See <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/976/changes>
Changes:
[tbarsballe] [GEOS-7651] Use IOUtils rename method for FileSystemResource
[Andrea Aime] [GEOS-7745] CSW based on internal layers ignores security restrictions
[...truncated 2783 lines...]
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
Sep 17, 2016 11:54:25 AM org.geoserver.config.util.XStreamPersister log
INFO: Loaded store 'cite', enabled
INFO: Loaded feature type 'RoadSegments', enabled
INFO: Loaded feature type 'Bridges', enabled
INFO: Loaded feature type 'Forests', enabled
INFO: Loaded feature type 'NamedPlaces', enabled
INFO: Loaded feature type 'BasicPolygons', enabled
INFO: Loaded feature type 'Streams', enabled
INFO: Loaded feature type 'Lakes', enabled
INFO: Loaded feature type 'Buildings', enabled
INFO: Loaded feature type 'Ponds', enabled
INFO: Loaded feature type 'DividedRoutes', enabled
INFO: Loaded feature type 'MapNeatline', enabled
INFO: Loaded feature type 'Geometryless', enabled
INFO: Loaded store 'cgf', enabled
INFO: Loaded feature type 'Polygons', enabled
INFO: Loaded feature type 'MLines', enabled
INFO: Loaded feature type 'Points', enabled
INFO: Loaded feature type 'Lines', enabled
INFO: Loaded feature type 'MPolygons', enabled
INFO: Loaded feature type 'MPoints', enabled
INFO: Loaded store 'cdf', enabled
INFO: Loaded feature type 'Nulls', enabled
INFO: Loaded feature type 'Locks', enabled
INFO: Loaded feature type 'Inserts', enabled
INFO: Loaded feature type 'Fifteen', enabled
INFO: Loaded feature type 'Deletes', enabled
INFO: Loaded feature type 'Updates', enabled
INFO: Loaded feature type 'Seven', enabled
INFO: Loaded feature type 'Other', enabled
INFO: Loaded store 'sf', enabled
INFO: Loaded feature type 'GenericEntity', enabled
INFO: Loaded feature type 'PrimitiveGeoFeature', enabled
INFO: Loaded feature type 'AggregateGeoFeature', enabled
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<csw:GetRecordsResponse xmlns:csw="http://www.opengis.net/cat/csw/2.0.2" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:dct="http://purl.org/dc/terms/" xmlns:ogc="http://www.opengis.net/ogc" xmlns:ows="http://www.opengis.net/ows" xmlns:rim="urn:oasis:names:tc:ebxml-regrep:xsd:rim:3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="2.0.2" xsi:schemaLocation="http://www.opengis.net/cat/csw/2.0.2 http://localhost:8080/geoserver/schemas/csw/2.0.2/record.xsd">
<csw:SearchStatus timestamp="2016-09-17T09:54:26.085Z"/>
<csw:SearchResults elementSet="summary" nextRecord="6" numberOfRecordsMatched="31" numberOfRecordsReturned="2">
<csw:SummaryRecord>
<dc:identifier>FeatureTypeInfoImpl-57ea4247:1573791440d:-7b73</dc:identifier>
<dc:title>Buildings</dc:title>
<dc:type>http://purl.org/dc/dcmitype/Dataset</dc:type>
<dc:subject>Buildings</dc:subject>
<dct:abstract>abstract about Buildings</dct:abstract>
<ows:BoundingBox crs="urn:x-ogc:def:crs:EPSG:6.11:4326">
<ows:LowerCorner>-90.0 -180.0</ows:LowerCorner>
<ows:UpperCorner>90.0 180.0</ows:UpperCorner>
</ows:BoundingBox>
</csw:SummaryRecord>
<csw:SummaryRecord>
<dc:identifier>LayerGroupInfoImpl-57ea4247:1573791440d:-7b2c</dc:identifier>
<dc:title>Buildings and Bridges</dc:title>
</csw:SearchResults>
</csw:GetRecordsResponse>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.404 sec
Running org.geoserver.csw.store.internal.ResourceAccessManagerCSWTest
Sep 17, 2016 11:54:26 AM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
Sep 17, 2016 11:54:26 AM org.geoserver.config.util.XStreamPersister log
Tests run: 2, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.516 sec <<< FAILURE!
testAllRecordsCite(org.geoserver.csw.store.internal.ResourceAccessManagerCSWTest) Time elapsed: 18 sec <<< FAILURE!
java.lang.AssertionError: expected:<12> but was:<30>
at org.junit.Assert.fail(Assert.java:88)
at org.junit.Assert.failNotEquals(Assert.java:743)
at org.junit.Assert.assertEquals(Assert.java:118)
at org.junit.Assert.assertEquals(Assert.java:555)
at org.junit.Assert.assertEquals(Assert.java:542)
at org.geoserver.csw.store.internal.ResourceAccessManagerCSWTest.testAllRecordsCite(ResourceAccessManagerCSWTest.java:120)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
Results :
Failed tests: testAllRecordsCite(org.geoserver.csw.store.internal.ResourceAccessManagerCSWTest): expected:<12> but was:<30>
Tests run: 109, Failures: 1, Errors: 0, Skipped: 0
[JENKINS] Recording test results
log4j:WARN No appenders could be found for logger (org.apache.commons.beanutils.converters.BooleanConverter).
log4j:WARN Please initialize the log4j system properly.
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] Reactor Summary:
[INFO]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 34.911 s]
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 39.509 s
[INFO] Finished at: 2016-09-17T11:54:29+02:00
[INFO] Final Memory: 102M/407M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-csw-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/csw/core/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/csw/web-csw/pom.xml> to org.geoserver.csw/gs-web-csw/2.10-SNAPSHOT/gs-web-csw-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/ws/src/extension/csw/core/pom.xml> to org.geoserver.csw/gs-csw-core/2.10-SNAPSHOT/gs-csw-core-2.10-SNAPSHOT.pom
channel stopped
