[...truncated 2536 lines...]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:497)
Caused by: java.lang.StringIndexOutOfBoundsException: String index out of range: -1
at java.lang.String.substring(String.java:1967)
at org.geotools.geojson.feature.FeatureHandler.setFID(FeatureHandler.java:318)
at org.geotools.geojson.feature.FeatureHandler.primitive(FeatureHandler.java:199)
at org.geotools.geojson.DelegatingHandler.primitive(DelegatingHandler.java:101)
at org.json.simple.parser.JSONParser.parse(Unknown Source)
at org.geotools.geojson.feature.FeatureJSON$FeatureCollectionIterator.readNext(FeatureJSON.java:746)
... 37 more
testInlineShapezip(org.geoserver.wps.ExecuteTest) Time elapsed: 193 sec <<< ERROR!
java.lang.RuntimeException: java.lang.StringIndexOutOfBoundsException: String index out of range: -1
at org.geotools.geojson.feature.FeatureJSON$FeatureCollectionIterator.readNext(FeatureJSON.java:750)
at org.geotools.geojson.feature.FeatureJSON$FeatureCollectionIterator.hasNext(FeatureJSON.java:734)
at org.geotools.geojson.feature.FeatureJSON.readFeatureCollection(FeatureJSON.java:362)
at org.geoserver.wps.ExecuteTest.testInlineShapezip(ExecuteTest.java:643)
... 37 more
Running org.geoserver.wps.GeoServerFactoryExtensionTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.896 sec
Running org.geoserver.wps.GetCapabilitiesTest
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.532 sec
Running org.geoserver.wps.InputLimitsTest
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.191 sec
Running org.geoserver.wps.MemoryProcessStoreTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.107 sec
Running org.geoserver.wps.NearestTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.049 sec
Running org.geoserver.wps.RawInputOutputTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.01 sec
Running org.geoserver.wps.ResourceAccessManagerWPSTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.902 sec
Running org.geoserver.wps.SnapTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.961 sec
Running org.geoserver.wps.UniqueProcessNamesTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.044 sec
Running org.geoserver.wps.WPSInitializerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.088 sec
Running org.geoserver.wps.WPSXStreamLoaderTest
<wps>
<enabled>true</enabled>
<name>WPS</name>
<title>Prototype GeoServer WPS</title>
<versions>
<org.geotools.util.Version>
<version>1.0.0</version>
</org.geotools.util.Version>
</versions>
<citeCompliant>false</citeCompliant>
<schemaBaseURL>http://schemas.opengis.net</schemaBaseURL>
<verbose>false</verbose>
<connectionTimeout>30.0</connectionTimeout>
<resourceExpirationTimeout>300</resourceExpirationTimeout>
<maxSynchronousProcesses>4</maxSynchronousProcesses>
<maxAsynchronousProcesses>4</maxAsynchronousProcesses>
<processGroups>
<processGroup>
<factoryClass>org.geotools.process.geometry.GeometryProcessFactory</factoryClass>
<enabled>false</enabled>
<filteredProcesses>
<accessInfo>
<name>geo:Area</name>
<validators>
<entry key="geom">
<maxSizeValidator>
<maxSizeMB>10</maxSizeMB>
</maxSizeValidator>
</entry>
</validators>
</accessInfo>
</filteredProcesses>
</processGroup>
<processGroup>
<factoryClass>org.geotools.process.raster.RasterProcessFactory</factoryClass>
<filteredProcesses>
<accessInfo>
<name>ras:Contour</name>
<validators>
<entry key="levels">
<rangeValidator>
<range>
<minValue>-8000.0</minValue>
<maxValue>8000.0</maxValue>
</range>
</rangeValidator>
</entry>
<maxMultiplicityValidator>
<maxInstances>3</maxInstances>
</maxMultiplicityValidator>
</entry>
</validators>
</accessInfo>
</processGroup>
</processGroups>
<maxComplexInputSize>0</maxComplexInputSize>
<maxSynchronousExecutionTime>0</maxSynchronousExecutionTime>
<maxAsynchronousExecutionTime>0</maxAsynchronousExecutionTime>
</wps>
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.085 sec
Running org.geoserver.wps.gs.AggregateProcessTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.745 sec
Running org.geoserver.wps.gs.BinaryProcessingsTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default1124212956508767572data\DEM\tazdem.tiff
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.838 sec
Running org.geoserver.wps.gs.BufferFeatureCollectionTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.403 sec
Running org.geoserver.wps.gs.ClipProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.572 sec
Running org.geoserver.wps.gs.CollectGeometriesTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.904 sec
Running org.geoserver.wps.gs.ContourProcessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.536 sec
Running org.geoserver.wps.gs.CountProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.441 sec
Running org.geoserver.wps.gs.Coverage2RenderedImageAdapterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.801 sec
Running org.geoserver.wps.gs.CropCoverageTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default7770352394071401058data\DEM\tazdem.tiff
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.836 sec
Running org.geoserver.wps.gs.GeorectifyCoverageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.381 sec
Running org.geoserver.wps.gs.ImportProcessTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default6743128076269747071data\cite\Buildings.properties
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.244 sec
Running org.geoserver.wps.gs.InclusionFeatureCollectionTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.705 sec
Running org.geoserver.wps.gs.PagedUniqueProcessTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.902 sec
Running org.geoserver.wps.gs.PolygonExtractionProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.033 sec
Running org.geoserver.wps.gs.QueryProcessTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.317 sec
Running org.geoserver.wps.gs.RangeLookupTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default7880115409756189522data\DEM\tazdem.tiff
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.275 sec
Running org.geoserver.wps.gs.RasterAsPointCollectionTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default6214532894970880947data\DEM\tazdem.tiff
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.326 sec
Running org.geoserver.wps.gs.RasterZonalStatsTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default7380691333077096976data\sfdem\sfdem.tiff
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.063 sec
Running org.geoserver.wps.gs.ReprojectProcessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.284 sec
Running org.geoserver.wps.gs.ScaleCoverageTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default7961304768742200844data\DEM\tazdem.tiff
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.65 sec
Running org.geoserver.wps.gs.SimplifyProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.114 sec
Running org.geoserver.wps.gs.StoreCoverageTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default8186236695685851952data\watertemp\NCOM_wattemp^CustomDimValueA.tiff
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.766 sec
Running org.geoserver.wps.gs.StyleCoverageTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default7885927631936692276data\DEM\tazdem.tiff
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.669 sec
Running org.geoserver.wps.gs.UnionFeatureCollectionTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.868 sec
Running org.geoserver.wps.gs.UniqueProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.248 sec
Running org.geoserver.wps.gs.VectorZonalStatsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.081 sec
Running org.geoserver.wps.jts.BeanProcessFactoryTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.108 sec
Running org.geoserver.wps.jts.GeometryProcessWPSTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.706 sec
Running org.geoserver.wps.ppio.GeotiffPPIOTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.541 sec
Running org.geoserver.wps.ppio.RawDataPPIOTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.02 sec
Running org.geoserver.wps.process.ProcessFilterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.798 sec
Running org.geoserver.wps.process.WPSConfigProcessFilterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.191 sec
Running org.geoserver.wps.resource.WPSResourceManagerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.532 sec
Running org.geoserver.wps.security.WPSAccessChallangeTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.547 sec
Running org.geoserver.wps.security.WPSAccessHideTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.206 sec
Running org.geoserver.wps.security.WPSAccessMixedTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.448 sec
Results :
Tests in error:
testInlineGeoJSON(org.geoserver.wps.ExecuteTest): java.lang.StringIndexOutOfBoundsException: String index out of range: -1
testInlineShapezip(org.geoserver.wps.ExecuteTest): java.lang.StringIndexOutOfBoundsException: String index out of range: -1
Tests run: 227, Failures: 0, Errors: 2, Skipped: 0
[JENKINS] Recording test results
[JENKINS] Archiving disabled
