[Geoserver-devel] Build failure on master in Maven but not Eclipse?
I’m currently getting a build failure with mvn but not eclipse on a fresh checkout of master in RestConfig:
Tests in error:
testGetStatusAsHTML(org.geoserver.rest.catalog.AboutControllerTest): An invalid XML character (Unicode: 0x1b) was found in the element content of the document.
Obviously I can’t actually find that character in the file - has anyone seen anything similar?
Ian
Ian Turton
Ciao Ian,
never seen it, but stackoverflow offers the following:
https://stackoverflow.com/questions/13877013/org-xml-sax-saxparseexception-an-invalid-xml-character-unicode-0x1b-was-foun
Hmm… encoding issue somewhere?
Tests in error:
Ian
Ian Turton
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Ian,
a full build is passing for master on Boundless Jenkins, Travis CI, and for me locally on debian unstable amd64 with OpenJDK 8.
As Andrea wrote, most likely a platform encoding issue. What is your platform and encoding? What is the output of "mvn -version"? You could also try a full "mvn clean install" build.
Do you have a stack trace with line numbers? Does it fail for the first or second test request?
Kind regards,
Ben.
On 24/05/17 03:02, Ian Turton wrote:
I'm currently getting a build failure with mvn but not eclipse on a fresh
Tests in error:
the document.
Obviously I can't actually find that character in the file - has anyone
Ian
Check out the vibrant tech community on one of the world's most
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
mvn -version:
Apache Maven 3.3.9 (bb52d8502b132ec0a5a3f4c09453c07478323dc5; 2015-11-10T16:41:47+00:00)
Maven home: /usr/share/maven-3.3.9
Java version: 1.8.0_66, vendor: Oracle Corporation
Java home: /usr/lib/jvm/jdk1.8.0_66/jre
Default locale: en_GB, platform encoding: UTF-8
OS name: “linux”, version: “3.19.0-32-generic”, arch: “amd64”, family: “unix”
The error is on the first call in that method (Document dom = getAsDOM(BASEPATH + “/about/status”):wink: and the full stack trace is:
org.xml.sax.SAXParseException; lineNumber: 44; columnNumber: 306; An invalid XML character (Unicode: 0x1b) was found in the element content of the document.
at com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(DOMParser.java:257)
at com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl.parse(DocumentBuilderImpl.java:339)
at org.geoserver.test.GeoServerSystemTestSupport.dom(GeoServerSystemTestSupport.java:1498)
at org.geoserver.test.GeoServerSystemTestSupport.dom(GeoServerSystemTestSupport.java:1477)
at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1376)
at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1232)
at org.geoserver.rest.catalog.AboutControllerTest.testGetStatusAsHTML(AboutControllerTest.java:100)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.apache.maven.surefire.junit4.JUnit4Provider.execute(JUnit4Provider.java:242)
at org.apache.maven.surefire.junit4.JUnit4Provider.executeTestSet(JUnit4Provider.java:137)
On 23 May 2017 at 22:33, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Ian,
As Andrea wrote, most likely a platform encoding issue. What is your platform and encoding? What is the output of “mvn -version”? You could also try a full “mvn clean install” build.
Kind regards,
Ben.
Tests in error:
the document.
Ian
Geoserver-devel@anonymised.comrge.net
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Ian Turton
Hi Ian,
does it make sense to change the test so that it dumps the raw xml (as a string) to the output
before trying to parse it? Would likely help to see what might be wrong with it.
On Wed, May 24, 2017 at 9:42 AM, Ian Turton <ijturton@anonymised.com> wrote:
mvn -version:
Ian,
Kind regards,
Ben.
Tests in error:
the document.
Ian
Director
New Zealand
Ian Turton
Ing. Andrea Aime
@geowolf
Technical Lead
OK I’ve managed to dig to the bottom of this one - https://github.com/geoserver/geoserver/pull/2357
Longer answer - for some reason I have some environment variables like BACKGROUND_CYAN= [46m (with an Escape char at the start) in my user env. If you pass these unescaped to the Dom parser it chokes, but of course my eclipse env and travis and jenkins etc don’t have that issue.
Ian
On 24 May 2017 at 08:51, Andrea Aime <andrea.aime@anonymised.com…> wrote:
Hi Ian,
mvn -version:
Ing. Andrea Aime
@geowolf
Technical Lead
On 23 May 2017 at 22:33, Ben Caradoc-Davies <ben@…4191…> wrote:
Ian,
Kind regards,
Ben.
Tests in error:
the document.
Ian
Director
New Zealand
Ian Turton
Ian Turton
Ian,
good catch. That might have easily have affected a user. Just when we thought we had sanitised all our inputs ...
Kind regards,
Ben.
On 24/05/17 23:00, Ian Turton wrote:
OK I've managed to dig to the bottom of this one -
my eclipse env and travis and jenkins etc don't have that issue.
Ian
On 24 May 2017 at 08:51, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Ian,
with it.
mvn -version:
OS name: "linux", version: "3.19.0-32-generic", arch: "amd64", family:
"unix"
getAsDOM(BASEPATH + "/about/status"):wink: and the full stack trace is:
the document.
DOMParser.java:257)
ssorImpl.java:62)
RunBefores.java:26)
Afters.java:27)
RunBefores.java:26)
Afters.java:27)
4Provider.java:112)
ssorImpl.java:62)
ter.java:75)
Ian,
Kind regards,
Ben.
fresh
Tests in error:
An
of
the document.
Ian
Director
New Zealand
Ian Turton
Ing. Andrea Aime
@geowolf
Technical Lead
phone: +39 0584 962313 <+39%200584%20962313>
fax: +39 0584 1660272 <+39%200584%20166%200272>
mob: +39 339 8844549 <+39%20339%20884%204549>
Director
New Zealand
