[Geoserver-devel] Build failed in Jenkins: GeoServer-Master » Web Feature Service Module #2525
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-wfs/2525/&gt;
[...truncated 3423 lines...]
[DEBUG] adding directory org/geoserver/wfs/xml/xs/
[DEBUG] adding entry org/geoserver/wfs/AbstractTransactionCurveTest.java
[DEBUG] adding entry org/geoserver/wfs/AliasTest.java
[DEBUG] adding entry org/geoserver/wfs/CatalogNamespaceSupportTest.java
[DEBUG] adding entry org/geoserver/wfs/DescribeFeatureTest.java
[DEBUG] adding entry org/geoserver/wfs/ExternalEntitiesTest.java
[DEBUG] adding entry org/geoserver/wfs/Fifteen.properties
[DEBUG] adding entry org/geoserver/wfs/GeometrylessTest.java
[DEBUG] adding entry org/geoserver/wfs/GeometrylessWriteTest.java
[DEBUG] adding entry org/geoserver/wfs/GetCapabilitiesTest.java
[DEBUG] adding entry org/geoserver/wfs/GetFeatureBboxTest.java
[DEBUG] adding entry org/geoserver/wfs/GetFeatureBoundedTest.java
[DEBUG] adding entry org/geoserver/wfs/GetFeatureCurvesTest.java
[DEBUG] adding entry org/geoserver/wfs/GetFeatureHitsIgnoreMaxFeaturesTest.java
[DEBUG] adding entry org/geoserver/wfs/GetFeatureMissingTypesTest.java
[DEBUG] adding entry org/geoserver/wfs/GetFeaturePagingTest.java
[DEBUG] adding entry org/geoserver/wfs/GetFeatureTest.java
[DEBUG] adding entry org/geoserver/wfs/GetFeatureWithLockTest.java
[DEBUG] adding entry org/geoserver/wfs/GoogleFeatures.properties
[DEBUG] adding entry org/geoserver/wfs/JoinExtractingVisitorTest.java
[DEBUG] adding entry org/geoserver/wfs/json/GeoJSONBuilderTest.java
[DEBUG] adding entry org/geoserver/wfs/json/GeoJsonDescribeTest.java
[DEBUG] adding entry org/geoserver/wfs/json/GeoJSONTest.java
[DEBUG] adding entry org/geoserver/wfs/json/JSONTypeTest.java
[DEBUG] adding entry org/geoserver/wfs/json/layers_ro.properties
[DEBUG] adding entry org/geoserver/wfs/json/Line3D.properties
[DEBUG] adding entry org/geoserver/wfs/json/MultiGeometriesWithNull.properties
[DEBUG] adding entry org/geoserver/wfs/json/PointLatLon.properties
[DEBUG] adding entry org/geoserver/wfs/json/PointLonLat.properties
[DEBUG] adding entry org/geoserver/wfs/json/PointReduced.properties
[DEBUG] adding entry org/geoserver/wfs/json/RoundingUtilTest.java
[DEBUG] adding entry org/geoserver/wfs/kvp/Filter_1_0_0_KvpParserTest.java
[DEBUG] adding entry org/geoserver/wfs/kvp/Filter_1_1_0_KvpParserTest.java
[DEBUG] adding entry org/geoserver/wfs/kvp/GetFeatureKvpRequestReaderTest.java
[DEBUG] adding entry org/geoserver/wfs/LockFeatureTest.java
[DEBUG] adding entry org/geoserver/wfs/MaxFeaturesTest.java
[DEBUG] adding entry org/geoserver/wfs/NullGeometries.properties
[DEBUG] adding entry org/geoserver/wfs/NumDecimalsTest.java
[DEBUG] adding entry org/geoserver/wfs/ReprojectionTest.java
[DEBUG] adding entry org/geoserver/wfs/ReprojectionWriteTest.java
[DEBUG] adding entry org/geoserver/wfs/ResourceAccessManagerContext.xml
[DEBUG] adding entry org/geoserver/wfs/ResourceAccessManagerWFSTest.java
[DEBUG] adding entry org/geoserver/wfs/response/All.Types.Dots.properties
[DEBUG] adding entry org/geoserver/wfs/response/AllTypes.properties
[DEBUG] adding entry org/geoserver/wfs/response/CSVOutputFormatTest.java
[DEBUG] adding entry org/geoserver/wfs/response/dots.in.name.properties
[DEBUG] adding entry org/geoserver/wfs/response/geommid.properties
[DEBUG] adding entry org/geoserver/wfs/response/longnames.properties
[DEBUG] adding entry org/geoserver/wfs/response/nullgeom.properties
[DEBUG] adding entry org/geoserver/wfs/response/shapeziptest.ftl
[DEBUG] adding entry org/geoserver/wfs/response/ShapeZipTest.java
[DEBUG] adding entry org/geoserver/wfs/response/WfsXmlWriterTest.java
[DEBUG] adding entry org/geoserver/wfs/RetypingTransactionTest.java
[DEBUG] adding entry org/geoserver/wfs/SecuredGetFeatureTest.java
[DEBUG] adding entry org/geoserver/wfs/SQLViewTest.java
[DEBUG] adding entry org/geoserver/wfs/SrsNameTest.java
[DEBUG] adding entry org/geoserver/wfs/StoredQueryProviderTest.java
[DEBUG] adding entry org/geoserver/wfs/TransactionListenerTest.java
[DEBUG] adding entry org/geoserver/wfs/TransactionListenerTestContext.xml
[DEBUG] adding entry org/geoserver/wfs/TransactionListenerTester.java
[DEBUG] adding entry org/geoserver/wfs/TransactionTest.java
[DEBUG] adding entry org/geoserver/wfs/v1_1/AliasTest.java
[DEBUG] adding entry org/geoserver/wfs/v1_1/BoundingBox3DTest.java
[DEBUG] adding entry org/geoserver/wfs/v1_1/CapabilitiesTransformerTest.java
[DEBUG] adding entry org/geoserver/wfs/v1_1/DescribeFeatureResponseTest.java
[DEBUG] adding entry org/geoserver/wfs/v1_1/DescribeFeatureTypeTest.java
[DEBUG] adding entry org/geoserver/wfs/v1_1/GetCapabilitiesTest.java
[DEBUG] adding entry org/geoserver/wfs/v1_1/GetFeature-invalid.xml
[DEBUG] adding entry org/geoserver/wfs/v1_1/GetFeature.xml
[DEBUG] adding entry org/geoserver/wfs/v1_1/GetFeatureBboxTest.java
[DEBUG] adding entry org/geoserver/wfs/v1_1/GetFeatureTest.java
[DEBUG] adding entry org/geoserver/wfs/v1_1/GetFeatureWithLockTest.java
[DEBUG] adding entry org/geoserver/wfs/v1_1/insertArc.xml
[DEBUG] adding entry org/geoserver/wfs/v1_1/insertCurvePolygon.xml
[DEBUG] adding entry org/geoserver/wfs/v1_1/insertMultiCurve.xml
[DEBUG] adding entry org/geoserver/wfs/v1_1/LockFeatureTest.java
[DEBUG] adding entry org/geoserver/wfs/v1_1/new.properties
[DEBUG] adding entry org/geoserver/wfs/v1_1/others.xsd
[DEBUG] adding entry org/geoserver/wfs/v1_1/TransactionCurveTest.java
[DEBUG] adding entry org/geoserver/wfs/v1_1/TransactionTest.java
[DEBUG] adding entry org/geoserver/wfs/v1_1/updateCompoundCurve.xml
[DEBUG] adding entry org/geoserver/wfs/v1_1/VersionNegotiationTest.java
[DEBUG] adding entry org/geoserver/wfs/v1_1/WFSReprojectionTest.java
[DEBUG] adding entry org/geoserver/wfs/v1_1/WFSReprojectionWriteTest.java
[DEBUG] adding entry org/geoserver/wfs/v1_1/WFSXmlTest.java
[DEBUG] adding entry org/geoserver/wfs/v1_1/With3D.properties
[DEBUG] adding entry org/geoserver/wfs/v1_1/WithGMLProperties.properties
[DEBUG] adding entry org/geoserver/wfs/v2_0/BoundingBox3DTest.java
[DEBUG] adding entry org/geoserver/wfs/v2_0/DescribeFeatureTypeTest.java
[DEBUG] adding entry org/geoserver/wfs/v2_0/ExtendedOperatorTest.java
[DEBUG] adding entry org/geoserver/wfs/v2_0/GetCapabilitiesTest.java
[DEBUG] adding entry org/geoserver/wfs/v2_0/GetFeatureCurvesTest.java
[DEBUG] adding entry org/geoserver/wfs/v2_0/GetFeatureJoinTest.java
[DEBUG] adding entry org/geoserver/wfs/v2_0/GetFeaturePagingTest.java
[DEBUG] adding entry org/geoserver/wfs/v2_0/GetFeatureTest.java
[DEBUG] adding entry org/geoserver/wfs/v2_0/GetFeatureWithLockTest.java
[DEBUG] adding entry org/geoserver/wfs/v2_0/GetPropertyValueTest.java
[DEBUG] adding entry org/geoserver/wfs/v2_0/insertArc.xml
[DEBUG] adding entry org/geoserver/wfs/v2_0/insertCurvePolygon.xml
[DEBUG] adding entry org/geoserver/wfs/v2_0/insertMultiCurve.xml
[DEBUG] adding entry org/geoserver/wfs/v2_0/LockFeatureTest.java
[DEBUG] adding entry org/geoserver/wfs/v2_0/SrsNameRequestTest.java
[DEBUG] adding entry org/geoserver/wfs/v2_0/SrsNameTest.java
[DEBUG] adding entry org/geoserver/wfs/v2_0/StoredQueryTest.java
[DEBUG] adding entry org/geoserver/wfs/v2_0/TransactionCurveTest.java
[DEBUG] adding entry org/geoserver/wfs/v2_0/TransactionTest.java
[DEBUG] adding entry org/geoserver/wfs/v2_0/updateCompoundCurve.xml
[DEBUG] adding entry org/geoserver/wfs/v2_0/WFS20TestSupport.java
[DEBUG] adding entry org/geoserver/wfs/wfs-minimal.xml
[DEBUG] adding entry org/geoserver/wfs/wfs-test.xml
[DEBUG] adding entry org/geoserver/wfs/WFSCascadedStoredQueryConfigurationParserTest.java
[DEBUG] adding entry org/geoserver/wfs/WFSCurvesTestSupport.java
[DEBUG] adding entry org/geoserver/wfs/WFSDisabledTest.java
[DEBUG] adding entry org/geoserver/wfs/WFSExceptionTest.java
[DEBUG] adding entry org/geoserver/wfs/WFSReprojectionUtilTest.java
[DEBUG] adding entry org/geoserver/wfs/WFSServiceExceptionTest.java
[DEBUG] adding entry org/geoserver/wfs/WFSTestSupport.java
[DEBUG] adding entry org/geoserver/wfs/WFSWorkspaceQualifierTest.java
[DEBUG] adding entry org/geoserver/wfs/WFSXStreamLoaderTest.java
[DEBUG] adding entry org/geoserver/wfs/xml/FeatureTypeInfoSchemaBuilderTest.java
[DEBUG] adding entry org/geoserver/wfs/xml/GML3FeatureProducerTest.java
[DEBUG] adding entry org/geoserver/wfs/xml/GMLOutputFormatTest.java
[DEBUG] adding entry org/geoserver/wfs/xml/v1_1/XMLParsingTest.java
[DEBUG] adding entry org/geoserver/wfs/xml/WFSURIHandlerTest.java
[DEBUG] adding entry org/geoserver/wfs/xml/xs/DateBindingTest.java
[DEBUG] org\geoserver\wfs\Fifteen.properties already added, skipping
[DEBUG] org\geoserver\wfs\GoogleFeatures.properties already added, skipping
[DEBUG] org\geoserver\wfs\json\layers_ro.properties already added, skipping
[DEBUG] org\geoserver\wfs\json\Line3D.properties already added, skipping
[DEBUG] org\geoserver\wfs\json\MultiGeometriesWithNull.properties already added, skipping
[DEBUG] org\geoserver\wfs\json\PointLatLon.properties already added, skipping
[DEBUG] org\geoserver\wfs\json\PointLonLat.properties already added, skipping
[DEBUG] org\geoserver\wfs\json\PointReduced.properties already added, skipping
[DEBUG] org\geoserver\wfs\NullGeometries.properties already added, skipping
[DEBUG] org\geoserver\wfs\ResourceAccessManagerContext.xml already added, skipping
[DEBUG] org\geoserver\wfs\response\All.Types.Dots.properties already added, skipping
[DEBUG] org\geoserver\wfs\response\AllTypes.properties already added, skipping
[DEBUG] org\geoserver\wfs\response\dots.in.name.properties already added, skipping
[DEBUG] org\geoserver\wfs\response\geommid.properties already added, skipping
[DEBUG] org\geoserver\wfs\response\longnames.properties already added, skipping
[DEBUG] org\geoserver\wfs\response\nullgeom.properties already added, skipping
[DEBUG] org\geoserver\wfs\response\shapeziptest.ftl already added, skipping
[DEBUG] org\geoserver\wfs\TransactionListenerTestContext.xml already added, skipping
[DEBUG] org\geoserver\wfs\v1_1\GetFeature-invalid.xml already added, skipping
[DEBUG] org\geoserver\wfs\v1_1\GetFeature.xml already added, skipping
[DEBUG] org\geoserver\wfs\v1_1\insertArc.xml already added, skipping
[DEBUG] org\geoserver\wfs\v1_1\insertCurvePolygon.xml already added, skipping
[DEBUG] org\geoserver\wfs\v1_1\insertMultiCurve.xml already added, skipping
[DEBUG] org\geoserver\wfs\v1_1\new.properties already added, skipping
[DEBUG] org\geoserver\wfs\v1_1\others.xsd already added, skipping
[DEBUG] org\geoserver\wfs\v1_1\updateCompoundCurve.xml already added, skipping
[DEBUG] org\geoserver\wfs\v1_1\With3D.properties already added, skipping
[DEBUG] org\geoserver\wfs\v1_1\WithGMLProperties.properties already added, skipping
[DEBUG] org\geoserver\wfs\v2_0\insertArc.xml already added, skipping
[DEBUG] org\geoserver\wfs\v2_0\insertCurvePolygon.xml already added, skipping
[DEBUG] org\geoserver\wfs\v2_0\insertMultiCurve.xml already added, skipping
[DEBUG] org\geoserver\wfs\v2_0\updateCompoundCurve.xml already added, skipping
[DEBUG] org\geoserver\wfs\wfs-minimal.xml already added, skipping
[DEBUG] org\geoserver\wfs\wfs-test.xml already added, skipping
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ gs-wfs ---
[DEBUG] Configuring mojo org.apache.maven.plugins:maven-dependency-plugin:2.1:copy-dependencies from plugin realm ClassRealm[plugin>org.apache.maven.plugins:maven-dependency-plugin:2.1, parent: sun.misc.Launcher$AppClassLoader@anonymised.com]
[DEBUG] Configuring mojo 'org.apache.maven.plugins:maven-dependency-plugin:2.1:copy-dependencies' with basic configurator -->
[DEBUG] (s) copyPom = false
[DEBUG] (f) excludeTransitive = false
[DEBUG] (s) failOnMissingClassifierArtifact = true
[DEBUG] (f) includeArtifactIds = gt-api,gwc-core
[DEBUG] (f) includeGroupIds = org.geotools,org.geowebcache
[DEBUG] (s) local = id: local
      url: file:///C:/Windows/system32/config/systemprofile/.m2/repository/
   layout: none
[DEBUG] (s) markersDirectory = C:\.jenkins\jobs\GeoServer-Master\workspace\src\wfs\target\dependency-maven-plugin-markers
[DEBUG] (f) outputAbsoluteArtifactFilename = false
[DEBUG] (s) outputDirectory = C:\.jenkins\jobs\GeoServer-Master\workspace\src\wfs\target\dependency
[DEBUG] (f) overWriteIfNewer = true
[DEBUG] (f) overWriteReleases = false
[DEBUG] (f) overWriteSnapshots = false
[DEBUG] (f) project = MavenProject: org.geoserver:gs-wfs:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\wfs\pom.xml
[DEBUG] (f) reactorProjects = [MavenProject: org.geoserver:geoserver:2.9-SNAPSHOT @ c:\.jenkins\jobs\GeoServer-Master\workspace\src\pom.xml, MavenProject: org.geoserver:gs-platform:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\platform\pom.xml, MavenProject: org.geoserver:gs-ows:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\ows\pom.xml, MavenProject: org.geoserver:gs-main:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\main\pom.xml, MavenProject: org.geoserver:gs-security:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\security\pom.xml, MavenProject: org.geoserver.security:gs-sec-jdbc:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\security\jdbc\pom.xml, MavenProject: org.geoserver.security:gs-sec-ldap:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\security\ldap\pom.xml, MavenProject: org.geoserver:gs-wcs:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\wcs\pom.xml, MavenProject: org.geoserver:gs-wcs1_0:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\wcs1_0\pom.xml, MavenProject: org.geoserver:gs-wcs1_1:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\wcs1_1\pom.xml, MavenProject: org.geoserver:gs-wcs2_0:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\wcs2_0\pom.xml, MavenProject: org.geoserver:gs-wfs:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\wfs\pom.xml, MavenProject: org.geoserver:gs-wms:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\wms\pom.xml, MavenProject: org.geoserver:gs-kml:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\kml\pom.xml, MavenProject: org.geoserver:gs-gwc:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\gwc\pom.xml, MavenProject: org.geoserver:gs-rest:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\rest\pom.xml, MavenProject: org.geoserver:gs-restconfig:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\restconfig\pom.xml, MavenProject: org.geoserver:web:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\pom.xml, MavenProject: org.geoserver.web:gs-web-core:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\core\pom.xml, MavenProject: org.geoserver.web:gs-web-wms:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\wms\pom.xml, MavenProject: org.geoserver.web:gs-web-gwc:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\gwc\pom.xml, MavenProject: org.geoserver.web:gs-web-wfs:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\wfs\pom.xml, MavenProject: org.geoserver.web:gs-web-demo:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\demo\pom.xml, MavenProject: org.geoserver.web:gs-web-wcs:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\wcs\pom.xml, MavenProject: org.geoserver.web:gs-web-sec:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\security\pom.xml, MavenProject: org.geoserver.web:gs-web-sec-core:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\security\core\pom.xml, MavenProject: org.geoserver.web:gs-web-sec-jdbc:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\security\jdbc\pom.xml, MavenProject: org.geoserver.web:gs-web-sec-ldap:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\security\ldap\pom.xml, MavenProject: org.geoserver.web:gs-web-rest:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\rest\pom.xml, MavenProject: org.geoserver.web:gs-web-app:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\app\pom.xml, MavenProject: org.geoserver:community:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\community\pom.xml, MavenProject: org.geoserver:extension:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\pom.xml, MavenProject: org.geoserver.extension:gs-app-schema:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\app-schema\pom.xml, MavenProject: org.geoserver.extension:gs-app-schema-test:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\app-schema\app-schema-test\pom.xml, MavenProject: org.geoserver.extension:gs-sample-data-access-test:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\app-schema\sample-data-access-test\pom.xml, MavenProject: org.geoserver.extension:gs-arcsde:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\arcsde\pom.xml, MavenProject: org.geoserver.extension:gs-geosearch:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\geosearch\pom.xml, MavenProject: org.geoserver.extension:gs-h2:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\h2\pom.xml, MavenProject: org.geoserver.extension:gs-sqlserver:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\sqlserver\pom.xml, MavenProject: org.geoserver.extension:gs-oracle:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\oracle\pom.xml, MavenProject: org.geoserver.extension:gs-mysql:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\mysql\pom.xml, MavenProject: org.geoserver.extension:gs-db2:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\db2\pom.xml, MavenProject: org.geoserver.extension:gs-imagemap:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\imagemap\pom.xml, MavenProject: org.geoserver.extension:gs-gdal:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\gdal\pom.xml, MavenProject: org.geoserver.extension:gs-jp2k:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\jp2k\pom.xml, MavenProject: org.geoserver.extension:gs-ogr:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\ogr\pom.xml, MavenProject: org.geoserver.extension:gs-ogr-core:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\ogr\ogr-core\pom.xml, MavenProject: org.geoserver.extension:gs-ogr-wfs:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\ogr\ogr-wfs\pom.xml, MavenProject: org.geoserver.extension:gs-wps:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\wps\pom.xml, MavenProject: org.geoserver.extension:gs-wps-core:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\wps\wps-core\pom.xml, MavenProject: org.geoserver.extension:gs-ogr-wps:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\ogr\ogr-wps\pom.xml, MavenProject: org.geoserver.extension:gs-excel:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\excel\pom.xml, MavenProject: org.geoserver.extension:gs-charts:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\charts\pom.xml, MavenProject: org.geoserver.extension:gs-feature-pregeneralized:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\feature-pregeneralized\pom.xml, MavenProject: org.geoserver.extension:gs-imagemosaic-jdbc:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\imagemosaic-jdbc\pom.xml, MavenProject: org.geoserver.extension:gs-control-flow:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\control-flow\pom.xml, MavenProject: org.geoserver.extension:gs-wps-cluster-hazelcast:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\wps\wps-cluster-hazelcast\pom.xml, MavenProject: org.geoserver.extension:gs-web-wps:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\wps\web-wps\pom.xml, MavenProject: org.geoserver.extension:gs-querylayer:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\querylayer\pom.xml, MavenProject: org.geoserver.extension:gs-teradata:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\teradata\pom.xml, MavenProject: org.geoserver.extension:gs-monitor:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\monitor\pom.xml, MavenProject: org.geoserver.extension:gs-monitor-core:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\monitor\core\pom.xml, MavenProject: org.geoserver.extension:gs-monitor-hibernate:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\monitor\hibernate\pom.xml, MavenProject: org.geoserver.extension:gs-security:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\security\pom.xml, MavenProject: org.geoserver.security:gs-sec-cas:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\security\cas\pom.xml, MavenProject: org.geoserver.extension:gs-web-sec:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\security\web\pom.xml, MavenProject: org.geoserver.security:gs-web-sec-cas:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\security\web\web-cas\pom.xml, MavenProject: org.geoserver:gs-xslt:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\xslt\pom.xml, MavenProject: org.geoserver.extension:gs-inspire:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\inspire\pom.xml, MavenProject: org.geoserver.extension:gs-css:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\css\pom.xml, MavenProject: org.geoserver:gs-csw:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\csw\pom.xml, MavenProject: org.geoserver.csw:gs-csw-api:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\csw\api\pom.xml, MavenProject: org.geoserver.csw:gs-csw-simple-store:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\csw\simple-store\pom.xml, MavenProject: org.geoserver.csw:gs-csw-core:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\csw\core\pom.xml, MavenProject: org.geoserver.csw:gs-web-csw:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\csw\web-csw\pom.xml, MavenProject: org.geoserver.extension:gs-dxf:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\dxf\pom.xml, MavenProject: org.geoserver.extension:gs-dxf-core:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\dxf\core\pom.xml, MavenProject: org.geoserver.extension:gs-dxf-wps:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\dxf\wps\pom.xml, MavenProject: org.geoserver.extension:gs-printing:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\printing\pom.xml, MavenProject: org.geoserver.extension:gs-wcs2_0-eo:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\wcs2_0-eo\pom.xml, MavenProject: org.geoserver.extension:gs-wcs2_0-eo-core:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\wcs2_0-eo\core\pom.xml, MavenProject: org.geoserver.extension:gs-web-wcs2_0-eo:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\wcs2_0-eo\web\pom.xml, MavenProject: org.geoserver.extension:gs-libjpeg-turbo:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\libjpeg-turbo\pom.xml, MavenProject: org.geoserver:gs-importer:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\pom.xml, MavenProject: org.geoserver.importer:gs-importer-core:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\core\pom.xml, MavenProject: org.geoserver.importer:gs-importer-rest:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\rest\pom.xml, MavenProject: org.geoserver.importer:gs-importer-bdb:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\bdb\pom.xml, MavenProject: org.geoserver.importer:gs-importer-web:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\web\pom.xml, MavenProject: org.geoserver.extension:gs-grib:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\grib\pom.xml, MavenProject: org.geoserver.extension:gs-netcdf:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\netcdf\pom.xml, MavenProject: org.geoserver.extension:gs-netcdf-out:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\netcdf-out\pom.xml, MavenProject: org.geoserver:gs-release:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\release\pom.xml]
[DEBUG] (s) remoteRepos = [ id: boundless
      url: https://repo.boundlessgeo.com/main/
   layout: default
snapshots: [enabled => true, update => daily]
releases: [enabled => true, update => daily]
, id: osgeo
      url: http://download.osgeo.org/webdav/geotools/
   layout: default
, id: maven-restlet
      url: http://maven.restlet.org
   layout: default
snapshots: [enabled => false, update => daily]
, id: hibspat
      url: http://www.hibernatespatial.org/repository
   layout: default
, id: central
      url: http://repo.maven.apache.org/maven2
   layout: default
[DEBUG] (f) silent = false
[DEBUG] (s) stripVersion = false
[DEBUG] (f) type = java-source
[DEBUG] (s) useRepositoryLayout = false
[DEBUG] (s) useSubDirectoryPerArtifact = false
[DEBUG] (s) useSubDirectoryPerType = false
[DEBUG] -- end configuration --
[INFO] Copying gt-api-15-SNAPSHOT.jar to C:\.jenkins\jobs\GeoServer-Master\workspace\src\wfs\target\dependency\gt-api-15-SNAPSHOT.jar
[INFO] Copying gwc-core-1.9-SNAPSHOT.jar to C:\.jenkins\jobs\GeoServer-Master\workspace\src\wfs\target\dependency\gwc-core-1.9-SNAPSHOT.jar
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-wfs ---
[DEBUG] Configuring mojo org.apache.maven.plugins:maven-install-plugin:2.3.1:install from plugin realm ClassRealm[plugin>org.apache.maven.plugins:maven-install-plugin:2.3.1, parent: sun.misc.Launcher$AppClassLoader@anonymised.com]
[DEBUG] Configuring mojo 'org.apache.maven.plugins:maven-install-plugin:2.3.1:install' with basic configurator -->
[DEBUG] (f) artifact = org.geoserver:gs-wfs:jar:2.9-SNAPSHOT
[DEBUG] (f) attachedArtifacts = [org.geoserver:gs-wfs:test-jar:tests:2.9-SNAPSHOT, org.geoserver:gs-wfs:java-source:sources:2.9-SNAPSHOT, org.geoserver:gs-wfs:java-source:test-sources:2.9-SNAPSHOT]
[DEBUG] (f) createChecksum = false
[DEBUG] (f) localRepository = id: local
   layout: none
[DEBUG] (f) packaging = jar
[DEBUG] (f) pomFile = C:\.jenkins\jobs\GeoServer-Master\workspace\src\wfs\pom.xml
[DEBUG] (f) updateReleaseInfo = false
[INFO] Installing C:\.jenkins\jobs\GeoServer-Master\workspace\src\wfs\target\gs-wfs-2.9-SNAPSHOT.jar to C:\Windows\system32\config\systemprofile\.m2\repository\org\geoserver\gs-wfs\2.9-SNAPSHOT\gs-wfs-2.9-SNAPSHOT.jar
[DEBUG] Writing resolution tracking file C:\Windows\system32\config\systemprofile\.m2\repository\org\geoserver\gs-wfs\2.9-SNAPSHOT\_maven.repositories
[INFO] Installing C:\.jenkins\jobs\GeoServer-Master\workspace\src\wfs\pom.xml to C:\Windows\system32\config\systemprofile\.m2\repository\org\geoserver\gs-wfs\2.9-SNAPSHOT\gs-wfs-2.9-SNAPSHOT.pom
[DEBUG] Installing org.geoserver:gs-wfs:2.9-SNAPSHOT/maven-metadata.xml to C:\Windows\system32\config\systemprofile\.m2\repository\org\geoserver\gs-wfs\2.9-SNAPSHOT\maven-metadata-local.xml
[DEBUG] Installing org.geoserver:gs-wfs/maven-metadata.xml to C:\Windows\system32\config\systemprofile\.m2\repository\org\geoserver\gs-wfs\maven-metadata-local.xml
[INFO] Installing C:\.jenkins\jobs\GeoServer-Master\workspace\src\wfs\target\gs-wfs-2.9-SNAPSHOT-tests.jar to C:\Windows\system32\config\systemprofile\.m2\repository\org\geoserver\gs-wfs\2.9-SNAPSHOT\gs-wfs-2.9-SNAPSHOT-tests.jar
[INFO] Installing C:\.jenkins\jobs\GeoServer-Master\workspace\src\wfs\target\gs-wfs-2.9-SNAPSHOT-sources.jar to C:\Windows\system32\config\systemprofile\.m2\repository\org\geoserver\gs-wfs\2.9-SNAPSHOT\gs-wfs-2.9-SNAPSHOT-sources.jar
[INFO] Installing C:\.jenkins\jobs\GeoServer-Master\workspace\src\wfs\target\gs-wfs-2.9-SNAPSHOT-test-sources.jar to C:\Windows\system32\config\systemprofile\.m2\repository\org\geoserver\gs-wfs\2.9-SNAPSHOT\gs-wfs-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving disabled
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-wfs/2526/&gt;
