[Geoserver-devel] Build failed in Jenkins: GeoTools-Master-OpenJDK8 #306
See <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/306/changes&gt;
Changes:
[Andrea Aime] [GEOT-5600] Follow up enabling the previous interpretation of repeat
[...truncated 7163 lines...]
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Application Schema Resolver ....................... SKIPPED
[INFO] Complex Features Support .......................... SKIPPED
[INFO] Application Schema DataAccess ..................... SKIPPED
[INFO] Sample DataAccess ................................. SKIPPED
[INFO] Brewer module ..................................... SKIPPED
[INFO] Vector grids ...................................... SKIPPED
[INFO] Validation Processor and Framework ................ SKIPPED
[INFO] Web Map Server client ............................. SKIPPED
[INFO] KML XML Support ................................... SKIPPED
[INFO] WCS XML Support ................................... SKIPPED
[INFO] WPS XML Support ................................... SKIPPED
[INFO] WMS XML Support ................................... SKIPPED
[INFO] CSW XML Support ................................... SKIPPED
[INFO] Geotools unsupported .............................. SKIPPED
[INFO] Process ........................................... SKIPPED
[INFO] Swing widgets ..................................... SKIPPED
[INFO] SWT widgets ....................................... SKIPPED
[INFO] WFS client module ................................. SKIPPED
[INFO] GeoJSON Support ................................... SKIPPED
[INFO] MBTiles Module .................................... SKIPPED
[INFO] WFS client module (NG) ............................ SKIPPED
[INFO] Process Feature ................................... SKIPPED
[INFO] Process Raster .................................... SKIPPED
[INFO] YSLD Parser/Encoder ............................... SKIPPED
[INFO] polylabel ......................................... SKIPPED
[INFO] ISO 19107 implementation using JTS ................ SKIPPED
[INFO] Geometries ........................................ SKIPPED
[INFO] Web Processing Service ............................ SKIPPED
[INFO] Process Geometry .................................. SKIPPED
[INFO] Application Schema Support (Unsupported Modules) .. SKIPPED
[INFO] SOLR module ....................................... SKIPPED
[INFO] Geobuf DataStore .................................. SKIPPED
[INFO] Cartographic CSS parser ........................... SKIPPED
[INFO] GeoJSON Datastore ................................. SKIPPED
[INFO] CSVDataStore ...................................... SKIPPED
[INFO] EPSG Authority Factory for Oracle ................. SKIPPED
[INFO] Next Generation JDBC DataStores ................... SKIPPED
[INFO] VPF Plugin ........................................ SKIPPED
[INFO] SAS Matlab grid coverage readers .................. SKIPPED
[INFO] Simple Feature Service store ...................... SKIPPED
[INFO] Aggregating DataStore ............................. SKIPPED
[INFO] MongoDB DataStore ................................. SKIPPED
[INFO] GeoTools Documentation ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 4:32.275s
[INFO] Finished at: Sun Dec 18 16:08:41 CET 2016
[INFO] Final Memory: 446M/1329M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.15:test (default-test) on project gt-render: There are test failures.
[ERROR]
[ERROR] Please refer to <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/render/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gt-render
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/jdbc/jdbc-mysql/pom.xml&gt; to org.geotools.jdbc/gt-jdbc-mysql/17-SNAPSHOT/gt-jdbc-mysql-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/wps/pom.xml&gt; to org.geotools/gt-wps/17-SNAPSHOT/gt-wps-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/opengis/pom.xml&gt; to org.geotools/gt-opengis/17-SNAPSHOT/gt-opengis-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/opengis/target/gt-opengis-17-SNAPSHOT.jar&gt; to org.geotools/gt-opengis/17-SNAPSHOT/gt-opengis-17-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/opengis/target/gt-opengis-17-SNAPSHOT-sources.jar&gt; to org.geotools/gt-opengis/17-SNAPSHOT/gt-opengis-17-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/validation/pom.xml&gt; to org.geotools/gt-validation/17-SNAPSHOT/gt-validation-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/app-schema/app-schema-resolver/pom.xml&gt; to org.geotools/gt-app-schema-resolver/17-SNAPSHOT/gt-app-schema-resolver-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/epsg-oracle/pom.xml&gt; to org.geotools/gt-epsg-oracle/17-SNAPSHOT/gt-epsg-oracle-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/epsg-extension/pom.xml&gt; to org.geotools/gt-epsg-extension/17-SNAPSHOT/gt-epsg-extension-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/grid/pom.xml&gt; to org.geotools/gt-grid/17-SNAPSHOT/gt-grid-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/coverage-multidim/grib/pom.xml&gt; to org.geotools/gt-grib/17-SNAPSHOT/gt-grib-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-csw/pom.xml&gt; to org.geotools.xsd/gt-xsd-csw/17-SNAPSHOT/gt-xsd-csw-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/ogc/net.opengis.ows/pom.xml&gt; to org.geotools.ogc/net.opengis.ows/17-SNAPSHOT/net.opengis.ows-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/transform/pom.xml&gt; to org.geotools/gt-transform/17-SNAPSHOT/gt-transform-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/swing/pom.xml&gt; to org.geotools/gt-swing/17-SNAPSHOT/gt-swing-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/pom.xml&gt; to org.geotools/unsupported/17-SNAPSHOT/unsupported-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/ogc/net.opengis.wfs/pom.xml&gt; to org.geotools.ogc/net.opengis.wfs/17-SNAPSHOT/net.opengis.wfs-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/referencing3D/pom.xml&gt; to org.geotools/gt-referencing3D/17-SNAPSHOT/gt-referencing3D-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/ogc/pom.xml&gt; to org.geotools/ogc/17-SNAPSHOT/ogc-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/render/pom.xml&gt; to org.geotools/gt-render/17-SNAPSHOT/gt-render-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/jdbc/jdbc-postgis/pom.xml&gt; to org.geotools.jdbc/gt-jdbc-postgis/17-SNAPSHOT/gt-jdbc-postgis-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/complex/pom.xml&gt; to org.geotools/gt-complex/17-SNAPSHOT/gt-complex-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-ows/pom.xml&gt; to org.geotools.xsd/gt-xsd-ows/17-SNAPSHOT/gt-xsd-ows-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/arcgrid/pom.xml&gt; to org.geotools/gt-arcgrid/17-SNAPSHOT/gt-arcgrid-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/arcgrid/target/gt-arcgrid-17-SNAPSHOT.jar&gt; to org.geotools/gt-arcgrid/17-SNAPSHOT/gt-arcgrid-17-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/arcgrid/target/gt-arcgrid-17-SNAPSHOT-sources.jar&gt; to org.geotools/gt-arcgrid/17-SNAPSHOT/gt-arcgrid-17-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/graph/pom.xml&gt; to org.geotools/gt-graph/17-SNAPSHOT/gt-graph-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/graph/target/gt-graph-17-SNAPSHOT.jar&gt; to org.geotools/gt-graph/17-SNAPSHOT/gt-graph-17-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/graph/target/gt-graph-17-SNAPSHOT-sources.jar&gt; to org.geotools/gt-graph/17-SNAPSHOT/gt-graph-17-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/process-feature/pom.xml&gt; to org.geotools/gt-process-feature/17-SNAPSHOT/gt-process-feature-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/process-geometry/pom.xml&gt; to org.geotools/gt-process-geometry/17-SNAPSHOT/gt-process-geometry-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/wfs/pom.xml&gt; to org.geotools/gt-wfs/17-SNAPSHOT/gt-wfs-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/ogc/net.opengis.wcs/pom.xml&gt; to org.geotools.ogc/net.opengis.wcs/17-SNAPSHOT/net.opengis.wcs-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/property/pom.xml&gt; to org.geotools/gt-property/17-SNAPSHOT/gt-property-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/property/target/gt-property-17-SNAPSHOT.jar&gt; to org.geotools/gt-property/17-SNAPSHOT/gt-property-17-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/property/target/gt-property-17-SNAPSHOT-sources.jar&gt; to org.geotools/gt-property/17-SNAPSHOT/gt-property-17-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/jdbc/jdbc-db2/pom.xml&gt; to org.geotools.jdbc/gt-jdbc-db2/17-SNAPSHOT/gt-jdbc-db2-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/csv/pom.xml&gt; to org.geotools/gt-csv/17-SNAPSHOT/gt-csv-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-fes/pom.xml&gt; to org.geotools.xsd/gt-xsd-fes/17-SNAPSHOT/gt-xsd-fes-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/jdbc/jdbc-spatialite/pom.xml&gt; to org.geotools.jdbc/gt-jdbc-spatialite/17-SNAPSHOT/gt-jdbc-spatialite-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/app-schema/pom.xml&gt; to org.geotools/app-schema/17-SNAPSHOT/app-schema-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/imagemosaic-jdbc/pom.xml&gt; to org.geotools/gt-imagemosaic-jdbc/17-SNAPSHOT/gt-imagemosaic-jdbc-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-wcs/pom.xml&gt; to org.geotools.xsd/gt-xsd-wcs/17-SNAPSHOT/gt-xsd-wcs-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/imagepyramid/pom.xml&gt; to org.geotools/gt-imagepyramid/17-SNAPSHOT/gt-imagepyramid-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/css/pom.xml&gt; to org.geotools/gt-css/17-SNAPSHOT/gt-css-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/jdbc/jdbc-teradata/pom.xml&gt; to org.geotools.jdbc/gt-jdbc-teradata/17-SNAPSHOT/gt-jdbc-teradata-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/ogr/ogr-jni/pom.xml&gt; to org.geotools/gt-ogr-jni/17-SNAPSHOT/gt-ogr-jni-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/wfs-ng/pom.xml&gt; to org.geotools/gt-wfs-ng/17-SNAPSHOT/gt-wfs-ng-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/epsg-hsql/pom.xml&gt; to org.geotools/gt-epsg-hsql/17-SNAPSHOT/gt-epsg-hsql-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/epsg-hsql/target/gt-epsg-hsql-17-SNAPSHOT.jar&gt; to org.geotools/gt-epsg-hsql/17-SNAPSHOT/gt-epsg-hsql-17-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/epsg-hsql/target/gt-epsg-hsql-17-SNAPSHOT-sources.jar&gt; to org.geotools/gt-epsg-hsql/17-SNAPSHOT/gt-epsg-hsql-17-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/arcsde/common/pom.xml&gt; to org.geotools/gt-arcsde-common/17-SNAPSHOT/gt-arcsde-common-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/build/pom.xml&gt; to org.geotools.maven/build/17-SNAPSHOT/build-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/xml/pom.xml&gt; to org.geotools/gt-xml/17-SNAPSHOT/gt-xml-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/ogr/ogr-bridj/pom.xml&gt; to org.geotools/gt-ogr-bridj/17-SNAPSHOT/gt-ogr-bridj-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/docs/pom.xml&gt; to org.geotools/docs/17-SNAPSHOT/docs-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/process/pom.xml&gt; to org.geotools/gt-process/17-SNAPSHOT/gt-process-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/geotiff/pom.xml&gt; to org.geotools/gt-geotiff/17-SNAPSHOT/gt-geotiff-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/geotiff/target/gt-geotiff-17-SNAPSHOT.jar&gt; to org.geotools/gt-geotiff/17-SNAPSHOT/gt-geotiff-17-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/geotiff/target/gt-geotiff-17-SNAPSHOT-sources.jar&gt; to org.geotools/gt-geotiff/17-SNAPSHOT/gt-geotiff-17-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/ogc/net.opengis.csw/pom.xml&gt; to org.geotools.ogc/net.opengis.csw/17-SNAPSHOT/net.opengis.csw-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/wms/pom.xml&gt; to org.geotools/gt-wms/17-SNAPSHOT/gt-wms-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/feature-aggregate/pom.xml&gt; to org.geotools.unsupported/gt-feature-aggregate/17-SNAPSHOT/gt-feature-aggregate-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/jdbc/jdbc-sqlserver/pom.xml&gt; to org.geotools.jdbc/gt-jdbc-sqlserver/17-SNAPSHOT/gt-jdbc-sqlserver-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/epsg-postgresql/pom.xml&gt; to org.geotools/gt-epsg-postgresql/17-SNAPSHOT/gt-epsg-postgresql-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/charts/pom.xml&gt; to org.geotools/gt-charts/17-SNAPSHOT/gt-charts-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/jdbc-ng/pom.xml&gt; to org.geotools/gt-jdbc-ng/17-SNAPSHOT/gt-jdbc-ng-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/referencing/pom.xml&gt; to org.geotools/gt-referencing/17-SNAPSHOT/gt-referencing-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/referencing/target/gt-referencing-17-SNAPSHOT.jar&gt; to org.geotools/gt-referencing/17-SNAPSHOT/gt-referencing-17-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/referencing/target/gt-referencing-17-SNAPSHOT-tests.jar&gt; to org.geotools/gt-referencing/17-SNAPSHOT/gt-referencing-17-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/referencing/target/gt-referencing-17-SNAPSHOT-sources.jar&gt; to org.geotools/gt-referencing/17-SNAPSHOT/gt-referencing-17-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/geobuf/pom.xml&gt; to org.geotools/gt-geobuf/17-SNAPSHOT/gt-geobuf-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/ogc/net.opengis.wps/pom.xml&gt; to org.geotools.ogc/net.opengis.wps/17-SNAPSHOT/net.opengis.wps-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/matfile5/pom.xml&gt; to org.geotools/gt-matfile5/17-SNAPSHOT/gt-matfile5-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/jdbc/jdbc-h2/pom.xml&gt; to org.geotools.jdbc/gt-jdbc-h2/17-SNAPSHOT/gt-jdbc-h2-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/coverage-multidim/pom.xml&gt; to org.geotools/gt-coverage-multidim/17-SNAPSHOT/gt-coverage-multidim-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-filter/pom.xml&gt; to org.geotools.xsd/gt-xsd-filter/17-SNAPSHOT/gt-xsd-filter-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-filter/target/gt-xsd-filter-17-SNAPSHOT.jar&gt; to org.geotools.xsd/gt-xsd-filter/17-SNAPSHOT/gt-xsd-filter-17-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-filter/target/gt-xsd-filter-17-SNAPSHOT-tests.jar&gt; to org.geotools.xsd/gt-xsd-filter/17-SNAPSHOT/gt-xsd-filter-17-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-filter/target/gt-xsd-filter-17-SNAPSHOT-sources.jar&gt; to org.geotools.xsd/gt-xsd-filter/17-SNAPSHOT/gt-xsd-filter-17-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/arcsde/sde-dummy/pom.xml&gt; to org.geotools/gt-sde-dummy/17-SNAPSHOT/gt-sde-dummy-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/mbtiles/pom.xml&gt; to org.geotools/gt-mbtiles/17-SNAPSHOT/gt-mbtiles-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/arcsde/datastore/pom.xml&gt; to org.geotools/gt-arcsde/17-SNAPSHOT/gt-arcsde-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/feature-pregeneralized/pom.xml&gt; to org.geotools/gt-feature-pregeneralized/17-SNAPSHOT/gt-feature-pregeneralized-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/jp2k/pom.xml&gt; to org.geotools/gt-jp2k/17-SNAPSHOT/gt-jp2k-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-wms/pom.xml&gt; to org.geotools.xsd/gt-xsd-wms/17-SNAPSHOT/gt-xsd-wms-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/app-schema/pom.xml&gt; to org.geotools/app-schema-unsupported/17-SNAPSHOT/app-schema-unsupported-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/arcsde/pom.xml&gt; to org.geotools/arcsde-plugin/17-SNAPSHOT/arcsde-plugin-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/ogc/net.opengis.fes/pom.xml&gt; to org.geotools.ogc/net.opengis.fes/17-SNAPSHOT/net.opengis.fes-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-kml/pom.xml&gt; to org.geotools.xsd/gt-xsd-kml/17-SNAPSHOT/gt-xsd-kml-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-sld/pom.xml&gt; to org.geotools.xsd/gt-xsd-sld/17-SNAPSHOT/gt-xsd-sld-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-sld/target/gt-xsd-sld-17-SNAPSHOT.jar&gt; to org.geotools.xsd/gt-xsd-sld/17-SNAPSHOT/gt-xsd-sld-17-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-sld/target/gt-xsd-sld-17-SNAPSHOT-sources.jar&gt; to org.geotools.xsd/gt-xsd-sld/17-SNAPSHOT/gt-xsd-sld-17-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/swt/pom.xml&gt; to org.geotools/gt-swt/17-SNAPSHOT/gt-swt-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/data/pom.xml&gt; to org.geotools/gt-data/17-SNAPSHOT/gt-data-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/data/target/gt-data-17-SNAPSHOT.jar&gt; to org.geotools/gt-data/17-SNAPSHOT/gt-data-17-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/data/target/gt-data-17-SNAPSHOT-sources.jar&gt; to org.geotools/gt-data/17-SNAPSHOT/gt-data-17-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/shapefile/pom.xml&gt; to org.geotools/gt-shapefile/17-SNAPSHOT/gt-shapefile-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/shapefile/target/gt-shapefile-17-SNAPSHOT.jar&gt; to org.geotools/gt-shapefile/17-SNAPSHOT/gt-shapefile-17-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/shapefile/target/gt-shapefile-17-SNAPSHOT-sources.jar&gt; to org.geotools/gt-shapefile/17-SNAPSHOT/gt-shapefile-17-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/pom.xml&gt; to org.geotools/modules/17-SNAPSHOT/modules-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/build/maven/jjtree-javacc/pom.xml&gt; to org.geotools.maven/jjtree-javacc/17-SNAPSHOT/jjtree-javacc-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/build/maven/jjtree-javacc/target/jjtree-javacc-17-SNAPSHOT.jar&gt; to org.geotools.maven/jjtree-javacc/17-SNAPSHOT/jjtree-javacc-17-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/build/maven/jjtree-javacc/target/jjtree-javacc-17-SNAPSHOT-sources.jar&gt; to org.geotools.maven/jjtree-javacc/17-SNAPSHOT/jjtree-javacc-17-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/cql/pom.xml&gt; to org.geotools/gt-cql/17-SNAPSHOT/gt-cql-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/cql/target/gt-cql-17-SNAPSHOT.jar&gt; to org.geotools/gt-cql/17-SNAPSHOT/gt-cql-17-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/cql/target/gt-cql-17-SNAPSHOT-sources.jar&gt; to org.geotools/gt-cql/17-SNAPSHOT/gt-cql-17-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/build/maven/javadoc/pom.xml&gt; to org.geotools.maven/javadoc/17-SNAPSHOT/javadoc-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/build/maven/javadoc/target/javadoc-17-SNAPSHOT.jar&gt; to org.geotools.maven/javadoc/17-SNAPSHOT/javadoc-17-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/build/maven/javadoc/target/javadoc-17-SNAPSHOT-sources.jar&gt; to org.geotools.maven/javadoc/17-SNAPSHOT/javadoc-17-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/geopkg/pom.xml&gt; to org.geotools/gt-geopkg/17-SNAPSHOT/gt-geopkg-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/jts-wrapper/pom.xml&gt; to org.geotools/gt-jts-wrapper/17-SNAPSHOT/gt-jts-wrapper-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/process-raster/pom.xml&gt; to org.geotools/gt-process-raster/17-SNAPSHOT/gt-process-raster-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/api/pom.xml&gt; to org.geotools/gt-api/17-SNAPSHOT/gt-api-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/api/target/gt-api-17-SNAPSHOT.jar&gt; to org.geotools/gt-api/17-SNAPSHOT/gt-api-17-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/api/target/gt-api-17-SNAPSHOT-sources.jar&gt; to org.geotools/gt-api/17-SNAPSHOT/gt-api-17-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/app-schema/app-schema/pom.xml&gt; to org.geotools/gt-app-schema/17-SNAPSHOT/gt-app-schema-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/mongodb/pom.xml&gt; to org.geotools/gt-mongodb/17-SNAPSHOT/gt-mongodb-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/sfs/pom.xml&gt; to org.geotools/gt-sfs/17-SNAPSHOT/gt-sfs-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/ogc/org.w3.xlink/pom.xml&gt; to org.geotools.ogc/org.w3.xlink/17-SNAPSHOT/org.w3.xlink-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/coverage-multidim/netcdf/pom.xml&gt; to org.geotools/gt-netcdf/17-SNAPSHOT/gt-netcdf-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/build/maven/xmlcodegen/pom.xml&gt; to org.geotools.maven/xmlcodegen/17-SNAPSHOT/xmlcodegen-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/build/maven/xmlcodegen/target/xmlcodegen-17-SNAPSHOT.jar&gt; to org.geotools.maven/xmlcodegen/17-SNAPSHOT/xmlcodegen-17-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/build/maven/xmlcodegen/target/xmlcodegen-17-SNAPSHOT-sources.jar&gt; to org.geotools.maven/xmlcodegen/17-SNAPSHOT/xmlcodegen-17-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/epsg-wkt/pom.xml&gt; to org.geotools/gt-epsg-wkt/17-SNAPSHOT/gt-epsg-wkt-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/epsg-wkt/target/gt-epsg-wkt-17-SNAPSHOT.jar&gt; to org.geotools/gt-epsg-wkt/17-SNAPSHOT/gt-epsg-wkt-17-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/epsg-wkt/target/gt-epsg-wkt-17-SNAPSHOT-sources.jar&gt; to org.geotools/gt-epsg-wkt/17-SNAPSHOT/gt-epsg-wkt-17-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/jdbc/pom.xml&gt; to org.geotools/gt-jdbc/17-SNAPSHOT/gt-jdbc-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/imagemosaic/pom.xml&gt; to org.geotools/gt-imagemosaic/17-SNAPSHOT/gt-imagemosaic-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/svg/pom.xml&gt; to org.geotools/gt-svg/17-SNAPSHOT/gt-svg-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/geojson/pom.xml&gt; to org.geotools/gt-geojson/17-SNAPSHOT/gt-geojson-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/pom.xml&gt; to org.geotools.xsd/xsd/17-SNAPSHOT/xsd-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/vpf/pom.xml&gt; to org.geotools/gt-vpf/17-SNAPSHOT/gt-vpf-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-wfs/pom.xml&gt; to org.geotools.xsd/gt-xsd-wfs/17-SNAPSHOT/gt-xsd-wfs-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/sample-data/pom.xml&gt; to org.geotools/gt-sample-data/17-SNAPSHOT/gt-sample-data-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/sample-data/target/gt-sample-data-17-SNAPSHOT.jar&gt; to org.geotools/gt-sample-data/17-SNAPSHOT/gt-sample-data-17-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/sample-data/target/gt-sample-data-17-SNAPSHOT-sources.jar&gt; to org.geotools/gt-sample-data/17-SNAPSHOT/gt-sample-data-17-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/jdbc/jdbc-oracle/pom.xml&gt; to org.geotools.jdbc/gt-jdbc-oracle/17-SNAPSHOT/gt-jdbc-oracle-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/grassraster/pom.xml&gt; to org.geotools/gt-grassraster/17-SNAPSHOT/gt-grassraster-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/build/maven/pom.xml&gt; to org.geotools.maven/maven/17-SNAPSHOT/maven-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-core/pom.xml&gt; to org.geotools.xsd/gt-xsd-core/17-SNAPSHOT/gt-xsd-core-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-core/target/gt-xsd-core-17-SNAPSHOT.jar&gt; to org.geotools.xsd/gt-xsd-core/17-SNAPSHOT/gt-xsd-core-17-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-core/target/gt-xsd-core-17-SNAPSHOT-sources.jar&gt; to org.geotools.xsd/gt-xsd-core/17-SNAPSHOT/gt-xsd-core-17-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/coverage-multidim/coverage-api/pom.xml&gt; to org.geotools/gt-coverage-api/17-SNAPSHOT/gt-coverage-api-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/ogr/pom.xml&gt; to org.geotools/gt-ogr/17-SNAPSHOT/gt-ogr-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/geojsonstore/pom.xml&gt; to org.geotools/gt-geojsondatastore/17-SNAPSHOT/gt-geojsondatastore-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/ogr/ogr-core/pom.xml&gt; to org.geotools/gt-ogr-core/17-SNAPSHOT/gt-ogr-core-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/geometry/pom.xml&gt; to org.geotools/gt-geometry/17-SNAPSHOT/gt-geometry-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/jdbc/pom.xml&gt; to org.geotools.jdbc/gt-jdbc/17-SNAPSHOT/gt-jdbc-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/pom.xml&gt; to org.geotools/extension/17-SNAPSHOT/extension-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/app-schema/sample-data-access/pom.xml&gt; to org.geotools/gt-sample-data-access/17-SNAPSHOT/gt-sample-data-access-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/polylabel/pom.xml&gt; to org.geotools/gt-polygon-labeller/17-SNAPSHOT/gt-polygon-labeller-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/ysld/pom.xml&gt; to org.geotools/gt-ysld/17-SNAPSHOT/gt-ysld-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/gtopo30/pom.xml&gt; to org.geotools/gt-gtopo30/17-SNAPSHOT/gt-gtopo30-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/coverage/pom.xml&gt; to org.geotools/gt-coverage/17-SNAPSHOT/gt-coverage-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/coverage/target/gt-coverage-17-SNAPSHOT.jar&gt; to org.geotools/gt-coverage/17-SNAPSHOT/gt-coverage-17-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/coverage/target/gt-coverage-17-SNAPSHOT-sources.jar&gt; to org.geotools/gt-coverage/17-SNAPSHOT/gt-coverage-17-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/pom.xml&gt; to org.geotools/geotools/17-SNAPSHOT/geotools-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/brewer/pom.xml&gt; to org.geotools/gt-brewer/17-SNAPSHOT/gt-brewer-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/image/pom.xml&gt; to org.geotools/gt-image/17-SNAPSHOT/gt-image-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/image/target/gt-image-17-SNAPSHOT.jar&gt; to org.geotools/gt-image/17-SNAPSHOT/gt-image-17-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/image/target/gt-image-17-SNAPSHOT-sources.jar&gt; to org.geotools/gt-image/17-SNAPSHOT/gt-image-17-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/build/maven/jar-collector/pom.xml&gt; to org.geotools.maven/jar-collector/17-SNAPSHOT/jar-collector-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/build/maven/jar-collector/target/jar-collector-17-SNAPSHOT.jar&gt; to org.geotools.maven/jar-collector/17-SNAPSHOT/jar-collector-17-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/build/maven/jar-collector/target/jar-collector-17-SNAPSHOT-sources.jar&gt; to org.geotools.maven/jar-collector/17-SNAPSHOT/jar-collector-17-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/imageio-ext-gdal/pom.xml&gt; to org.geotools/gt-imageio-ext-gdal/17-SNAPSHOT/gt-imageio-ext-gdal-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/solr/pom.xml&gt; to org.geotools/gt-solr/17-SNAPSHOT/gt-solr-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/metadata/pom.xml&gt; to org.geotools/gt-metadata/17-SNAPSHOT/gt-metadata-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/metadata/target/gt-metadata-17-SNAPSHOT.jar&gt; to org.geotools/gt-metadata/17-SNAPSHOT/gt-metadata-17-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/metadata/target/gt-metadata-17-SNAPSHOT-sources.jar&gt; to org.geotools/gt-metadata/17-SNAPSHOT/gt-metadata-17-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/main/pom.xml&gt; to org.geotools/gt-main/17-SNAPSHOT/gt-main-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/main/target/gt-main-17-SNAPSHOT.jar&gt; to org.geotools/gt-main/17-SNAPSHOT/gt-main-17-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/main/target/gt-main-17-SNAPSHOT-tests.jar&gt; to org.geotools/gt-main/17-SNAPSHOT/gt-main-17-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/main/target/gt-main-17-SNAPSHOT-sources.jar&gt; to org.geotools/gt-main/17-SNAPSHOT/gt-main-17-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-gml2/pom.xml&gt; to org.geotools.xsd/gt-xsd-gml2/17-SNAPSHOT/gt-xsd-gml2-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-gml2/target/gt-xsd-gml2-17-SNAPSHOT.jar&gt; to org.geotools.xsd/gt-xsd-gml2/17-SNAPSHOT/gt-xsd-gml2-17-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-gml2/target/gt-xsd-gml2-17-SNAPSHOT-sources.jar&gt; to org.geotools.xsd/gt-xsd-gml2/17-SNAPSHOT/gt-xsd-gml2-17-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/pom.xml&gt; to org.geotools/library/17-SNAPSHOT/library-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-gml3/pom.xml&gt; to org.geotools.xsd/gt-xsd-gml3/17-SNAPSHOT/gt-xsd-gml3-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-gml3/target/gt-xsd-gml3-17-SNAPSHOT.jar&gt; to org.geotools.xsd/gt-xsd-gml3/17-SNAPSHOT/gt-xsd-gml3-17-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-gml3/target/gt-xsd-gml3-17-SNAPSHOT-sources.jar&gt; to org.geotools.xsd/gt-xsd-gml3/17-SNAPSHOT/gt-xsd-gml3-17-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-wps/pom.xml&gt; to org.geotools.xsd/gt-xsd-wps/17-SNAPSHOT/gt-xsd-wps-17-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/pom.xml&gt; to org.geotools/plugin/17-SNAPSHOT/plugin-17-SNAPSHOT.pom
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/307/changes&gt;
