[Geoserver-devel] build failure on clean trunk checkout
Setting up a clean checkout[1] to review process work.
Failure looks straight forward:
[ERROR] BUILD ERROR
[INFO] Failed to execute: Executing Ant script: /config.build.xml [config]: Failed to execute.
Unable to locate configuration: /Users/jody/java/geoserver/trunk/src/web/app/minimal
The indicated directory does not exist; I assume this refers to a “default” for the geoserver data directory that I have not set.
Jody Garnett
[1] http://docs.geoserver.org/latest/en/developer/quickstart/index.html
THis is because (i assume) you are building from a fresh git clone. Which means you don’t get any svn:externals resolved, like the one to minimal in src/web/app. I usually just create these links manually.
On Wed, May 4, 2011 at 5:50 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
[ERROR] BUILD ERROR
Jody Garnett
WhatsUp Gold - Download Free Network Management Software
The most intuitive, comprehensive, and cost-effective network
management toolset available today. Delivers lowest initial
acquisition cost and overall TCO of any competing solution.
http://p.sf.net/sfu/whatsupgold-sd
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Apparently a lack of svn externals when using git to checkout.
Jody Garnett
[ERROR] BUILD ERROR
Jody Garnett
Under Linux I use a script to make symlinks. This is much better than svn, because update is faster (one update not five).
If you are using Linux, your convenience, here is my script (which I run from the base working directory [carefully unwrap any lines!]):
$ cat bin/fix-geoserver-links
#!/bin/sh
ln -sfn ../../../data/minimal src/web/app/minimal
ln -sfn ../../../../../../../../../../src/web/core/src/main/java/org/geoserver/web/css src/web/app/src/test/java/org/geoserver/wicket/test/css
ln -sfn ../../../../../../../../../../src/web/core/src/main/java/org/geoserver/web/img src/web/app/src/test/java/org/geoserver/wicket/test/img
ln -sfn ../../data/citewfs-1.1/styles data/citewfs-1.1-h2/styles
Does Win7 support some sort of symlink?
Jody Garnett
[ERROR] BUILD ERROR
The indicated directory does not exist; I assume this refers to a "default" for the geoserver data directory that I have not set.
Jody Garnett
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineering Team Leader
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
I was on mac; the single sys link for web/app minimal was enough to get me going.
Jody Garnett
#!/bin/sh
ln -sfn …/…/…/data/minimal src/web/app/minimal
ln -sfn
…/…/…/…/…/…/…/…/…/…/src/web/core/src/main/java/org/geoserver/web/css
ln -sfn
…/…/…/…/…/…/…/…/…/…/src/web/core/src/main/java/org/geoserver/web/img
ln -sfn …/…/data/citewfs-1.1/styles data/citewfs-1.1-h2/styles
Jody Garnett
[ERROR] BUILD ERROR
Jody Garnett
