[Geoserver-devel] Build failed in Jenkins: GeoServer-Master » Web Processing Service Module #2490
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver.extension$gs-wps-core/2490/&gt;
[...truncated 2535 lines...]
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default9199443469851665650data\DEM\tazdem.tiff
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 55.171 sec
Running org.geoserver.wps.ExecuteTest
Tests run: 41, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 24.244 sec
Running org.geoserver.wps.GeoServerFactoryExtensionTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.908 sec
Running org.geoserver.wps.GetCapabilitiesTest
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.902 sec
Running org.geoserver.wps.InputLimitsTest
Tests run: 12, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 11.926 sec <<< FAILURE!
testAsyncExecutionLimits(org.geoserver.wps.InputLimitsTest) Time elapsed: 2502 sec <<< FAILURE!
junit.framework.AssertionFailedError: Expecting to find matches for Xpath //wps:Status/wps:ProcessFailed
  at junit.framework.Assert.fail(Assert.java:57)
  at junit.framework.Assert.assertTrue(Assert.java:22)
  at org.custommonkey.xmlunit.XMLAssert.assertXpathExists(XMLAssert.java:901)
  at org.geoserver.wps.InputLimitsTest.testAsyncExecutionLimits(InputLimitsTest.java:573)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:497)
Running org.geoserver.wps.MemoryProcessStoreTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.wps.NearestTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.844 sec
Running org.geoserver.wps.RawInputOutputTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.369 sec
Running org.geoserver.wps.ResourceAccessManagerWPSTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.639 sec
Running org.geoserver.wps.SnapTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.099 sec
Running org.geoserver.wps.UniqueProcessNamesTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.202 sec
Running org.geoserver.wps.WPSInitializerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.074 sec
Running org.geoserver.wps.WPSXStreamLoaderTest
<wps>
  <enabled>true</enabled>
  <name>WPS</name>
  <title>Prototype GeoServer WPS</title>
  <versions>
    <org.geotools.util.Version>
      <version>1.0.0</version>
    </org.geotools.util.Version>
  </versions>
  <citeCompliant>false</citeCompliant>
  <schemaBaseURL>http://schemas.opengis.net</schemaBaseURL>
  <verbose>false</verbose>
  <connectionTimeout>30.0</connectionTimeout>
  <resourceExpirationTimeout>300</resourceExpirationTimeout>
  <maxSynchronousProcesses>4</maxSynchronousProcesses>
  <maxAsynchronousProcesses>4</maxAsynchronousProcesses>
  <processGroups>
    <processGroup>
      <factoryClass>org.geotools.process.geometry.GeometryProcessFactory</factoryClass>
      <enabled>false</enabled>
      <filteredProcesses>
        <accessInfo>
          <name>geo:Area</name>
          <validators>
            <entry key="geom">
              <maxSizeValidator>
                <maxSizeMB>10</maxSizeMB>
              </maxSizeValidator>
            </entry>
          </validators>
        </accessInfo>
      </filteredProcesses>
    </processGroup>
    <processGroup>
      <factoryClass>org.geotools.process.raster.RasterProcessFactory</factoryClass>
      <filteredProcesses>
        <accessInfo>
          <name>ras:Contour</name>
          <validators>
            <entry key="levels">
              <rangeValidator>
                <range>
                  <minValue>-8000.0</minValue>
                  <maxValue>8000.0</maxValue>
                </range>
              </rangeValidator>
            </entry>
              <maxMultiplicityValidator>
                <maxInstances>3</maxInstances>
              </maxMultiplicityValidator>
            </entry>
          </validators>
        </accessInfo>
    </processGroup>
  </processGroups>
  <maxComplexInputSize>0</maxComplexInputSize>
  <maxSynchronousExecutionTime>0</maxSynchronousExecutionTime>
  <maxAsynchronousExecutionTime>0</maxAsynchronousExecutionTime>
</wps>
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.515 sec
Running org.geoserver.wps.gs.AggregateProcessTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.355 sec
Running org.geoserver.wps.gs.BinaryProcessingsTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default5589319703189871811data\DEM\tazdem.tiff
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.813 sec
Running org.geoserver.wps.gs.BufferFeatureCollectionTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.903 sec
Running org.geoserver.wps.gs.ClipProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.049 sec
Running org.geoserver.wps.gs.CollectGeometriesTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.2 sec
Running org.geoserver.wps.gs.ContourProcessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.754 sec
Running org.geoserver.wps.gs.CountProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.758 sec
Running org.geoserver.wps.gs.Coverage2RenderedImageAdapterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.536 sec
Running org.geoserver.wps.gs.CropCoverageTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default1897720062127028556data\DEM\tazdem.tiff
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.833 sec
Running org.geoserver.wps.gs.GeorectifyCoverageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.266 sec
Running org.geoserver.wps.gs.ImportProcessTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default6019294712146592047data\cite\Buildings.properties
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.069 sec
Running org.geoserver.wps.gs.InclusionFeatureCollectionTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.901 sec
Running org.geoserver.wps.gs.PagedUniqueProcessTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.785 sec
Running org.geoserver.wps.gs.PolygonExtractionProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.769 sec
Running org.geoserver.wps.gs.QueryProcessTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.362 sec
Running org.geoserver.wps.gs.RangeLookupTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default4289994431964403005data\DEM\tazdem.tiff
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.655 sec
Running org.geoserver.wps.gs.RasterAsPointCollectionTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default6550381081131868158data\DEM\tazdem.tiff
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.876 sec
Running org.geoserver.wps.gs.RasterZonalStatsTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default1818449063309386977data\sfdem\sfdem.tiff
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.073 sec
Running org.geoserver.wps.gs.ReprojectProcessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.931 sec
Running org.geoserver.wps.gs.ScaleCoverageTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default7544220163697622630data\DEM\tazdem.tiff
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.144 sec
Running org.geoserver.wps.gs.SimplifyProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.037 sec
Running org.geoserver.wps.gs.StoreCoverageTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default2182062319662120627data\watertemp\NCOM_wattemp^CustomDimValueA.tiff
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.467 sec
Running org.geoserver.wps.gs.StyleCoverageTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default5687982504230753681data\DEM\tazdem.tiff
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.246 sec
Running org.geoserver.wps.gs.UnionFeatureCollectionTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.636 sec
Running org.geoserver.wps.gs.UniqueProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.685 sec
Running org.geoserver.wps.gs.VectorZonalStatsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.206 sec
Running org.geoserver.wps.jts.BeanProcessFactoryTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.63 sec
Running org.geoserver.wps.jts.GeometryProcessWPSTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.15 sec
Running org.geoserver.wps.ppio.GeotiffPPIOTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.688 sec
Running org.geoserver.wps.ppio.RawDataPPIOTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.wps.process.ProcessFilterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.84 sec
Running org.geoserver.wps.process.WPSConfigProcessFilterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.717 sec
Running org.geoserver.wps.resource.WPSResourceManagerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.958 sec
Running org.geoserver.wps.security.WPSAccessChallangeTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.538 sec
Running org.geoserver.wps.security.WPSAccessHideTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.117 sec
Running org.geoserver.wps.security.WPSAccessMixedTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.173 sec
Results :
Failed tests: testAsyncExecutionLimits(org.geoserver.wps.InputLimitsTest): Expecting to find matches for Xpath //wps:Status/wps:ProcessFailed
Tests run: 227, Failures: 1, Errors: 0, Skipped: 0
[JENKINS] Recording test results
[JENKINS] Archiving disabled
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver.extension$gs-wps-core/2491/&gt;
