[Geoserver-devel] Build failed in Jenkins / Travis: Local maven repo being corrupted
I’m updating a reply to a Jenkins message, related to an email I have sent this morning.
It seems like travis has local maven repository somehow corrupted.
See my previous reply of this morning in relation to a Jenkins build failure.
In addition, I have noticed that a Travis build on GS master is failed on a very trivial pull request: https://github.com/geoserver/geoserver/pull/1499
Checking the log, it has similar issue:
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-main: Compilation failure
[ERROR] error: error reading /home/travis/.m2/repository/org/geotools/gt-shapefile/15-SNAPSHOT/gt-shapefile-15-SNAPSHOT.jar; error in opening zip file
There are other pull requests failing. As an instance:
[https://github.com/geoserver/geoserver/pull/1498](https://github.com/geoserver/geoserver/pull/1498)
The reason it's the same.
Hope this helps. Cheers, Daniele
On Wed, Feb 17, 2016 at 3:45 PM, Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
Mmm… It seems there is a corrupted artifact on
/var/lib/jenkins/.m2/repository/org/geotools/gt-coverage/15-SNAPSHOT/gt-coverage-15-SNAPSHOT.jar
I have merged the related pull requests 1-2 days ago and the travis build were green:
https://github.com/geotools/geotools/pull/1107
https://github.com/geotools/geotools/pull/1117
So I think they are unrelated.
Any suggestion?
Daniele
On Wed, Feb 17, 2016 at 3:35 PM, <monitor@anonymised.com> wrote:
See <http://ares.boundlessgeo.com/jenkins/job/geotools-master-online/407/changes>
Changes:
[daniele.romagnoli] [GEOT-5352]-Update: Added small better check on Coordinates
[daniele.romagnoli] NetCDF/GRIB: Minor improvements on the Indexer Creator testing tool:
[…truncated 2738 lines…]
[INFO]
[INFO] — git-commit-id-plugin:2.1.2:revision (default) @ gt-validation —
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gt-validation <<<
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar (attach-sources) @ gt-validation —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geotools-master-online/ws/modules/extension/validation/target/gt-validation-15-SNAPSHOT-sources.jar>
[INFO]
[INFO] — maven-install-plugin:2.3.1:install (default-install) @ gt-validation —
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geotools-master-online/ws/modules/extension/validation/target/gt-validation-15-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geotools/gt-validation/15-SNAPSHOT/gt-validation-15-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geotools-master-online/ws/modules/extension/validation/pom.xml> to /var/lib/jenkins/.m2/repository/org/geotools/gt-validation/15-SNAPSHOT/gt-validation-15-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geotools-master-online/ws/modules/extension/validation/target/gt-validation-15-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geotools/gt-validation/15-SNAPSHOT/gt-validation-15-SNAPSHOT-sources.jar
[INFO]
[INFO] Building GeoPackage Module 15-SNAPSHOT
[INFO]
[INFO] — maven-clean-plugin:2.4.1:clean (default-clean) @ gt-geopkg —
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geotools-master-online/ws/modules/unsupported/geopkg/target>
[INFO]
[INFO] — git-commit-id-plugin:2.1.2:revision (default) @ gt-geopkg —
[INFO]
[INFO] — maven-resources-plugin:2.6:resources (default-resources) @ gt-geopkg —
[INFO] Using ‘UTF-8’ encoding to copy filtered resources.
[INFO] Copying 15 resources
[INFO]
[INFO] — maven-compiler-plugin:3.1:compile (default-compile) @ gt-geopkg —
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 33 source files to <http://ares.boundlessgeo.com/jenkins/job/geotools-master-online/ws/modules/unsupported/geopkg/target/classes>
[ERROR] COMPILATION ERROR :
[ERROR] error: error reading /var/lib/jenkins/.m2/repository/org/geotools/gt-coverage/15-SNAPSHOT/gt-coverage-15-SNAPSHOT.jar; error in opening zip file
[INFO] 1 error
[INFO]
[INFO] Building MBTiles Module 15-SNAPSHOT
[INFO]
[INFO] — maven-clean-plugin:2.4.1:clean (default-clean) @ gt-mbtiles —
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geotools-master-online/ws/modules/unsupported/mbtiles/target>
[INFO]
[INFO] — git-commit-id-plugin:2.1.2:revision (default) @ gt-mbtiles —
[INFO]
[INFO] — maven-resources-plugin:2.6:resources (default-resources) @ gt-mbtiles —
[INFO] Copying 2 resources
[INFO]
[INFO] — maven-compiler-plugin:3.1:compile (default-compile) @ gt-mbtiles —
[INFO] Compiling 9 source files to <http://ares.boundlessgeo.com/jenkins/job/geotools-master-online/ws/modules/unsupported/mbtiles/target/classes>
[INFO] 1 error
[INFO]
[INFO] Skipping Coverage tools
[INFO]
[INFO] Building Web Processing Service 15-SNAPSHOT
Downloading: https://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.wps/15-SNAPSHOT/maven-metadata.xml
966/966 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.wps/15-SNAPSHOT/maven-metadata.xml (966 B at 1.7 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wps/15-SNAPSHOT/maven-metadata.xml
961/961 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wps/15-SNAPSHOT/maven-metadata.xml (961 B at 1.6 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-process/15-SNAPSHOT/maven-metadata.xml
957/957 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-process/15-SNAPSHOT/maven-metadata.xml (957 B at 1.5 KB/sec)
[INFO]
[INFO] — maven-clean-plugin:2.4.1:clean (default-clean) @ gt-wps —
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geotools-master-online/ws/modules/unsupported/wps/target>
[INFO]
[INFO] — git-commit-id-plugin:2.1.2:revision (default) @ gt-wps —
[INFO]
[INFO] — maven-resources-plugin:2.6:resources (default-resources) @ gt-wps —
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geotools-master-online/ws/modules/unsupported/wps/src/main/resources>
[INFO]
[INFO] — maven-compiler-plugin:3.1:compile (default-compile) @ gt-wps —
[INFO] Compiling 23 source files to <http://ares.boundlessgeo.com/jenkins/job/geotools-master-online/ws/modules/unsupported/wps/target/classes>
[INFO] 1 error
[INFO]
[INFO] Building Next Generation JDBC DataStores 15-SNAPSHOT
[INFO]
[INFO] — maven-clean-plugin:2.4.1:clean (default-clean) @ gt-jdbc-ng —
[INFO]
[INFO] — git-commit-id-plugin:2.1.2:revision (default) @ gt-jdbc-ng —
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gt-jdbc-ng >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gt-jdbc-ng <<<
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar (attach-sources) @ gt-jdbc-ng —
[INFO]
[INFO] — maven-install-plugin:2.3.1:install (default-install) @ gt-jdbc-ng —
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geotools-master-online/ws/modules/unsupported/jdbc-ng/pom.xml> to /var/lib/jenkins/.m2/repository/org/geotools/gt-jdbc-ng/15-SNAPSHOT/gt-jdbc-ng-15-SNAPSHOT.pom
[INFO]
[INFO] Building GeoTools Documentation 15-SNAPSHOT
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-wfs/15-SNAPSHOT/maven-metadata.xml
953/953 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-wfs/15-SNAPSHOT/maven-metadata.xml (953 B at 1.6 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-wms/15-SNAPSHOT/maven-metadata.xml
953/953 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-wms/15-SNAPSHOT/maven-metadata.xml (953 B at 1.5 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-kml/15-SNAPSHOT/maven-metadata.xml
961/961 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-kml/15-SNAPSHOT/maven-metadata.xml (961 B at 1.7 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-sld/15-SNAPSHOT/maven-metadata.xml
961/961 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-sld/15-SNAPSHOT/maven-metadata.xml (961 B at 1.8 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-brewer/15-SNAPSHOT/maven-metadata.xml
956/956 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-brewer/15-SNAPSHOT/maven-metadata.xml (956 B at 1.7 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-swing/15-SNAPSHOT/maven-metadata.xml
955/955 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-swing/15-SNAPSHOT/maven-metadata.xml (955 B at 8.5 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-process-feature/15-SNAPSHOT/maven-metadata.xml
965/965 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-process-feature/15-SNAPSHOT/maven-metadata.xml (965 B at 1.7 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-grid/15-SNAPSHOT/maven-metadata.xml
954/954 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-grid/15-SNAPSHOT/maven-metadata.xml (954 B at 1.7 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-process-geometry/15-SNAPSHOT/maven-metadata.xml
966/966 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-process-geometry/15-SNAPSHOT/maven-metadata.xml (966 B at 1.5 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-process-raster/15-SNAPSHOT/maven-metadata.xml
964/964 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-process-raster/15-SNAPSHOT/maven-metadata.xml (964 B at 1.8 KB/sec)
[INFO]
[INFO] — maven-clean-plugin:2.4.1:clean (default-clean) @ docs —
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geotools-master-online/ws/docs/target>
[INFO]
[INFO] — git-commit-id-plugin:2.1.2:revision (default) @ docs —
[INFO]
[INFO] — maven-resources-plugin:2.6:resources (default-resources) @ docs —
[INFO] Copying 12 resources
[INFO]
[INFO] — maven-compiler-plugin:3.1:compile (default-compile) @ docs —
[INFO] Compiling 94 source files to <http://ares.boundlessgeo.com/jenkins/job/geotools-master-online/ws/docs/target/classes>
[INFO] 1 error
[INFO] Reactor Summary:
[INFO]
[INFO] JDBC DataStore Support … SUCCESS [16.657s]
[INFO] ArcSDE DataStore plugin … FAILURE [5.016s]
[INFO] JDBC DataStore Plugins … SUCCESS [0.137s]
[INFO] H2 DataStore … SUCCESS [39.634s]
[INFO] Oracle DataStore … SUCCESS [8.354s]
[INFO] PostGIS DataStore … SUCCESS [9:48.354s]
[INFO] imagemosaic datasource module … FAILURE [3.326s]
[INFO] imagepyramid datasource module … SKIPPED
[INFO] imagemosaic-jdbc module … FAILURE [0.997s]
[INFO] DB2 DataStore … SUCCESS [4.633s]
[INFO] MySQL DataStore … SUCCESS [1:55.874s]
[INFO] SQL Server DataStore … SUCCESS [4.643s]
[INFO] SpatiaLite DataStore … SUCCESS [4.007s]
[INFO] Teradata DataStore … SUCCESS [4.572s]
[INFO] API interfaces … SKIPPED
[INFO] NetCDF gridcoverage module … SKIPPED
[INFO] GRIB gridcoverage module … SKIPPED
[INFO] Application Schema DataAccess … FAILURE [10.231s]
[INFO] Validation Processor and Framework … SUCCESS [7.845s]
[INFO] GeoPackage Module … FAILURE [1.075s]
[INFO] MBTiles Module … FAILURE [0.714s]
[INFO] Coverage tools … SKIPPED
[INFO] Web Processing Service … FAILURE [2.791s]
[INFO] Next Generation JDBC DataStores … SUCCESS [0.363s]
[INFO] GeoTools Documentation … FAILURE [7.785s]
[INFO] BUILD FAILURE
[INFO] Total time: 13:53.956s
[INFO] Finished at: Wed Feb 17 14:35:09 UTC 2016
[INFO] Final Memory: 46M/321M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.1:compile (default-compile) on project gt-arcsde: Compilation failure
[ERROR] → [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.1:compile (default-compile) on project gt-imagemosaic: Compilation failure
[ERROR] → [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.1:compile (default-compile) on project gt-imagemosaic-jdbc: Compilation failure
[ERROR] → [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.1:compile (default-compile) on project gt-app-schema: Compilation failure
[ERROR] → [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.1:compile (default-compile) on project gt-geopkg: Compilation failure
[ERROR] → [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.1:compile (default-compile) on project gt-mbtiles: Compilation failure
[ERROR] → [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.1:compile (default-compile) on project gt-wps: Compilation failure
[ERROR] → [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.1:compile (default-compile) on project docs: Compilation failure
[ERROR] → [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn -rf :gt-arcsde
Build step ‘Invoke top-level Maven targets’ marked build as failure
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=272487151&iu=/4140
GeoTools-Devel mailing list
GeoTools-Devel@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-devel
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
Daniele,
I kicked the geotools-master build to recreate these artifacts and it appears to have fixed one failing ares build affected by the artifact corruption.
Everyone should keep an eye on pull requests to see if Travis CI builds also recover.
Kind regards,
Ben.
On 18/02/16 06:13, Daniele Romagnoli wrote:
I'm updating a reply to a Jenkins message, related to an email I have sent
this morning.
failure.
Mmm... It seems there is a corrupted artifact on
were green:
Any suggestion?
Daniele
See <
Changes:
Coordinates
[...truncated 2738 lines...]
[INFO]
[INFO] --- git-commit-id-plugin:2.1.2:revision (default) @ gt-validation
[INFO]
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gt-validation
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @
gt-validation ---
[INFO] Installing <
http://ares.boundlessgeo.com/jenkins/job/geotools-master-online/ws/modules/extension/validation/target/gt-validation-15-SNAPSHOT.jar&gt;
to
[INFO] Installing <
http://ares.boundlessgeo.com/jenkins/job/geotools-master-online/ws/modules/extension/validation/pom.xml&gt;
to
[INFO] Installing <
http://ares.boundlessgeo.com/jenkins/job/geotools-master-online/ws/modules/extension/validation/target/gt-validation-15-SNAPSHOT-sources.jar&gt;
to
[INFO]
[INFO]
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gt-geopkg ---
[INFO] Deleting <
[INFO]
[INFO] --- git-commit-id-plugin:2.1.2:revision (default) @ gt-geopkg ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @
gt-geopkg ---
[INFO]
[INFO] --- maven-compiler-plugin:3.1:compile (default-compile) @
gt-geopkg ---
[INFO] 1 error
[INFO]
[INFO]
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gt-mbtiles ---
[INFO] Deleting <
[INFO]
[INFO] --- git-commit-id-plugin:2.1.2:revision (default) @ gt-mbtiles ---
[INFO]
gt-mbtiles ---
[INFO]
gt-mbtiles ---
[INFO] 1 error
[INFO]
failures.
[INFO]
[INFO]
[INFO]
Downloading:
966/966 B
Downloaded:
Downloading:
961/961 B
Downloaded:
Downloading:
957/957 B
Downloaded:
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gt-wps ---
[INFO] Deleting <
[INFO]
[INFO] --- git-commit-id-plugin:2.1.2:revision (default) @ gt-wps ---
[INFO]
gt-wps ---
[INFO]
[INFO] --- maven-compiler-plugin:3.1:compile (default-compile) @ gt-wps
[INFO] 1 error
[INFO]
[INFO]
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gt-jdbc-ng ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.2:revision (default) @ gt-jdbc-ng ---
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gt-jdbc-ng ---
[INFO]
gt-jdbc-ng ---
[INFO] Installing <
http://ares.boundlessgeo.com/jenkins/job/geotools-master-online/ws/modules/unsupported/jdbc-ng/pom.xml&gt;
to
[INFO]
[INFO]
Downloading:
953/953 B
Downloaded:
Downloading:
953/953 B
Downloaded:
Downloading:
961/961 B
Downloaded:
Downloading:
961/961 B
Downloaded:
Downloading:
956/956 B
Downloaded:
Downloading:
955/955 B
Downloaded:
Downloading:
965/965 B
Downloaded:
Downloading:
954/954 B
Downloaded:
Downloading:
966/966 B
Downloaded:
Downloading:
964/964 B
Downloaded:
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ docs ---
[INFO] Deleting <
[INFO]
[INFO] --- git-commit-id-plugin:2.1.2:revision (default) @ docs ---
[INFO]
docs ---
[INFO]
[INFO] --- maven-compiler-plugin:3.1:compile (default-compile) @ docs ---
[INFO] 1 error
[INFO]
[INFO]
[INFO] JDBC DataStore Support ............................ SUCCESS
[16.657s]
[INFO] ArcSDE DataStore plugin ........................... FAILURE
[5.016s]
[INFO] JDBC DataStore Plugins ............................ SUCCESS
[0.137s]
[INFO] H2 DataStore ...................................... SUCCESS
[39.634s]
[INFO] Oracle DataStore .................................. SUCCESS
[8.354s]
[INFO] PostGIS DataStore ................................. SUCCESS
[9:48.354s]
[INFO] imagemosaic datasource module ..................... FAILURE
[3.326s]
[INFO] imagepyramid datasource module .................... SKIPPED
[INFO] imagemosaic-jdbc module ........................... FAILURE
[0.997s]
[INFO] DB2 DataStore ..................................... SUCCESS
[4.633s]
[INFO] MySQL DataStore ................................... SUCCESS
[1:55.874s]
[INFO] SQL Server DataStore .............................. SUCCESS
[4.643s]
[INFO] SpatiaLite DataStore .............................. SUCCESS
[4.007s]
[INFO] Teradata DataStore ................................ SUCCESS
[4.572s]
[INFO] API interfaces .................................... SKIPPED
[INFO] NetCDF gridcoverage module ........................ SKIPPED
[INFO] GRIB gridcoverage module .......................... SKIPPED
[INFO] Application Schema DataAccess ..................... FAILURE
[10.231s]
[INFO] Validation Processor and Framework ................ SUCCESS
[7.845s]
[INFO] GeoPackage Module ................................. FAILURE
[1.075s]
[INFO] MBTiles Module .................................... FAILURE
[0.714s]
[INFO] Coverage tools .................................... SKIPPED
[INFO] Web Processing Service ............................ FAILURE
[2.791s]
[INFO] Next Generation JDBC DataStores ................... SUCCESS
[0.363s]
[INFO] GeoTools Documentation ............................ FAILURE
[7.785s]
[INFO]
[INFO]
[INFO]
[ERROR] -> [Help 1]
[ERROR] -> [Help 1]
[ERROR] -> [Help 1]
[ERROR] -> [Help 1]
[ERROR] -> [Help 1]
[ERROR] -> [Help 1]
[ERROR] -> [Help 1]
[ERROR] -> [Help 1]
[ERROR]
-e switch.
[ERROR]
[ERROR] [Help 1]
[ERROR]
command
[ERROR] mvn <goals> -rf :gt-arcsde
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
