[Geoserver-devel] Build failed in Jenkins: GeoServer-Master-OpenJDK8 #772
See <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/772/&gt;
[...truncated 1681 lines...]
  at org.geotools.factory.FactoryCreator.getServiceProvider(FactoryCreator.java:145)
  at org.geotools.referencing.ReferencingFactoryFinder.getFactory(ReferencingFactoryFinder.java:197)
  at org.geotools.referencing.ReferencingFactoryFinder.getCRSFactory(ReferencingFactoryFinder.java:288)
  at org.geotools.data.PrjFileReader.<init>(PrjFileReader.java:94)
  at org.geotools.data.PrjFileReader.<init>(PrjFileReader.java:68)
  at org.geotools.gce.arcgrid.ArcGridReader.initCoordinateReferenceSystem(ArcGridReader.java:676)
  at org.geotools.gce.arcgrid.ArcGridReader.<init>(ArcGridReader.java:156)
  ... 42 more
Running org.vfny.geoserver.global.xml.WriterHelperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.vfny.geoserver.util.ResponseUtilsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.vfny.geoserver.util.SLDValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.069 sec
Results :
Tests in error:
  testForceCoverage(org.vfny.geoserver.ProjectionPolicyTest): org/geotools/referencing/operation/projection/MercatorPseudoProvider$Spherical
  testReproject(org.vfny.geoserver.ProjectionPolicyTest): org/geotools/geometry/jts/DefaultCoordinateSequenceTransformer
  testWithRename(org.vfny.geoserver.ProjectionPolicyTest): org/geotools/geometry/jts/DefaultCoordinateSequenceTransformer
  testOverride(org.vfny.geoserver.crs.OverrideCRSTest): org/geotools/referencing/factory/PropertyAuthorityFactory$Parser
  testFallbackOnEPSGDatabaseStd(org.vfny.geoserver.crs.OvverideTransformationsTest): No code "EPSG:3002" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testOverrideEPSGOperation(org.vfny.geoserver.crs.OvverideTransformationsTest): No code "EPSG:4269" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testNadCon(org.vfny.geoserver.crs.OvverideTransformationsTest): No code "EPSG:4138" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testCreateOperationFromCustomCodes(org.vfny.geoserver.crs.OvverideTransformationsTest): org/geotools/referencing/factory/PropertyAuthorityFactory$Parser
  testFindDataFileForAbsolutePath(org.vfny.geoserver.global.GeoserverDataDirectoryTest): org.geotools.data.DataSourceException: No factory of kind "CRSFactory" found.
Tests run: 718, Failures: 0, Errors: 9, Skipped: 2
[JENKINS] Recording test results
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.597 s]
[INFO] Core Platform Module ............................... SUCCESS [ 15.438 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 9.741 s]
[INFO] Main Module ........................................ FAILURE [02:32 min]
[INFO] GeoServer Security Modules ......................... SKIPPED
[INFO] GeoServer JDBC Security Module ..................... SKIPPED
[INFO] GeoServer LDAP Security Module ..................... SKIPPED
[INFO] Web Coverage Service Module ........................ SKIPPED
[INFO] Web Coverage Service 1.0 Module .................... SKIPPED
[INFO] Web Coverage Service 1.1 Module .................... SKIPPED
[INFO] Web Coverage Service 2.0 Module .................... SKIPPED
[INFO] Web Feature Service Module ......................... SKIPPED
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] REST Support Module ................................ SKIPPED
[INFO] REST Configuration Service Module .................. SKIPPED
[INFO] GeoServer Web Modules .............................. SKIPPED
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Community Space .................................... SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 03:15 min
[INFO] Finished at: 2016-07-08T17:19:13+02:00
[INFO] Final Memory: 103M/474M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-main: There are test failures.
[ERROR]
[ERROR] Please refer to <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/main/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/csw/web-csw/pom.xml&gt; to org.geoserver.csw/gs-web-csw/2.10-SNAPSHOT/gs-web-csw-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/netcdf-out/pom.xml&gt; to org.geoserver.extension/gs-netcdf-out/2.10-SNAPSHOT/gs-netcdf-out-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/arcsde/pom.xml&gt; to org.geoserver.extension/gs-arcsde/2.10-SNAPSHOT/gs-arcsde-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/app-schema/app-schema-test/pom.xml&gt; to org.geoserver.extension/gs-app-schema-test/2.10-SNAPSHOT/gs-app-schema-test-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/teradata/pom.xml&gt; to org.geoserver.extension/gs-teradata/2.10-SNAPSHOT/gs-teradata-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/wfs/pom.xml&gt; to org.geoserver.web/gs-web-wfs/2.10-SNAPSHOT/gs-web-wfs-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/ogr/ogr-wps/pom.xml&gt; to org.geoserver.extension/gs-ogr-wps/2.10-SNAPSHOT/gs-ogr-wps-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/gdal/pom.xml&gt; to org.geoserver.extension/gs-gdal/2.10-SNAPSHOT/gs-gdal-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/dxf/core/pom.xml&gt; to org.geoserver.extension/gs-dxf-core/2.10-SNAPSHOT/gs-dxf-core-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/security/pom.xml&gt; to org.geoserver.extension/gs-security/2.10-SNAPSHOT/gs-security-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/ogr/pom.xml&gt; to org.geoserver.extension/gs-ogr/2.10-SNAPSHOT/gs-ogr-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/security/web/pom.xml&gt; to org.geoserver.extension/gs-web-sec/2.10-SNAPSHOT/gs-web-sec-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs/pom.xml&gt; to org.geoserver/gs-wcs/2.10-SNAPSHOT/gs-wcs-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/db2/pom.xml&gt; to org.geoserver.extension/gs-db2/2.10-SNAPSHOT/gs-db2-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_1/pom.xml&gt; to org.geoserver/gs-wcs1_1/2.10-SNAPSHOT/gs-wcs1_1-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/charts/pom.xml&gt; to org.geoserver.extension/gs-charts/2.10-SNAPSHOT/gs-charts-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_0/pom.xml&gt; to org.geoserver/gs-wcs1_0/2.10-SNAPSHOT/gs-wcs1_0-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/core/pom.xml&gt; to org.geoserver.web/gs-web-core/2.10-SNAPSHOT/gs-web-core-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs2_0/pom.xml&gt; to org.geoserver/gs-wcs2_0/2.10-SNAPSHOT/gs-wcs2_0-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/monitor/hibernate/pom.xml&gt; to org.geoserver.extension/gs-monitor-hibernate/2.10-SNAPSHOT/gs-monitor-hibernate-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/jdbc/pom.xml&gt; to org.geoserver.security/gs-sec-jdbc/2.10-SNAPSHOT/gs-sec-jdbc-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/wcs2_0-eo/core/pom.xml&gt; to org.geoserver.extension/gs-wcs2_0-eo-core/2.10-SNAPSHOT/gs-wcs2_0-eo-core-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/pom.xml&gt; to org.geoserver/web/2.10-SNAPSHOT/web-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/libjpeg-turbo/pom.xml&gt; to org.geoserver.extension/gs-libjpeg-turbo/2.10-SNAPSHOT/gs-libjpeg-turbo-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/pom.xml&gt; to org.geoserver/extension/2.10-SNAPSHOT/extension-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/ldap/pom.xml&gt; to org.geoserver.web/gs-web-sec-ldap/2.10-SNAPSHOT/gs-web-sec-ldap-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/wps/pom.xml&gt; to org.geoserver.extension/gs-wps/2.10-SNAPSHOT/gs-wps-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/dxf/pom.xml&gt; to org.geoserver.extension/gs-dxf/2.10-SNAPSHOT/gs-dxf-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/csw/simple-store/pom.xml&gt; to org.geoserver.csw/gs-csw-simple-store/2.10-SNAPSHOT/gs-csw-simple-store-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/app-schema/sample-data-access-test/pom.xml&gt; to org.geoserver.extension/gs-sample-data-access-test/2.10-SNAPSHOT/gs-sample-data-access-test-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/feature-pregeneralized/pom.xml&gt; to org.geoserver.extension/gs-feature-pregeneralized/2.10-SNAPSHOT/gs-feature-pregeneralized-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/csw/core/pom.xml&gt; to org.geoserver.csw/gs-csw-core/2.10-SNAPSHOT/gs-csw-core-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/ows/pom.xml&gt; to org.geoserver/gs-ows/2.10-SNAPSHOT/gs-ows-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/ows/target/gs-ows-2.10-SNAPSHOT.jar&gt; to org.geoserver/gs-ows/2.10-SNAPSHOT/gs-ows-2.10-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/ows/target/gs-ows-2.10-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-ows/2.10-SNAPSHOT/gs-ows-2.10-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/ows/target/gs-ows-2.10-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-ows/2.10-SNAPSHOT/gs-ows-2.10-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/ows/target/gs-ows-2.10-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-ows/2.10-SNAPSHOT/gs-ows-2.10-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/community/pom.xml&gt; to org.geoserver/community/2.10-SNAPSHOT/community-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wfs/pom.xml&gt; to org.geoserver/gs-wfs/2.10-SNAPSHOT/gs-wfs-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/ldap/pom.xml&gt; to org.geoserver.security/gs-sec-ldap/2.10-SNAPSHOT/gs-sec-ldap-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml&gt; to org.geoserver.extension/gs-wps-cluster-hazelcast/2.10-SNAPSHOT/gs-wps-cluster-hazelcast-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/excel/pom.xml&gt; to org.geoserver.extension/gs-excel/2.10-SNAPSHOT/gs-excel-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/wms/pom.xml&gt; to org.geoserver.web/gs-web-wms/2.10-SNAPSHOT/gs-web-wms-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/inspire/pom.xml&gt; to org.geoserver.extension/gs-inspire/2.10-SNAPSHOT/gs-inspire-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/wps/wps-core/pom.xml&gt; to org.geoserver.extension/gs-wps-core/2.10-SNAPSHOT/gs-wps-core-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/css/pom.xml&gt; to org.geoserver.extension/gs-css/2.10-SNAPSHOT/gs-css-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/main/pom.xml&gt; to org.geoserver/gs-main/2.10-SNAPSHOT/gs-main-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/netcdf/pom.xml&gt; to org.geoserver.extension/gs-netcdf/2.10-SNAPSHOT/gs-netcdf-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/rest/pom.xml&gt; to org.geoserver/gs-rest/2.10-SNAPSHOT/gs-rest-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/security/cas/pom.xml&gt; to org.geoserver.security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/wcs2_0-eo/pom.xml&gt; to org.geoserver.extension/gs-wcs2_0-eo/2.10-SNAPSHOT/gs-wcs2_0-eo-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/pom.xml&gt; to org.geoserver/geoserver/2.10-SNAPSHOT/geoserver-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/target/geoserver-2.10-SNAPSHOT-tests.jar&gt; to org.geoserver/geoserver/2.10-SNAPSHOT/geoserver-2.10-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/rest/pom.xml&gt; to org.geoserver.web/gs-web-rest/2.10-SNAPSHOT/gs-web-rest-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/monitor/pom.xml&gt; to org.geoserver.extension/gs-monitor/2.10-SNAPSHOT/gs-monitor-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/restconfig/pom.xml&gt; to org.geoserver/gs-restconfig/2.10-SNAPSHOT/gs-restconfig-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/platform/pom.xml&gt; to org.geoserver/gs-platform/2.10-SNAPSHOT/gs-platform-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/platform/target/gs-platform-2.10-SNAPSHOT.jar&gt; to org.geoserver/gs-platform/2.10-SNAPSHOT/gs-platform-2.10-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/platform/target/gs-platform-2.10-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-platform/2.10-SNAPSHOT/gs-platform-2.10-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/platform/target/gs-platform-2.10-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-platform/2.10-SNAPSHOT/gs-platform-2.10-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/platform/target/gs-platform-2.10-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-platform/2.10-SNAPSHOT/gs-platform-2.10-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/pom.xml&gt; to org.geoserver.web/gs-web-sec/2.10-SNAPSHOT/gs-web-sec-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wms/pom.xml&gt; to org.geoserver/gs-wms/2.10-SNAPSHOT/gs-wms-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/imagemap/pom.xml&gt; to org.geoserver.extension/gs-imagemap/2.10-SNAPSHOT/gs-imagemap-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/xslt/pom.xml&gt; to org.geoserver/gs-xslt/2.10-SNAPSHOT/gs-xslt-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/mysql/pom.xml&gt; to org.geoserver.extension/gs-mysql/2.10-SNAPSHOT/gs-mysql-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/grib/pom.xml&gt; to org.geoserver.extension/gs-grib/2.10-SNAPSHOT/gs-grib-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/csw/pom.xml&gt; to org.geoserver/gs-csw/2.10-SNAPSHOT/gs-csw-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/oracle/pom.xml&gt; to org.geoserver.extension/gs-oracle/2.10-SNAPSHOT/gs-oracle-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/sqlserver/pom.xml&gt; to org.geoserver.extension/gs-sqlserver/2.10-SNAPSHOT/gs-sqlserver-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/importer/bdb/pom.xml&gt; to org.geoserver.importer/gs-importer-bdb/2.10-SNAPSHOT/gs-importer-bdb-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/demo/pom.xml&gt; to org.geoserver.web/gs-web-demo/2.10-SNAPSHOT/gs-web-demo-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/monitor/core/pom.xml&gt; to org.geoserver.extension/gs-monitor-core/2.10-SNAPSHOT/gs-monitor-core-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/ogr/ogr-core/pom.xml&gt; to org.geoserver.extension/gs-ogr-core/2.10-SNAPSHOT/gs-ogr-core-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/importer/core/pom.xml&gt; to org.geoserver.importer/gs-importer-core/2.10-SNAPSHOT/gs-importer-core-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/gwc/pom.xml&gt; to org.geoserver/gs-gwc/2.10-SNAPSHOT/gs-gwc-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/ogr/ogr-wfs/pom.xml&gt; to org.geoserver.extension/gs-ogr-wfs/2.10-SNAPSHOT/gs-ogr-wfs-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/pom.xml&gt; to org.geoserver/gs-security/2.10-SNAPSHOT/gs-security-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/h2/pom.xml&gt; to org.geoserver.extension/gs-h2/2.10-SNAPSHOT/gs-h2-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/wcs/pom.xml&gt; to org.geoserver.web/gs-web-wcs/2.10-SNAPSHOT/gs-web-wcs-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/jp2k/pom.xml&gt; to org.geoserver.extension/gs-jp2k/2.10-SNAPSHOT/gs-jp2k-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/importer/pom.xml&gt; to org.geoserver/gs-importer/2.10-SNAPSHOT/gs-importer-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/app/pom.xml&gt; to org.geoserver.web/gs-web-app/2.10-SNAPSHOT/gs-web-app-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/control-flow/pom.xml&gt; to org.geoserver.extension/gs-control-flow/2.10-SNAPSHOT/gs-control-flow-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/imagemosaic-jdbc/pom.xml&gt; to org.geoserver.extension/gs-imagemosaic-jdbc/2.10-SNAPSHOT/gs-imagemosaic-jdbc-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/kml/pom.xml&gt; to org.geoserver/gs-kml/2.10-SNAPSHOT/gs-kml-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/wcs2_0-eo/web/pom.xml&gt; to org.geoserver.extension/gs-web-wcs2_0-eo/2.10-SNAPSHOT/gs-web-wcs2_0-eo-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/gwc/pom.xml&gt; to org.geoserver.web/gs-web-gwc/2.10-SNAPSHOT/gs-web-gwc-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/core/pom.xml&gt; to org.geoserver.web/gs-web-sec-core/2.10-SNAPSHOT/gs-web-sec-core-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/security/web/web-cas/pom.xml&gt; to org.geoserver.security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/security/jdbc/pom.xml&gt; to org.geoserver.web/gs-web-sec-jdbc/2.10-SNAPSHOT/gs-web-sec-jdbc-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/printing/pom.xml&gt; to org.geoserver.extension/gs-printing/2.10-SNAPSHOT/gs-printing-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/importer/web/pom.xml&gt; to org.geoserver.importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/importer/rest/pom.xml&gt; to org.geoserver.importer/gs-importer-rest/2.10-SNAPSHOT/gs-importer-rest-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/dxf/wps/pom.xml&gt; to org.geoserver.extension/gs-dxf-wps/2.10-SNAPSHOT/gs-dxf-wps-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/querylayer/pom.xml&gt; to org.geoserver.extension/gs-querylayer/2.10-SNAPSHOT/gs-querylayer-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/csw/api/pom.xml&gt; to org.geoserver.csw/gs-csw-api/2.10-SNAPSHOT/gs-csw-api-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/wps/web-wps/pom.xml&gt; to org.geoserver.extension/gs-web-wps/2.10-SNAPSHOT/gs-web-wps-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/app-schema/pom.xml&gt; to org.geoserver.extension/gs-app-schema/2.10-SNAPSHOT/gs-app-schema-2.10-SNAPSHOT.pom
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/773/changes&gt;
Changes:
[nuno.oliveira] Add GWC SQLite integration community module
[nuno.oliveira] [GEOS-7592] Add WMTS web admin page
[nuno.oliveira] [GEOS-7593] Add ISNPIRE required metadata to WMTS get capabilities
[nuno.oliveira] Add GWC SQLite integration community module documentation
[...truncated 10874 lines...]
Running org.geoserver.web.wicket.KeywordsEditorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.484 sec
Running org.geoserver.web.wicket.SRSPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.142 sec
Running org.geoserver.web.wicket.SRSToCRSModelTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.web.wicket.WKTToCRSModelTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Running org.geoserver.web.wicket.browser.FileBreadcrumsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.094 sec
Running org.geoserver.web.wicket.browser.FileDataViewTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.862 sec
Running org.geoserver.web.wicket.browser.GeoServerFileChooserTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.862 sec
Running org.geoserver.web.wicket.property.PropertyEditorFormComponentTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.565 sec
Results :
Tests in error:
  testLoginFormAction(org.geoserver.web.GeoServerAboutPageTest): No get method defined for class: class org.apache.wicket.markup.html.TransparentWebMarkupContainer expression: build
Tests run: 182, Failures: 0, Errors: 1, Skipped: 0
[INFO]
[INFO] Main Module ........................................ SUCCESS [02:23 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.644 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 22.439 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 24.261 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.457 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 22.027 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 27.221 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 54.149 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:32 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:19 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 34.017 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:02 min]
[INFO] REST Support Module ................................ SUCCESS [ 14.492 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:10 min]
[INFO] Core UI Module ..................................... FAILURE [01:06 min]
[INFO] Total time: 13:16 min
[INFO] Finished at: 2016-07-08T19:06:36+02:00
[INFO] Final Memory: 78M/487M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-web-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/web/core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-core
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs/target/gs-wcs-2.10-SNAPSHOT.jar&gt; to org.geoserver/gs-wcs/2.10-SNAPSHOT/gs-wcs-2.10-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs/target/gs-wcs-2.10-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-wcs/2.10-SNAPSHOT/gs-wcs-2.10-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs/target/gs-wcs-2.10-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-wcs/2.10-SNAPSHOT/gs-wcs-2.10-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_1/target/gs-wcs1_1-2.10-SNAPSHOT.jar&gt; to org.geoserver/gs-wcs1_1/2.10-SNAPSHOT/gs-wcs1_1-2.10-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_1/target/gs-wcs1_1-2.10-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-wcs1_1/2.10-SNAPSHOT/gs-wcs1_1-2.10-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_1/target/gs-wcs1_1-2.10-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-wcs1_1/2.10-SNAPSHOT/gs-wcs1_1-2.10-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_1/target/gs-wcs1_1-2.10-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-wcs1_1/2.10-SNAPSHOT/gs-wcs1_1-2.10-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_0/target/gs-wcs1_0-2.10-SNAPSHOT.jar&gt; to org.geoserver/gs-wcs1_0/2.10-SNAPSHOT/gs-wcs1_0-2.10-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_0/target/gs-wcs1_0-2.10-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-wcs1_0/2.10-SNAPSHOT/gs-wcs1_0-2.10-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_0/target/gs-wcs1_0-2.10-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-wcs1_0/2.10-SNAPSHOT/gs-wcs1_0-2.10-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs1_0/target/gs-wcs1_0-2.10-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-wcs1_0/2.10-SNAPSHOT/gs-wcs1_0-2.10-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs2_0/target/gs-wcs2_0-2.10-SNAPSHOT.jar&gt; to org.geoserver/gs-wcs2_0/2.10-SNAPSHOT/gs-wcs2_0-2.10-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs2_0/target/gs-wcs2_0-2.10-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-wcs2_0/2.10-SNAPSHOT/gs-wcs2_0-2.10-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs2_0/target/gs-wcs2_0-2.10-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-wcs2_0/2.10-SNAPSHOT/gs-wcs2_0-2.10-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wcs2_0/target/gs-wcs2_0-2.10-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-wcs2_0/2.10-SNAPSHOT/gs-wcs2_0-2.10-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/jdbc/target/gs-sec-jdbc-2.10-SNAPSHOT.jar&gt; to org.geoserver.security/gs-sec-jdbc/2.10-SNAPSHOT/gs-sec-jdbc-2.10-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/jdbc/target/gs-sec-jdbc-2.10-SNAPSHOT-tests.jar&gt; to org.geoserver.security/gs-sec-jdbc/2.10-SNAPSHOT/gs-sec-jdbc-2.10-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/jdbc/target/gs-sec-jdbc-2.10-SNAPSHOT-sources.jar&gt; to org.geoserver.security/gs-sec-jdbc/2.10-SNAPSHOT/gs-sec-jdbc-2.10-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/jdbc/target/gs-sec-jdbc-2.10-SNAPSHOT-test-sources.jar&gt; to org.geoserver.security/gs-sec-jdbc/2.10-SNAPSHOT/gs-sec-jdbc-2.10-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wfs/target/gs-wfs-2.10-SNAPSHOT.jar&gt; to org.geoserver/gs-wfs/2.10-SNAPSHOT/gs-wfs-2.10-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wfs/target/gs-wfs-2.10-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-wfs/2.10-SNAPSHOT/gs-wfs-2.10-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wfs/target/gs-wfs-2.10-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-wfs/2.10-SNAPSHOT/gs-wfs-2.10-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wfs/target/gs-wfs-2.10-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-wfs/2.10-SNAPSHOT/gs-wfs-2.10-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/ldap/target/gs-sec-ldap-2.10-SNAPSHOT.jar&gt; to org.geoserver.security/gs-sec-ldap/2.10-SNAPSHOT/gs-sec-ldap-2.10-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/ldap/target/gs-sec-ldap-2.10-SNAPSHOT-tests.jar&gt; to org.geoserver.security/gs-sec-ldap/2.10-SNAPSHOT/gs-sec-ldap-2.10-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/ldap/target/gs-sec-ldap-2.10-SNAPSHOT-sources.jar&gt; to org.geoserver.security/gs-sec-ldap/2.10-SNAPSHOT/gs-sec-ldap-2.10-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/ldap/target/gs-sec-ldap-2.10-SNAPSHOT-test-sources.jar&gt; to org.geoserver.security/gs-sec-ldap/2.10-SNAPSHOT/gs-sec-ldap-2.10-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/main/target/gs-main-2.10-SNAPSHOT.jar&gt; to org.geoserver/gs-main/2.10-SNAPSHOT/gs-main-2.10-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/main/target/gs-main-2.10-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-main/2.10-SNAPSHOT/gs-main-2.10-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/main/target/gs-main-2.10-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-main/2.10-SNAPSHOT/gs-main-2.10-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/main/target/gs-main-2.10-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-main/2.10-SNAPSHOT/gs-main-2.10-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/rest/target/gs-rest-2.10-SNAPSHOT.jar&gt; to org.geoserver/gs-rest/2.10-SNAPSHOT/gs-rest-2.10-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/rest/target/gs-rest-2.10-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-rest/2.10-SNAPSHOT/gs-rest-2.10-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/rest/target/gs-rest-2.10-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-rest/2.10-SNAPSHOT/gs-rest-2.10-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/rest/target/gs-rest-2.10-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-rest/2.10-SNAPSHOT/gs-rest-2.10-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/restconfig/target/gs-restconfig-2.10-SNAPSHOT.jar&gt; to org.geoserver/gs-restconfig/2.10-SNAPSHOT/gs-restconfig-2.10-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/restconfig/target/gs-restconfig-2.10-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-restconfig/2.10-SNAPSHOT/gs-restconfig-2.10-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/restconfig/target/gs-restconfig-2.10-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-restconfig/2.10-SNAPSHOT/gs-restconfig-2.10-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/restconfig/target/gs-restconfig-2.10-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-restconfig/2.10-SNAPSHOT/gs-restconfig-2.10-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wms/target/gs-wms-2.10-SNAPSHOT.jar&gt; to org.geoserver/gs-wms/2.10-SNAPSHOT/gs-wms-2.10-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wms/target/gs-wms-2.10-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-wms/2.10-SNAPSHOT/gs-wms-2.10-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wms/target/gs-wms-2.10-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-wms/2.10-SNAPSHOT/gs-wms-2.10-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/wms/target/gs-wms-2.10-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-wms/2.10-SNAPSHOT/gs-wms-2.10-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/gwc/target/gs-gwc-2.10-SNAPSHOT.jar&gt; to org.geoserver/gs-gwc/2.10-SNAPSHOT/gs-gwc-2.10-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/gwc/target/gs-gwc-2.10-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-gwc/2.10-SNAPSHOT/gs-gwc-2.10-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/gwc/target/gs-gwc-2.10-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-gwc/2.10-SNAPSHOT/gs-gwc-2.10-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/gwc/target/gs-gwc-2.10-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-gwc/2.10-SNAPSHOT/gs-gwc-2.10-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/security/target/gs-security-2.10-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-security/2.10-SNAPSHOT/gs-security-2.10-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/kml/target/gs-kml-2.10-SNAPSHOT.jar&gt; to org.geoserver/gs-kml/2.10-SNAPSHOT/gs-kml-2.10-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/kml/target/gs-kml-2.10-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-kml/2.10-SNAPSHOT/gs-kml-2.10-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/kml/target/gs-kml-2.10-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-kml/2.10-SNAPSHOT/gs-kml-2.10-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/kml/target/gs-kml-2.10-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-kml/2.10-SNAPSHOT/gs-kml-2.10-SNAPSHOT-test-sources.jar
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/774/changes&gt;
Changes:
[Andrea Aime] Remove jpeg-png from the list of mime types used for wms 1.3 cite
[...truncated 415 lines...]
  at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:265)
  at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:222)
  at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:293)
  at org.apache.wicket.util.tester.BaseWicketTester.processRequest(BaseWicketTester.java:718)
  at org.apache.wicket.util.tester.BaseWicketTester.processRequest(BaseWicketTester.java:657)
  at org.apache.wicket.util.tester.BaseWicketTester.processRequest(BaseWicketTester.java:629)
  at org.apache.wicket.util.tester.BaseWicketTester.executeUrl(BaseWicketTester.java:2722)
  at org.geoserver.web.GeoServerAboutPageTest.testLoginFormAction(GeoServerAboutPageTest.java:19)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:498)
Running org.geoserver.web.GeoServerBasePageTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.148 sec
Running org.geoserver.web.GeoServerConsoleFlagTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.616 sec
Running org.geoserver.web.GeoServerHomePageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.014 sec
Running org.geoserver.web.GeoServerRedirectTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.071 sec
Running org.geoserver.web.GeoServerResourceStreamLocatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.web.GeoServerSecuredPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.422 sec
Running org.geoserver.web.admin.AdminPrivilegeTest
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.909 sec
Running org.geoserver.web.admin.ContactPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.715 sec
Running org.geoserver.web.admin.CoverageAccessPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.775 sec
Running org.geoserver.web.admin.GlobalSettingsPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.939 sec
Running org.geoserver.web.admin.JAIPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.573 sec
Running org.geoserver.web.admin.LogPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.645 sec
Running org.geoserver.web.admin.ResourceAccessManagerAdminPrivilegeTest
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.359 sec
Running org.geoserver.web.admin.StatusPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.618 sec
Running org.geoserver.web.data.ConfirmRemovalPanelTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.687 sec
Running org.geoserver.web.data.layer.LayerPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.063 sec
Running org.geoserver.web.data.layer.NewLayerPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.745 sec
Running org.geoserver.web.data.layergroup.LayerGroupEditPageTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.376 sec
Running org.geoserver.web.data.layergroup.LayerGroupPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.12 sec
Running org.geoserver.web.data.resource.FeatureResourceConfigurationPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.551 sec
Running org.geoserver.web.data.resource.ResourceConfigurationPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.14 sec
Running org.geoserver.web.data.resource.ResourceNameValidatorTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.web.data.store.CoverageStoreEditPageTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.504 sec
Running org.geoserver.web.data.store.CoverageStoreNewPageTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.7 sec
Running org.geoserver.web.data.store.DataAccessEditPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.965 sec
Running org.geoserver.web.data.store.DataAccessNewPageTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.909 sec
Running org.geoserver.web.data.store.NewDataPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.87 sec
Running org.geoserver.web.data.store.ParamInfoTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.web.data.store.ShapefileDirectoryStorePageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.202 sec
Running org.geoserver.web.data.store.StoreModelTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.489 sec
Running org.geoserver.web.data.store.StorePageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.183 sec
Running org.geoserver.web.data.store.panel.FileModelTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.web.data.table.NewLayerProviderTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.618 sec
Running org.geoserver.web.data.workspace.WorkspaceEditPageTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.774 sec
Running org.geoserver.web.data.workspace.WorkspaceNewPageTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.517 sec
Running org.geoserver.web.data.workspace.WorkspacePageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.007 sec
Running org.geoserver.web.publish.HTTPLayerConfigTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.69 sec
Running org.geoserver.web.wicket.CRSPanelTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.831 sec
Running org.geoserver.web.wicket.ConfirmationAjaxLinkTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.816 sec
Running org.geoserver.web.wicket.DecimalListTextFieldTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.093 sec
Running org.geoserver.web.wicket.DecimalTextFieldTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.06 sec
Running org.geoserver.web.wicket.EnvelopePanelTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.467 sec
Running org.geoserver.web.wicket.FileExistsValidatorTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec
Running org.geoserver.web.wicket.GeoServerPagingNavigatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.679 sec
Running org.geoserver.web.wicket.GeoServerTablePanelTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.233 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.51 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.135 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.106 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.987 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.885 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.551 sec
Results :
Tests in error:
log4j:WARN No appenders could be found for logger (org.apache.commons.beanutils.converters.BooleanConverter).
log4j:WARN Please initialize the log4j system properly.
[INFO]
[INFO] Core UI Module ..................................... FAILURE [01:28 min]
[INFO] Total time: 01:41 min
[INFO] Finished at: 2016-07-08T20:55:03+02:00
[INFO] Final Memory: 67M/373M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/775/changes&gt;
Changes:
[emerkle] Port Plugin for GeoGig to GeoServer 2.10
[emerkle] Add test dependency on geogig-geotools tests for community/geogig
[...truncated 414 lines...]
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.834 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.493 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.632 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.776 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.399 sec
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.636 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.509 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.723 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.538 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.514 sec
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.149 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.584 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.473 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.02 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.567 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.333 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.029 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.445 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.18 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.492 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.677 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.91 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.717 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.963 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.126 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.313 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.042 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.561 sec
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.776 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.631 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.107 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.689 sec
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.777 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.724 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.073 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.055 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.534 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.623 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.177 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.474 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.057 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.095 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.877 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.783 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.414 sec
Results :
Tests in error:
[INFO]
[INFO] Core UI Module ..................................... FAILURE [01:08 min]
[INFO] Total time: 01:19 min
[INFO] Finished at: 2016-07-09T05:54:38+02:00
[INFO] Final Memory: 72M/437M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/776/changes&gt;
Changes:
[bradh] [GEOS-7629] GSIP-147 Align with Geotools copyright header management
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.829 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.089 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.794 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.837 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.352 sec
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.605 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.586 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.526 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.882 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.561 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.651 sec
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.263 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.629 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.588 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.966 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.78 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.437 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.115 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.442 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.117 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.583 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.732 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.95 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.742 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.983 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.178 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.32 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.094 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.569 sec
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.7 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.603 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.044 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.777 sec
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.679 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.608 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.079 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.059 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.41 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.794 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.344 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.523 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.313 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.103 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.831 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.44 sec
Results :
Tests in error:
[JENKINS] Recording test results
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] Reactor Summary:
[INFO]
[INFO] Core UI Module ..................................... FAILURE [01:10 min]
[INFO] Total time: 01:21 min
[INFO] Finished at: 2016-07-09T11:54:38+02:00
[INFO] Final Memory: 68M/437M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/777/&gt;
