See <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/697/changes>
Changes:
[niels] LDAP: UserGroupService + refactoring to share code with RoleService
[...truncated 261 lines...]
Finished Calculation of disk usage of workspace in 0 seconds
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
[INFO] Reactor Build Order:
[INFO]
[INFO] Security UI LDAP Module
[INFO] GeoServer Web Application
[INFO]
[INFO] Building Security UI LDAP Module 2.10-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec-ldap ---
[INFO] Deleting <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/ldap/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-ldap ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec-ldap ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-sec-ldap ---
[INFO] skip non existing resourceDirectory <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/ldap/src/main/resources>
[INFO] Copying 8 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-sec-ldap ---
[INFO] Compiling 6 source files to <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/ldap/target/classes>
[ERROR] COMPILATION ERROR :
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanel.java>:\[14,34\] error: cannot find symbol
[ERROR] package org.geoserver.security.ldap
<http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanel.java>:\[22,69\] error: cannot find symbol
[ERROR] class LDAPUserGroupServiceConfig
<http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanel.java>:\[46,55\] error: cannot find symbol
[ERROR] class LDAPUserGroupServicePanel
<http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanelInfo.java>:\[7,34\] error: cannot find symbol
<http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanelInfo.java>:\[8,34\] error: cannot find symbol
<http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanelInfo.java>:\[17,35\] error: cannot find symbol
<http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanelInfo.java>:\[23,24\] error: cannot find symbol
[ERROR] class LDAPUserGroupServicePanelInfo
<http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanelInfo.java>:\[24,30\] error: cannot find symbol
[INFO] 8 errors
[INFO] Reactor Summary:
[INFO]
[INFO] Security UI LDAP Module ............................ FAILURE [ 6.261 s]
[INFO] BUILD FAILURE
[INFO] Total time: 16.274 s
[INFO] Finished at: 2016-05-31T22:53:34+02:00
[INFO] Final Memory: 66M/265M
[WARNING] The requested profile "allExtensions" could not be activated because it does not exist.
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-web-sec-ldap: Compilation failure: Compilation failure:
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanel.java>:\[22,69\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanel.java>:\[46,55\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanelInfo.java>:\[7,34\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanelInfo.java>:\[8,34\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanelInfo.java>:\[17,35\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanelInfo.java>:\[23,24\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/ldap/src/main/java/org/geoserver/web/security/ldap/LDAPUserGroupServicePanelInfo.java>:\[24,30\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/ldap/pom.xml> to org.geoserver.web/gs-web-sec-ldap/2.10-SNAPSHOT/gs-web-sec-ldap-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/app/pom.xml> to org.geoserver.web/gs-web-app/2.10-SNAPSHOT/gs-web-app-2.10-SNAPSHOT.pom
channel stopped
