I’m seeing this failure on a clean master checkout, building with Oracle JDK 8:
[INFO] Security UI Core Module … FAILURE [03:00 min]
Tests in error:
testRemoveWithRoles(org.geoserver.security.web.user.UserListPageTest): org.geoserver.security.web.user.SelectionUserRemovalLink$1.access$0(Lorg/geoserver/security/web/user/SelectionUserRemovalLink$1;)Lorg/geoserver/security/web/user/SelectionUserRemovalLink;
testRemove(org.geoserver.security.web.user.UserListPageTest): org.geoserver.security.web.user.SelectionUserRemovalLink$1.access$0(Lorg/geoserver/security/web/user/SelectionUserRemovalLink$1;)Lorg/geoserver/security/web/user/SelectionUserRemovalLink;
However if I run it from Eclipse using Java 8 there are no problems… at first
I thought it was due to a different execution order, but we have pegged down
the execution order in the main pom.xml :
maven-surefire-plugin
2.12.3
alphabetical
So hum… not sure… anyone else seeing it?
Geosolutions’ Winter Holidays from 24/12 to 6/1
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
