Changes:
[tbarsballe] build_release creates local branch from remote if it doesn't exist yet
[...truncated 4715 lines...]
[INFO] DB2 DataStore ..................................... SKIPPED
[INFO] MySQL DataStore ................................... SKIPPED
[INFO] SQL Server DataStore .............................. SKIPPED
[INFO] SpatiaLite DataStore .............................. SKIPPED
[INFO] Teradata DataStore ................................ SKIPPED
[INFO] JP2K based grid coverage readers .................. SKIPPED
[INFO] OGR DataStore Module .............................. SKIPPED
[INFO] Core OGR DataStore Module ......................... SKIPPED
[INFO] Bridj OGR DataStore Module ........................ SKIPPED
[INFO] JNI OGR DataStore Module .......................... SKIPPED
[INFO] Vertical coordinate transformations ............... SKIPPED
[INFO] Dynamic symbolizers for SVG symbols ............... SKIPPED
[INFO] Coverage Multidimensional Module .................. SKIPPED
[INFO] API interfaces .................................... SKIPPED
[INFO] NetCDF gridcoverage module ........................ SKIPPED
[INFO] GRIB gridcoverage module .......................... SKIPPED
[INFO] GeoPackage Module ................................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Application Schema Resolver ....................... SKIPPED
[INFO] Complex Features Support .......................... SKIPPED
[INFO] Application Schema DataAccess ..................... SKIPPED
[INFO] Sample DataAccess ................................. SKIPPED
[INFO] Brewer module ..................................... SKIPPED
[INFO] Vector grids ...................................... SKIPPED
[INFO] Validation Processor and Framework ................ SKIPPED
[INFO] Web Map Server client ............................. SKIPPED
[INFO] KML XML Support ................................... SKIPPED
[INFO] WCS XML Support ................................... SKIPPED
[INFO] WPS XML Support ................................... SKIPPED
[INFO] WMS XML Support ................................... SKIPPED
[INFO] CSW XML Support ................................... SKIPPED
[INFO] Geotools unsupported .............................. SKIPPED
[INFO] Process ........................................... SKIPPED
[INFO] Process Feature ................................... SKIPPED
[INFO] Process Raster .................................... SKIPPED
[INFO] YSLD Parser/Encoder ............................... SKIPPED
[INFO] Swing widgets ..................................... SKIPPED
[INFO] SWT widgets ....................................... SKIPPED
[INFO] Process Geometry .................................. SKIPPED
[INFO] GeoJSON Support ................................... SKIPPED
[INFO] MBTiles Module .................................... SKIPPED
[INFO] WFS client module (NG) ............................ SKIPPED
[INFO] polylabel ......................................... SKIPPED
[INFO] ISO 19107 implementation using JTS ................ SKIPPED
[INFO] Geometries ........................................ SKIPPED
[INFO] Web Processing Service ............................ SKIPPED
[INFO] Application Schema Support (Unsupported Modules) .. SKIPPED
[INFO] SOLR module ....................................... SKIPPED
[INFO] Geobuf DataStore .................................. SKIPPED
[INFO] Cartographic CSS parser ........................... SKIPPED
[INFO] GeoJSON Datastore ................................. SKIPPED
[INFO] CSVDataStore ...................................... SKIPPED
[INFO] EPSG Authority Factory for Oracle ................. SKIPPED
[INFO] Next Generation JDBC DataStores ................... SKIPPED
[INFO] SAS Matlab grid coverage readers .................. SKIPPED
[INFO] Simple Feature Service store ...................... SKIPPED
[INFO] Aggregating DataStore ............................. SKIPPED
[INFO] MongoDB DataStore ................................. SKIPPED
[INFO] GeoTools Documentation ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 2:52.699s
[INFO] Finished at: Mon Jun 19 21:01:39 CEST 2017
[INFO] Final Memory: 370M/1133M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.15:test (default-test) on project gt-coverage: There are test failures.
[ERROR]
[ERROR] Please refer to <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/coverage/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gt-coverage
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/jdbc/jdbc-mysql/pom.xml> to org.geotools.jdbc/gt-jdbc-mysql/18-SNAPSHOT/gt-jdbc-mysql-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/wps/pom.xml> to org.geotools/gt-wps/18-SNAPSHOT/gt-wps-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/opengis/pom.xml> to org.geotools/gt-opengis/18-SNAPSHOT/gt-opengis-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/opengis/target/gt-opengis-18-SNAPSHOT.jar> to org.geotools/gt-opengis/18-SNAPSHOT/gt-opengis-18-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/opengis/target/gt-opengis-18-SNAPSHOT-sources.jar> to org.geotools/gt-opengis/18-SNAPSHOT/gt-opengis-18-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/validation/pom.xml> to org.geotools/gt-validation/18-SNAPSHOT/gt-validation-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/app-schema/app-schema-resolver/pom.xml> to org.geotools/gt-app-schema-resolver/18-SNAPSHOT/gt-app-schema-resolver-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/epsg-oracle/pom.xml> to org.geotools/gt-epsg-oracle/18-SNAPSHOT/gt-epsg-oracle-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/epsg-extension/pom.xml> to org.geotools/gt-epsg-extension/18-SNAPSHOT/gt-epsg-extension-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/grid/pom.xml> to org.geotools/gt-grid/18-SNAPSHOT/gt-grid-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/coverage-multidim/grib/pom.xml> to org.geotools/gt-grib/18-SNAPSHOT/gt-grib-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-csw/pom.xml> to org.geotools.xsd/gt-xsd-csw/18-SNAPSHOT/gt-xsd-csw-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/ogc/net.opengis.ows/pom.xml> to org.geotools.ogc/net.opengis.ows/18-SNAPSHOT/net.opengis.ows-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/transform/pom.xml> to org.geotools/gt-transform/18-SNAPSHOT/gt-transform-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/swing/pom.xml> to org.geotools/gt-swing/18-SNAPSHOT/gt-swing-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/pom.xml> to org.geotools/unsupported/18-SNAPSHOT/unsupported-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/ogc/net.opengis.wfs/pom.xml> to org.geotools.ogc/net.opengis.wfs/18-SNAPSHOT/net.opengis.wfs-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/referencing3D/pom.xml> to org.geotools/gt-referencing3D/18-SNAPSHOT/gt-referencing3D-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/ogc/pom.xml> to org.geotools/ogc/18-SNAPSHOT/ogc-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/render/pom.xml> to org.geotools/gt-render/18-SNAPSHOT/gt-render-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/jdbc/jdbc-postgis/pom.xml> to org.geotools.jdbc/gt-jdbc-postgis/18-SNAPSHOT/gt-jdbc-postgis-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/complex/pom.xml> to org.geotools/gt-complex/18-SNAPSHOT/gt-complex-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-ows/pom.xml> to org.geotools.xsd/gt-xsd-ows/18-SNAPSHOT/gt-xsd-ows-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/arcgrid/pom.xml> to org.geotools/gt-arcgrid/18-SNAPSHOT/gt-arcgrid-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/graph/pom.xml> to org.geotools/gt-graph/18-SNAPSHOT/gt-graph-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/graph/target/gt-graph-18-SNAPSHOT.jar> to org.geotools/gt-graph/18-SNAPSHOT/gt-graph-18-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/graph/target/gt-graph-18-SNAPSHOT-sources.jar> to org.geotools/gt-graph/18-SNAPSHOT/gt-graph-18-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/process-feature/pom.xml> to org.geotools/gt-process-feature/18-SNAPSHOT/gt-process-feature-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/process-geometry/pom.xml> to org.geotools/gt-process-geometry/18-SNAPSHOT/gt-process-geometry-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/ogc/net.opengis.wcs/pom.xml> to org.geotools.ogc/net.opengis.wcs/18-SNAPSHOT/net.opengis.wcs-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/property/pom.xml> to org.geotools/gt-property/18-SNAPSHOT/gt-property-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/property/target/gt-property-18-SNAPSHOT.jar> to org.geotools/gt-property/18-SNAPSHOT/gt-property-18-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/property/target/gt-property-18-SNAPSHOT-sources.jar> to org.geotools/gt-property/18-SNAPSHOT/gt-property-18-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/jdbc/jdbc-db2/pom.xml> to org.geotools.jdbc/gt-jdbc-db2/18-SNAPSHOT/gt-jdbc-db2-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/csv/pom.xml> to org.geotools/gt-csv/18-SNAPSHOT/gt-csv-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-fes/pom.xml> to org.geotools.xsd/gt-xsd-fes/18-SNAPSHOT/gt-xsd-fes-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/jdbc/jdbc-spatialite/pom.xml> to org.geotools.jdbc/gt-jdbc-spatialite/18-SNAPSHOT/gt-jdbc-spatialite-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/app-schema/pom.xml> to org.geotools/app-schema/18-SNAPSHOT/app-schema-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/imagemosaic-jdbc/pom.xml> to org.geotools/gt-imagemosaic-jdbc/18-SNAPSHOT/gt-imagemosaic-jdbc-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-wcs/pom.xml> to org.geotools.xsd/gt-xsd-wcs/18-SNAPSHOT/gt-xsd-wcs-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/imagepyramid/pom.xml> to org.geotools/gt-imagepyramid/18-SNAPSHOT/gt-imagepyramid-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/css/pom.xml> to org.geotools/gt-css/18-SNAPSHOT/gt-css-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/jdbc/jdbc-teradata/pom.xml> to org.geotools.jdbc/gt-jdbc-teradata/18-SNAPSHOT/gt-jdbc-teradata-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/ogr/ogr-jni/pom.xml> to org.geotools/gt-ogr-jni/18-SNAPSHOT/gt-ogr-jni-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/wfs-ng/pom.xml> to org.geotools/gt-wfs-ng/18-SNAPSHOT/gt-wfs-ng-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/epsg-hsql/pom.xml> to org.geotools/gt-epsg-hsql/18-SNAPSHOT/gt-epsg-hsql-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/epsg-hsql/target/gt-epsg-hsql-18-SNAPSHOT.jar> to org.geotools/gt-epsg-hsql/18-SNAPSHOT/gt-epsg-hsql-18-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/epsg-hsql/target/gt-epsg-hsql-18-SNAPSHOT-sources.jar> to org.geotools/gt-epsg-hsql/18-SNAPSHOT/gt-epsg-hsql-18-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/arcsde/common/pom.xml> to org.geotools/gt-arcsde-common/18-SNAPSHOT/gt-arcsde-common-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/build/pom.xml> to org.geotools.maven/build/18-SNAPSHOT/build-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/xml/pom.xml> to org.geotools/gt-xml/18-SNAPSHOT/gt-xml-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/ogr/ogr-bridj/pom.xml> to org.geotools/gt-ogr-bridj/18-SNAPSHOT/gt-ogr-bridj-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/docs/pom.xml> to org.geotools/docs/18-SNAPSHOT/docs-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/process/pom.xml> to org.geotools/gt-process/18-SNAPSHOT/gt-process-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/geotiff/pom.xml> to org.geotools/gt-geotiff/18-SNAPSHOT/gt-geotiff-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/ogc/net.opengis.csw/pom.xml> to org.geotools.ogc/net.opengis.csw/18-SNAPSHOT/net.opengis.csw-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/wms/pom.xml> to org.geotools/gt-wms/18-SNAPSHOT/gt-wms-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/feature-aggregate/pom.xml> to org.geotools.unsupported/gt-feature-aggregate/18-SNAPSHOT/gt-feature-aggregate-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/jdbc/jdbc-sqlserver/pom.xml> to org.geotools.jdbc/gt-jdbc-sqlserver/18-SNAPSHOT/gt-jdbc-sqlserver-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/epsg-postgresql/pom.xml> to org.geotools/gt-epsg-postgresql/18-SNAPSHOT/gt-epsg-postgresql-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/charts/pom.xml> to org.geotools/gt-charts/18-SNAPSHOT/gt-charts-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/jdbc-ng/pom.xml> to org.geotools/gt-jdbc-ng/18-SNAPSHOT/gt-jdbc-ng-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/referencing/pom.xml> to org.geotools/gt-referencing/18-SNAPSHOT/gt-referencing-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/referencing/target/gt-referencing-18-SNAPSHOT.jar> to org.geotools/gt-referencing/18-SNAPSHOT/gt-referencing-18-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/referencing/target/gt-referencing-18-SNAPSHOT-tests.jar> to org.geotools/gt-referencing/18-SNAPSHOT/gt-referencing-18-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/referencing/target/gt-referencing-18-SNAPSHOT-sources.jar> to org.geotools/gt-referencing/18-SNAPSHOT/gt-referencing-18-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/geobuf/pom.xml> to org.geotools/gt-geobuf/18-SNAPSHOT/gt-geobuf-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/ogc/net.opengis.wps/pom.xml> to org.geotools.ogc/net.opengis.wps/18-SNAPSHOT/net.opengis.wps-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/matfile5/pom.xml> to org.geotools/gt-matfile5/18-SNAPSHOT/gt-matfile5-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/jdbc/jdbc-h2/pom.xml> to org.geotools.jdbc/gt-jdbc-h2/18-SNAPSHOT/gt-jdbc-h2-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/coverage-multidim/pom.xml> to org.geotools/gt-coverage-multidim/18-SNAPSHOT/gt-coverage-multidim-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-filter/pom.xml> to org.geotools.xsd/gt-xsd-filter/18-SNAPSHOT/gt-xsd-filter-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/arcsde/sde-dummy/pom.xml> to org.geotools/gt-sde-dummy/18-SNAPSHOT/gt-sde-dummy-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/mbtiles/pom.xml> to org.geotools/gt-mbtiles/18-SNAPSHOT/gt-mbtiles-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/arcsde/datastore/pom.xml> to org.geotools/gt-arcsde/18-SNAPSHOT/gt-arcsde-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/feature-pregeneralized/pom.xml> to org.geotools/gt-feature-pregeneralized/18-SNAPSHOT/gt-feature-pregeneralized-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/jp2k/pom.xml> to org.geotools/gt-jp2k/18-SNAPSHOT/gt-jp2k-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-wms/pom.xml> to org.geotools.xsd/gt-xsd-wms/18-SNAPSHOT/gt-xsd-wms-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/app-schema/pom.xml> to org.geotools/app-schema-unsupported/18-SNAPSHOT/app-schema-unsupported-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/arcsde/pom.xml> to org.geotools/arcsde-plugin/18-SNAPSHOT/arcsde-plugin-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/ogc/net.opengis.fes/pom.xml> to org.geotools.ogc/net.opengis.fes/18-SNAPSHOT/net.opengis.fes-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-kml/pom.xml> to org.geotools.xsd/gt-xsd-kml/18-SNAPSHOT/gt-xsd-kml-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-sld/pom.xml> to org.geotools.xsd/gt-xsd-sld/18-SNAPSHOT/gt-xsd-sld-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/swt/pom.xml> to org.geotools/gt-swt/18-SNAPSHOT/gt-swt-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/data/pom.xml> to org.geotools/gt-data/18-SNAPSHOT/gt-data-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/data/target/gt-data-18-SNAPSHOT.jar> to org.geotools/gt-data/18-SNAPSHOT/gt-data-18-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/data/target/gt-data-18-SNAPSHOT-sources.jar> to org.geotools/gt-data/18-SNAPSHOT/gt-data-18-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/shapefile/pom.xml> to org.geotools/gt-shapefile/18-SNAPSHOT/gt-shapefile-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/shapefile/target/gt-shapefile-18-SNAPSHOT.jar> to org.geotools/gt-shapefile/18-SNAPSHOT/gt-shapefile-18-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/shapefile/target/gt-shapefile-18-SNAPSHOT-sources.jar> to org.geotools/gt-shapefile/18-SNAPSHOT/gt-shapefile-18-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/pom.xml> to org.geotools/modules/18-SNAPSHOT/modules-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/build/maven/jjtree-javacc/pom.xml> to org.geotools.maven/jjtree-javacc/18-SNAPSHOT/jjtree-javacc-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/build/maven/jjtree-javacc/target/jjtree-javacc-18-SNAPSHOT.jar> to org.geotools.maven/jjtree-javacc/18-SNAPSHOT/jjtree-javacc-18-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/build/maven/jjtree-javacc/target/jjtree-javacc-18-SNAPSHOT-sources.jar> to org.geotools.maven/jjtree-javacc/18-SNAPSHOT/jjtree-javacc-18-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/cql/pom.xml> to org.geotools/gt-cql/18-SNAPSHOT/gt-cql-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/cql/target/gt-cql-18-SNAPSHOT.jar> to org.geotools/gt-cql/18-SNAPSHOT/gt-cql-18-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/cql/target/gt-cql-18-SNAPSHOT-sources.jar> to org.geotools/gt-cql/18-SNAPSHOT/gt-cql-18-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/build/maven/javadoc/pom.xml> to org.geotools.maven/javadoc/18-SNAPSHOT/javadoc-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/build/maven/javadoc/target/javadoc-18-SNAPSHOT.jar> to org.geotools.maven/javadoc/18-SNAPSHOT/javadoc-18-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/build/maven/javadoc/target/javadoc-18-SNAPSHOT-sources.jar> to org.geotools.maven/javadoc/18-SNAPSHOT/javadoc-18-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/geopkg/pom.xml> to org.geotools/gt-geopkg/18-SNAPSHOT/gt-geopkg-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/jts-wrapper/pom.xml> to org.geotools/gt-jts-wrapper/18-SNAPSHOT/gt-jts-wrapper-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/process-raster/pom.xml> to org.geotools/gt-process-raster/18-SNAPSHOT/gt-process-raster-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/api/pom.xml> to org.geotools/gt-api/18-SNAPSHOT/gt-api-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/api/target/gt-api-18-SNAPSHOT.jar> to org.geotools/gt-api/18-SNAPSHOT/gt-api-18-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/api/target/gt-api-18-SNAPSHOT-sources.jar> to org.geotools/gt-api/18-SNAPSHOT/gt-api-18-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/app-schema/app-schema/pom.xml> to org.geotools/gt-app-schema/18-SNAPSHOT/gt-app-schema-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/mongodb/pom.xml> to org.geotools/gt-mongodb/18-SNAPSHOT/gt-mongodb-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/sfs/pom.xml> to org.geotools/gt-sfs/18-SNAPSHOT/gt-sfs-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/ogc/org.w3.xlink/pom.xml> to org.geotools.ogc/org.w3.xlink/18-SNAPSHOT/org.w3.xlink-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/coverage-multidim/netcdf/pom.xml> to org.geotools/gt-netcdf/18-SNAPSHOT/gt-netcdf-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/build/maven/xmlcodegen/pom.xml> to org.geotools.maven/xmlcodegen/18-SNAPSHOT/xmlcodegen-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/build/maven/xmlcodegen/target/xmlcodegen-18-SNAPSHOT.jar> to org.geotools.maven/xmlcodegen/18-SNAPSHOT/xmlcodegen-18-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/build/maven/xmlcodegen/target/xmlcodegen-18-SNAPSHOT-sources.jar> to org.geotools.maven/xmlcodegen/18-SNAPSHOT/xmlcodegen-18-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/epsg-wkt/pom.xml> to org.geotools/gt-epsg-wkt/18-SNAPSHOT/gt-epsg-wkt-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/epsg-wkt/target/gt-epsg-wkt-18-SNAPSHOT.jar> to org.geotools/gt-epsg-wkt/18-SNAPSHOT/gt-epsg-wkt-18-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/epsg-wkt/target/gt-epsg-wkt-18-SNAPSHOT-sources.jar> to org.geotools/gt-epsg-wkt/18-SNAPSHOT/gt-epsg-wkt-18-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/jdbc/pom.xml> to org.geotools/gt-jdbc/18-SNAPSHOT/gt-jdbc-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/imagemosaic/pom.xml> to org.geotools/gt-imagemosaic/18-SNAPSHOT/gt-imagemosaic-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/svg/pom.xml> to org.geotools/gt-svg/18-SNAPSHOT/gt-svg-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/geojson/pom.xml> to org.geotools/gt-geojson/18-SNAPSHOT/gt-geojson-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/pom.xml> to org.geotools.xsd/xsd/18-SNAPSHOT/xsd-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-wfs/pom.xml> to org.geotools.xsd/gt-xsd-wfs/18-SNAPSHOT/gt-xsd-wfs-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/sample-data/pom.xml> to org.geotools/gt-sample-data/18-SNAPSHOT/gt-sample-data-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/sample-data/target/gt-sample-data-18-SNAPSHOT.jar> to org.geotools/gt-sample-data/18-SNAPSHOT/gt-sample-data-18-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/sample-data/target/gt-sample-data-18-SNAPSHOT-sources.jar> to org.geotools/gt-sample-data/18-SNAPSHOT/gt-sample-data-18-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/jdbc/jdbc-oracle/pom.xml> to org.geotools.jdbc/gt-jdbc-oracle/18-SNAPSHOT/gt-jdbc-oracle-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/grassraster/pom.xml> to org.geotools/gt-grassraster/18-SNAPSHOT/gt-grassraster-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/build/maven/pom.xml> to org.geotools.maven/maven/18-SNAPSHOT/maven-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-core/pom.xml> to org.geotools.xsd/gt-xsd-core/18-SNAPSHOT/gt-xsd-core-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-core/target/gt-xsd-core-18-SNAPSHOT.jar> to org.geotools.xsd/gt-xsd-core/18-SNAPSHOT/gt-xsd-core-18-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-core/target/gt-xsd-core-18-SNAPSHOT-sources.jar> to org.geotools.xsd/gt-xsd-core/18-SNAPSHOT/gt-xsd-core-18-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/coverage-multidim/coverage-api/pom.xml> to org.geotools/gt-coverage-api/18-SNAPSHOT/gt-coverage-api-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/ogr/pom.xml> to org.geotools/gt-ogr/18-SNAPSHOT/gt-ogr-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/geojsonstore/pom.xml> to org.geotools/gt-geojsondatastore/18-SNAPSHOT/gt-geojsondatastore-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/ogr/ogr-core/pom.xml> to org.geotools/gt-ogr-core/18-SNAPSHOT/gt-ogr-core-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/geometry/pom.xml> to org.geotools/gt-geometry/18-SNAPSHOT/gt-geometry-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/jdbc/pom.xml> to org.geotools.jdbc/gt-jdbc/18-SNAPSHOT/gt-jdbc-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/pom.xml> to org.geotools/extension/18-SNAPSHOT/extension-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/app-schema/sample-data-access/pom.xml> to org.geotools/gt-sample-data-access/18-SNAPSHOT/gt-sample-data-access-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/polylabel/pom.xml> to org.geotools/gt-polygon-labeller/18-SNAPSHOT/gt-polygon-labeller-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/ysld/pom.xml> to org.geotools/gt-ysld/18-SNAPSHOT/gt-ysld-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/gtopo30/pom.xml> to org.geotools/gt-gtopo30/18-SNAPSHOT/gt-gtopo30-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/coverage/pom.xml> to org.geotools/gt-coverage/18-SNAPSHOT/gt-coverage-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/pom.xml> to org.geotools/geotools/18-SNAPSHOT/geotools-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/brewer/pom.xml> to org.geotools/gt-brewer/18-SNAPSHOT/gt-brewer-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/image/pom.xml> to org.geotools/gt-image/18-SNAPSHOT/gt-image-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/build/maven/jar-collector/pom.xml> to org.geotools.maven/jar-collector/18-SNAPSHOT/jar-collector-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/build/maven/jar-collector/target/jar-collector-18-SNAPSHOT.jar> to org.geotools.maven/jar-collector/18-SNAPSHOT/jar-collector-18-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/build/maven/jar-collector/target/jar-collector-18-SNAPSHOT-sources.jar> to org.geotools.maven/jar-collector/18-SNAPSHOT/jar-collector-18-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/imageio-ext-gdal/pom.xml> to org.geotools/gt-imageio-ext-gdal/18-SNAPSHOT/gt-imageio-ext-gdal-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/unsupported/solr/pom.xml> to org.geotools/gt-solr/18-SNAPSHOT/gt-solr-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/metadata/pom.xml> to org.geotools/gt-metadata/18-SNAPSHOT/gt-metadata-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/metadata/target/gt-metadata-18-SNAPSHOT.jar> to org.geotools/gt-metadata/18-SNAPSHOT/gt-metadata-18-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/metadata/target/gt-metadata-18-SNAPSHOT-sources.jar> to org.geotools/gt-metadata/18-SNAPSHOT/gt-metadata-18-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/main/pom.xml> to org.geotools/gt-main/18-SNAPSHOT/gt-main-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/main/target/gt-main-18-SNAPSHOT.jar> to org.geotools/gt-main/18-SNAPSHOT/gt-main-18-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/main/target/gt-main-18-SNAPSHOT-tests.jar> to org.geotools/gt-main/18-SNAPSHOT/gt-main-18-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/main/target/gt-main-18-SNAPSHOT-sources.jar> to org.geotools/gt-main/18-SNAPSHOT/gt-main-18-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-gml2/pom.xml> to org.geotools.xsd/gt-xsd-gml2/18-SNAPSHOT/gt-xsd-gml2-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/library/pom.xml> to org.geotools/library/18-SNAPSHOT/library-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-gml3/pom.xml> to org.geotools.xsd/gt-xsd-gml3/18-SNAPSHOT/gt-xsd-gml3-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/extension/xsd/xsd-wps/pom.xml> to org.geotools.xsd/gt-xsd-wps/18-SNAPSHOT/gt-xsd-wps-18-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoTools-Master-OpenJDK8/ws/modules/plugin/pom.xml> to org.geotools/plugin/18-SNAPSHOT/plugin-18-SNAPSHOT.pom
channel stopped
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
