[Geoserver-devel] Build failing in GeoServer because of missing DefaultProcessor
the DefaultProcessor class has been recently removed from GeoTools,
this is causing the GeoServer nightly build to fail with a compile problem:
[INFO] Compiling 3 source files to /var/lib/hudson/jobs/geoserver-master/workspace/src/community/dds/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
/var/lib/hudson/jobs/geoserver-master/workspace/src/community/dds/src/main/java/org/geoserver/wms/worldwind/util/BilWCSUtils.java:[13,39] cannot find symbol
symbol  : class DefaultProcessor
/var/lib/hudson/jobs/geoserver-master/workspace/src/community/dds/src/main/java/org/geoserver/wms/worldwind/util/BilWCSUtils.java:[56,14] cannot find symbol
location: class org.geoserver.wms.worldwind.util.BilWCSUtils
/var/lib/hudson/jobs/geoserver-master/workspace/src/community/dds/src/main/java/org/geoserver/wms/worldwind/util/BilWCSUtils.java:[56,47] cannot find symbol
Full logs here:
http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1327/console
Granted, the class was deprecated, and the module is a community one back in GeoServer, but still…
is there an easy fix?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
