[Geoserver-devel] Build failed in Jenkins: GeoTools-15-OpenJDK8 #54
See <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/54/changes&gt;
Changes:
[jody.garnett] Adding EntityResolver support to WFS-NG
[jody.garnett] resolve merge conflcits checking against master and 15.x
[...truncated 7217 lines...]
[INFO] Application Schema Resolver ....................... SKIPPED
[INFO] Complex Features Support .......................... SKIPPED
[INFO] Application Schema DataAccess ..................... SKIPPED
[INFO] Sample DataAccess ................................. SKIPPED
[INFO] Brewer module ..................................... SKIPPED
[INFO] Vector grids ...................................... SKIPPED
[INFO] Validation Processor and Framework ................ SKIPPED
[INFO] Web Map Server client ............................. SKIPPED
[INFO] KML XML Support ................................... SKIPPED
[INFO] WCS XML Support ................................... SKIPPED
[INFO] WPS XML Support ................................... SKIPPED
[INFO] WMS XML Support ................................... SKIPPED
[INFO] CSW XML Support ................................... SKIPPED
[INFO] Geotools unsupported .............................. SKIPPED
[INFO] Process ........................................... SKIPPED
[INFO] Swing widgets ..................................... SKIPPED
[INFO] SWT widgets ....................................... SKIPPED
[INFO] WFS client module ................................. SKIPPED
[INFO] GeoJSON Support ................................... SKIPPED
[INFO] GeoPackage Module ................................. SKIPPED
[INFO] MBTiles Module .................................... SKIPPED
[INFO] WFS client module (NG) ............................ SKIPPED
[INFO] Process Feature ................................... SKIPPED
[INFO] Process Raster .................................... SKIPPED
[INFO] YSLD Parser/Encoder ............................... SKIPPED
[INFO] Coverage tools .................................... SKIPPED
[INFO] ISO 19107 implementation using JTS ................ SKIPPED
[INFO] Geometries ........................................ SKIPPED
[INFO] Web Processing Service ............................ SKIPPED
[INFO] Process Geometry .................................. SKIPPED
[INFO] Application Schema Support (Unsupported Modules) .. SKIPPED
[INFO] SOLR module ....................................... SKIPPED
[INFO] Geobuf DataStore .................................. SKIPPED
[INFO] Cartographic CSS parser ........................... SKIPPED
[INFO] GeoJSON Datastore ................................. SKIPPED
[INFO] CSVDataStore ...................................... SKIPPED
[INFO] EPSG Authority Factory for Oracle ................. SKIPPED
[INFO] Next Generation JDBC DataStores ................... SKIPPED
[INFO] VPF Plugin ........................................ SKIPPED
[INFO] SAS Matlab grid coverage readers .................. SKIPPED
[INFO] Simple Feature Service store ...................... SKIPPED
[INFO] Aggregating DataStore ............................. SKIPPED
[INFO] MongoDB DataStore ................................. SKIPPED
[INFO] GeoTools Documentation ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 4:22.559s
[INFO] Finished at: Wed Sep 28 02:51:16 CEST 2016
[INFO] Final Memory: 258M/472M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.15:test (default-test) on project gt-render: There are test failures.
[ERROR]
[ERROR] Please refer to <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/render/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gt-render
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/jdbc/jdbc-mysql/pom.xml&gt; to org.geotools.jdbc/gt-jdbc-mysql/15-SNAPSHOT/gt-jdbc-mysql-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/wps/pom.xml&gt; to org.geotools/gt-wps/15-SNAPSHOT/gt-wps-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/opengis/pom.xml&gt; to org.geotools/gt-opengis/15-SNAPSHOT/gt-opengis-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/opengis/target/gt-opengis-15-SNAPSHOT.jar&gt; to org.geotools/gt-opengis/15-SNAPSHOT/gt-opengis-15-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/opengis/target/gt-opengis-15-SNAPSHOT-sources.jar&gt; to org.geotools/gt-opengis/15-SNAPSHOT/gt-opengis-15-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/validation/pom.xml&gt; to org.geotools/gt-validation/15-SNAPSHOT/gt-validation-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/app-schema/app-schema-resolver/pom.xml&gt; to org.geotools/gt-app-schema-resolver/15-SNAPSHOT/gt-app-schema-resolver-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/epsg-oracle/pom.xml&gt; to org.geotools/gt-epsg-oracle/15-SNAPSHOT/gt-epsg-oracle-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/epsg-extension/pom.xml&gt; to org.geotools/gt-epsg-extension/15-SNAPSHOT/gt-epsg-extension-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/grid/pom.xml&gt; to org.geotools/gt-grid/15-SNAPSHOT/gt-grid-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/coverage-multidim/grib/pom.xml&gt; to org.geotools/gt-grib/15-SNAPSHOT/gt-grib-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/xsd/xsd-csw/pom.xml&gt; to org.geotools.xsd/gt-xsd-csw/15-SNAPSHOT/gt-xsd-csw-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/ogc/net.opengis.ows/pom.xml&gt; to org.geotools.ogc/net.opengis.ows/15-SNAPSHOT/net.opengis.ows-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/transform/pom.xml&gt; to org.geotools/gt-transform/15-SNAPSHOT/gt-transform-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/swing/pom.xml&gt; to org.geotools/gt-swing/15-SNAPSHOT/gt-swing-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/pom.xml&gt; to org.geotools/unsupported/15-SNAPSHOT/unsupported-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/ogc/net.opengis.wfs/pom.xml&gt; to org.geotools.ogc/net.opengis.wfs/15-SNAPSHOT/net.opengis.wfs-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/referencing3D/pom.xml&gt; to org.geotools/gt-referencing3D/15-SNAPSHOT/gt-referencing3D-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/ogc/pom.xml&gt; to org.geotools/ogc/15-SNAPSHOT/ogc-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/render/pom.xml&gt; to org.geotools/gt-render/15-SNAPSHOT/gt-render-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/jdbc/jdbc-postgis/pom.xml&gt; to org.geotools.jdbc/gt-jdbc-postgis/15-SNAPSHOT/gt-jdbc-postgis-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/complex/pom.xml&gt; to org.geotools/gt-complex/15-SNAPSHOT/gt-complex-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/xsd/xsd-ows/pom.xml&gt; to org.geotools.xsd/gt-xsd-ows/15-SNAPSHOT/gt-xsd-ows-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/arcgrid/pom.xml&gt; to org.geotools/gt-arcgrid/15-SNAPSHOT/gt-arcgrid-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/arcgrid/target/gt-arcgrid-15-SNAPSHOT.jar&gt; to org.geotools/gt-arcgrid/15-SNAPSHOT/gt-arcgrid-15-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/arcgrid/target/gt-arcgrid-15-SNAPSHOT-sources.jar&gt; to org.geotools/gt-arcgrid/15-SNAPSHOT/gt-arcgrid-15-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/graph/pom.xml&gt; to org.geotools/gt-graph/15-SNAPSHOT/gt-graph-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/graph/target/gt-graph-15-SNAPSHOT.jar&gt; to org.geotools/gt-graph/15-SNAPSHOT/gt-graph-15-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/graph/target/gt-graph-15-SNAPSHOT-sources.jar&gt; to org.geotools/gt-graph/15-SNAPSHOT/gt-graph-15-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/process-feature/pom.xml&gt; to org.geotools/gt-process-feature/15-SNAPSHOT/gt-process-feature-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/process-geometry/pom.xml&gt; to org.geotools/gt-process-geometry/15-SNAPSHOT/gt-process-geometry-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/wfs/pom.xml&gt; to org.geotools/gt-wfs/15-SNAPSHOT/gt-wfs-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/ogc/net.opengis.wcs/pom.xml&gt; to org.geotools.ogc/net.opengis.wcs/15-SNAPSHOT/net.opengis.wcs-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/property/pom.xml&gt; to org.geotools/gt-property/15-SNAPSHOT/gt-property-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/property/target/gt-property-15-SNAPSHOT.jar&gt; to org.geotools/gt-property/15-SNAPSHOT/gt-property-15-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/property/target/gt-property-15-SNAPSHOT-sources.jar&gt; to org.geotools/gt-property/15-SNAPSHOT/gt-property-15-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/jdbc/jdbc-db2/pom.xml&gt; to org.geotools.jdbc/gt-jdbc-db2/15-SNAPSHOT/gt-jdbc-db2-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/csv/pom.xml&gt; to org.geotools/gt-csv/15-SNAPSHOT/gt-csv-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/xsd/xsd-fes/pom.xml&gt; to org.geotools.xsd/gt-xsd-fes/15-SNAPSHOT/gt-xsd-fes-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/jdbc/jdbc-spatialite/pom.xml&gt; to org.geotools.jdbc/gt-jdbc-spatialite/15-SNAPSHOT/gt-jdbc-spatialite-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/app-schema/pom.xml&gt; to org.geotools/app-schema/15-SNAPSHOT/app-schema-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/imagemosaic-jdbc/pom.xml&gt; to org.geotools/gt-imagemosaic-jdbc/15-SNAPSHOT/gt-imagemosaic-jdbc-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/xsd/xsd-wcs/pom.xml&gt; to org.geotools.xsd/gt-xsd-wcs/15-SNAPSHOT/gt-xsd-wcs-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/imagepyramid/pom.xml&gt; to org.geotools/gt-imagepyramid/15-SNAPSHOT/gt-imagepyramid-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/css/pom.xml&gt; to org.geotools/gt-css/15-SNAPSHOT/gt-css-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/jdbc/jdbc-teradata/pom.xml&gt; to org.geotools.jdbc/gt-jdbc-teradata/15-SNAPSHOT/gt-jdbc-teradata-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/ogr/ogr-jni/pom.xml&gt; to org.geotools/gt-ogr-jni/15-SNAPSHOT/gt-ogr-jni-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/wfs-ng/pom.xml&gt; to org.geotools/gt-wfs-ng/15-SNAPSHOT/gt-wfs-ng-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/epsg-hsql/pom.xml&gt; to org.geotools/gt-epsg-hsql/15-SNAPSHOT/gt-epsg-hsql-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/epsg-hsql/target/gt-epsg-hsql-15-SNAPSHOT.jar&gt; to org.geotools/gt-epsg-hsql/15-SNAPSHOT/gt-epsg-hsql-15-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/epsg-hsql/target/gt-epsg-hsql-15-SNAPSHOT-sources.jar&gt; to org.geotools/gt-epsg-hsql/15-SNAPSHOT/gt-epsg-hsql-15-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/arcsde/common/pom.xml&gt; to org.geotools/gt-arcsde-common/15-SNAPSHOT/gt-arcsde-common-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/build/pom.xml&gt; to org.geotools.maven/build/15-SNAPSHOT/build-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/xml/pom.xml&gt; to org.geotools/gt-xml/15-SNAPSHOT/gt-xml-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/ogr/ogr-bridj/pom.xml&gt; to org.geotools/gt-ogr-bridj/15-SNAPSHOT/gt-ogr-bridj-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/docs/pom.xml&gt; to org.geotools/docs/15-SNAPSHOT/docs-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/process/pom.xml&gt; to org.geotools/gt-process/15-SNAPSHOT/gt-process-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/geotiff/pom.xml&gt; to org.geotools/gt-geotiff/15-SNAPSHOT/gt-geotiff-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/geotiff/target/gt-geotiff-15-SNAPSHOT.jar&gt; to org.geotools/gt-geotiff/15-SNAPSHOT/gt-geotiff-15-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/geotiff/target/gt-geotiff-15-SNAPSHOT-sources.jar&gt; to org.geotools/gt-geotiff/15-SNAPSHOT/gt-geotiff-15-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/ogc/net.opengis.csw/pom.xml&gt; to org.geotools.ogc/net.opengis.csw/15-SNAPSHOT/net.opengis.csw-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/wms/pom.xml&gt; to org.geotools/gt-wms/15-SNAPSHOT/gt-wms-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/feature-aggregate/pom.xml&gt; to org.geotools.unsupported/gt-feature-aggregate/15-SNAPSHOT/gt-feature-aggregate-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/jdbc/jdbc-sqlserver/pom.xml&gt; to org.geotools.jdbc/gt-jdbc-sqlserver/15-SNAPSHOT/gt-jdbc-sqlserver-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/epsg-postgresql/pom.xml&gt; to org.geotools/gt-epsg-postgresql/15-SNAPSHOT/gt-epsg-postgresql-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/charts/pom.xml&gt; to org.geotools/gt-charts/15-SNAPSHOT/gt-charts-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/jdbc-ng/pom.xml&gt; to org.geotools/gt-jdbc-ng/15-SNAPSHOT/gt-jdbc-ng-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/referencing/pom.xml&gt; to org.geotools/gt-referencing/15-SNAPSHOT/gt-referencing-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/referencing/target/gt-referencing-15-SNAPSHOT.jar&gt; to org.geotools/gt-referencing/15-SNAPSHOT/gt-referencing-15-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/referencing/target/gt-referencing-15-SNAPSHOT-tests.jar&gt; to org.geotools/gt-referencing/15-SNAPSHOT/gt-referencing-15-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/referencing/target/gt-referencing-15-SNAPSHOT-sources.jar&gt; to org.geotools/gt-referencing/15-SNAPSHOT/gt-referencing-15-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/geobuf/pom.xml&gt; to org.geotools/gt-geobuf/15-SNAPSHOT/gt-geobuf-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/ogc/net.opengis.wps/pom.xml&gt; to org.geotools.ogc/net.opengis.wps/15-SNAPSHOT/net.opengis.wps-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/matfile5/pom.xml&gt; to org.geotools/gt-matfile5/15-SNAPSHOT/gt-matfile5-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/jdbc/jdbc-h2/pom.xml&gt; to org.geotools.jdbc/gt-jdbc-h2/15-SNAPSHOT/gt-jdbc-h2-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/coverage-multidim/pom.xml&gt; to org.geotools/gt-coverage-multidim/15-SNAPSHOT/gt-coverage-multidim-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/xsd/xsd-filter/pom.xml&gt; to org.geotools.xsd/gt-xsd-filter/15-SNAPSHOT/gt-xsd-filter-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/xsd/xsd-filter/target/gt-xsd-filter-15-SNAPSHOT.jar&gt; to org.geotools.xsd/gt-xsd-filter/15-SNAPSHOT/gt-xsd-filter-15-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/xsd/xsd-filter/target/gt-xsd-filter-15-SNAPSHOT-tests.jar&gt; to org.geotools.xsd/gt-xsd-filter/15-SNAPSHOT/gt-xsd-filter-15-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/xsd/xsd-filter/target/gt-xsd-filter-15-SNAPSHOT-sources.jar&gt; to org.geotools.xsd/gt-xsd-filter/15-SNAPSHOT/gt-xsd-filter-15-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/arcsde/sde-dummy/pom.xml&gt; to org.geotools/gt-sde-dummy/15-SNAPSHOT/gt-sde-dummy-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/mbtiles/pom.xml&gt; to org.geotools/gt-mbtiles/15-SNAPSHOT/gt-mbtiles-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/arcsde/datastore/pom.xml&gt; to org.geotools/gt-arcsde/15-SNAPSHOT/gt-arcsde-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/feature-pregeneralized/pom.xml&gt; to org.geotools/gt-feature-pregeneralized/15-SNAPSHOT/gt-feature-pregeneralized-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/jp2k/pom.xml&gt; to org.geotools/gt-jp2k/15-SNAPSHOT/gt-jp2k-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/xsd/xsd-wms/pom.xml&gt; to org.geotools.xsd/gt-xsd-wms/15-SNAPSHOT/gt-xsd-wms-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/app-schema/pom.xml&gt; to org.geotools/app-schema-unsupported/15-SNAPSHOT/app-schema-unsupported-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/arcsde/pom.xml&gt; to org.geotools/arcsde-plugin/15-SNAPSHOT/arcsde-plugin-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/ogc/net.opengis.fes/pom.xml&gt; to org.geotools.ogc/net.opengis.fes/15-SNAPSHOT/net.opengis.fes-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/xsd/xsd-kml/pom.xml&gt; to org.geotools.xsd/gt-xsd-kml/15-SNAPSHOT/gt-xsd-kml-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/xsd/xsd-sld/pom.xml&gt; to org.geotools.xsd/gt-xsd-sld/15-SNAPSHOT/gt-xsd-sld-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/xsd/xsd-sld/target/gt-xsd-sld-15-SNAPSHOT.jar&gt; to org.geotools.xsd/gt-xsd-sld/15-SNAPSHOT/gt-xsd-sld-15-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/xsd/xsd-sld/target/gt-xsd-sld-15-SNAPSHOT-sources.jar&gt; to org.geotools.xsd/gt-xsd-sld/15-SNAPSHOT/gt-xsd-sld-15-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/swt/pom.xml&gt; to org.geotools/gt-swt/15-SNAPSHOT/gt-swt-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/data/pom.xml&gt; to org.geotools/gt-data/15-SNAPSHOT/gt-data-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/data/target/gt-data-15-SNAPSHOT.jar&gt; to org.geotools/gt-data/15-SNAPSHOT/gt-data-15-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/data/target/gt-data-15-SNAPSHOT-sources.jar&gt; to org.geotools/gt-data/15-SNAPSHOT/gt-data-15-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/shapefile/pom.xml&gt; to org.geotools/gt-shapefile/15-SNAPSHOT/gt-shapefile-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/shapefile/target/gt-shapefile-15-SNAPSHOT.jar&gt; to org.geotools/gt-shapefile/15-SNAPSHOT/gt-shapefile-15-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/shapefile/target/gt-shapefile-15-SNAPSHOT-sources.jar&gt; to org.geotools/gt-shapefile/15-SNAPSHOT/gt-shapefile-15-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/pom.xml&gt; to org.geotools/modules/15-SNAPSHOT/modules-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/build/maven/jjtree-javacc/pom.xml&gt; to org.geotools.maven/jjtree-javacc/15-SNAPSHOT/jjtree-javacc-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/build/maven/jjtree-javacc/target/jjtree-javacc-15-SNAPSHOT.jar&gt; to org.geotools.maven/jjtree-javacc/15-SNAPSHOT/jjtree-javacc-15-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/build/maven/jjtree-javacc/target/jjtree-javacc-15-SNAPSHOT-sources.jar&gt; to org.geotools.maven/jjtree-javacc/15-SNAPSHOT/jjtree-javacc-15-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/geopkg/pom.xml&gt; to org.geotools/gt-geopkg/15-SNAPSHOT/gt-geopkg-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/cql/pom.xml&gt; to org.geotools/gt-cql/15-SNAPSHOT/gt-cql-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/cql/target/gt-cql-15-SNAPSHOT.jar&gt; to org.geotools/gt-cql/15-SNAPSHOT/gt-cql-15-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/cql/target/gt-cql-15-SNAPSHOT-sources.jar&gt; to org.geotools/gt-cql/15-SNAPSHOT/gt-cql-15-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/build/maven/javadoc/pom.xml&gt; to org.geotools.maven/javadoc/15-SNAPSHOT/javadoc-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/build/maven/javadoc/target/javadoc-15-SNAPSHOT.jar&gt; to org.geotools.maven/javadoc/15-SNAPSHOT/javadoc-15-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/build/maven/javadoc/target/javadoc-15-SNAPSHOT-sources.jar&gt; to org.geotools.maven/javadoc/15-SNAPSHOT/javadoc-15-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/jts-wrapper/pom.xml&gt; to org.geotools/gt-jts-wrapper/15-SNAPSHOT/gt-jts-wrapper-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/process-raster/pom.xml&gt; to org.geotools/gt-process-raster/15-SNAPSHOT/gt-process-raster-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/coveragetools/pom.xml&gt; to org.geotools/gt-coveragetools/15-SNAPSHOT/gt-coveragetools-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/api/pom.xml&gt; to org.geotools/gt-api/15-SNAPSHOT/gt-api-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/api/target/gt-api-15-SNAPSHOT.jar&gt; to org.geotools/gt-api/15-SNAPSHOT/gt-api-15-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/api/target/gt-api-15-SNAPSHOT-sources.jar&gt; to org.geotools/gt-api/15-SNAPSHOT/gt-api-15-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/app-schema/app-schema/pom.xml&gt; to org.geotools/gt-app-schema/15-SNAPSHOT/gt-app-schema-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/mongodb/pom.xml&gt; to org.geotools/gt-mongodb/15-SNAPSHOT/gt-mongodb-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/sfs/pom.xml&gt; to org.geotools/gt-sfs/15-SNAPSHOT/gt-sfs-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/ogc/org.w3.xlink/pom.xml&gt; to org.geotools.ogc/org.w3.xlink/15-SNAPSHOT/org.w3.xlink-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/coverage-multidim/netcdf/pom.xml&gt; to org.geotools/gt-netcdf/15-SNAPSHOT/gt-netcdf-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/build/maven/xmlcodegen/pom.xml&gt; to org.geotools.maven/xmlcodegen/15-SNAPSHOT/xmlcodegen-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/build/maven/xmlcodegen/target/xmlcodegen-15-SNAPSHOT.jar&gt; to org.geotools.maven/xmlcodegen/15-SNAPSHOT/xmlcodegen-15-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/build/maven/xmlcodegen/target/xmlcodegen-15-SNAPSHOT-sources.jar&gt; to org.geotools.maven/xmlcodegen/15-SNAPSHOT/xmlcodegen-15-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/epsg-wkt/pom.xml&gt; to org.geotools/gt-epsg-wkt/15-SNAPSHOT/gt-epsg-wkt-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/epsg-wkt/target/gt-epsg-wkt-15-SNAPSHOT.jar&gt; to org.geotools/gt-epsg-wkt/15-SNAPSHOT/gt-epsg-wkt-15-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/epsg-wkt/target/gt-epsg-wkt-15-SNAPSHOT-sources.jar&gt; to org.geotools/gt-epsg-wkt/15-SNAPSHOT/gt-epsg-wkt-15-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/jdbc/pom.xml&gt; to org.geotools/gt-jdbc/15-SNAPSHOT/gt-jdbc-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/imagemosaic/pom.xml&gt; to org.geotools/gt-imagemosaic/15-SNAPSHOT/gt-imagemosaic-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/svg/pom.xml&gt; to org.geotools/gt-svg/15-SNAPSHOT/gt-svg-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/geojson/pom.xml&gt; to org.geotools/gt-geojson/15-SNAPSHOT/gt-geojson-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/xsd/pom.xml&gt; to org.geotools.xsd/xsd/15-SNAPSHOT/xsd-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/vpf/pom.xml&gt; to org.geotools/gt-vpf/15-SNAPSHOT/gt-vpf-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/xsd/xsd-wfs/pom.xml&gt; to org.geotools.xsd/gt-xsd-wfs/15-SNAPSHOT/gt-xsd-wfs-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/sample-data/pom.xml&gt; to org.geotools/gt-sample-data/15-SNAPSHOT/gt-sample-data-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/sample-data/target/gt-sample-data-15-SNAPSHOT.jar&gt; to org.geotools/gt-sample-data/15-SNAPSHOT/gt-sample-data-15-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/sample-data/target/gt-sample-data-15-SNAPSHOT-sources.jar&gt; to org.geotools/gt-sample-data/15-SNAPSHOT/gt-sample-data-15-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/jdbc/jdbc-oracle/pom.xml&gt; to org.geotools.jdbc/gt-jdbc-oracle/15-SNAPSHOT/gt-jdbc-oracle-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/grassraster/pom.xml&gt; to org.geotools/gt-grassraster/15-SNAPSHOT/gt-grassraster-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/build/maven/pom.xml&gt; to org.geotools.maven/maven/15-SNAPSHOT/maven-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/xsd/xsd-core/pom.xml&gt; to org.geotools.xsd/gt-xsd-core/15-SNAPSHOT/gt-xsd-core-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/xsd/xsd-core/target/gt-xsd-core-15-SNAPSHOT.jar&gt; to org.geotools.xsd/gt-xsd-core/15-SNAPSHOT/gt-xsd-core-15-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/xsd/xsd-core/target/gt-xsd-core-15-SNAPSHOT-sources.jar&gt; to org.geotools.xsd/gt-xsd-core/15-SNAPSHOT/gt-xsd-core-15-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/coverage-multidim/coverage-api/pom.xml&gt; to org.geotools/gt-coverage-api/15-SNAPSHOT/gt-coverage-api-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/ogr/pom.xml&gt; to org.geotools/gt-ogr/15-SNAPSHOT/gt-ogr-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/geojsonstore/pom.xml&gt; to org.geotools/gt-geojsondatastore/15-SNAPSHOT/gt-geojsondatastore-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/ogr/ogr-core/pom.xml&gt; to org.geotools/gt-ogr-core/15-SNAPSHOT/gt-ogr-core-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/geometry/pom.xml&gt; to org.geotools/gt-geometry/15-SNAPSHOT/gt-geometry-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/jdbc/pom.xml&gt; to org.geotools.jdbc/gt-jdbc/15-SNAPSHOT/gt-jdbc-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/pom.xml&gt; to org.geotools/extension/15-SNAPSHOT/extension-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/app-schema/sample-data-access/pom.xml&gt; to org.geotools/gt-sample-data-access/15-SNAPSHOT/gt-sample-data-access-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/ysld/pom.xml&gt; to org.geotools/gt-ysld/15-SNAPSHOT/gt-ysld-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/gtopo30/pom.xml&gt; to org.geotools/gt-gtopo30/15-SNAPSHOT/gt-gtopo30-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/coverage/pom.xml&gt; to org.geotools/gt-coverage/15-SNAPSHOT/gt-coverage-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/coverage/target/gt-coverage-15-SNAPSHOT.jar&gt; to org.geotools/gt-coverage/15-SNAPSHOT/gt-coverage-15-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/coverage/target/gt-coverage-15-SNAPSHOT-sources.jar&gt; to org.geotools/gt-coverage/15-SNAPSHOT/gt-coverage-15-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/pom.xml&gt; to org.geotools/geotools/15-SNAPSHOT/geotools-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/brewer/pom.xml&gt; to org.geotools/gt-brewer/15-SNAPSHOT/gt-brewer-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/image/pom.xml&gt; to org.geotools/gt-image/15-SNAPSHOT/gt-image-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/image/target/gt-image-15-SNAPSHOT.jar&gt; to org.geotools/gt-image/15-SNAPSHOT/gt-image-15-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/image/target/gt-image-15-SNAPSHOT-sources.jar&gt; to org.geotools/gt-image/15-SNAPSHOT/gt-image-15-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/build/maven/jar-collector/pom.xml&gt; to org.geotools.maven/jar-collector/15-SNAPSHOT/jar-collector-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/build/maven/jar-collector/target/jar-collector-15-SNAPSHOT.jar&gt; to org.geotools.maven/jar-collector/15-SNAPSHOT/jar-collector-15-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/build/maven/jar-collector/target/jar-collector-15-SNAPSHOT-sources.jar&gt; to org.geotools.maven/jar-collector/15-SNAPSHOT/jar-collector-15-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/imageio-ext-gdal/pom.xml&gt; to org.geotools/gt-imageio-ext-gdal/15-SNAPSHOT/gt-imageio-ext-gdal-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/unsupported/solr/pom.xml&gt; to org.geotools/gt-solr/15-SNAPSHOT/gt-solr-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/metadata/pom.xml&gt; to org.geotools/gt-metadata/15-SNAPSHOT/gt-metadata-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/metadata/target/gt-metadata-15-SNAPSHOT.jar&gt; to org.geotools/gt-metadata/15-SNAPSHOT/gt-metadata-15-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/metadata/target/gt-metadata-15-SNAPSHOT-sources.jar&gt; to org.geotools/gt-metadata/15-SNAPSHOT/gt-metadata-15-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/main/pom.xml&gt; to org.geotools/gt-main/15-SNAPSHOT/gt-main-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/main/target/gt-main-15-SNAPSHOT.jar&gt; to org.geotools/gt-main/15-SNAPSHOT/gt-main-15-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/main/target/gt-main-15-SNAPSHOT-tests.jar&gt; to org.geotools/gt-main/15-SNAPSHOT/gt-main-15-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/main/target/gt-main-15-SNAPSHOT-sources.jar&gt; to org.geotools/gt-main/15-SNAPSHOT/gt-main-15-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/xsd/xsd-gml2/pom.xml&gt; to org.geotools.xsd/gt-xsd-gml2/15-SNAPSHOT/gt-xsd-gml2-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/xsd/xsd-gml2/target/gt-xsd-gml2-15-SNAPSHOT.jar&gt; to org.geotools.xsd/gt-xsd-gml2/15-SNAPSHOT/gt-xsd-gml2-15-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/xsd/xsd-gml2/target/gt-xsd-gml2-15-SNAPSHOT-sources.jar&gt; to org.geotools.xsd/gt-xsd-gml2/15-SNAPSHOT/gt-xsd-gml2-15-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/library/pom.xml&gt; to org.geotools/library/15-SNAPSHOT/library-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/xsd/xsd-gml3/pom.xml&gt; to org.geotools.xsd/gt-xsd-gml3/15-SNAPSHOT/gt-xsd-gml3-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/xsd/xsd-gml3/target/gt-xsd-gml3-15-SNAPSHOT.jar&gt; to org.geotools.xsd/gt-xsd-gml3/15-SNAPSHOT/gt-xsd-gml3-15-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/xsd/xsd-gml3/target/gt-xsd-gml3-15-SNAPSHOT-sources.jar&gt; to org.geotools.xsd/gt-xsd-gml3/15-SNAPSHOT/gt-xsd-gml3-15-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/extension/xsd/xsd-wps/pom.xml&gt; to org.geotools.xsd/gt-xsd-wps/15-SNAPSHOT/gt-xsd-wps-15-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/ws/modules/plugin/pom.xml&gt; to org.geotools/plugin/15-SNAPSHOT/plugin-15-SNAPSHOT.pom
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoTools-15-OpenJDK8/55/&gt;
