Hi devs,
I checked out the sources from the trunk and tried to build and got the following error.Could you please help me to resolve it?
I am using maven 3.0.2
[INFO] BUILD FAILURE
[INFO] Total time: 9.154s
[INFO] Finished at: Wed Jan 26 13:10:34 IST 2011
[INFO] Final Memory: 29M/393M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-plugin-plugin:2.6:descriptor (default-descriptor) on project config: The API of the mojo scanner is not compatible with this plugin version. Please check the plugin dependencies configured in the POM and ensure the versions match. org.apache.maven.tools.plugin.scanner.MojoScanner.populatePluginDescriptor(Lorg/apache/maven/tools/plugin/PluginToolsRequest;)V → [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-plugin-plugin:2.6:descriptor (default-descriptor) on project config: The API of the mojo scanner is not compatible with this plugin version. Please check the plugin dependencies configured in the POM and ensure the versions match.
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:217)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:84)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:59)
at org.apache.maven.lifecycle.internal.LifecycleStarter.singleThreadedBuild(LifecycleStarter.java:183)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:161)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:319)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:534)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:196)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:141)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:290)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:230)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:409)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:352)
Caused by: org.apache.maven.plugin.MojoExecutionException: The API of the mojo scanner is not compatible with this plugin version. Please check the plugin dependencies configured in the POM and ensure the versions match.
at org.apache.maven.plugin.plugin.AbstractGeneratorMojo.execute(AbstractGeneratorMojo.java:193)
at org.apache.maven.plugin.plugin.DescriptorGeneratorMojo.execute(DescriptorGeneratorMojo.java:79)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:107)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:209)
… 19 more
Caused by: java.lang.NoSuchMethodError: org.apache.maven.tools.plugin.scanner.MojoScanner.populatePluginDescriptor(Lorg/apache/maven/tools/plugin/PluginToolsRequest;)V
at org.apache.maven.plugin.plugin.AbstractGeneratorMojo.execute(AbstractGeneratorMojo.java:171)
… 22 more
Shelan Perera
Blog : http://www.shelanlk.com
Twitter: shelan
skype :shelan.perera
gtalk :shelanrc
I am the master of my fate:
I am the captain of my soul.
invictus
Hi Shelan,
We have not yet switched to maven 3 for building geoserver yet, we still use maven 2. This issue looks perhaps like an incompatibility with one of the custom plugins our build system uses.
I would try installing the latest maven 2 and try again.
-Justin
On Wed, Jan 26, 2011 at 12:43 AM, shelan Perera <shelanrc@anonymised.com> wrote:
Hi devs,
… 19 more
… 22 more
Shelan Perera
Twitter: shelan
gtalk :shelanrc
invictus
Special Offer-- Download ArcSight Logger for FREE (a $49 USD value)!
Finally, a world-class log management solution at an even better price-free!
Download using promo code Free_Logger_4_Dev2Dev. Offer expires
February 28th, so secure your free ArcSight Logger TODAY!
http://p.sf.net/sfu/arcsight-sfd2d
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Hi Justin,
Thanks. I was able to build it successfully using maven 2.x.
On Wed, Jan 26, 2011 at 7:57 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hi Shelan,
-Justin
Hi devs,
… 19 more
… 22 more
Shelan Perera
Twitter: shelan
gtalk :shelanrc
invictus
Justin Deoliveira
Shelan Perera
Twitter: shelan
gtalk :shelanrc
invictus
