[Geoserver-devel] Build failed in Jenkins: GeoServer-Master » Web Map Service Module #1833
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-wms/1833/&gt;
[...truncated 203 lines...]
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.825 sec
Running org.geoserver.wms.dimension.VectorCustomDimensionDefaultValueTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.997 sec
Running org.geoserver.wms.dimension.VectorElevationDimensionDefaultValueTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.513 sec
Running org.geoserver.wms.dimension.VectorTimeDimensionDefaultValueTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.903 sec
Running org.geoserver.wms.featureinfo.DynamicSizeStyleExtractorTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.328 sec
Running org.geoserver.wms.featureinfo.FeatureDescriptionTemplateTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.wms.featureinfo.FeatureTemplateTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.497 sec
Running org.geoserver.wms.featureinfo.GetFeatureInfoJSONTest
Results for FeatureType 'http://www.opengis.net/cite:Forests’:
NAME = Green Forest
FID = 109
Tests run: 37, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.82 sec
Running org.geoserver.wms.featureinfo.HTMLFeatureInfoOutputFormatTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.373 sec
Running org.geoserver.wms.featureinfo.RenderingBasedFeatureInfoTest
Query:
   feature type: Bridges
   filter: [ the_geom intersects POLYGON ((0.00019952 0.0006988, 0.00020032 0.0006988, 0.00020032 0.0006996, 0.00019952 0.0006996, 0.00019952 0.0006988)) ]
   [properties: ALL ]
The response iTESTs: {"type":"FeatureCollection","totalFeatures":"unknown","features":[{"type":"Feature","id":"Forests.1107531798144","geometry":{"type":"MultiPolygon","coordinates":[[[[-0.0014,-0.0024],[-0.0014,2.0E-4],[2.0E-4,7.0E-4],[0.0014,0.001],[0.0028,0.0014],[0.0042,0.0018],[0.0042,-0.0024],[-0.0014,-0.0024]]]]},"geometry_name":"the_geom","properties":{"FID":"109","NAME":"Green Forest","bbox":[-0.0014,-0.0024,0.0042,0.0018]}}],"crs":{"type":"name","properties":{"name":"urn:ogc:def:crs:EPSG::4326"}},"bbox":[-0.0014,-0.0024,0.0042,0.0018]}
Query:
   filter: [ the_geom intersects POLYGON ((0.0001968 0.0006942, 0.0002032 0.0006942, 0.0002032 0.0007006, 0.0001968 0.0007006, 0.0001968 0.0006942)) ]
   [properties: ALL ]
Query:
   filter: [ the_geom intersects POLYGON ((0.00019872 0.0006976, 0.00020112 0.0006976, 0.00020112 0.0007, 0.00019872 0.0007, 0.00019872 0.0006976)) ]
   [properties: ALL ]
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.091 sec
Running org.geoserver.wms.featureinfo.TextFeatureInfoOutputFormatTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.279 sec
Running org.geoserver.wms.georss.AtomGeoRSSTransformerTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.42 sec
Running org.geoserver.wms.georss.RSSGeoRSSTransformerTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.513 sec
Running org.geoserver.wms.legendgraphic.AbstractLegendGraphicOutputFormatTest
Tests run: 19, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.747 sec
Running org.geoserver.wms.legendgraphic.GetLegendGraphicKvpReaderTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.435 sec
Running org.geoserver.wms.map.GIFMapResponseTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default1599502625960080628data\DEM\tazdem.tiff
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.34 sec
Running org.geoserver.wms.map.GetMapIntegrationTest
[CoverageInfoImpl[usa], CoverageInfoImpl[indexed], CoverageInfoImpl[paletted], CoverageInfoImpl[mosaic], CoverageInfoImpl[fourbits]]
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.416 sec
Running org.geoserver.wms.map.GetMapKvpRequestReaderTest
Tests run: 24, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.091 sec
Running org.geoserver.wms.map.GetMapXmlReaderTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.622 sec
Running org.geoserver.wms.map.OpenLayersMapOutputFormatTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.326 sec
Running org.geoserver.wms.map.OpenLayersMapTemplateTest
Running org.geoserver.wms.map.QuickTileCacheTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.wms.map.RasterSymbolizerVisitorTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.wms.map.RasterWithoutOutlineMapStyleTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.402 sec
Running org.geoserver.wms.map.RawMapTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.047 sec
Running org.geoserver.wms.map.RenderedImageMapOutputFormatExtendedTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.7 sec
Running org.geoserver.wms.map.RenderedImageMapOutputFormatTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default7830854722366788173data\DEM\tazdem.tiff
Tests run: 6, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 7.005 sec <<< FAILURE!
testTimeoutOption(org.geoserver.wms.map.RenderedImageMapOutputFormatTest) Time elapsed: 1155 sec <<< FAILURE!
java.lang.AssertionError: Timeout was not reached
  at org.junit.Assert.fail(Assert.java:88)
  at org.geoserver.wms.map.RenderedImageMapOutputFormatTest.testTimeoutOption(RenderedImageMapOutputFormatTest.java:221)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
Running org.geoserver.wms.map.png.GetMapIntegrationTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.965 sec
Running org.geoserver.wms.svg.SVGMapProducerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.638 sec
Running org.geoserver.wms.svg.SVGTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.528 sec
Running org.geoserver.wms.wms_1_1_1.CapabilitiesAllowedMimeTypesTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.591 sec
Running org.geoserver.wms.wms_1_1_1.CapabilitiesAuthorityURLAndIdentifierTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.856 sec
Running org.geoserver.wms.wms_1_1_1.CapabilitiesBBOXForEachCRSTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.685 sec
Running org.geoserver.wms.wms_1_1_1.CapabilitiesModifyingTest
ERROR: 'Can't obtain Envelope of Layer-Groups: Error occurred trying to write out metadata for layer group: test'
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.778 sec
Running org.geoserver.wms.wms_1_1_1.CapabilitiesTest
Tests run: 16, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.464 sec
Running org.geoserver.wms.wms_1_1_1.CustomDimensionsTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.231 sec
Running org.geoserver.wms.wms_1_1_1.DescribeLayerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.435 sec
Running org.geoserver.wms.wms_1_1_1.DimensionsRasterCapabilitiesTest
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.292 sec
Running org.geoserver.wms.wms_1_1_1.DimensionsRasterGetFeatureInfoTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.496 sec
Running org.geoserver.wms.wms_1_1_1.DimensionsRasterGetMapTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.543 sec
Running org.geoserver.wms.wms_1_1_1.DimensionsVectorCapabilitiesTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.681 sec
Running org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.464 sec
Running org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.87 sec
Running org.geoserver.wms.wms_1_1_1.DynamicDimensionsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.168 sec
Running org.geoserver.wms.wms_1_1_1.GetCapabilitiesLegendURL_1_1_1Test
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.168 sec
Running org.geoserver.wms.wms_1_1_1.GetFeatureInfoRestrictedTest
Running org.geoserver.wms.wms_1_1_1.GetFeatureInfoTest
NAME = Green Forest
FID = 109
Tests run: 32, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.308 sec
Running org.geoserver.wms.wms_1_1_1.GetLegendGraphicTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.45 sec
Running org.geoserver.wms.wms_1_1_1.GetMapIntegrationTest
Tests run: 44, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.209 sec
Running org.geoserver.wms.wms_1_1_1.GetStylesIntegrationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.373 sec
Running org.geoserver.wms.wms_1_1_1.LayerGroupWorkspaceTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.744 sec
Running org.geoserver.wms.wms_1_1_1.LayerWorkspaceTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.497 sec
Running org.geoserver.wms.wms_1_1_1.SLDWithInlineFeatureTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.482 sec
Running org.geoserver.wms.wms_1_1_1.WMSCascadeTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.061 sec
Running org.geoserver.wms.wms_1_3.CapabilitiesAllowedMimeTypesTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.012 sec
Running org.geoserver.wms.wms_1_3.CapabilitiesAuthorityURLAndIdentifierTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.529 sec
Running org.geoserver.wms.wms_1_3.CapabilitiesBBOXForEachCRSTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.498 sec
Running org.geoserver.wms.wms_1_3.CapabilitiesIntegrationTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.884 sec
Running org.geoserver.wms.wms_1_3.CapabilitiesSystemTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.683 sec
Running org.geoserver.wms.wms_1_3.CustomDimensionsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.888 sec
Running org.geoserver.wms.wms_1_3.DimensionsRasterCapabilitiesTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.824 sec
Running org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.712 sec
Running org.geoserver.wms.wms_1_3.GetCapabilitiesLegendUR_1_3_0LTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.2 sec
Running org.geoserver.wms.wms_1_3.GetFeatureInfoIntegrationTest
Results for FeatureType 'http://www.opengis.net/cite/geometry:Polygons’:
id = t0002
polygonProperty = [GEOMETRY (Polygon) with 5 points]
Tests run: 23, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.59 sec
Running org.geoserver.wms.wms_1_3.GetMapIntegrationTest
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.901 sec
Running org.geoserver.wms.wms_1_3.LayerGroupWorkspaceTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.681 sec
Running org.geoserver.wms.wms_1_3.LayerWorkspaceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.42 sec
Running org.geoserver.wms.wms_1_3.WMSCascadeTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.67 sec
Results :
Failed tests: testTimeoutOption(org.geoserver.wms.map.RenderedImageMapOutputFormatTest): Timeout was not reached
Tests run: 683, Failures: 1, Errors: 0, Skipped: 0
[JENKINS] Recording test results
[JENKINS] Archiving disabled
