[Geoserver-devel] Build failed in Jenkins: GeoServer-Master » Web Processing Service Module #2425
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver.extension$gs-wps-core/2425/&gt;
[...truncated 132 lines...]
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default872141876631930571data\DEM\tazdem.tiff
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 43.613 sec
Running org.geoserver.wps.ExecuteTest
Tests run: 41, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 21.217 sec
Running org.geoserver.wps.GeoServerFactoryExtensionTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.334 sec
Running org.geoserver.wps.GetCapabilitiesTest
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.391 sec
Running org.geoserver.wps.InputLimitsTest
Tests run: 12, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 9.919 sec <<< FAILURE!
testAsyncExecutionLimits(org.geoserver.wps.InputLimitsTest) Time elapsed: 2520 sec <<< FAILURE!
junit.framework.AssertionFailedError: Expecting to find matches for Xpath //wps:Status/wps:ProcessFailed
  at junit.framework.Assert.fail(Assert.java:57)
  at junit.framework.Assert.assertTrue(Assert.java:22)
  at org.custommonkey.xmlunit.XMLAssert.assertXpathExists(XMLAssert.java:901)
  at org.geoserver.wps.InputLimitsTest.testAsyncExecutionLimits(InputLimitsTest.java:573)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
Running org.geoserver.wps.MemoryProcessStoreTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.07 sec
Running org.geoserver.wps.NearestTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.799 sec
Running org.geoserver.wps.RawInputOutputTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.598 sec
Running org.geoserver.wps.ResourceAccessManagerWPSTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.116 sec
Running org.geoserver.wps.SnapTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.302 sec
Running org.geoserver.wps.UniqueProcessNamesTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.24 sec
Running org.geoserver.wps.WPSInitializerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.121 sec
Running org.geoserver.wps.WPSXStreamLoaderTest
<wps>
  <enabled>true</enabled>
  <name>WPS</name>
  <title>Prototype GeoServer WPS</title>
  <versions>
    <org.geotools.util.Version>
      <version>1.0.0</version>
    </org.geotools.util.Version>
  </versions>
  <citeCompliant>false</citeCompliant>
  <schemaBaseURL>http://schemas.opengis.net</schemaBaseURL>
  <verbose>false</verbose>
  <connectionTimeout>30.0</connectionTimeout>
  <resourceExpirationTimeout>300</resourceExpirationTimeout>
  <maxSynchronousProcesses>4</maxSynchronousProcesses>
  <maxAsynchronousProcesses>4</maxAsynchronousProcesses>
  <processGroups>
    <processGroup>
      <factoryClass>org.geotools.process.geometry.GeometryProcessFactory</factoryClass>
      <enabled>false</enabled>
      <filteredProcesses>
        <accessInfo>
          <name>geo:Area</name>
          <validators>
            <entry key="geom">
              <maxSizeValidator>
                <maxSizeMB>10</maxSizeMB>
              </maxSizeValidator>
            </entry>
          </validators>
        </accessInfo>
      </filteredProcesses>
    </processGroup>
    <processGroup>
      <factoryClass>org.geotools.process.raster.RasterProcessFactory</factoryClass>
      <filteredProcesses>
        <accessInfo>
          <name>ras:Contour</name>
          <validators>
            <entry key="levels">
              <rangeValidator>
                <range>
                  <minValue>-8000.0</minValue>
                  <maxValue>8000.0</maxValue>
                </range>
              </rangeValidator>
            </entry>
              <maxMultiplicityValidator>
                <maxInstances>3</maxInstances>
              </maxMultiplicityValidator>
            </entry>
          </validators>
        </accessInfo>
    </processGroup>
  </processGroups>
  <maxComplexInputSize>0</maxComplexInputSize>
  <maxSynchronousExecutionTime>0</maxSynchronousExecutionTime>
  <maxAsynchronousExecutionTime>0</maxAsynchronousExecutionTime>
</wps>
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.471 sec
Running org.geoserver.wps.gs.AggregateProcessTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.088 sec
Running org.geoserver.wps.gs.BinaryProcessingsTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default5207325082482436001data\DEM\tazdem.tiff
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.26 sec
Running org.geoserver.wps.gs.BufferFeatureCollectionTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.669 sec
Running org.geoserver.wps.gs.ClipProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.47 sec
Running org.geoserver.wps.gs.CollectGeometriesTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.304 sec
Running org.geoserver.wps.gs.ContourProcessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.487 sec
Running org.geoserver.wps.gs.CountProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.869 sec
Running org.geoserver.wps.gs.Coverage2RenderedImageAdapterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.461 sec
Running org.geoserver.wps.gs.CropCoverageTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default8489251414474332176data\DEM\tazdem.tiff
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.836 sec
Running org.geoserver.wps.gs.GeorectifyCoverageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.82 sec
Running org.geoserver.wps.gs.ImportProcessTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default3832612157300779680data\cite\Buildings.properties
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.478 sec
Running org.geoserver.wps.gs.InclusionFeatureCollectionTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.147 sec
Running org.geoserver.wps.gs.PagedUniqueProcessTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.544 sec
Running org.geoserver.wps.gs.PolygonExtractionProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.958 sec
Running org.geoserver.wps.gs.QueryProcessTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.837 sec
Running org.geoserver.wps.gs.RangeLookupTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default1387683959582404587data\DEM\tazdem.tiff
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.92 sec
Running org.geoserver.wps.gs.RasterAsPointCollectionTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default2389442579915626283data\DEM\tazdem.tiff
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.399 sec
Running org.geoserver.wps.gs.RasterZonalStatsTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default2471949423109950784data\sfdem\sfdem.tiff
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.201 sec
Running org.geoserver.wps.gs.ReprojectProcessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.331 sec
Running org.geoserver.wps.gs.ScaleCoverageTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default1859024540890309494data\DEM\tazdem.tiff
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.893 sec
Running org.geoserver.wps.gs.SimplifyProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.269 sec
Running org.geoserver.wps.gs.StoreCoverageTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default8387743680214185680data\watertemp\NCOM_wattemp^CustomDimValueA.tiff
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.652 sec
Running org.geoserver.wps.gs.StyleCoverageTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default2709600865482392569data\DEM\tazdem.tiff
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.611 sec
Running org.geoserver.wps.gs.UnionFeatureCollectionTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.997 sec
Running org.geoserver.wps.gs.UniqueProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.247 sec
Running org.geoserver.wps.gs.VectorZonalStatsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.386 sec
Running org.geoserver.wps.jts.BeanProcessFactoryTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.844 sec
Running org.geoserver.wps.jts.GeometryProcessWPSTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.219 sec
Running org.geoserver.wps.ppio.GeotiffPPIOTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.254 sec
Running org.geoserver.wps.ppio.RawDataPPIOTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.wps.process.ProcessFilterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.56 sec
Running org.geoserver.wps.process.WPSConfigProcessFilterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.863 sec
Running org.geoserver.wps.resource.WPSResourceManagerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.067 sec
Running org.geoserver.wps.security.WPSAccessChallangeTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.112 sec
Running org.geoserver.wps.security.WPSAccessHideTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.335 sec
Running org.geoserver.wps.security.WPSAccessMixedTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.118 sec
Results :
Failed tests: testAsyncExecutionLimits(org.geoserver.wps.InputLimitsTest): Expecting to find matches for Xpath //wps:Status/wps:ProcessFailed
Tests run: 227, Failures: 1, Errors: 0, Skipped: 0
[JENKINS] Recording test results
[JENKINS] Archiving disabled
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver.extension$gs-wps-core/2426/&gt;
