[Geoserver-devel] Build failed in Jenkins: GeoServer-Master » XLST based WFS output format #2416
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-xslt/2416/&gt;
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO]
[INFO] Building XLST based WFS output format 2.9-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-xslt ---
[INFO] Deleting <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-xslt/ws/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-xslt ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-xslt ---
[INFO] [GitCommitIdMojo] Running on 'C:\.jenkins\jobs\GeoServer-Master\workspace\.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GSIP-131] Minor fixup to StyleGenerator code
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 26.11.2015 @ 23:34:40 CET
[INFO] [GitCommitIdMojo] build.timestamp = 27-nov-2015 16:16
[INFO] [GitCommitIdMojo] build.build.time = 27.11.2015 @ 17:12:40 CET
[INFO] [GitCommitIdMojo] build.branch = 16c0a838bab4c7b788ebe5adad5df7378e09609f
[INFO] [GitCommitIdMojo] build.commit.user.email = tbarsballe@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Torben Barsbsballe
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 16c0a83
[INFO] [GitCommitIdMojo] build.commit.id = 16c0a838bab4c7b788ebe5adad5df7378e09609f
[INFO] [GitCommitIdMojo] build.commit.message.full = [GSIP-131] Minor fixup to StyleGenerator code
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-xslt ---
[INFO] Copying 5 resources
[INFO] skip non existing resourceDirectory <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-xslt/ws/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-xslt ---
[INFO] Compiling 12 source files to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-xslt/ws/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-xslt ---
[INFO] Copying 0 resource
[INFO] Copying 8 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-xslt ---
[INFO] Compiling 4 source files to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-xslt/ws/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-xslt ---
[INFO] Surefire report directory: <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-xslt/ws/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wfs.xslt.GetFeatureXSLTTest
Empty formats
Formats are: {HTML=HTML, text/html; subtype=xslt=text/html; subtype=xslt}
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 22.769 sec
Running org.geoserver.wfs.xslt.config.TransformRepositoryTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.455 sec
Running org.geoserver.wfs.xslt.rest.TransformRestTest
Exception in thread "xsltTimerFactory" java.lang.NullPointerException
  at org.geoserver.wfs.xslt.config.TransformRepository.getAllTransforms(TransformRepository.java:175)
  at org.geoserver.wfs.xslt.XSLTOutputFormatUpdater.run(XSLTOutputFormatUpdater.java:43)
  at java.util.TimerThread.mainLoop(Timer.java:555)
  at java.util.TimerThread.run(Timer.java:505)
Tests run: 9, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 3.437 sec <<< FAILURE!
testListHTML(org.geoserver.wfs.xslt.rest.TransformRestTest) Time elapsed: 0 sec <<< FAILURE!
java.lang.AssertionError
  at org.junit.Assert.fail(Assert.java:86)
  at org.junit.Assert.assertTrue(Assert.java:41)
  at org.junit.Assert.assertTrue(Assert.java:52)
  at org.geoserver.wfs.xslt.rest.TransformRestTest.prepare(TransformRestTest.java:48)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
  at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:24)
Results :
Failed tests: testListHTML(org.geoserver.wfs.xslt.rest.TransformRestTest)
Tests run: 29, Failures: 1, Errors: 0, Skipped: 0
[JENKINS] Recording test results
[JENKINS] Archiving disabled
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-xslt/2417/&gt;
