I’ve checked the windows build server failure and tracked it down to a commit by Jody/Torben:
“Patch to allow an ExternalGraphic to be used instead of the GetLegendGraphic service in the WMS GetCapabilities LegendURL”
The test that’s failing was indeed added in that commit, the logs read as follow:
04 nov 12:46:14 ERROR [wicket.RequestCycle] - Exception ‘java.util.regex.PatternSyntaxException: Unexpected internal error near index 1
^’ occurred during validation org.geoserver.wms.web.data.ExternalGraphicPanel$1 on component 0:form:legendPanel:container:list:onlineResource
org.apache.wicket.WicketRuntimeException: Exception ‘java.util.regex.PatternSyntaxException: Unexpected internal error near index 1
at org.apache.wicket.markup.html.form.FormComponent.validateValidators(FormComponent.java:1622)
at org.apache.wicket.markup.html.form.FormComponent.validate(FormComponent.java:1201)
at org.apache.wicket.markup.html.form.Form$23.validate(Form.java:2161)
at org.apache.wicket.markup.html.form.Form$ValidationVisitor.formComponent(Form.java:173)
at org.apache.wicket.markup.html.form.FormComponent.visitFormComponentsPostOrderHelper(FormComponent.java:441)
at org.apache.wicket.markup.html.form.FormComponent.visitFormComponentsPostOrderHelper(FormComponent.java:428)
at org.apache.wicket.markup.html.form.FormComponent.visitFormComponentsPostOrder(FormComponent.java:400)
at org.apache.wicket.markup.html.form.Form.visitFormComponentsPostOrder(Form.java:1233)
at org.apache.wicket.markup.html.form.Form.validateComponents(Form.java:2153)
at org.apache.wicket.markup.html.form.Form.validate(Form.java:2133)
at org.apache.wicket.markup.html.form.Form.process(Form.java:1005)
at org.apache.wicket.markup.html.form.Form.process(Form.java:955)
at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:920)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:182)
at org.apache.wicket.request.target.component.listener.ListenerInterfaceRequestTarget.processEvents(ListenerInterfaceRequestTarget.java:73)
at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92)
at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
at org.apache.wicket.protocol.http.MockWebApplication.processRequestCycle(MockWebApplication.java:527)
at org.apache.wicket.util.tester.FormTester.submit(FormTester.java:695)
at org.geoserver.wms.web.data.StyleNewPageTest.testLegend(StyleNewPageTest.java:106)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:86)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:459)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:675)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:382)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:192)
Caused by: java.util.regex.PatternSyntaxException: Unexpected internal error near index 1
at java.util.regex.Pattern.error(Unknown Source)
at java.util.regex.Pattern.compile(Unknown Source)
at java.util.regex.Pattern.(Unknown Source)
at java.lang.String.split(Unknown Source)
at org.geoserver.wms.web.data.ExternalGraphicPanel$1.onValidate(ExternalGraphicPanel.java:141)
at org.apache.wicket.validation.validator.AbstractValidator.validate(AbstractValidator.java:81)
at org.apache.wicket.markup.html.form.FormComponent.validateValidators(FormComponent.java:1612)
… 57 more
Could you have a look? I remind you the windows build server is an official one just like ares, so developers
are expected to have a look at its failures and check if their commits might be causing them.
Commits breaking the build on the official build servers are candidates for revert (but I’d rather avoid that).
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
