @ community >>>
[INFO]
[WARNING] Failed to getClass for org.apache.maven.plugin.source.TestSourceJarMojo
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) < generate-sources @ community <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ community ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ community ---
[INFO] Installing <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/community/pom.xml&gt; to /home/tomcat/.m2/repository/org/geoserver/community/2.10-SNAPSHOT/community-2.10-SNAPSHOT.pom
[INFO] Installing <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/community/target/community-2.10-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/2.10-SNAPSHOT/community-2.10-SNAPSHOT-tests.jar
[INFO]
[INFO] Building Importer Core Module 2.10-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-importer-core ---
[INFO] Deleting <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/importer/core/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-importer-core ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-importer-core ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-importer-core ---
[INFO] Copying 0 resource
[INFO] Copying 2 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-importer-core ---
[INFO] Compiling 73 source files to <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/importer/core/target/classes&gt;
[ERROR] COMPILATION ERROR :
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/FileData.java&gt;:\[32,29\] error: cannot find symbol
[ERROR] class Resources
<http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/SpatialFile.java&gt;:\[85,32\] error: cannot find symbol
<http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/SpatialFile.java&gt;:\[93,34\] error: cannot find symbol
[INFO] 3 errors
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 2.522 s]
[INFO] Importer Core Module ............................... FAILURE [ 4.655 s]
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 16.913 s
[INFO] Finished at: 2016-05-20T02:53:33+02:00
[INFO] Final Memory: 66M/275M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-importer-core: Compilation failure: Compilation failure:
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/SpatialFile.java&gt;:\[85,32\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/SpatialFile.java&gt;:\[93,34\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-importer-core
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/community/pom.xml&gt; to org.geoserver/community/2.10-SNAPSHOT/community-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/community/target/community-2.10-SNAPSHOT-tests.jar&gt; to org.geoserver/community/2.10-SNAPSHOT/community-2.10-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/importer/bdb/pom.xml&gt; to org.geoserver.importer/gs-importer-bdb/2.10-SNAPSHOT/gs-importer-bdb-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/importer/core/pom.xml&gt; to org.geoserver.importer/gs-importer-core/2.10-SNAPSHOT/gs-importer-core-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/importer/web/pom.xml&gt; to org.geoserver.importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/importer/rest/pom.xml&gt; to org.geoserver.importer/gs-importer-rest/2.10-SNAPSHOT/gs-importer-rest-2.10-SNAPSHOT.pom
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/676/&gt;
